path: root/net/hsr
2016-10-18net/hsr: Remove unused but set variableTobias Klauser
Remove the unused but set variable master_dev in check_local_dest to fix the following GCC warning when building with 'W=1': net/hsr/hsr_forward.c: In function ‘check_local_dest’: net/hsr/hsr_forward.c:303:21: warning: variable ‘master_dev’ set but not used [-Wunused-but-set-variable] Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-16net/hsr: Use setup_timer and mod_timer.Muhammad Falak R Wani
The function setup_timer combines the initialization of a timer with the initialization of the timer's function and data fields. The mulitiline code for timer initialization is now replaced with function setup_timer. Also, quoting the mod_timer() function comment: -> mod_timer() is a more efficient way to update the expire field of an active timer (if the timer is inactive it will be activated). Use setup_timer() and mod_timer() to setup and arm a timer, making the code compact and aid readablity. Signed-off-by: Muhammad Falak R Wani <falakreyaz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-21NLA_BINARY misuse bug in HSRPeter Heise
Removed .type field from NLA to do proper length checking. Reported by Daniel Borkmann and Julia Lawall. Signed-off-by: Peter Heise <peter.heise@airbus.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-15net/hsr: Added support for HSR v1Peter Heise
This patch adds support for the newer version 1 of the HSR networking standard. Version 0 is still default and the new version has to be selected via iproute2. Main changes are in the supervision frame handling and its ethertype field. Signed-off-by: Peter Heise <peter.heise@airbus.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-23net/hsr: fix a warning messageDan Carpenter
WARN_ON_ONCE() takes a condition, it doesn't take an error message. I have converted this to WARN() instead. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-18net: hsr: convert to using IFF_NO_QUEUEPhil Sutter
Signed-off-by: Phil Sutter <phil@nwl.cc> Cc: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01net/hsr: Fix NULL pointer dereference and refcnt bugs when deleting a HSR ↵Arvid Brodin
interface. To repeat: $ sudo ip link del hsr0 BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff8187f495>] hsr_del_port+0x15/0xa0 etc... Bug description: As part of the hsr master device destruction, hsr_del_port() is called for each of the hsr ports. At each such call, the master device is updated regarding features and mtu. When the master device is freed before the slave interfaces, master will be NULL in hsr_del_port(), which led to a NULL pointer dereference. Additionally, dev_put() was called on the master device itself in hsr_del_port(), causing a refcnt error. A third bug in the same code path was that the rtnl lock was not taken before hsr_del_port() was called as part of hsr_dev_destroy(). The reporter (Nicolas Dichtel) also said: "hsr_netdev_notify() supposes that the port will always be available when the notification is for an hsr interface. It's wrong. For example, netdev_wait_allrefs() may resend NETDEV_UNREGISTER.". As a precaution against this, a check for port == NULL was added in hsr_dev_notify(). Reported-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Fixes: 51f3c605318b056a ("net/hsr: Move slave init to hsr_slave.c.") Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-11net/hsr: Remove left-over never-true conditional code.Arvid Brodin
MacAddressB is an array (unsigned char MacAddressB[ETH_ALEN]) and is allocated as a part of *node_dst (which is a struct hsr_node). So the condition is always false. Detected by Dan Carpenter. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Fix NULL pointer dereference on incomplete hsr_newlink() params.Arvid Brodin
If none of the slave interfaces are specified, struct nlattr *data[] may be NULL. Make sure to check for that. While I'm at it, fix the horrible error messages displayed when only one of the slave interfaces isn't specified. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Better frame dispatchArvid Brodin
This patch removes the separate paths for frames coming from the outside, and frames sent from the HSR device, and instead makes all frames go through hsr_forward_skb() in hsr_forward.c. This greatly improves code readability and also opens up the possibility for future support of the HSR Interlink device that is the basis for HSR RedBoxes and HSR QuadBoxes, as well as VLAN compatibility. Other improvements: * A reduction in the number of times an skb is copied on machines without HAVE_EFFICIENT_UNALIGNED_ACCESS, which improves throughput somewhat. * Headers are now created using the standard eth_header(), and using the standard hard_header_len. * Each HSR slave now gets its own private skb, so slave-specific fields can be correctly set. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Added SET_NETDEV_DEVTYPE and features |= NETIF_F_NETNS_LOCAL to ↵Arvid Brodin
dev_setup. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Implemented .ndo_fix_features (better device features handling).Arvid Brodin
2014-07-08net/hsr: Use list_head (and rcu) instead of array for slave devices.Arvid Brodin
2014-07-08net/hsr: Move slave init to hsr_slave.c.Arvid Brodin
Also try to prevent some possible slave dereference race conditions. This is finalized in the next patch, which abandons the slave array in favour of a list_head list and list RCU. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Operstate handling cleanup.Arvid Brodin
2014-07-08net/hsr: Move to per-hsr device prune timer.Arvid Brodin
2014-07-08net/hsr: Switch from dev_add_pack() to netdev_rx_handler_register()Arvid Brodin
Also move the frame receive handler to hsr_slave.c. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Better variable names and update of contact info.Arvid Brodin
2014-03-27hsr: replace del_timer by del_timer_syncJulia Lawall
Use del_timer_sync to ensure that the timer is stopped on all CPUs before the driver exists. This change was suggested by Thomas Gleixner. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ declarer name module_exit; identifier ex; @@ module_exit(ex); @@ identifier r.ex; @@ ex(...) { <... - del_timer + del_timer_sync (...) ...> } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c net/ipv6/sit.c The SIT driver conflict consists of a bug fix being done by hand in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper was created (netdev_alloc_pcpu_stats()) which takes care of this. The two wireless conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-03hsr: off by one sanity check in hsr_register_frame_in()Dan Carpenter
This is a sanity check and we never pass invalid values so this patch doesn't change anything. However the node->time_in[] array has HSR_MAX_SLAVE (2) elements and not HSR_MAX_DEV (3). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-18hsr: Use ether_addr_copyJoe Perches
It's slightly smaller/faster for some architectures. Make sure def_multicast_addr is __aligned(2) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17net/hsr: using kfree_rcu() to simplify the codeWei Yongjun
The callback function of call_rcu() just calls a kfree(), so we can use kfree_rcu() instead of call_rcu() + callback function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-30net/hsr: Support iproute print_opt ('ip -details ...')Arvid Brodin
This implements the rtnl_link_ops fill_info routine for HSR. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-30net/hsr: Very small fix of comment style.Arvid Brodin
2013-11-19genetlink: make multicast groups const, prevent abuseJohannes Berg
Register generic netlink multicast groups as an array with the family and give them contiguous group IDs. Then instead of passing the global group ID to the various functions that send messages, pass the ID relative to the family - for most families that's just 0 because the only have one group. This avoids the list_head and ID in each group, adding a new field for the mcast group ID offset to the family. At the same time, this allows us to prevent abusing groups again like the quota and dropmon code did, since we can now check that a family only uses a group it owns. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: pass family to functions using groupsJohannes Berg
This doesn't really change anything, but prepares for the next patch that will change the APIs to pass the group ID within the family, rather than the global group ID. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19hsr: don't call genl_unregister_mc_group()Johannes Berg
There's no need to unregister the multicast group if the generic netlink family is registered immediately after. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: only pass array to genl_register_family_with_ops()Johannes Berg
As suggested by David Miller, make genl_register_family_with_ops() a macro and pass only the array, evaluating ARRAY_SIZE() in the macro, this is a little safer. The openvswitch has some indirection, assing ops/n_ops directly in that code. This might ultimately just assign the pointers in the family initializations, saving the struct genl_family_and_ops and code (once mcast groups are handled differently.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14net/hsr: Fix possible leak in 'hsr_get_node_status()'Geyslan G. Bem
If 'hsr_get_node_data()' returns error, going directly to 'fail' label doesn't free the memory pointed by 'skb_out'. Signed-off-by: Geyslan G. Bem <geyslan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: make all genl_ops users constJohannes Berg
Now that genl_ops are no longer modified in place when registering, they can be made const. This patch was done mostly with spatch: @@ identifier ops; @@ +const struct genl_ops ops[] = { ... }; (except the struct thing in net/openvswitch/datapath.c) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14hsr: use genl_register_family_with_ops()Johannes Berg
This simplifies the code since there's no longer a need to have error handling in the registration. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-03net/hsr: Add support for the High-availability Seamless Redundancy protocol ↵Arvid Brodin
(HSRv0) High-availability Seamless Redundancy ("HSR") provides instant failover redundancy for Ethernet networks. It requires a special network topology where all nodes are connected in a ring (each node having two physical network interfaces). It is suited for applications that demand high availability and very short reaction time. HSR acts on the Ethernet layer, using a registered Ethernet protocol type to send special HSR frames in both directions over the ring. The driver creates virtual network interfaces that can be used just like any ordinary Linux network interface, for IP/TCP/UDP traffic etc. All nodes in the network ring must be HSR capable. This code is a "best effort" to comply with the HSR standard as described in IEC 62439-3:2010 (HSRv0). Signed-off-by: Arvid Brodin <arvid.brodin@xdin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
