path: root/net/ieee802154
2014-08-02inet: frags: use kmem_cache for inet_frag_queueNikolay Aleksandrov
Use kmem_cache to allocate/free inet_frag_queue objects since they're all the same size per inet_frags user and are alloced/freed in high volumes thus making it a perfect case for kmem_cache. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-02inet: frags: rename last_in to flagsNikolay Aleksandrov
The last_in field has been used to store various flags different from first/last frag in so give it a more descriptive name: flags. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-28Merge tag 'master-2014-07-25' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next John W. Linville says: ==================== pull request: wireless-next 2014-07-25 Please pull this batch of updates intended for the 3.17 stream! For the mac80211 bits, Johannes says: "We have a lot of TDLS patches, among them a fix that should make hwsim tests happy again. The rest, this time, is mostly small fixes." For the Bluetooth bits, Gustavo says: "Some more patches for 3.17. The most important change here is the move of the 6lowpan code to net/6lowpan. It has been agreed with Davem that this change will go through the bluetooth tree. The rest are mostly clean up and fixes." and, "Here follows some more patches for 3.17. These are mostly fixes to what we've sent to you before for next merge window." For the iwlwifi bits, Emmanuel says: "I have the usual amount of BT Coex stuff. Arik continues to work on TDLS and Ariej contributes a few things for HS2.0. I added a few more things to the firmware debugging infrastructure. Eran fixes a small bug - pretty normal content." And for the Atheros bits, Kalle says: "For ath6kl me and Jessica added support for ar6004 hw3.0, our latest version of ar6004. For ath10k Janusz added a printout so that it's easier to check what ath10k kconfig options are enabled. He also added a debugfs file to configure maximum amsdu and ampdu values. Also we had few fixes as usual." On top of that is the usual large batch of various driver updates -- brcmfmac, mwifiex, the TI drivers, and wil6210 all get some action. Rafał has also been very busy with b43 and related updates. Also, I pulled the wireless tree into this in order to resolve a merge conflict... P.S. The change to fs/compat_ioctl.c reflects a name change in a Bluetooth header file... ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: set limits and make init_net's high_thresh limit globalNikolay Aleksandrov
This patch makes init_net's high_thresh limit to be the maximum for all namespaces, thus introducing a global memory limit threshold equal to the sum of the individual high_thresh limits which are capped. It also introduces some sane minimums for low_thresh as it shouldn't be able to drop below 0 (or > high_thresh in the unsigned case), and overall low_thresh should not ever be above high_thresh, so we make the following relations for a namespace: init_net: high_thresh - max(not capped), min(init_net low_thresh) low_thresh - max(init_net high_thresh), min (0) all other namespaces: high_thresh = max(init_net high_thresh), min(namespace's low_thresh) low_thresh = max(namespace's high_thresh), min(0) The major issue with having low_thresh > high_thresh is that we'll schedule eviction but never evict anything and thus rely only on the timers. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: use seqlock for hash rebuildFlorian Westphal
rehash is rare operation, don't force readers to take the read-side rwlock. Instead, we only have to detect the (rare) case where the secret was altered while we are trying to insert a new inetfrag queue into the table. If it was changed, drop the bucket lock and recompute the hash to get the 'new' chain bucket that we have to insert into. Joint work with Nikolay Aleksandrov. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: remove periodic secret rebuild timerFlorian Westphal
merge functionality into the eviction workqueue. Instead of rebuilding every n seconds, take advantage of the upper hash chain length limit. If we hit it, mark table for rebuild and schedule workqueue. To prevent frequent rebuilds when we're completely overloaded, don't rebuild more than once every 5 seconds. ipfrag_secret_interval sysctl is now obsolete and has been marked as deprecated, it still can be changed so scripts won't be broken but it won't have any effect. A comment is left above each unused secret_timer variable to avoid confusion. Joint work with Nikolay Aleksandrov. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: remove lru listFlorian Westphal
no longer used. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: move evictor calls into frag_find functionFlorian Westphal
First step to move eviction handling into a work queue. We lose two spots that accounted evicted fragments in MIB counters. Accounting will be restored since the upcoming work-queue evictor invokes the frag queue timer callbacks instead. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: remove hash size assumptions from callersFlorian Westphal
hide actual hash size from individual users: The _find function will now fold the given hash value into the required range. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-27inet: frag: constify match, hashfn and constructor argumentsFlorian Westphal
2014-07-15ieee802154: remove unnecessary break after gotoFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-126lowpan: introduce new net/6lowpan directoryAlexander Aring
This patch moves generic code which is used by bluetooth and ieee802154 6lowpan to a new net/6lowpan directory. This directory contains generic 6LoWPAN code which is shared between bluetooth and ieee802154 MAC-Layer. This is the IPHC - "IPv6 Header Compression" format at the moment. Which is described by RFC 6282 [0]. The BLTE 6LoWPAN draft describes that the IPHC is the same format like IEEE 802.15.4, see [1]. Futuremore we can put more code into this directory which is shared between BLTE and IEEE 802.15.4 6LoWPAN like RFC 6775 or the routing protocol RPL RFC 6550. To avoid naming conflicts I renamed 6lowpan-y to ieee802154_6lowpan-y in net/ieee802154/Makefile. [0] http://tools.ietf.org/html/rfc6282 [1] http://tools.ietf.org/html/draft-ietf-6lowpan-btle-12#section-3.2 [2] http://tools.ietf.org/html/rfc6775 [3] http://tools.ietf.org/html/rfc6550 Signed-off-by: Alexander Aring <alex.aring@gmail.com> Acked-by: Jukka Rissanen <jukka.rissanen@linux.intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-07-076lowpan: mac802154: fix coding style issuesVarka Bhadram
This patch fixed the coding style issues reported by checkpatch.pl following issues fixed: CHECK: Alignment should match open parenthesis WARNING: line over 80 characters CHECK: Blank lines aren't necessary before a close brace '}' WARNING: networking block comments don't use an empty /* line, use /* Comment... WARNING: Missing a blank line after declarations WARNING: networking block comments start with * on subsequent lines CHECK: braces {} should be used on all arms of this statement Signed-off-by: Varka Bhadram <varkab@cdac.in> Tested-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-026lowpan_rtnl: fix off by one while fragmentationAlexander Aring
This patch fix a off by one error while fragmentation. If the frag_cap value is equal to skb_unprocessed value we need to stop the fragmentation loop because the last fragment which has a size of skb_unprocessed fits into the frag capability size. This issue was introduced by commit d4b2816d67d6e07b2f27037f282d8db03a5829d7 ("6lowpan: fix fragmentation"). Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-026lowpan_rtnl: fix fragmentation with two fragmentsAlexander Aring
This patch fix the 6LoWPAN fragmentation for the case if we have exactly two fragments. The problem is that the (skb_unprocessed >= frag_cap) condition is always false on the second fragment after sending the first fragment. A fragmentation with only one fragment doesn't make any sense. The solution is that we use a do while loop here, that ensures we sending always a minimum of two fragments if we need a fragmentation. This issue was introduced by commit d4b2816d67d6e07b2f27037f282d8db03a5829d7 ("6lowpan: fix fragmentation"). Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-22ieee802154: missing put_dev() on errorDan Carpenter
We should call put_dev() on the error path here. Fixes: 3e9c156e2c21 ('ieee802154: add netlink interfaces for llsec') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16ieee802154: add netlink interfaces for llsecPhoebe Buckheister
This patch adds user-visible interfaces for the llsec infrastructure. For the added methods, the only major difference between all add/remove implementation lies in how the specific object is parsed, and for dump requests, how objects are written into netlink messages. To save on boilerplate code, table dumps are routed through a helper function that handles netlink dump state, leaving the actual dumping code to care only about iterating over the table to be dumped and filling netlink messages. For add/remove methods, the boilerplate required to work is not quite as large, but still enough to also move into a local helper. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16ieee802154: add dgram sockopts for security controlPhoebe Buckheister
Allow datagram sockets to override the security settings of the device they send from on a per-socket basis. Requires CAP_NET_ADMIN or CAP_NET_RAW, since raw sockets can send arbitrary packets anyway. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15ieee802154: fix dgram socket sendmsg()Phoebe Buckheister
802.15.4 datagram sockets do not currently have a compliant sendmsg(). The destination address supplied is always ignored, and in unconnected mode, packets are broadcast instead of dropped with -EDESTADDRREQ. This patch fixes 802.15.4 dgram sockets to be compliant, i.e. !conn && !msg_name => -EDESTADDRREQ !conn && msg_name => send to msg_name conn && !msg_name => send to connected conn && msg_name => -EISCONN Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-156lowpan: fix fragmentationPhoebe Buckheister
Currently, 6lowpan creates one 802.15.4 MAC header for the original packet the device was given by upper layers and reuses this header for all fragments, if fragmentation is required. This also reuses frame sequence numbers, which must not happen. 6lowpan also has issues with fragmentation in the presence of security headers, since those may imply the presence of trailing fields that are not accounted for by the fragmentation code right now. Fix both of these issues by properly allocating fragment skbs with headromm and tailroom as specified by the underlying device, create one header for each skb instead of reusing the original header, let the underlying device do the rest. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15ieee802154: change _cb handling slightlyPhoebe Buckheister
The current mac_cb handling of ieee802154 is rather awkward and limited. Decompose the single flags field into multiple fields with the meanings of each subfield of the flags field to make future extensions (for example, link-layer security) easier. Also don't set the frame sequence number in upper layers, since that's a thing the MAC is supposed to set on frame transmit - we set it on header creation, but assuming that upper layers do not blindly duplicate our headers, this is fine. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15ieee802154: add definitions for link-layer security and header functionsPhoebe Buckheister
When dealing with 802.15.4, one often has to know the maximum payload size for a given packet. This depends on many factors, one of which is whether or not a security header is present in the frame. These definitions and functions provide an easy way for any upper layer to calculate the maximum payload size for a packet. The first obvious user for this is 6lowpan, which duplicates this calculation and gets it partially wrong because it ignores security headers. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-206lowpan: make lowpan_cb staticLuis R. Rodriguez
CC: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: linux-zigbee-devel@lists.sourceforge.net Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-206lowpan: add helper to get 6lowpan namespaceLuis R. Rodriguez
This will simplify the new reassembly backport with no code changes being required. CC: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: linux-zigbee-devel@lists.sourceforge.net Cc: David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-01mac802154: make csma/cca parameters per-wpanPhoebe Buckheister
Commit 9b2777d6089bcd (ieee802154: add TX power control to wpan_phy) and following erroneously added CSMA and CCA parameters for 802.15.4 devices as PHY parameters, while they are actually MAC parameters and can differ for any two WPAN instances. Since it is now sensible to have multiple WPAN devices with differing CSMA/CCA parameters, make these parameters MAC parameters instead. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20ieee802154: dgram: cleanup set of broadcast panidAlexander Aring
This patch is only a cleanup to use the right define for a panid field. The broadcast address and panid broadcast is still the same value. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Cc: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20af_ieee802154: fix check on broadcast addressAlexander Aring
This patch fixes an issue which was introduced by commit b70ab2e87f17176d18f67ef331064441a032b5f3 ("ieee802154: enforce consistent endianness in the 802.15.4 stack"). The correct behaviour should be a check on the broadcast address field which is 0xffff. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Reported-by: Jan Luebbe <jlu@pengutronix.de> Cc: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-18ieee802154: properly unshare skbs in ieee802154 *_rcv functionsPhoebe Buckheister
ieee802154 sockets do not properly unshare received skbs, which leads to panics (at least) when they are used in conjunction with 6lowpan, so run skb_share_check on received skbs. 6lowpan also contains a use-after-free, which is trivially fixed by replacing the inlined skb_share_check with the explicit call. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Tested-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: add proper length checks to header creationsPhoebe Buckheister
Have mac802154 header_ops.create fail with -EMSGSIZE if the length passed will be too large to fit a frame. Since 6lowpan will ensure that no packet payload will be too large, pass a length of 0 there. 802.15.4 dgram sockets will also return -EMSGSIZE on payloads larger than the device MTU instead of -EINVAL. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-146lowpan: move lowpan frag_info out of 802.15.4 headersPhoebe Buckheister
Fragmentation and reassembly information for 6lowpan is independent from the 802.15.4 stack and used only by the 6lowpan reassembly process. Move the ieee802154_frag_info struct to a private are, it needn't be in the 802.15.4 skb control block. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: use ieee802154_addr instead of *_sa variantsPhoebe Buckheister
Change all internal uses of ieee802154_addr_sa to ieee802154_addr, except for those instances that communicate directly with userspace. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14mac802154: use header operations to create/parse headersPhoebe Buckheister
Use the operations on 802.15.4 header structs introduced in a previous patch to create and parse all headers in the mac802154 stack. This patch reduces code duplication between different parts of the mac802154 stack that needed information from headers, and also fixes a few bugs that seem to have gone unnoticed until now: * 802.15.4 dgram sockets would return a slightly incorrect value for the SIOCINQ ioctl * mac802154 would not drop frames with the "security enabled" bit set, even though it does not support security, in violation of the standard Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: add header structs with endiannes and operationsPhoebe Buckheister
This patch provides a set of structures to represent 802.15.4 MAC headers, and a set of operations to push/pull/peek these structs from skbs. We cannot simply pointer-cast the skb MAC header pointer to these structs, because 802.15.4 headers are wildly variable - depending on the first three bytes, virtually all other fields of the header may be present or not, and be present with different lengths. The new header creation/parsing routines also support 802.15.4 security headers, which are currently not supported by the mac802154 implementation of the protocol. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: enforce consistent endianness in the 802.15.4 stackPhoebe Buckheister
Enable sparse warnings about endianness, replace the remaining fields regarding network operations without explicit endianness annotations with such that are annotated, and propagate this through the entire stack. Uses of ieee802154_addr_sa are not changed yet, this patch is only concerned with all other fields (such as address filters, operation parameters and the likes). Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ieee802154: rename struct ieee802154_addr to *_saPhoebe Buckheister
The struct as currently defined uses host byte order for some fields, and most big endian/EUI display byte order for other fields. Inside the stack, endianness should ideally match network byte order where possible to minimize the number of byteswaps done in critical paths, but this patch does not address this; it is only preparatory. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-136lowpan: reassembly: un-export local functionsFlorian Westphal
most of these are only used locally, make them static. fold lowpan_expire_frag_queue into its caller, its small enough. Cc: Alexander Aring <alex.aring@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-12ieee802154: Convert uses of __constant_<foo> to <foo>Joe Perches
The use of __constant_<foo> has been unnecessary for quite awhile now. Make these uses consistent with the rest of the kernel. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-106lowpan: reassembly: fix access of ctl table entryAlexander Aring
Correct offset is 3 of the 6lowpanfrag_max_datagram_size value in proc entry ctl table and not 2. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-076lowpan: reassembly: fix return of init functionAlexander Aring
This patch adds a missing return after fragmentation init. Otherwise we register a sysctl interface and deregister it afterwards which makes no sense. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-066lowpan: move 6lowpan header to include/netAlexander Aring
This header is used by bluetooth and ieee802154 branch. This patch move this header to the include/net directory to avoid a use of a relative path in include. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-066lowpan: add missing include of net/ipv6.hAlexander Aring
The 6lowpan.h file contains some static inline function which use internal ipv6 api structs. Add a include of ipv6.h to be sure that it's known before. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-04ieee802154: fix whitespace issues in KconfigAlexander Aring
This patch fixes some whitespace issues in Kconfig files of IEEE 802.15.4 subsytem. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-026lowpan: use memcpy to set tag value in fraghdrAlexander Aring
2014-03-026lowpan: remove initialization of tag valueAlexander Aring
The initialization of the tag value doesn't matter at begin of fragmentation. This patch removes the initialization to zero. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-026lowpan: fix type of datagram size parameterAlexander Aring
Datagram size value is u16 because we convert it to host byte order and we need to read it. Only the tag value belongs to __be16 type. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-286lowpan: handling 6lowpan fragmentation via inet_frag apiAlexander Aring
This patch drops the current way of 6lowpan fragmentation on receiving side and replace it with a implementation which use the inet_frag api. The old fragmentation handling has some race conditions and isn't rfc4944 compatible. Also adding support to match fragments on destination address, source address, tag value and datagram_size which is missing in the current implementation. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-286lowpan: fix some checkpatch issuesAlexander Aring
Detected with: ./scripts/checkpatch.pl --strict -f net/ieee802154/6lowpan_rtnl.c Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-286lowpan: move 6lowpan.c to 6lowpan_rtnl.cAlexander Aring
We have a 6lowpan.c file and 6lowpan.ko file. To avoid confusing we should move 6lowpan.c to 6lowpan_rtnl.c. Then we can support multiple source files for 6lowpan module. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-286lowpan: change tag type to __be16Alexander Aring
2014-02-286lowpan: fix fragmentation on sending sideAlexander Aring
This patch fix the fragmentation on sending side according to rfc4944. Also add improvement to use the full payload of a PDU which calculate the nearest divided to 8 payload length for the fragmentation datagram size attribute. The main issue is that the datagram size of fragmentation header use the ipv6 payload length, but rfc4944 says it's the ipv6 payload length inclusive network header size (and transport header size if compressed). Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
