path: root/net/ieee802154
2013-04-08ieee802154/nl-mac.c: make some MLME operations optionalWerner Almesberger
Check for NULL before calling the following operations from "struct ieee802154_mlme_ops": assoc_req, assoc_resp, disassoc_req, start_req, and scan_req. This fixes a current oops where those functions are called but not implemented. It also updates the documentation to clarify that they are now optional by design. If a call to an unimplemented function is attempted, the kernel returns EOPNOTSUPP via netlink. The following operations are still required: get_phy, get_pan_id, get_short_addr, and get_dsn. Note that the places where this patch changes the initialization of "ret" should not affect the rest of the code since "ret" was always set (again) before returning its value. Signed-off-by: Werner Almesberger <werner@almesberger.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-076lowpan: handle dev_queue_xmit() error code properlyAlan Ott
dev_queue_xmit() will return a positive value if the packet could not be queued, often because the real network device (in our case the mac802154 wpan device) has its queue stopped. lowpan_xmit() should handle the positive return code (for the debug statement) and return that value to the higher layer so the higher layer will retry sending the packet. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-29netlink: fix the warning introduced by netlink API replacementHong zhi guo
Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-28net-next: replace obsolete NLMSG_* with type safe nlmsg_*Hong zhi guo
2013-03-276lowpan: use IEEE802154_ADDR_LEN instead of a magic numberTony Cheneau
Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-276lowpan: fix a small formatting issueTony Cheneau
This formatting issue was introduced with commit d4ac32365dcbfd341a87eae444c26679f889249a Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-27ieee802154/dgram: Pass source address in dgram_recvmsgStephen Röttger
This patch lets dgram_recvmsg fill in the sockaddr struct in msg->msg_name with the source address of the packet. This is used by the userland functions recvmsg and recvfrom to get the senders address. [Stefan: Changed from old zigbee legacy tree to mainline] Signed-off-by: Stephen Röttger <stephen.roettger@zero-entropy.de> Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: modify udp compression/uncompression to match the standardTony Cheneau
The previous code would just compress the UDP header and send the compressed UDP header along with the uncompressed one. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: use the PANID provided by the device instead of a static valueTony Cheneau
2013-03-266lowpan: obtain IEEE802.15.4 sequence number from the MAC layerTony Cheneau
Sets the sequence number in the frame format. Without this fix, the sequence number is always set to 0. This makes trafic analysis very hard. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: store fragment tag values per device instead of net stack wideTony Cheneau
2013-03-266lowpan: add debug messages for 6LoWPAN fragmentationTony Cheneau
Add pr_debug() call in order to debug 6LoWPAN fragmentation and reassembly. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: fix first fragment (FRAG1) handlingTony Cheneau
The first fragment, FRAG1, must contain some payload according to the specs. However, as it is currently written, the first fragment will remain empty and only contain the 6lowpan headers. This patch also extracts the transport layer information from the first fragment. This information is used later on when uncompressing UDP header. Thanks to Wolf-Bastian Pöttner for noticing that the offset value was not properly initialized. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: use short IEEE 802.15.4 addresses for broadcast destinationTony Cheneau
The IEEE 802.15.4 standard uses the 0xFFFF short address (2 bytes) for message broadcasting. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: always enable link-layer acknowledgmentsTony Cheneau
This feature is especially important when using fragmentation, because the reassembly mechanism cannot recover from the loss of a fragment. Note that some hardware ignore this flag and not will not transmit acknowledgments even if this is set. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: next header is not properly set upon decompression of a UDP header.Tony Cheneau
This causes a drop of the UDP packet. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-266lowpan: lowpan_is_iid_16_bit_compressable() does not detect compressible ↵Tony Cheneau
address correctly The current test is not RFC6282 compliant. The same issue has been found and fixed in Contiki. This patch is basically a port of their fix. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-106lowpan: Fix endianness issue in is_addr_link_local().YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-066lowpan: use stack buffer instead of heapAlexander Aring
head buffer is only temporary available in lowpan_header_create. So it's not necessary to put it on the heap. Also fixed a comment codestyle issue. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-066lowpan: Remove __init tag from lowpan_netlink_fini().David S. Miller
It's called from both __init and __exit code, so neither tag is appropriate. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-06driver-core: constify data for class_find_device()Michał Mirosław
All in-kernel users of class_find_device() don't really need mutable data for match callback. In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c) this patch changes match callbacks to use const search data. The const is propagated to rtc_class_open() and power_supply_get_by_name() parameters. Note that there's a dev reference leak in suspend_test.c that's not touched in this patch. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-186lowpan: Handle uncompressed IPv6 packets over 6LoWPANAlan Ott
Handle the reception of uncompressed packets (dispatch type = IPv6). Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-186lowpan: Refactor packet delivery into a functionAlan Ott
Refactor the handing of the skb's to the individual lowpan devices into a function. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-11net/ieee802154: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> CC: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2012-11-306lowpan: consider checksum bytes in fragmentation thresholdAlan Ott
Change the threshold for framentation of a lowpan packet from using the MTU size to now use the MTU size minus the checksum length, which is added by the hardware. For IEEE 802.15.4, this effectively changes it from 127 bytes to 125 bytes. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18net/ieee802154/6lowpan.c: Remove unecessary semicolonPeter Senna Tschudin
Found by http://coccinelle.lip6.fr/ Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-016lowpan: handle NETDEV_UNREGISTER eventAlan Ott
Before, it was impossible to remove a wpan device which had lowpan attached to it. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@tempietto.lan>
2012-09-016lowpan: Make a copy of skb's delivered to 6lowpanAlan Ott
Since lowpan_process_data() modifies the skb (by calling skb_pull()), we need our own copy so that it doesn't affect the data received by other protcols (in this case, af_ieee802154). Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: David S. Miller <davem@tempietto.lan>
2012-07-166lowpan: Change byte order when storing/accessing to len fieldTony Cheneau
Lenght field should be encoded using big endian byte order, such as intend in the specs. As it is currently written, the len field would not be decoded properly on an implementation using the correct byte ordering. Hence, it could lead to interroperability issues. Also, I rewrote the code so that iphc0 argument of lowpan_alloc_new_frame could be removed. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-166lowpan: Change byte order when storing/accessing u16 tagTony Cheneau
The tag field should be stored and accessed using big endian byte order (as intended in the specs). Or else, when displayed with a trafic analyser, such a Wireshark, the field not properly displayed (e.g. 0x01 00 instead of 0x00 01, and so on). Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-166lowpan: Fix null pointer dereference in UDP uncompression functionTony Cheneau
When a UDP packet gets fragmented, a crash will occur at reassembly time. This is because skb->transport_header is not set during earlier period of fragment reassembly. As a consequence, call to udp_hdr() return NULL and uh (which is NULL) gets dereferenced without much test. Signed-off-by: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-126lowpan: rework fragment-deleting routinealex.bluesman.smirnov@gmail.com
6lowpan module starts collecting incomming frames and fragments right after lowpan_module_init() therefor it will be better to clean unfinished fragments in lowpan_cleanup_module() function instead of doing it when link goes down. Changed spinlocks type to prevent deadlock with expired timer event and removed unused one. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-126lowpan: fix tag variable sizealex.bluesman.smirnov@gmail.com
Function lowpan_alloc_new_frame() takes u8 tag as an argument. However, its only caller, lowpan_process_data() passes down a u16. Hence, the tag value can get corrupted. This prevent 6lowpan fragment reassembly of a message when the fragment tag value is over 256. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Tony Cheneau <tony.cheneau@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-126lowpan: get extra headroom in allocated framealex.bluesman.smirnov@gmail.com
Use netdev_alloc_skb_ip_align() instead of alloc_skb() to get some extra headroom in case we need to forward this frame in a tunnel or something else. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-126lowpan: revert: add missing spin_lock_init()alex.bluesman.smirnov@gmail.com
Revert the commit 768f7c7c121e80f458a9d013b2e8b169e5dfb1e5 to initialize spinlock in the more preferable way and make it static to avoid sparse warning. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/batman-adv/bridge_loop_avoidance.c net/batman-adv/bridge_loop_avoidance.h net/batman-adv/soft-interface.c net/mac80211/mlme.c With merge help from Antonio Quartulli (batman-adv) and Stephen Rothwell (drivers/net/usb/qmi_wwan.c). The net/mac80211/mlme.c conflict seemed easy enough, accounting for a conversion to some new tracing macros. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-08ieee802154: verify packet size before trying to allocate itSasha Levin
Currently when sending data over datagram, the send function will attempt to allocate any size passed on from the userspace. We should make sure that this size is checked and limited. We'll limit it to the MTU of the device, which is checked later anyway. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-056lowpan: revert 'reuse eth_mac_addr()'alex.bluesman.smirnov@gmail.com
This reverts the commit cdf49c283e2e105da86ca575ad35b453f5ff24ea which replaces lowpan '.ndo_set_mac_address' method by ethernet's one. Accorind to the IEEE 802.15.4 standard, device has 8-byte length address, so this hook loses the last 2 bytes which may rise a compatibility problems with other IEEE 802.15.4 standard implementations. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-28net: Use NLMSG_DEFAULT_SIZE in combination with nlmsg_new()Thomas Graf
Using NLMSG_GOODSIZE results in multiple pages being used as nlmsg_new() will automatically add the size of the netlink header to the payload thus exceeding the page limit. NLMSG_DEFAULT_SIZE takes this into account. Signed-off-by: Thomas Graf <tgraf@suug.ch> Cc: Jiri Pirko <jpirko@redhat.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-276lowpan: double unlock on an error pathDan Carpenter
We already unlocked a few lines earlier here, so we can go directly to drop without passing through unlock. This was introduced recently in c5d3687f6c ('6lowpan: read data from skb safely'). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-256lowpan: remove excessive argument in pr_debugalex.bluesman.smirnov@gmail.com
Remove excessive __func__ argument in pr_debug function and some excessive debug messages. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-256lowpan: fix hop limit compressionalex.bluesman.smirnov@gmail.com
Add missing pointer shift for the 'default' case. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Tony Cheneau <tony.cheneau+zigbeedev@amnesiak.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-256lowpan: read data from skb safelyalex.bluesman.smirnov@gmail.com
Check if skb buffer can pull requested amount of bytes and return an error in opposite case. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16ieee802154: interface type to be addedalex.bluesman.smirnov@gmail.com
This stack implementation distinguishes several types of slave interfaces. Another parameter to 'add_iface_' function is added to clarify the interface type is going to be registered. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/e1000e/param.c drivers/net/wireless/iwlwifi/iwl-agn-rx.c drivers/net/wireless/iwlwifi/iwl-trans-pcie-rx.c drivers/net/wireless/iwlwifi/iwl-trans.h Resolved the iwlwifi conflict with mainline using 3-way diff posted by John Linville and Stephen Rothwell. In 'net' we added a bug fix to make iwlwifi report a more accurate skb->truesize but this conflicted with RX path changes that happened meanwhile in net-next. In e1000e a conflict arose in the validation code for settings of adapter->itr. 'net-next' had more sophisticated logic so that logic was used. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-266lowpan: duplicate definition of IEEE802154_ALENalex.bluesman.smirnov@gmail.com
The same macros is defined in 'include/net/af_ieee802154.h' and is called IEEE802154_ADDR_LEN. No need another one, so remove it. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-266lowpan: move frame allocation code to a separate functionalex.bluesman.smirnov@gmail.com
Separate frame allocation routine from data processing function. This makes code more human readable and easier for understanding. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
