Signed-off-by: Julian Wollrath <jwollrath@web.de>
This commit implements a new TCP congestion control algorithm: BBR
(Bottleneck Bandwidth and RTT). A detailed description of BBR will be
published in ACM Queue, Vol. 14 No. 5, September-October 2016, as
"BBR: Congestion-Based Congestion Control".
BBR has significantly increased throughput and reduced latency for
connections on Google's internal backbone networks and google.com and
YouTube Web servers.
BBR requires only changes on the sender side, not in the network or
the receiver side. Thus it can be incrementally deployed on today's
Internet, or in datacenters.
The Internet has predominantly used loss-based congestion control
(largely Reno or CUBIC) since the 1980s, relying on packet loss as the
signal to slow down. While this worked well for many years, loss-based
congestion control is unfortunately out-dated in today's networks. On
today's Internet, loss-based congestion control causes the infamous
bufferbloat problem, often causing seconds of needless queuing delay,
since it fills the bloated buffers in many last-mile links. On today's
high-speed long-haul links using commodity switches with shallow
buffers, loss-based congestion control has abysmal throughput because
it over-reacts to losses caused by transient traffic bursts.
In 1981 Kleinrock and Gale showed that the optimal operating point for
a network maximizes delivered bandwidth while minimizing delay and
loss, not only for single connections but for the network as a
whole. Finding that optimal operating point has been elusive, since
any single network measurement is ambiguous: network measurements are
the result of both bandwidth and propagation delay, and those two
cannot be measured simultaneously.
While it is impossible to disambiguate any single bandwidth or RTT
measurement, a connection's behavior over time tells a clearer
story. BBR uses a measurement strategy designed to resolve this
ambiguity. It combines these measurements with a robust servo loop
using recent control systems advances to implement a distributed
congestion control algorithm that reacts to actual congestion, not
packet loss or transient queue delay, and is designed to converge with
high probability to a point near the optimal operating point.
In a nutshell, BBR creates an explicit model of the network pipe by
sequentially probing the bottleneck bandwidth and RTT. On the arrival
of each ACK, BBR derives the current delivery rate of the last round
trip, and feeds it through a windowed max-filter to estimate the
bottleneck bandwidth. Conversely it uses a windowed min-filter to
estimate the round trip propagation delay. The max-filtered bandwidth
and min-filtered RTT estimates form BBR's model of the network pipe.
Using its model, BBR sets control parameters to govern sending
behavior. The primary control is the pacing rate: BBR applies a gain
multiplier to transmit faster or slower than the observed bottleneck
bandwidth. The conventional congestion window (cwnd) is now the
secondary control; the cwnd is set to a small multiple of the
estimated BDP (bandwidth-delay product) in order to allow full
utilization and bandwidth probing while bounding the potential amount
of queue at the bottleneck.
When a BBR connection starts, it enters STARTUP mode and applies a
high gain to perform an exponential search to quickly probe the
bottleneck bandwidth (doubling its sending rate each round trip, like
slow start). However, instead of continuing until it fills up the
buffer (i.e. a loss), or until delay or ACK spacing reaches some
threshold (like Hystart), it uses its model of the pipe to estimate
when that pipe is full: it estimates the pipe is full when it notices
the estimated bandwidth has stopped growing. At that point it exits
STARTUP and enters DRAIN mode, where it reduces its pacing rate to
drain the queue it estimates it has created.
Then BBR enters steady state. In steady state, PROBE_BW mode cycles
between first pacing faster to probe for more bandwidth, then pacing
slower to drain any queue that created if no more bandwidth was
available, and then cruising at the estimated bandwidth to utilize the
pipe without creating excess queue. Occasionally, on an as-needed
basis, it sends significantly slower to probe for RTT (PROBE_RTT
mode).
BBR has been fully deployed on Google's wide-area backbone networks
and we're experimenting with BBR on Google.com and YouTube on a global
scale. Replacing CUBIC with BBR has resulted in significant
improvements in network latency and application (RPC, browser, and
video) metrics. For more details please refer to our upcoming ACM
Queue publication.
Example performance results, to illustrate the difference between BBR
and CUBIC:
Resilience to random loss (e.g. from shallow buffers):
Consider a netperf TCP_STREAM test lasting 30 secs on an emulated
path with a 10Gbps bottleneck, 100ms RTT, and 1% packet loss
rate. CUBIC gets 3.27 Mbps, and BBR gets 9150 Mbps (2798x higher).
Low latency with the bloated buffers common in today's last-mile links:
Consider a netperf TCP_STREAM test lasting 120 secs on an emulated
path with a 10Mbps bottleneck, 40ms RTT, and 1000-packet bottleneck
buffer. Both fully utilize the bottleneck bandwidth, but BBR
achieves this with a median RTT 25x lower (43 ms instead of 1.09
secs).
Our long-term goal is to improve the congestion control algorithms
used on the Internet. We are hopeful that BBR can help advance the
efforts toward this goal, and motivate the community to do further
research.
Test results, performance evaluations, feedback, and BBR-related
discussions are very welcome in the public e-mail list for BBR:
https://groups.google.com/forum/#!forum/bbr-dev
NOTE: BBR *must* be used with the fq qdisc ("man tc-fq") with pacing
enabled, since pacing is integral to the BBR design and
implementation. BBR without pacing would not function properly, and
may incur unnecessary high packet loss rates.
Signed-off-by: Van Jacobson <vanj@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
TCP-NV (New Vegas) is a major update to TCP-Vegas.
An earlier version of NV was presented at 2010's LPC.
It is a delayed based congestion avoidance for the
data center. This version has been tested within a
10G rack where the HW RTTs are 20-50us and with
1 to 400 flows.
A description of TCP-NV, including implementation
details as well as experimental results, can be found at:
http://www.brakmo.org/networking/tcp-nv/TCPNV.html
Signed-off-by: Lawrence Brakmo <brakmo@fb.com>
There are no longer any in-tree drivers that use it.
The current ip_tunnel cache implementation is prone to a race
that will cause the wrong dst to be cached on cuncurrent dst cache
miss and ip tunnel update via netlink.
Replacing with the generic implementation fix the issue.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
The ESP algorithms using CBC mode require echainiv. Hence INET*_ESP have
to select CRYPTO_ECHAINIV in order to work properly. This solves the
issues caused by a misconfiguration as described in [1].
The original approach, patching crypto/Kconfig was turned down by
Herbert Xu [2].
[1] https://lists.strongswan.org/pipermail/users/2015-December/009074.html
[2] http://marc.info/?l=linux-crypto-vger&m=145224655809562&w=2
Signed-off-by: Thomas Egerer <hakke_007@gmx.de>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This implements SOCK_DESTROY for TCP sockets. It causes all
blocking calls on the socket to fail fast with ECONNABORTED and
causes a protocol close of the socket. It informs the other end
of the connection by sending a RST, i.e., initiating a TCP ABORT
as per RFC 793. ECONNABORTED was chosen for consistency with
FreeBSD.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
geneve_core module handles send and receive functionality.
This way OVS could use the Geneve API. Now with use of
tunnel meatadata mode OVS can directly use Geneve netdevice.
So there is no need for separate module for Geneve. Following
patch consolidates Geneve protocol processing in single module.
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Reviewed-by: Jesse Gross <jesse@nicira.com>
Acked-by: John W. Linville <linville@tuxdriver.com>
CAIA Delay-Gradient (CDG) is a TCP congestion control that modifies
the TCP sender in order to [1]:
o Use the delay gradient as a congestion signal.
o Back off with an average probability that is independent of the RTT.
o Coexist with flows that use loss-based congestion control, i.e.,
flows that are unresponsive to the delay signal.
o Tolerate packet loss unrelated to congestion. (Disabled by default.)
Its FreeBSD implementation was presented for the ICCRG in July 2012;
slides are available at http://www.ietf.org/proceedings/84/iccrg.html
Running the experiment scenarios in [1] suggests that our implementation
achieves more goodput compared with FreeBSD 10.0 senders, although it also
causes more queueing delay for a given backoff factor.
The loss tolerance heuristic is disabled by default due to safety concerns
for its use in the Internet [2, p. 45-46].
We use a variant of the Hybrid Slow start algorithm in tcp_cubic to reduce
the probability of slow start overshoot.
[1] D.A. Hayes and G. Armitage. "Revisiting TCP congestion control using
delay gradients." In Networking 2011, pages 328-341. Springer, 2011.
[2] K.K. Jonassen. "Implementing CAIA Delay-Gradient in Linux."
MSc thesis. Department of Informatics, University of Oslo, 2015.
Cc: Eric Dumazet <edumazet@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: David Hayes <davihay@ifi.uio.no>
Cc: Andreas Petlund <apetlund@simula.no>
Cc: Dave Taht <dave.taht@bufferbloat.net>
Cc: Nicolas Kuhn <nicolas.kuhn@telecom-bretagne.eu>
Signed-off-by: Kenneth Klette Jonassen <kennetkl@ifi.uio.no>
Acked-by: Yuchung Cheng <ycheng@google.com>
net/ipv4/geneve.c -> net/ipv4/geneve_core.c
This name better reflects the purpose of the module.
Move fou_build_header out of ip_tunnel.c and into fou.c splitting
it up into fou_build_header, gue_build_header, and fou_build_udp.
This allows for other users for TX of FOU or GUE. Change ip_tunnel_encap
to call fou_build_header or gue_build_header based on the tunnel
encapsulation type. Similarly, added fou_encap_hlen and gue_encap_hlen
functions which are called by ip_encap_hlen. New net/fou.h has
prototypes and defines for this.
Added NET_FOU_IP_TUNNELS configuration. When this is set, IP tunnels
can use FOU/GUE and fou module is also selected.
Signed-off-by: Tom Herbert <therbert@google.com>
Fix a openvswitch compilation error when CONFIG_INET is not set:
In file included from include/net/geneve.h:4:0,
from net/openvswitch/flow_netlink.c:45:
include/net/udp_tunnel.h: In function 'udp_tunnel_handle_offloads':
>> include/net/udp_tunnel.h:100:2: error: implicit declaration of function 'iptunnel_handle_offloads' [-Werror=implicit-function-declaration]
>> return iptunnel_handle_offloads(skb, udp_csum, type);
>> >> include/net/udp_tunnel.h:100:2: warning: return makes pointer from integer without a cast
>> >> cc1: some warnings being treated as errors
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Andy Zhou <azhou@nicira.com>
This adds a device level support for Geneve -- Generic Network
Virtualization Encapsulation. The protocol is documented at
http://tools.ietf.org/html/draft-gross-geneve-01
Only protocol layer Geneve support is provided by this driver.
Openvswitch can be used for configuring, set up and tear down
functional Geneve tunnels.
Signed-off-by: Jesse Gross <jesse@nicira.com>
This work adds the DataCenter TCP (DCTCP) congestion control
algorithm [1], which has been first published at SIGCOMM 2010 [2],
resp. follow-up analysis at SIGMETRICS 2011 [3] (and also, more
recently as an informational IETF draft available at [4]).
DCTCP is an enhancement to the TCP congestion control algorithm for
data center networks. Typical data center workloads are i.e.
i) partition/aggregate (queries; bursty, delay sensitive), ii) short
messages e.g. 50KB-1MB (for coordination and control state; delay
sensitive), and iii) large flows e.g. 1MB-100MB (data update;
throughput sensitive). DCTCP has therefore been designed for such
environments to provide/achieve the following three requirements:
* High burst tolerance (incast due to partition/aggregate)
* Low latency (short flows, queries)
* High throughput (continuous data updates, large file
transfers) with commodity, shallow buffered switches
The basic idea of its design consists of two fundamentals: i) on the
switch side, packets are being marked when its internal queue
length > threshold K (K is chosen so that a large enough headroom
for marked traffic is still available in the switch queue); ii) the
sender/host side maintains a moving average of the fraction of marked
packets, so each RTT, F is being updated as follows:
F := X / Y, where X is # of marked ACKs, Y is total # of ACKs
alpha := (1 - g) * alpha + g * F, where g is a smoothing constant
The resulting alpha (iow: probability that switch queue is congested)
is then being used in order to adaptively decrease the congestion
window W:
W := (1 - (alpha / 2)) * W
The means for receiving marked packets resp. marking them on switch
side in DCTCP is the use of ECN.
RFC3168 describes a mechanism for using Explicit Congestion Notification
from the switch for early detection of congestion, rather than waiting
for segment loss to occur.
However, this method only detects the presence of congestion, not
the *extent*. In the presence of mild congestion, it reduces the TCP
congestion window too aggressively and unnecessarily affects the
throughput of long flows [4].
DCTCP, as mentioned, enhances Explicit Congestion Notification (ECN)
processing to estimate the fraction of bytes that encounter congestion,
rather than simply detecting that some congestion has occurred. DCTCP
then scales the TCP congestion window based on this estimate [4],
thus it can derive multibit feedback from the information present in
the single-bit sequence of marks in its control law. And thus act in
*proportion* to the extent of congestion, not its *presence*.
Switches therefore set the Congestion Experienced (CE) codepoint in
packets when internal queue lengths exceed threshold K. Resulting,
DCTCP delivers the same or better throughput than normal TCP, while
using 90% less buffer space.
It was found in [2] that DCTCP enables the applications to handle 10x
the current background traffic, without impacting foreground traffic.
Moreover, a 10x increase in foreground traffic did not cause any
timeouts, and thus largely eliminates TCP incast collapse problems.
The algorithm itself has already seen deployments in large production
data centers since then.
We did a long-term stress-test and analysis in a data center, short
summary of our TCP incast tests with iperf compared to cubic:
This test measured DCTCP throughput and latency and compared it with
CUBIC throughput and latency for an incast scenario. In this test, 19
senders sent at maximum rate to a single receiver. The receiver simply
ran iperf -s.
The senders ran iperf -c <receiver> -t 30. All senders started
simultaneously (using local clocks synchronized by ntp).
This test was repeated multiple times. Below shows the results from a
single test. Other tests are similar. (DCTCP results were extremely
consistent, CUBIC results show some variance induced by the TCP timeouts
that CUBIC encountered.)
For this test, we report statistics on the number of TCP timeouts,
flow throughput, and traffic latency.
1) Timeouts (total over all flows, and per flow summaries):
CUBIC DCTCP
Total 3227 25
Mean 169.842 1.316
Median 183 1
Max 207 5
Min 123 0
Stddev 28.991 1.600
Timeout data is taken by measuring the net change in netstat -s
"other TCP timeouts" reported. As a result, the timeout measurements
above are not restricted to the test traffic, and we believe that it
is likely that all of the "DCTCP timeouts" are actually timeouts for
non-test traffic. We report them nevertheless. CUBIC will also include
some non-test timeouts, but they are drawfed by bona fide test traffic
timeouts for CUBIC. Clearly DCTCP does an excellent job of preventing
TCP timeouts. DCTCP reduces timeouts by at least two orders of
magnitude and may well have eliminated them in this scenario.
2) Throughput (per flow in Mbps):
CUBIC DCTCP
Mean 521.684 521.895
Median 464 523
Max 776 527
Min 403 519
Stddev 105.891 2.601
Fairness 0.962 0.999
Throughput data was simply the average throughput for each flow
reported by iperf. By avoiding TCP timeouts, DCTCP is able to
achieve much better per-flow results. In CUBIC, many flows
experience TCP timeouts which makes flow throughput unpredictable and
unfair. DCTCP, on the other hand, provides very clean predictable
throughput without incurring TCP timeouts. Thus, the standard deviation
of CUBIC throughput is dramatically higher than the standard deviation
of DCTCP throughput.
Mean throughput is nearly identical because even though cubic flows
suffer TCP timeouts, other flows will step in and fill the unused
bandwidth. Note that this test is something of a best case scenario
for incast under CUBIC: it allows other flows to fill in for flows
experiencing a timeout. Under situations where the receiver is issuing
requests and then waiting for all flows to complete, flows cannot fill
in for timed out flows and throughput will drop dramatically.
3) Latency (in ms):
CUBIC DCTCP
Mean 4.0088 0.04219
Median 4.055 0.0395
Max 4.2 0.085
Min 3.32 0.028
Stddev 0.1666 0.01064
Latency for each protocol was computed by running "ping -i 0.2
<receiver>" from a single sender to the receiver during the incast
test. For DCTCP, "ping -Q 0x6 -i 0.2 <receiver>" was used to ensure
that traffic traversed the DCTCP queue and was not dropped when the
queue size was greater than the marking threshold. The summary
statistics above are over all ping metrics measured between the single
sender, receiver pair.
The latency results for this test show a dramatic difference between
CUBIC and DCTCP. CUBIC intentionally overflows the switch buffer
which incurs the maximum queue latency (more buffer memory will lead
to high latency.) DCTCP, on the other hand, deliberately attempts to
keep queue occupancy low. The result is a two orders of magnitude
reduction of latency with DCTCP - even with a switch with relatively
little RAM. Switches with larger amounts of RAM will incur increasing
amounts of latency for CUBIC, but not for DCTCP.
4) Convergence and stability test:
This test measured the time that DCTCP took to fairly redistribute
bandwidth when a new flow commences. It also measured DCTCP's ability
to remain stable at a fair bandwidth distribution. DCTCP is compared
with CUBIC for this test.
At the commencement of this test, a single flow is sending at maximum
rate (near 10 Gbps) to a single receiver. One second after that first
flow commences, a new flow from a distinct server begins sending to
the same receiver as the first flow. After the second flow has sent
data for 10 seconds, the second flow is terminated. The first flow
sends for an additional second. Ideally, the bandwidth would be evenly
shared as soon as the second flow starts, and recover as soon as it
stops.
The results of this test are shown below. Note that the flow bandwidth
for the two flows was measured near the same time, but not
simultaneously.
DCTCP performs nearly perfectly within the measurement limitations
of this test: bandwidth is quickly distributed fairly between the two
flows, remains stable throughout the duration of the test, and
recovers quickly. CUBIC, in contrast, is slow to divide the bandwidth
fairly, and has trouble remaining stable.
CUBIC DCTCP
Seconds Flow 1 Flow 2 Seconds Flow 1 Flow 2
0 9.93 0 0 9.92 0
0.5 9.87 0 0.5 9.86 0
1 8.73 2.25 1 6.46 4.88
1.5 7.29 2.8 1.5 4.9 4.99
2 6.96 3.1 2 4.92 4.94
2.5 6.67 3.34 2.5 4.93 5
3 6.39 3.57 3 4.92 4.99
3.5 6.24 3.75 3.5 4.94 4.74
4 6 3.94 4 5.34 4.71
4.5 5.88 4.09 4.5 4.99 4.97
5 5.27 4.98 5 4.83 5.01
5.5 4.93 5.04 5.5 4.89 4.99
6 4.9 4.99 6 4.92 5.04
6.5 4.93 5.1 6.5 4.91 4.97
7 4.28 5.8 7 4.97 4.97
7.5 4.62 4.91 7.5 4.99 4.82
8 5.05 4.45 8 5.16 4.76
8.5 5.93 4.09 8.5 4.94 4.98
9 5.73 4.2 9 4.92 5.02
9.5 5.62 4.32 9.5 4.87 5.03
10 6.12 3.2 10 4.91 5.01
10.5 6.91 3.11 10.5 4.87 5.04
11 8.48 0 11 8.49 4.94
11.5 9.87 0 11.5 9.9 0
SYN/ACK ECT test:
This test demonstrates the importance of ECT on SYN and SYN-ACK packets
by measuring the connection probability in the presence of competing
flows for a DCTCP connection attempt *without* ECT in the SYN packet.
The test was repeated five times for each number of competing flows.
Competing Flows 1 | 2 | 4 | 8 | 16
Mean Connection Probability 1 | 0.67 | 0.45 | 0.28 | 0
Median Connection Probability 1 | 0.65 | 0.45 | 0.25 | 0
As the number of competing flows moves beyond 1, the connection
probability drops rapidly.
Enabling DCTCP with this patch requires the following steps:
DCTCP must be running both on the sender and receiver side in your
data center, i.e.:
sysctl -w net.ipv4.tcp_congestion_control=dctcp
Also, ECN functionality must be enabled on all switches in your
data center for DCTCP to work. The default ECN marking threshold (K)
heuristic on the switch for DCTCP is e.g., 20 packets (30KB) at
1Gbps, and 65 packets (~100KB) at 10Gbps (K > 1/7 * C * RTT, [4]).
In above tests, for each switch port, traffic was segregated into two
queues. For any packet with a DSCP of 0x01 - or equivalently a TOS of
0x04 - the packet was placed into the DCTCP queue. All other packets
were placed into the default drop-tail queue. For the DCTCP queue,
RED/ECN marking was enabled, here, with a marking threshold of 75 KB.
More details however, we refer you to the paper [2] under section 3).
There are no code changes required to applications running in user
space. DCTCP has been implemented in full *isolation* of the rest of
the TCP code as its own congestion control module, so that it can run
without a need to expose code to the core of the TCP stack, and thus
nothing changes for non-DCTCP users.
Changes in the CA framework code are minimal, and DCTCP algorithm
operates on mechanisms that are already available in most Silicon.
The gain (dctcp_shift_g) is currently a fixed constant (1/16) from
the paper, but we leave the option that it can be chosen carefully
to a different value by the user.
In case DCTCP is being used and ECN support on peer site is off,
DCTCP falls back after 3WHS to operate in normal TCP Reno mode.
ss {-4,-6} -t -i diag interface:
... dctcp wscale:7,7 rto:203 rtt:2.349/0.026 mss:1448 cwnd:2054
ssthresh:1102 ce_state 0 alpha 15 ab_ecn 0 ab_tot 735584
send 10129.2Mbps pacing_rate 20254.1Mbps unacked:1822 retrans:0/15
reordering:101 rcv_space:29200
... dctcp-reno wscale:7,7 rto:201 rtt:0.711/1.327 ato:40 mss:1448
cwnd:10 ssthresh:1102 fallback_mode send 162.9Mbps pacing_rate
325.5Mbps rcv_rtt:1.5 rcv_space:29200
More information about DCTCP can be found in [1-4].
[1] http://simula.stanford.edu/~alizade/Site/DCTCP.html
[2] http://simula.stanford.edu/~alizade/Site/DCTCP_files/dctcp-final.pdf
[3] http://simula.stanford.edu/~alizade/Site/DCTCP_files/dctcp_analysis-full.pdf
[4] http://tools.ietf.org/html/draft-bensley-tcpm-dctcp-00
Joint work with Florian Westphal and Glenn Judd.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Glenn Judd <glenn.judd@morganstanley.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
This patch provides a receive path for foo-over-udp. This allows
direct encapsulation of IP protocols over UDP. The bound destination
port is used to map to an IP protocol, and the XFRM framework
(udp_encap_rcv) is used to receive encapsulated packets. Upon
reception, the encapsulation header is logically removed (pointer
to transport header is advanced) and the packet is reinjected into
the receive path with the IP protocol indicated by the mapping.
Netlink is used to configure FOU ports. The configuration information
includes the port number to bind to and the IP protocol corresponding
to that port.
This should support GRE/UDP
(http://tools.ietf.org/html/draft-yong-tsvwg-gre-in-udp-encap-02),
as will as the other IP tunneling protocols (IPIP, SIT).
Added udp_tunnel.c which can contain some common functions for UDP
tunnels. The first function in this is udp_sock_create which is used
to open the listener port for a UDP tunnel.
This config option is superfluous in that it only guards a call
to neigh_app_ns(). Enabling CONFIG_ARPD by default has no
change in behavior. There will now be call to __neigh_notify()
for each ARP resolution, which has no impact unless there is a
user space daemon waiting to receive the notification, i.e.,
the case for which CONFIG_ARPD was designed anyways.
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Gao feng <gaofeng@cn.fujitsu.com>
Cc: Joe Perches <joe@perches.com>
Cc: Veaceslav Falico <vfalico@redhat.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Commit 202dc3fc599c1dded235d3b448d9ca924252e354 (Documentation: remove
obsolete networking/multicast.txt file) deleted the obsolete file. After
the file has been removed, clean up a couple of places where references
to the deleted file were made so that users wouldn't be confused when
they consult the Help menu.
Signed-off-by: Jean Sacren <sakiwit@gmail.com>
Use common function get calculate rtnl_link_stats64 stats.
Reuse common ip-tunneling code which is re-factored from GRE
module.
Following patch refactors GRE code into ip tunneling code and GRE
specific code. Common tunneling code is moved to ip_tunnel module.
ip_tunnel module is written as generic library which can be used
by different tunneling implementations.
ip_tunnel module contains following components:
- packet xmit and rcv generic code. xmit flow looks like
(gre_xmit/ipip_xmit)->ip_tunnel_xmit->ip_local_out.
- hash table of all devices.
- lookup for tunnel devices.
- control plane operations like device create, destroy, ioctl, netlink
operations code.
- registration for tunneling modules, like gre, ipip etc.
- define single pcpu_tstats dev->tstats.
- struct tnl_ptk_info added to pass parsed tunnel packet parameters.
ipip.h header is renamed to ip_tunnel.h
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: "David S. Miller" <davem@davemloft.net>
CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
CC: James Morris <jmorris@namei.org>
CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
CC: Patrick McHardy <kaber@trash.net>
New VTI tunnel kernel module, Kconfig and Makefile changes.
Signed-off-by: Saurabh Mohan <saurabh.mohan@vyatta.com>
Reviewed-by: Stephen Hemminger <shemminger@vyatta.com>
We are going to delete the Token ring support. This removes any
special processing in the core networking for token ring, (aside
from net/tr.c itself), leaving the drivers and remaining tokenring
support present but inert.
The mass removal of the drivers and net/tr.c will be in a separate
commit, so that the history of these files that we still care
about won't have the giant deletion tied into their history.
By making this a standalone config option (auto-selected as needed),
selecting CRYPTO from here rather than from XFRM (which is boolean)
allows the core crypto code to become a module again even when XFRM=y.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Tested-by: Anisse Astier <anisse@astier.eu>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
igmp: Avoid zero delay when receiving odd mixture of IGMP queries
netdev: make net_device_ops const
bcm63xx: make ethtool_ops const
usbnet: make ethtool_ops const
net: Fix build with INET disabled.
net: introduce netif_addr_lock_nested() and call if when appropriate
net: correct lock name in dev_[uc/mc]_sync documentations.
net: sk_update_clone is only used in net/core/sock.c
8139cp: fix missing napi_gro_flush.
pktgen: set correct max and min in pktgen_setup_inject()
smsc911x: Unconditionally include linux/smscphy.h in smsc911x.h
asix: fix infinite loop in rx_fixup()
net: Default UDP and UNIX diag to 'n'.
r6040: fix typo in use of MCR0 register bits
net: fix sock_clone reference mismatch with tcp memcontrol
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits)
Kconfig: acpi: Fix typo in comment.
misc latin1 to utf8 conversions
devres: Fix a typo in devm_kfree comment
btrfs: free-space-cache.c: remove extra semicolon.
fat: Spelling s/obsolate/obsolete/g
SCSI, pmcraid: Fix spelling error in a pmcraid_err() call
tools/power turbostat: update fields in manpage
mac80211: drop spelling fix
types.h: fix comment spelling for 'architectures'
typo fixes: aera -> area, exntension -> extension
devices.txt: Fix typo of 'VMware'.
sis900: Fix enum typo 'sis900_rx_bufer_status'
decompress_bunzip2: remove invalid vi modeline
treewide: Fix comment and string typo 'bufer'
hyper-v: Update MAINTAINERS
treewide: Fix typos in various parts of the kernel, and fix some comments.
clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR
gpio: Kconfig: drop unknown symbol 'CS5535_GPIO'
leds: Kconfig: Fix typo 'D2NET_V2'
sound: Kconfig: drop unknown symbol ARCH_CLPS7500
Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new
kconfig additions, close to removed commented-out old ones)
Eric Dumazet reported, that when inet_diag is built-in the udp_diag also goes
built-in and when ipv6 is a module the udp6 lookup symbol is not found.
LD .tmp_vmlinux1
net/built-in.o: In function `udp_dump_one':
udp_diag.c:(.text+0xa2b40): undefined reference to `__udp6_lib_lookup'
make: *** [.tmp_vmlinux1] Erreur 1
Fix this by making udp diag build mode depend on both -- inet diag and ipv6.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Copy-s/tcp/udp/-paste from TCP bits.
These comments mention CONFIG options that do not exist: not as a symbol
in a Kconfig file (without the CONFIG_ prefix) and neither as a symbol
(with that prefix) in the code.
There's one reference to XSCALE_PMU_TIMER as a negative dependency.
But XSCALE_PMU_TIMER is never defined (CONFIG_XSCALE_PMU_TIMER is
also unused in the code). It shows up with type "unknown" if you search
for it in menuconfig. Apparently a negative dependency on an unknown
symbol is always true. That negative dependency can be removed too.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The time has finally come to remove the hash based routing table
implementation in ipv4.
FIB Trie is mature, well tested, and I've done an audit of it's code
to confirm that it implements insert, delete, and lookup with the same
identical semantics as fib_hash did.
If there are any semantic differences found in fib_trie, we should
simply fix them.
I've placed the trie statistic config option under advanced router
configuration.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Fix dependencies of netfilter realm match: it depends on NET_CLS_ROUTE,
which itself depends on NET_SCHED; this dependency is missing from netfilter.
Since matching on realms is also useful without having NET_SCHED enabled and
the option really only controls whether the tclassid member is included in
route and dst entries, rename the config option to IP_ROUTE_CLASSID and move
it outside of traffic scheduling context to get rid of the NET_SCHED dependeny.
Reported-by: Vladis Kletnieks <Valdis.Kletnieks@vt.edu>
Some of the documentation refers to web pages under
the domain `osdl.org'. However, `osdl.org' now
redirects to `linuxfoundation.org'.
Rather than rely on redirections, this patch updates
the addresses appropriately; for the most part, only
documentation that is meant to be current has been
updated.
The patch should be pretty quick to scan and check;
each new web-page url was gotten by trying out the
original URL in a browser and then simply copying the
the redirected URL (formatting as necessary).
There is some conflict as to which one of these domain
names is preferred:
linuxfoundation.org
linux-foundation.org
So, I wrote:
info@linuxfoundation.org
and got this reply:
Message-ID: <4CE17EE6.9040807@linuxfoundation.org>
Date: Mon, 15 Nov 2010 10:41:42 -0800
linuxfoundation.org is preferred. The canonical name for our web site is
www.linuxfoundation.org. Our list site is actually
lists.linux-foundation.org.
Regarding email linuxfoundation.org is preferred there are a few people
who choose to use linux-foundation.org for their own reasons.
Consequently, I used `linuxfoundation.org' for web pages and
`lists.linux-foundation.org' for mailing-list web pages and email addresses;
the only personal email address I updated from `@osdl.org' was that of
Andrew Morton, who prefers `linux-foundation.org' according `git log'.
Signed-off-by: Michael Witten <mfwitten@gmail.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
net/ipv4/Kconfig
net/ipv4/tcp_timer.c
This reverts commit e81963b180ac502fda0326edf059b1e29cdef1a2.
LRO is now deprecated in favour of GRO, and only a few drivers use it,
so it is desirable to build it as a module in distribution kernels.
The original change to prevent building it as a module was made in an
attempt to avoid the case where some dependents are set to y and some
to m, and INET_LRO can be set to m rather than y. However, the
Kconfig system will reliably set INET_LRO=y in this case.
The GRE tunnel driver needs to invoke icmpv6 helpers in the
ipv6 stack when ipv6 support is enabled.
Therefore if IPV6 is enabled, we have to enforce that GRE's
enabling (modular or static) matches that of ipv6.
Reported-by: Patrick McHardy <kaber@trash.net>
Reported-by: Herbert Xu <herbert@gondor.apana.org.au>
net/mac80211/main.c
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
PPP: introduce "pptp" module which implements point-to-point tunneling protocol using pppox framework
NET: introduce the "gre" module for demultiplexing GRE packets on version criteria
(required to pptp and ip_gre may coexists)
NET: ip_gre: update to use the "gre" module
This patch introduces then pptp support to the linux kernel which
dramatically speeds up pptp vpn connections and decreases cpu usage in
comparison of existing user-space implementation
(poptop/pptpclient). There is accel-pptp project
(https://sourceforge.net/projects/accel-pptp/) to utilize this module,
it contains plugin for pppd to use pptp in client-mode and modified
pptpd (poptop) to build high-performance pptp NAS.
There was many changes from initial submitted patch, most important are:
1. using rcu instead of read-write locks
2. using static bitmap instead of dynamically allocated
3. using vmalloc for memory allocation instead of BITS_PER_LONG + __get_free_pages
4. fixed many coding style issues
Thanks to Eric Dumazet.
Signed-off-by: Dmitry Kozlov <xeb@mail.ru>
syncookies default to on since
e994b7c901ded7200b525a707c6da71f2cf6d4bb
(tcp: Don't make syn cookies initial setting depend on CONFIG_SYSCTL).
IP_MROUTE_MULTIPLE_TABLES should depend on IP_MROUTE.
This patch adds support for multiple independant multicast routing instances,
named "tables".
Userspace multicast routing daemons can bind to a specific table instance by
issuing a setsockopt call using a new option MRT_TABLE. The table number is
stored in the raw socket data and affects all following ipmr setsockopt(),
getsockopt() and ioctl() calls. By default, a single table (RT_TABLE_DEFAULT)
is created with a default routing rule pointing to it. Newly created pimreg
devices have the table number appended ("pimregX"), with the exception of
devices created in the default table, which are named just "pimreg" for
compatibility reasons.
Packets are directed to a specific table instance using routing rules,
similar to how regular routing rules work. Currently iif, oif and mark
are supported as keys, source and destination addresses could be supported
additionally.
Example usage:
- bind pimd/xorp/... to a specific table:
uint32_t table = 123;
setsockopt(fd, IPPROTO_IP, MRT_TABLE, &table, sizeof(table));
- create routing rules directing packets to the new table:
# ip mrule add iif eth0 lookup 123
# ip mrule add oif eth0 lookup 123
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
We're adding enough nfs documentation that it may as well have its own
subdirectory.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
