path: root/net/ipv4/Makefile
2008-01-28[IPV4]: Cleanup the sysctl_net_ipv4.c filePavel Emelyanov
This includes several cleanups: * tune Makefile to compile out this file when SYSCTL=n. Now it looks like net/core/sysctl_net_core.c one; * move the ipv4_config to af_inet.c to exist all the time; * remove additional sysctl_ip_nonlocal_bind declaration (it is already declared in net/ip.h); * remove no nonger needed ifdefs from this file. This is a preparation for using ctl paths for net/ipv4/ sysctl table. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Collect frag queues management objects togetherPavel Emelyanov
There are some objects that are common in all the places which are used to keep track of frag queues, they are: * hash table * LRU list * rw lock * rnd number for hash function * the number of queues * the amount of memory occupied by queues * secret timer Move all this stuff into one structure (struct inet_frags) to make it possible use them uniformly in the future. Like with the previous patch this mostly consists of hunks like - write_lock(&ipfrag_lock); + write_lock(&ip4_frags.lock); To address the issue with exporting the number of queues and the amount of memory occupied by queues outside the .c file they are declared in, I introduce a couple of helpers. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Generic Large Receive Offload for TCP trafficJan-Bernd Themann
This patch provides generic Large Receive Offload (LRO) functionality for IPv4/TCP traffic. LRO combines received tcp packets to a single larger tcp packet and passes them then to the network stack in order to increase performance (throughput). The interface supports two modes: Drivers can either pass SKBs or fragment lists to the LRO engine. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV4]: The scheduled removal of multipath cached routing support.David S. Miller
With help from Chris Wedgwood. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: Consolidate common SNMP codeHerbert Xu
This patch moves the SNMP code shared between IPv4/IPv6 from proc.c into net/ipv4/af_inet.c. This makes sense because these functions aren't specific to /proc. As a result we can again skip proc.o if /proc is disabled. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: Fix build without procfs.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: TCP Illinois congestion control (rev3)Stephen Hemminger
This is an implementation of TCP Illinois invented by Shao Liu at University of Illinois. It is a another variant of Reno which adapts the alpha and beta parameters based on RTT. The basic idea is to increase window less rapidly as delay approaches the maximum. See the papers and talks to get a more complete description. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP] YeAH-TCP: algorithm implementationAngelo P. Castellani
YeAH-TCP is a sender-side high-speed enabled TCP congestion control algorithm, which uses a mixed loss/delay approach to compute the congestion window. It's design goals target high efficiency, internal, RTT and Reno fairness, resilience to link loss while keeping network elements load as low as possible. For further details look here: http://wil.cs.caltech.edu/pfldnet2007/paper/YeAH_TCP.pdf Signed-off-by: Angelo P. Castellani <angelo.castellani@gmail.con> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: CIPSOv4 enginePaul Moore
Add support for the Commercial IP Security Option (CIPSO) to the IPv4 network stack. CIPSO has become a de-facto standard for trusted/labeled networking amongst existing Trusted Operating Systems such as Trusted Solaris, HP-UX CMW, etc. This implementation is designed to be used with the NetLabel subsystem to provide explicit packet labeling to LSM developers. The CIPSO/IPv4 packet labeling works by the LSM calling a NetLabel API function which attaches a CIPSO label (IPv4 option) to a given socket; this in turn attaches the CIPSO label to every packet leaving the socket without any extra processing on the outbound side. On the inbound side the individual packet's sk_buff is examined through a call to a NetLabel API function to determine if a CIPSO/IPv4 label is present and if so the security attributes of the CIPSO label are returned to the caller of the NetLabel API function. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-10[TCP]: Remove TCP CompoundDavid S. Miller
This reverts: f890f921040fef6a35e39d15b729af1fd1a35f29 The inclusion of TCP Compound needs to be reverted at this time because it is not 100% certain that this code conforms to the requirements of Developer's Certificate of Origin 1.1 paragraph (b). Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TCP]: TCP Probe congestion window tracingStephen Hemminger
This adds a new module for tracking TCP state variables non-intrusively using kprobes. It has a simple /proc interface that outputs one line for each packet received. A sample usage is to collect congestion window and ssthresh over time graphs. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TCP]: TCP Compound congestion controlAngelo P. Castellani
TCP Compound is a sender-side only change to TCP that uses a mixed Reno/Vegas approach to calculate the cwnd. For further details look here: ftp://ftp.research.microsoft.com/pub/tr/TR-2005-86.pdf Signed-off-by: Angelo P. Castellani <angelo.castellani@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TCP]: TCP Veno congestion controlBin Zhou
TCP Veno module is a new congestion control module to improve TCP performance over wireless networks. The key innovation in TCP Veno is the enhancement of TCP Reno/Sack congestion control algorithm by using the estimated state of a connection based on TCP Vegas. This scheme significantly reduces "blind" reduction of TCP window regardless of the cause of packet loss. This work is based on the research paper "TCP Veno: TCP Enhancement for Transmission over Wireless Access Networks." C. P. Fu, S. C. Liew, IEEE Journal on Selected Areas in Communication, Feb. 2003. Original paper and many latest research works on veno: http://www.ntu.edu.sg/home/ascpfu/veno/veno.html Signed-off-by: Bin Zhou <zhou0022@ntu.edu.sg> Cheng Peng Fu <ascpfu@ntu.edu.sg> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[TCP]: TCP Low Priority congestion controlWong Hoi Sing Edison
TCP Low Priority is a distributed algorithm whose goal is to utilize only the excess network bandwidth as compared to the ``fair share`` of bandwidth as targeted by TCP. Available from: http://www.ece.rice.edu/~akuzma/Doc/akuzma/TCP-LP.pdf Original Author: Aleksandar Kuzmanovic <akuzma@northwestern.edu> See http://www-ece.rice.edu/networks/TCP-LP/ for their implementation. As of 2.6.13, Linux supports pluggable congestion control algorithms. Due to the limitation of the API, we take the following changes from the original TCP-LP implementation: o We use newReno in most core CA handling. Only add some checking within cong_avoid. o Error correcting in remote HZ, therefore remote HZ will be keeped on checking and updating. o Handling calculation of One-Way-Delay (OWD) within rtt_sample, sicne OWD have a similar meaning as RTT. Also correct the buggy formular. o Handle reaction for Early Congestion Indication (ECI) within pkts_acked, as mentioned within pseudo code. o OWD is handled in relative format, where local time stamp will in tcp_time_stamp format. Port from 2.4.19 to 2.6.16 as module by: Wong Hoi Sing Edison <hswong3i@gmail.com> Hung Hing Lun <hlhung3i@gmail.com> Signed-off-by: Wong Hoi Sing Edison <hswong3i@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[INET]: Introduce tunnel4/tunnel6Herbert Xu
Basically this patch moves the generic tunnel protocol stuff out of xfrm4_tunnel/xfrm6_tunnel and moves it into the new files of tunnel4.c and tunnel6 respectively. The reason for this is that the problem that Hugo uncovered is only the tip of the iceberg. The real problem is that when we removed the dependency of ipip on xfrm4_tunnel we didn't really consider the module case at all. For instance, as it is it's possible to build both ipip and xfrm4_tunnel as modules and if the latter is loaded then ipip simply won't load. After considering the alternatives I've decided that the best way out of this is to restore the dependency of ipip on the non-xfrm-specific part of xfrm4_tunnel. This is acceptable IMHO because the intention of the removal was really to be able to use ipip without the xfrm subsystem. This is still preserved by this patch. So now both ipip/xfrm4_tunnel depend on the new tunnel4.c which handles the arbitration between the two. The order of processing is determined by a simple integer which ensures that ipip gets processed before xfrm4_tunnel. The situation for ICMP handling is a little bit more complicated since we may not have enough information to determine who it's for. It's not a big deal at the moment since the xfrm ICMP handlers are basically no-ops. In future we can deal with this when we look at ICMP caching in general. The user-visible change to this is the removal of the TUNNEL Kconfig prompts. This makes sense because it can only be used through IPCOMP as it stands. The addition of the new modules shouldn't introduce any problems since module dependency will cause them to be loaded. Oh and I also turned some unnecessary pskb's in IPv6 related to this patch to skb's. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: net/ipv[46]/netfilter.c cleanupsPatrick McHardy
Don't wrap entire file in #ifdef CONFIG_NETFILTER, remove a few unneccessary includes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP] BIC: CUBIC window growth (2.0)Stephen Hemminger
Replace existing BIC version 1.1 with new version 2.0. The main change is to replace the window growth function with a cubic function as described in: http://www.csc.ncsu.edu/faculty/rhee/export/bitcp/cubic-paper.pdf Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET_DIAG]: Move the tcp_diag interface to the proper placeArnaldo Carvalho de Melo
With this the previous setup is back, i.e. tcp_diag can be built as a module, as dccp_diag and both share the infrastructure available in inet_diag. If one selects CONFIG_INET_DIAG as module CONFIG_INET_TCP_DIAG will also be built as a module, as will CONFIG_INET_DCCP_DIAG, if CONFIG_IP_DCCP was selected static or as a module, if CONFIG_INET_DIAG is y, being statically linked CONFIG_INET_TCP_DIAG will follow suit and CONFIG_INET_DCCP_DIAG will be built in the same manner as CONFIG_IP_DCCP. Now to aim at UDP, converting it to use inet_hashinfo, so that we can use iproute2 for UDP sockets as well. Ah, just to show an example of this new infrastructure working for DCCP :-) [root@qemu ~]# ./ss -dane State Recv-Q Send-Q Local Address:Port Peer Address:Port LISTEN 0 0 *:5001 *:* ino:942 sk:cfd503a0 ESTAB 0 0 127.0.0.1:5001 127.0.0.1:32770 ino:943 sk:cfd50a60 ESTAB 0 0 127.0.0.1:32770 127.0.0.1:5001 ino:947 sk:cfd50700 TIME-WAIT 0 0 127.0.0.1:32769 127.0.0.1:5001 timer:(timewait,3.430ms,0) ino:0 sk:cf209620 Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET_DIAG]: Rename tcp_diag.[ch] to inet_diag.[ch]Arnaldo Carvalho de Melo
Next changeset will introduce net/ipv4/tcp_diag.c, moving the code that was put transitioanlly in inet_diag.c. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCPDIAG]: Just rename everything to inet_diagArnaldo Carvalho de Melo
Next changeset will rename tcp_diag.[ch] to inet_diag.[ch]. I'm taking this longer route so as to easy review, making clear the changes made all along the way. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Just move the inet_connection_sock function from tcp sourcesArnaldo Carvalho de Melo
Completing the previous changeset, this also generalises tcp_v4_synq_add, renaming it to inet_csk_reqsk_queue_hash_add, already geing used in the DCCP tree, which I plan to merge RSN. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise the TCP sock ID lookup routinesArnaldo Carvalho de Melo
And also some TIME_WAIT functions. [acme@toy net-2.6.14]$ grep built-in /tmp/before.size /tmp/after.size /tmp/before.size: 282955 13122 9312 305389 4a8ed net/ipv4/built-in.o /tmp/after.size: 281566 13122 9312 304000 4a380 net/ipv4/built-in.o [acme@toy net-2.6.14]$ I kept them still inlined, will uninline at some point to see what would be the performance difference. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move the TCP hashtable functions/structs to inet_hashtables.[ch]Arnaldo Carvalho de Melo
2005-08-29[NETFILTER]: Move ipv4 specific code from net/core/netfilter.c to ↵Harald Welte
net/ipv4/netfilter.c Netfilter cleanup - Move ipv4 code from net/core/netfilter.c to net/ipv4/netfilter.c - Move ipv6 netfilter code from net/ipv6/ip6_output.c to net/ipv6/netfilter.c Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-27[NET]: Move in_aton from net/ipv4/utils.c to net/core/utils.cMatt Mackall
Move in_aton to allow netpoll and pktgen to work without the rest of the IPv4 stack. Fix whitespace and add comment for the odd placement. Delete now-empty net/ipv4/utils.c Re-enable netpoll/netconsole without CONFIG_INET Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add Scalable TCP congestion control module.John Heffner
This patch implements Tom Kelly's Scalable TCP congestion control algorithm for the modular framework. The algorithm has some nice scaling properties, and has been used a fair bit in research, though is known to have significant fairness issues, so it's not really suitable for general purpose use. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add H-TCP congestion control module.Baruch Even
H-TCP is a congestion control algorithm developed at the Hamilton Institute, by Douglas Leith and Robert Shorten. It is extending the standard Reno algorithm with mode switching is thus a relatively simple modification. H-TCP is defined in a layered manner as it is still a research platform. The basic form includes the modification of beta according to the ratio of maxRTT to min RTT and the alpha=2*factor*(1-beta) relation, where factor is dependant on the time since last congestion. The other layers improve convergence by adding appropriate factors to alpha. The following patch implements the H-TCP algorithm in it's basic form. Signed-Off-By: Baruch Even <baruch@ev-en.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add TCP Vegas congestion control module.Stephen Hemminger
TCP Vegas code modified for the new TCP infrastructure. Vegas now uses microsecond resolution timestamps for better estimation of performance over higher speed links. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add TCP Hybla congestion control module.Daniele Lacamera
TCP Hybla congestion avoidance. - "In heterogeneous networks, TCP connections that incorporate a terrestrial or satellite radio link are greatly disadvantaged with respect to entirely wired connections, because of their longer round trip times (RTTs). To cope with this problem, a new TCP proposal, the TCP Hybla, is presented and discussed in the paper[1]. It stems from an analytical evaluation of the congestion window dynamics in the TCP standard versions (Tahoe, Reno, NewReno), which suggests the necessary modifications to remove the performance dependence on RTT.[...]"[1] [1]: Carlo Caini, Rosario Firrincieli, "TCP Hybla: a TCP enhancement for heterogeneous networks", International Journal of Satellite Communications and Networking Volume 22, Issue 5 , Pages 547 - 566. September 2004. Signed-off-by: Daniele Lacamera (root at danielinux.net)net Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add High Speed TCP congestion control module.John Heffner
Sally Floyd's high speed TCP congestion control. This is useful for comparison and research. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add TCP Westwood congestion control module.Stephen Hemminger
This is the existing 2.6.12 Westwood code moved from tcp_input to the new congestion framework. A lot of the inline functions have been eliminated to try and make it clearer. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add TCP BIC congestion control module.Stephen Hemminger
TCP BIC congestion control reworked to use the new congestion control infrastructure. This version is more up to date than the BIC code in 2.6.12; it incorporates enhancements from BICTCP 1.1, to handle low latency links. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add pluggable congestion control algorithm infrastructure.Stephen Hemminger
Allow TCP to have multiple pluggable congestion control algorithms. Algorithms are defined by a set of operations and can be built in or modules. The legacy "new RENO" algorithm is used as a starting point and fallback. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[IPV4]: Add LC-Trie FIB lookup algorithm.Robert Olsson
Signed-off-by: Robert Olsson <Robert.Olsson@data.slu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
