[IPV4]: Remove bogus ifdef mess in arp_process
[ Upstream commit: 3660019e5f96fd9a8b7d4214a96523c0bf7b676d ]
The #ifdef's in arp_process() were not only a mess, they were also wrong
in the CONFIG_NET_ETHERNET=n and (CONFIG_NETDEV_1000=y or
CONFIG_NETDEV_10000=y) cases.
Since they are not required this patch removes them.
Also removed are some #ifdef's around #include's that caused compile
errors after this change.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Back in the times of Linux 2.2, negative values for the creat parameter
of __neigh_lookup() had a particular meaning, but no longer, so we
should pass 1 instead.
This patch converts the ipv4_devconf config members (everything except
sysctl) to an array. This allows easier manipulation which will be
needed later on to provide better management of default config values.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The seq_file operations stuff can be marked constant to
get it out of dirty cache.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Add whitespace around keywords.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Many files include the filename at the beginning, serveral used a wrong one.
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com>
argument and inferred net-endian variables in callers annotated.
argument and return value are net-endian. Annotated function and inferred
net-endian variables in callers.
ip_route_input() takes net-endian source and destination address.
* Annotated as such.
* arguments of its invocations annotated where needed.
* local helpers getting the same values passed to by it (ip_route_input_mc(),
ip_route_input_slow(), ip_handle_martian_source(), ip_mkroute_input(),
ip_mkroute_input_def(), __mkroute_input()) annotated
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This patch contains the following possible cleanups:
- make the following needlessly global function static:
- arp.c: arp_rcv()
- remove the following unused EXPORT_SYMBOL's:
- devinet.c: devinet_ioctl
- fib_frontend.c: ip_rt_ioctl
- inet_hashtables.c: inet_bind_bucket_create
- inet_hashtables.c: inet_bind_hash
- tcp_input.c: sysctl_tcp_abc
- tcp_ipv4.c: sysctl_tcp_tw_reuse
- tcp_output.c: sysctl_tcp_mtu_probing
- tcp_output.c: sysctl_tcp_base_mss
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
net: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
To help in reducing the number of include dependencies, several files were
touched as they were getting needed headers indirectly for stuff they use.
Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had
linux/dccp.h include twice.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and
introduces __in_dev_get_rcu() to cover the second case.
1) RCU with refcnt should use in_dev_get().
2) RCU without refcnt should use __in_dev_get_rcu().
3) All others must hold RTNL and use __in_dev_get_rtnl().
There is one exception in net/ipv4/route.c which is in fact a pre-existing
race condition. I've marked it as such so that we remember to fix it.
This patch is based on suggestions and prior work by Suzanne Wood and
Paul McKenney.
Meelis Roos <mroos@linux.ee> wrote:
> RK> My firewall setup relies on proxyarp working. However, with 2.6.14-rc3,
> RK> it appears to be completely broken. The firewall is 212.18.232.186,
> Same here with some kernel between 14-rc2 and 14-rc3 - no reposnse to
> ARP on a proxyarp gateway. Sorry, no exact revison and no more debugging
> yet since it'a a production gateway.
The breakage is caused by the change to use the CB area for flagging
whether a packet has been queued due to proxy_delay. This area gets
cleared every time arp_rcv gets called. Unfortunately packets delayed
due to proxy_delay also go through arp_rcv when they are reprocessed.
In fact, I can't think of a reason why delayed proxy packets should go
through netfilter again at all. So the easiest solution is to bypass
that and go straight to arp_process.
This is essentially what would've happened before netfilter support
was added to ARP.
Reduces skb size by 8 bytes on 64-bit.
Bonding just wants the device before the skb_bond()
decapsulation occurs, so simply pass that original
device into packet_type->func() as an argument.
It remains to be seen whether we can use this same
exact thing to get rid of skb->input_dev as well.
infrastructure for it.
Let it rip!
