path: root/net/ipv4/cipso_ipv4.c
2009-03-28netlabel: Label incoming TCP connections correctly in SELinuxPaul Moore
The current NetLabel/SELinux behavior for incoming TCP connections works but only through a series of happy coincidences that rely on the limited nature of standard CIPSO (only able to convey MLS attributes) and the write equality imposed by the SELinux MLS constraints. The problem is that network sockets created as the result of an incoming TCP connection were not on-the-wire labeled based on the security attributes of the parent socket but rather based on the wire label of the remote peer. The issue had to do with how IP options were managed as part of the network stack and where the LSM hooks were in relation to the code which set the IP options on these newly created child sockets. While NetLabel/SELinux did correctly set the socket's on-the-wire label it was promptly cleared by the network stack and reset based on the IP options of the remote peer. This patch, in conjunction with a prior patch that adjusted the LSM hook locations, works to set the correct on-the-wire label format for new incoming connections through the security_inet_conn_request() hook. Besides the correct behavior there are many advantages to this change, the most significant is that all of the NetLabel socket labeling code in SELinux now lives in hooks which can return error codes to the core stack which allows us to finally get ride of the selinux_netlbl_inode_permission() logic which greatly simplfies the NetLabel/SELinux glue code. In the process of developing this patch I also ran into a small handful of AF_INET6 cleanliness issues that have been fixed which should make the code safer and easier to extend in the future. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-23cipso: Fix documentation commentPaul Moore
The CIPSO protocol engine incorrectly stated that the FIPS-188 specification could be found in the kernel's Documentation directory. This patch corrects that by removing the comment and directing users to the FIPS-188 documented hosted online. For the sake of completeness I've also included a link to the CIPSO draft specification on the NetLabel website. Thanks to Randy Dunlap for spotting the error and letting me know. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-12-31netlabel: Update kernel configuration APIPaul Moore
Update the NetLabel kernel API to expose the new features added in kernel releases 2.6.25 and 2.6.28: the static/fallback label functionality and network address based selectors. Signed-off-by: Paul Moore <paul.moore@hp.com>
2008-10-31Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/p54/p54common.c
2008-10-29cipso: unsigned buf_len cannot be negativeroel kluin
unsigned buf_len cannot be negative Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Paul Moore <paul.moore@hp.com>
2008-10-28net: don't use INIT_RCU_HEADAlexey Dobriyan
call_rcu() will unconditionally rewrite RCU head anyway. Applies to struct neigh_parms struct neigh_table struct net struct cipso_v4_doi struct in_ifaddr struct in_device rt->u.dst Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-10cipso: Add support for native local labeling and fixup mapping namesPaul Moore
This patch accomplishes three minor tasks: add a new tag type for local labeling, rename the CIPSO_V4_MAP_STD define to CIPSO_V4_MAP_TRANS and replace some of the CIPSO "magic numbers" with constants from the header file. The first change allows CIPSO to support full LSM labels/contexts, not just MLS attributes. The second change brings the mapping names inline with what userspace is using, compatibility is preserved since we don't actually change the value. The last change is to aid readability and help prevent mistakes. Signed-off-by: Paul Moore <paul.moore@hp.com>
2008-10-10selinux: Set socket NetLabel based on connection endpointPaul Moore
Previous work enabled the use of address based NetLabel selectors, which while highly useful, brought the potential for additional per-packet overhead when used. This patch attempts to solve that by applying NetLabel socket labels when sockets are connect()'d. This should alleviate the per-packet NetLabel labeling for all connected sockets (yes, it even works for connected DGRAM sockets). Signed-off-by: Paul Moore <paul.moore@hp.com> Reviewed-by: James Morris <jmorris@namei.org>
2008-10-10netlabel: Add functionality to set the security attributes of a packetPaul Moore
This patch builds upon the new NetLabel address selector functionality by providing the NetLabel KAPI and CIPSO engine support needed to enable the new packet-based labeling. The only new addition to the NetLabel KAPI at this point is shown below: * int netlbl_skbuff_setattr(skb, family, secattr) ... and is designed to be called from a Netfilter hook after the packet's IP header has been populated such as in the FORWARD or LOCAL_OUT hooks. This patch also provides the necessary SELinux hooks to support this new functionality. Smack support is not currently included due to uncertainty regarding the permissions needed to expand the Smack network access controls. Signed-off-by: Paul Moore <paul.moore@hp.com> Reviewed-by: James Morris <jmorris@namei.org>
2008-10-10netlabel: Replace protocol/NetLabel linking with refrerence countsPaul Moore
NetLabel has always had a list of backpointers in the CIPSO DOI definition structure which pointed to the NetLabel LSM domain mapping structures which referenced the CIPSO DOI struct. The rationale for this was that when an administrator removed a CIPSO DOI from the system all of the associated NetLabel LSM domain mappings should be removed as well; a list of backpointers made this a simple operation. Unfortunately, while the backpointers did make the removal easier they were a bit of a mess from an implementation point of view which was making further development difficult. Since the removal of a CIPSO DOI is a realtively rare event it seems to make sense to remove this backpointer list as the optimization was hurting us more then it was helping. However, we still need to be able to track when a CIPSO DOI definition is being used so replace the backpointer list with a reference count. In order to preserve the current functionality of removing the associated LSM domain mappings when a CIPSO DOI is removed we walk the LSM domain mapping table, removing the relevant entries. Signed-off-by: Paul Moore <paul.moore@hp.com> Reviewed-by: James Morris <jmorris@namei.org>
2008-05-13cipso: Relax too much careful cipso hash function.Pavel Emelyanov
The cipso_v4_cache is allocated to contain CIPSO_V4_CACHE_BUCKETS buckets. The CIPSO_V4_CACHE_BUCKETS = 1 << CIPSO_V4_CACHE_BUCKETBITS, where CIPSO_V4_CACHE_BUCKETBITS = 7. The bucket-selection function for this hash is calculated like this: bkt = hash & (CIPSO_V4_CACHE_BUCKETBITS - 1); ^^^ i.e. picking only 4 buckets of possible 128 :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02net: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4]: Remove unused ip_options->is_data.Denis V. Lunev
ip_options->is_data is assigned only and never checked. The structure is not a part of kernel interface to the userspace. So, it is safe to remove this field. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05NetLabel: introduce a new kernel configuration API for NetLabelPaul Moore
Add a new set of configuration functions to the NetLabel/LSM API so that LSMs can perform their own configuration of the NetLabel subsystem without relying on assistance from userspace. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Reviewed-by: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30NetLabel: Add secid token support to the NetLabel secattr structPaul Moore
This patch adds support to the NetLabel LSM secattr struct for a secid token and a type field, paving the way for full LSM/SELinux context support and "static" or "fallback" labels. In addition, this patch adds a fair amount of documentation to the core NetLabel structures used as part of the NetLabel kernel API. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-01-28[IPV4] net/ipv4/cipso_ipv4.c: use LIST_HEAD instead of LIST_HEAD_INITDenis Cheng
single list_head variable initialized with LIST_HEAD_INIT could almost always can be replaced with LIST_HEAD declaration, this shrinks the code and looks better. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-26[NetLabel]: correct usage of RCU lockingPaul Moore
This fixes some awkward, and perhaps even problematic, RCU lock usage in the NetLabel code as well as some other related trivial cleanups found when looking through the RCU locking. Most of the changes involve removing the redundant RCU read locks wrapping spinlocks in the case of a RCU writer. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[CIPSO]: remove duplicated code in the cipso_v4_*_getattr() functionsPaul Moore
The bulk of the CIPSO option parsing/processing in the cipso_v4_sock_getattr() and cipso_v4_skb_getattr() functions are identical, the only real difference being where the functions obtain the CIPSO option itself. This patch creates a new function, cipso_v4_getattr(), which contains the common CIPSO option parsing/processing code and modifies the existing functions to call this new helper function. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-08[CIPSO]: Fix several unaligned kernel accesses in the CIPSO engine.Paul Moore
IPv4 options are not very well aligned within the packet and the format of a CIPSO option is even worse. The result is that the CIPSO engine in the kernel does a few unaligned accesses when parsing and validating incoming packets with CIPSO options attached which generate error messages on certain alignment sensitive platforms. This patch fixes this by marking these unaligned accesses with the get_unaliagned() macro. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-08[NetLabel]: consolidate the struct socket/sock handling to just struct sockPaul Moore
The current NetLabel code has some redundant APIs which allow both "struct socket" and "struct sock" types to be used; this may have made sense at some point but it is wasteful now. Remove the functions that operate on sockets and convert the callers. Not only does this make the code smaller and more consistent but it pushes the locking burden up to the caller which can be more intelligent about the locks. Also, perform the same conversion (socket to sock) on the SELinux/NetLabel glue code where it make sense. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: selinux: preserve boolean values across policy reloads selinux: change numbering of boolean directory inodes in selinuxfs selinux: remove unused enumeration constant from selinuxfs selinux: explicitly number all selinuxfs inodes selinux: export initial SID contexts via selinuxfs selinux: remove userland security class and permission definitions SELinux: move security_skb_extlbl_sid() out of the security server MAINTAINERS: update selinux entry SELinux: rename selinux_netlabel.h to netlabel.h SELinux: extract the NetLabel SELinux support from the security server NetLabel: convert a BUG_ON in the CIPSO code to a runtime check NetLabel: cleanup and document CIPSO constants
2007-04-26NetLabel: convert a BUG_ON in the CIPSO code to a runtime checkPaul Moore
This patch changes a BUG_ON in the CIPSO code to a runtime check. It should also increase the readability of the code as it replaces an unexplained constant with a well defined macro. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26NetLabel: cleanup and document CIPSO constantsPaul Moore
This patch collects all of the CIPSO constants and puts them in one place; it also documents each value explaining how the value is derived. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: cleanupStephen Hemminger
Add whitespace around keywords. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-12[NetLabel]: parse the CIPSO ranged tag on incoming packetsPaul Moore
Commit 484b366932be0b73a22c74a82748ca10a721643e added support for the CIPSO ranged categories tag. However, it appears that I made a mistake when rebasing then patch to the latest upstream sources for submission and dropped the part of the patch that actually parses the tag on incoming packets. This patch fixes this mistake by adding the required function call to the cipso_v4_skbuff_getattr() function. I've run this patch over the weekend and have not noticed any problems. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[NetLabel]: Verify sensitivity level has a valid CIPSO mappingPaul Moore
The current CIPSO engine has a problem where it does not verify that the given sensitivity level has a valid CIPSO mapping when the "std" CIPSO DOI type is used. The end result is that bad packets are sent on the wire which should have never been sent in the first place. This patch corrects this problem by verifying the sensitivity level mapping similar to what is done with the category mapping. This patch also changes the returned error code in this case to -EPERM to better match what the category mapping verification code returns. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02NetLabel: add the ranged tag to the CIPSOv4 protocolPaul Moore
Add support for the ranged tag (tag type #5) to the CIPSOv4 protocol. The ranged tag allows for seven, or eight if zero is the lowest category, category ranges to be specified in a CIPSO option. Each range is specified by two unsigned 16 bit fields, each with a maximum value of 65534. The two values specify the start and end of the category range; if the start of the category range is zero then it is omitted. See Documentation/netlabel/draft-ietf-cipso-ipsecurity-01.txt for more details. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: add the enumerated tag to the CIPSOv4 protocolPaul Moore
Add support for the enumerated tag (tag type #2) to the CIPSOv4 protocol. The enumerated tag allows for 15 categories to be specified in a CIPSO option, where each category is an unsigned 16 bit field with a maximum value of 65534. See Documentation/netlabel/draft-ietf-cipso-ipsecurity-01.txt for more details. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: convert to an extensibile/sparse category bitmapPaul Moore
The original NetLabel category bitmap was a straight char bitmap which worked fine for the initial release as it only supported 240 bits due to limitations in the CIPSO restricted bitmap tag (tag type 0x01). This patch converts that straight char bitmap into an extensibile/sparse bitmap in order to lay the foundation for other CIPSO tag types and protocols. This patch also has a nice side effect in that all of the security attributes passed by NetLabel into the LSM are now in a format which is in the host's native byte/bit ordering which makes the LSM specific code much simpler; look at the changes in security/selinux/ss/ebitmap.c as an example. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02[CIPSO]: Missing annotation in cipso_ipv4 update.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02NetLabel: use cipso_v4_doi_search() for local CIPSOv4 functionsPaul Moore
The cipso_v4_doi_search() function behaves the same as cipso_v4_doi_getdef() but is a local, static function so use it whenever possibile in the CIPSOv4 code base. Signed-of-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: return the correct error for translated CIPSOv4 tagsPaul Moore
The CIPSOv4 translated tag #1 mapping does not always return the correct error code if the desired mapping does not exist; instead of returning -EPERM it returns -ENOSPC indicating that the buffer is not large enough to hold the translated value. This was caused by failing to check a specific error condition. This patch fixes this so that unknown mappings return -EPERM which is consistent with the rest of the related CIPSOv4 code. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: fixup the handling of CIPSOv4 tags to allow for multiple tag typesPaul Moore
While the original CIPSOv4 code had provisions for multiple tag types the implementation was not as great as it could be, pushing a lot of non-tag specific processing into the tag specific code blocks. This patch fixes that issue making it easier to support multiple tag types in the future. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: add tag verification when adding new CIPSOv4 DOI definitionsPaul Moore
Currently the CIPSOv4 engine does not do any sort of checking when a new DOI definition is added. The tags are still verified but only as a side effect of normal NetLabel operation (packet processing, socket labeling, etc.) which would cause application errors due to the faulty configuration. This patch adds tag checking when new DOI definition are added allowing us to catch these configuration problems when they happen. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: check for a CIPSOv4 option before we do call into the CIPSOv4 layerPaul Moore
Right now the NetLabel code always jumps into the CIPSOv4 layer to determine if a CIPSO IP option is present. However, we can do this check directly in the NetLabel code by making use of the CIPSO_V4_OPTEXIST() macro which should save us a function call in the common case of not having a CIPSOv4 option present. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: make netlbl_lsm_secattr struct easier/quicker to understandPaul Moore
The existing netlbl_lsm_secattr struct required the LSM to check all of the fields to determine if any security attributes were present resulting in a lot of work in the common case of no attributes. This patch adds a 'flags' field which is used to indicate which attributes are present in the structure; this should allow the LSM to do a quick comparison to determine if the structure holds any security attributes. Example: if (netlbl_lsm_secattr->flags) /* security attributes present */ else /* NO security attributes present */ Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02[NETLABEL]: Use kmemdup in cipso_ipv4.cArnaldo Carvalho de Melo
Code diff stats: [acme@newtoy net-2.6.20]$ codiff /tmp/cipso_ipv4.o.before /tmp/cipso_ipv4.o.after /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv4/cipso_ipv4.c: cipso_v4_cache_add | -46 1 function changed, 46 bytes removed [acme@newtoy net-2.6.20]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[IPV6]: Assorted trivial endianness annotations.Al Viro
2006-10-30[NetLabel]: protect the CIPSOv4 socket option from setsockopt()Paul Moore
This patch makes two changes to protect applications from either removing or tampering with the CIPSOv4 IP option on a socket. The first is the requirement that applications have the CAP_NET_RAW capability to set an IPOPT_CIPSO option on a socket; this prevents untrusted applications from setting their own CIPSOv4 security attributes on the packets they send. The second change is to SELinux and it prevents applications from setting any IPv4 options when there is an IPOPT_CIPSO option already present on the socket; this prevents applications from removing CIPSOv4 security attributes from the packets they send. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15NetLabel: the CIPSOv4 passthrough mapping does not pass categories correctlyPaul Moore
The CIPSO passthrough mapping had a problem when sending categories which would cause no or incorrect categories to be sent on the wire with a packet. This patch fixes the problem which was a simple off-by-one bug. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-15NetLabel: only deref the CIPSOv4 standard map fields when using standard mappingPaul Moore
Fix several places in the CIPSO code where it was dereferencing fields which did not have valid pointers by moving those pointer dereferences into code blocks where the pointers are valid. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-11NetLabel: fix a cache race conditionpaul.moore@hp.com
Testing revealed a problem with the NetLabel cache where a cached entry could be freed while in use by the LSM layer causing an oops and other problems. This patch fixes that problem by introducing a reference counter to the cache entry so that it is only freed when it is no longer in use. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-09-29[NetLabel]: audit fixups due to delayed feedbackPaul Moore
Fix some issues Steve Grubb had with the way NetLabel was using the audit subsystem. This should make NetLabel more consistent with other kernel generated audit messages specifying configuration changes. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NetLabel]: add audit support for configuration changesPaul Moore
This patch adds audit support to NetLabel, including six new audit message types shown below. #define AUDIT_MAC_UNLBL_ACCEPT 1406 #define AUDIT_MAC_UNLBL_DENY 1407 #define AUDIT_MAC_CIPSOV4_ADD 1408 #define AUDIT_MAC_CIPSOV4_DEL 1409 #define AUDIT_MAC_MAP_ADD 1410 #define AUDIT_MAC_MAP_DEL 1411 Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: rework the Netlink attribute handling (part 1)Paul Moore
At the suggestion of Thomas Graf, rewrite NetLabel's use of Netlink attributes to better follow the common Netlink attribute usage. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: make the CIPSOv4 cache spinlocks bottom half safePaul Moore
The CIPSOv4 cache traversal routines are triggered both the userspace events (cache invalidation due to DOI removal or updated SELinux policy) and network packet processing events. As a result there is a problem with the existing CIPSOv4 cache spinlocks as they are not bottom-half/softirq safe. This patch converts the CIPSOv4 cache spin_[un]lock() calls into spin_[un]lock_bh() calls to address this problem. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: correct improper handling of non-NetLabel peer contextsPaul Moore
Fix a problem where NetLabel would always set the value of sk_security_struct->peer_sid in selinux_netlbl_sock_graft() to the context of the socket, causing problems when users would query the context of the connection. This patch fixes this so that the value in sk_security_struct->peer_sid is only set when the connection is NetLabel based, otherwise the value is untouched. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Make code static.Adrian Bunk
This patch makes needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
