commit 06c4648d46d1b757d6b9591a86810be79818b60c upstream.
Currently such notifications are only generated when the device comes up or the
address changes. However one use case for these notifications is to enable
faster network recovery after a virtual machine migration (by causing switches
to relearn their MAC tables). A migration appears to the network stack as a
temporary loss of carrier and therefore does not trigger either of the current
conditions. Rather than adding carrier up as a trigger (which can cause issues
when interfaces a flapping) simply add an interface which the driver can use
to explicitly trigger the notification.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: netdev@vger.kernel.org
[ Upstream commit 88af182e389097997c5e2a0b42285b3522796759 ]
Yuck. It turns out that when we restart sysctls we were restarting
with the values already changed. Which unfortunately meant that
the second time through we thought there was no change and skipped
all kinds of work, despite the fact that there was indeed a change.
I have fixed this the simplest way possible by restoring the changed
values when we restart the sysctl write.
One of my coworkers spotted this bug when after disabling forwarding
on an interface pings were still forwarded.
[ Upstream commit 28f6aeea3f12d37bd258b2c0d5ba891bff4ec479 ]
when using policy routing and the skb mark:
there are cases where a back path validation requires us
to use a different routing table for src ip validation than
the one used for mapping ingress dst ip.
One such a case is transparent proxying where we pretend to be
the destination system and therefore the local table
is used for incoming packets but possibly a main table would
be used on outbound.
Make the default behavior to allow the above and if users
need to turn on the symmetry via sysctl src_valid_mark
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
This fixes a bug with arp_notify.
If arp_notify is enabled, kernel will crash if address is changed
and no IP address is assigned.
http://bugzilla.kernel.org/show_bug.cgi?id=14330
Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
This patch fixes commit e36b9d16c6a6d0f59803b3ef04ff3c22c3844c10. The approach
there is to call dev_close()/dev_open() whenever the device type is changed in
order to remap the device IP multicast addresses to HW multicast addresses.
This approach suffers from 2 drawbacks:
*. It assumes tha the device is UP when calling dev_close(), or otherwise
dev_close() has no affect. It is worth to mention that initscripts (Redhat)
and sysconfig (Suse) doesn't act the same in this matter.
*. dev_close() has other side affects, like deleting entries from the routing
table, which might be unnecessary.
The fix here is to directly remap the IP multicast addresses to HW multicast
addresses for a bonding device that changes its type, and nothing else.
Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Moni Shoua <monis@voltaire.com>
sysctls are unregistered with the rntl_lock held making
it unsafe to unconditionally grab the the rtnl_lock. Instead
we need to call rtnl_trylock and restart the system call
if we can not grab it. Otherwise we could deadlock at unregistration
time.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
This patch changes the return value of nlmsg_notify() as follows:
If NETLINK_BROADCAST_ERROR is set by any of the listeners and
an error in the delivery happened, return the broadcast error;
else if there are no listeners apart from the socket that
requested a change with the echo flag, return the result of the
unicast notification. Thus, with this patch, the unicast
notification is handled in the same way of a broadcast listener
that has set the NETLINK_BROADCAST_ERROR socket flag.
This patch is useful in case that the caller of nlmsg_notify()
wants to know the result of the delivery of a netlink notification
(including the broadcast delivery) and take any action in case
that the delivery failed. For example, ctnetlink can drop packets
if the event delivery failed to provide reliable logging and
state-synchronization at the cost of dropping packets.
This patch also modifies the rtnetlink code to ignore the return
value of rtnl_notify() in all callers. The function rtnl_notify()
(before this patch) returned the error of the unicast notification
which makes rtnl_set_sk_err() reports errors to all listeners. This
is not of any help since the origin of the change (the socket that
requested the echoing) notices the ENOBUFS error if the notification
fails and should resync itself.
Acked-by: Patrick McHardy <kaber@trash.net>
This adds another inet device option to enable gratuitous ARP
when device is brought up or address change. This is handy for
clusters or virtualization.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Jianjun Kong <jianjun@zeuux.org>
call_rcu() will unconditionally rewrite RCU head anyway.
Applies to
struct neigh_parms
struct neigh_table
struct net
struct cipso_v4_doi
struct in_ifaddr
struct in_device
rt->u.dst
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)
ipv4: Add a missing rcu_assign_pointer() in routing cache.
[netdrvr] ibmtr: PCMCIA IBMTR is ok on 64bit
xen-netfront: Avoid unaligned accesses to IP header
lmc: copy_*_user under spinlock
[netdrvr] myri10ge, ixgbe: remove broken select INTEL_IOATDMA
Some code here depends on CONFIG_KMOD to not try to load
protocol modules or similar, replace by CONFIG_MODULES
where more than just request_module depends on CONFIG_KMOD
and and also use try_then_request_module in ebtables.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
name and nlen parameters passed to ->strategy hook are unused, remove
them. In general ->strategy hook should know what it's doing, and don't
do something tricky for which, say, pointer to original userspace array
may be needed (name).
Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ]
Cc: Matt Mackall <mpm@selenic.com>
Re-enable IP when the MTU gets back to a valid size.
This patch just checks if the in_dev is NULL on a NETDEV_CHANGEMTU event
and if MTU is valid (bigger than 68), then re-enable in_dev.
Also a function that checks valid MTU size was created.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Removes legacy reinvent-the-wheel type thing. The generic
machinery integrates much better to automated debugging aids
such as kerneloops.org (and others), and is unambiguous due to
better naming. Non-intuively BUG_TRAP() is actually equal to
WARN_ON() rather than BUG_ON() though some might actually be
promoted to BUG_ON() but I left that to future.
I could make at least one BUILD_BUG_ON conversion.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Signed-off-by: Denis V. Lunev <den@openvz.org>
Large Receive Offload (LRO) is only appropriate for packets that are
destined for the host, and should be disabled if received packets may be
forwarded. It can also confuse the GSO on output.
Add dev_disable_lro() function which uses the appropriate ethtool ops to
disable LRO if enabled.
Add calls to dev_disable_lro() in br_add_if() and functions that enable
IPv4 and IPv6 forwarding.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Makes people happy who try to keep a list of addresses up to date by
listening to notifications.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
The field was supposed to allow the creation of an anycast route by
assigning an anycast address to an address prefix. It was never
implemented so this field is unused and serves no purpose. Remove it.
Introduce per-sock inlines: sock_net(), sock_net_set()
and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Introduce per-net_device inlines: dev_net(), dev_net_set().
The context is available from a network device passed in.
Add namespace parameter to devinet_ioctl and locate device inside it for
state changes.
After all these preparations it is time to enable main IPv4 device
initialization routine inside namespace. It is safe do this now.
This bug did bite at least one user, who did have to resort to rebooting
the system after an "ifconfig eth0 127.0.0.1" typo.
Deleting the address and adding a new is a less intrusive workaround.
But I still beleive this is a bug that should be fixed. Some way or
another.
Another possibility would be to remove the scope mangling based on
address. This will always be incomplete (are 127/8 the only address
space with host scope requirements?)
We set the scope to RT_SCOPE_HOST if an IPv4 interface is configured
with a loopback address (127/8). The scope is never reset, and will
remain set to RT_SCOPE_HOST after changing the address. This patch
resets the scope if the address is changed again, to restore normal
functionality.
Signed-off-by: Bjorn Mork <bjorn@mork.no>
The namespace is available when required except rtm_to_ifaddr. Add
namespace argument to it.
Remove error code assignment inside brackets on failure. The code
looks better if the error is assigned before condition check. Also,
the compiler treats this better.
struct ipv4_devconf can now become static.
Acked-by: Pavel Emelyanov <xemul@openvz.org>
inet_confirm_addr can be called with NULL in_dev from arp_ignore iff
scope is RT_SCOPE_LINK.
Lets always pass the device and check for RT_SCOPE_LINK scope inside
inet_confirm_addr. This let us take network namespace from in_device a
need for an additional argument.
arp_ignore has two arguments: dev & in_dev. dev is used for
inet_confirm_addr calling only.
inet_confirm_addr, in turn, either gets in_dev from the device passed
or iterates over all network devices if the device passed is NULL. It
seems logical to directly pass in_dev into inet_confirm_addr.
Previous NETNS patches broke CONFIG_SYSCTL=n case
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
These are scattered over the code, but almost all the
"critical" places already have the proper struct net
at hand except for snmp proc showing function and routing
rtnl handler.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
They are all collected in the net/ipv4/devinet.c file and
mostly use the IPV4_DEVCONF_DFLT macro.
So I add the net parameter to it and patch users accordingly.
This is the core.
Add all and default pointers on the netns_ipv4 and register
a new pernet subsys to initialize them.
Also add the ctl_table_header to register the
net.ipv4.ip_forward ctl.
I don't allocate additional memory for init_net, but use
global devinets.
Some handers and strategies of devinet sysctl tables need
to know the net to propagate the ctl change to all the
net devices.
I use the (currently unused) extra2 pointer on the tables
to get it.
Holding the reference on the struct net is not possible,
because otherwise we'll get a net->ctl_table->net circular
dependency. But since the ctl tables are unregistered during
the net destruction, this is safe to get it w/o additional
protection.
Currently, this function is void, so failures in creating
sysctls for new/renamed devices are not reported to anywhere.
Fixing this is another complex (needed?) task, but this
return value is needed during the namespaces creation to
handle the case, when we failed to create "all" and "default"
entries.
This includes:
* moving neigh_sysctl_(un)register calls inside
devinet_sysctl_(un)register ones, as they are always
called in pairs;
* making __devinet_sysctl_unregister() to unregister
the ipv4_devconf struct, while original devinet_sysctl_unregister()
works with the in_device to handle both - devconf and
neigh sysctls;
* make stubs for CONFIG_SYSCTL=n case to get rid of
in-code ifdefs.
AFAIS these two entries should do the same thing - change the
forwarding state on ipv4_devconf and on all the devices.
I propose to merge the handlers together using ctl paths.
The inet_forward_change() is static after this and I move
it higher to be closer to other "propagation" helpers and
to avoid diff making patches based on { and } matching :)
i.e. - make them easier to read.
This looks very much like the patch for neighbors.
The path is also located on the stack and is prepared
inside the function. This time, the call to the registering
function is guarded with the RTNL lock, but I decided
to keep it on the stack not to litter the devinet.c file
with unneeded names and to make it look similar to the
neighbors code.
This is also intended to help us with the net namespaces
and saves the vmlinux size as well - this time by more
than 670 bytes.
The difference from the first version is just the patch
offsets, that changed due to changes in the patch #2.
Currently this call is used to register sysctls for devices
and for the "default" confs. The "all" sysctls are registered
separately.
Besides, the inet_device is passed to this function, but it is
not needed there at all - just the device name and ifindex are
required.
Thanks to Herbert, who noticed, that this call doesn't even
require the devconf pointer (the last argument) - all we need
we can take from the in_device itself.
The fix is to make a __devinet_sysctl_register(), which registers
sysctls for all "devices" we need, including "default" and "all" :)
The original devinet_sysctl_register() works with struct net_device,
not the inet_device, and calls the introduced function, passing
the device name and ifindex (to be used as procname and ctl_name)
into it.
I moved the call to kmalloc() from the *t declaration into
the code (this is confusing when a variable is initialized
with the result of some call) and removed unneeded comment
near the error path. Just like I did with the neigh ctl-s.
Besides, I fixed the goto's and the labels - they were indented
with spaces :(
After this patch none of the netlink callback support anything
except the initial network namespace but the rtnetlink infrastructure
now handles multiple network namespaces.
Changes from v2:
- IPv6 addrlabel processing
Changes from v1:
- no need for special rtnl_unlock handling
- fixed IPv6 ndisc
Before I can enable rtnetlink to work in all network namespaces I need
to be certain that something won't break. So this patch deliberately
disables all of the rtnletlink methods in everything except the
initial network namespace. After the methods have been audited this
extra check can be disabled.
Changes from v1:
- added IPv6 addrlabel protection
When re-naming an interface, the previous secondary address
labels get lost e.g.
$> brctl addbr foo
$> ip addr add 192.168.0.1 dev foo
$> ip addr add 192.168.0.2 dev foo label foo:00
$> ip addr show dev foo | grep inet
inet 192.168.0.1/32 scope global foo
inet 192.168.0.2/32 scope global foo:00
$> ip link set foo name bar
$> ip addr show dev bar | grep inet
inet 192.168.0.1/32 scope global bar
inet 192.168.0.2/32 scope global bar:2
Turns out to be a simple thinko in inetdev_changename() - clearly we
want to look at the address label, rather than the device name, for
a suffix to retain.
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
According to Herbert, the ipv4_devconf_setall should be called
only when the ifa is added to the device. However, failed
ifa allocation may bring things into inconsistent state.
Move the call to ipv4_devconf_setall after the ifa allocation.
Fits both net-2.6 (with offsets) and net-2.6.25 (cleanly).
