path: root/net/ipv4/gre.c
2012-03-12net: ipv4: Standardize prefixes for message loggingJoe Perches
Add #define pr_fmt(fmt) as appropriate. Add "IPv4: ", "TCP: ", and "IPsec: " to appropriate files. Standardize on "UDPLite: " for appropriate uses. Some prefixes were previously "UDPLITE: " and "UDP-Lite: ". Add KBUILD_MODNAME ": " to icmp and gre. Remove embedded prefixes as appropriate. Add missing "\n" to pr_info in gre.c. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-23gre: fix improper error handlingxeb@mail.ru
Fix improper protocol err_handler, current implementation is fully unapplicable and may cause kernel crash due to double kfree_skb. Signed-off-by: Dmitry Kozlov <xeb@mail.ru> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21Remove redundant linux/version.h includes from net/Jesper Juhl
It was suggested by "make versioncheck" that the follwing includes of linux/version.h are redundant: /home/jj/src/linux-2.6/net/caif/caif_dev.c: 14 linux/version.h not needed. /home/jj/src/linux-2.6/net/caif/chnl_net.c: 10 linux/version.h not needed. /home/jj/src/linux-2.6/net/ipv4/gre.c: 19 linux/version.h not needed. /home/jj/src/linux-2.6/net/netfilter/ipset/ip_set_core.c: 20 linux/version.h not needed. /home/jj/src/linux-2.6/net/netfilter/xt_set.c: 16 linux/version.h not needed. and it seems that it is right. Beyond manually inspecting the source files I also did a few build tests with various configs to confirm that including the header in those files is indeed not needed. Here's a patch to remove the pointless includes. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-25tunnels: add _rcu annotationsEric Dumazet
(struct ip6_tnl)->next is rcu protected : (struct ip_tunnel)->next is rcu protected : (struct xfrm6_tunnel)->next is rcu protected : add __rcu annotation and proper rcu primitives. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03gre: protocol table can be staticstephen hemminger
This table is only used in gre.c Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-21PPTP: PPP over IPv4 (Point-to-Point Tunneling Protocol)Dmitry Kozlov
PPP: introduce "pptp" module which implements point-to-point tunneling protocol using pppox framework NET: introduce the "gre" module for demultiplexing GRE packets on version criteria (required to pptp and ip_gre may coexists) NET: ip_gre: update to use the "gre" module This patch introduces then pptp support to the linux kernel which dramatically speeds up pptp vpn connections and decreases cpu usage in comparison of existing user-space implementation (poptop/pptpclient). There is accel-pptp project (https://sourceforge.net/projects/accel-pptp/) to utilize this module, it contains plugin for pppd to use pptp in client-mode and modified pptpd (poptop) to build high-performance pptp NAS. There was many changes from initial submitted patch, most important are: 1. using rcu instead of read-write locks 2. using static bitmap instead of dynamically allocated 3. using vmalloc for memory allocation instead of BITS_PER_LONG + __get_free_pages 4. fixed many coding style issues Thanks to Eric Dumazet. Signed-off-by: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
