[ Upstream commit e05c4ad3ed874ee4f5e2c969e55d318ec654332c ]
Should check use count of include mode filter instead of total number
of include mode filters.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
[ Upstream commit a1889c0d2039a53ae04abb9f20c62500bd312bf3 ]
Convert array index from the loop bound to the loop index.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression e1,e2,ar;
for(e1 = 0; e1 < e2; e1++) { <...
ar[
- e2
+ e1
// </smpl>
In igmp_group_dropped() we call ip_mc_clear_src(), which resets the number
of source filters per mulitcast. However, igmp_group_dropped() is also
called on NETDEV_DOWN, NETDEV_PRE_TYPE_CHANGE and NETDEV_UNREGISTER, which
means that the group might get added back on NETDEV_UP, NETDEV_REGISTER and
NETDEV_POST_TYPE_CHANGE respectively, leaving us with broken source
filters.
To fix that, we must clear the source filters only when there are no users
in the ip_mc_list, i.e. in ip_mc_dec_group() and on device destroy.
Acked-by: David L Stevens <dlstevens@us.ibm.com>
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
The rcu callback ip_mc_socklist_reclaim() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ip_mc_socklist_reclaim).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback ip_sf_socklist_reclaim() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ip_sf_socklist_reclaim).
The rcu callback ip_mc_list_reclaim() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ip_mc_list_reclaim).
Instead of rt->rt_{src,dst}
Output route resolution never returns a route with rt_src set to zero
(which is INADDR_ANY).
Even if the flow key for the output route lookup specifies INADDR_ANY
for the source address, the output route resolution chooses a real
source address to use in the final route.
This test has existed forever in igmp_send_report() and David Stevens
simply copied over the erroneous test when implementing support for
IGMPv3.
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
The idea here is this minimizes the number of places one has to edit
in order to make changes to how flows are defined and used.
All callers are under rcu_read_lock() protection already.
Rename to ip_check_mc_rcu() to make it even more clear.
Instead of on the stack.
IGMP allocates MTU sized skbs. This may fail for large MTU (order-2
allocations), so add a fallback to try lower sizes.
Instead of iterating in_dev->mc_list from bonding driver, its better
to call a helper function provided by igmp.c
Details of implementation (locking) are private to igmp code.
ip_mc_rejoin_group(struct ip_mc_list *im) becomes
ip_mc_rejoin_groups(struct in_device *in_dev);
Use the macros defined for the members of flowi to clean the code up.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
net/ipv4/igmp.c: In function 'ip_mc_inc_group':
net/ipv4/igmp.c:1228: error: implicit declaration of function 'for_each_pmc_rtnl'
net/ipv4/igmp.c:1228: error: expected ';' before '{' token
net/ipv4/igmp.c: In function 'ip_mc_unmap':
net/ipv4/igmp.c:1333: error: expected ';' before 'igmp_group_dropped'
Move for_each_pmc_rcu and for_each_pmc_rtnl macro definitions
outside of multicast ifdef protection.
in_dev->mc_list is protected by one rwlock (in_dev->mc_list_lock).
This can easily be converted to a RCU protection.
Writers hold RTNL, so mc_list_lock is removed, not replaced by a
spinlock.
Cc: Cypher Wu <cypher.w@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
When we test rt->fl.iif against zero, we're seeing if it's
an output or an input route.
Make that explicit with some helper functions.
commit 8723e1b4ad9be4444 (inet: RCU changes in inetdev_by_index())
forgot one call site in ip_mc_drop_socket()
We should not decrease idev refcount after inetdev_by_index() call,
since refcount is not increased anymore.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Reported-by: Miles Lane <miles.lane@gmail.com>
Convert inetdev_by_index() to not increment in_dev refcount.
Callers hold RCU or RTNL, and should not decrement in_dev refcount.
We hold RTNL in ip_mc_find_dev(), no need to touch device refcount.
The IGMP specs states that if the system receives a
membership report, it shouldn't send another for the
next minute. However, if a link failure happens right
after that, the backup slave and the switch connected
to this slave will not know about the multicast and
the traffic will hang for about a minute.
This patch fixes it to rejoin multicast groups immediately
after a failover restoring the multicast traffic.
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
A recent patch to allow IGMPv2 responses to IGMPv3 queries
bypasses length checks for valid query lengths, incorrectly
resets the v2_seen timer, and does not support IGMPv1.
The following patch responds with a v2 report as required
by IGMPv2 while correcting the other problems introduced
by the patch.
Signed-Off-By: David L Stevens <dlstevens@us.ibm.com>
After all these years, it turns out that the
/proc/sys/net/ipv4/conf/*/force_igmp_version
parameter isn't fully implemented.
*Symptom*:
When set force_igmp_version to a value of 2, the kernel should only perform
multicast IGMPv2 operations (IETF rfc2236). An host-initiated Join message
will be sent as a IGMPv2 Join message. But if a IGMPv3 query message is
received, the host responds with a IGMPv3 join message. Per rfc3376 and
rfc2236, a IGMPv2 host should treat a IGMPv3 query as a IGMPv2 query and
respond with an IGMPv2 Join message.
*Consequences*:
This is an issue when a IGMPv3 capable switch is the querier and will only
issue IGMPv3 queries (which double as IGMPv2 querys) and there's an
intermediate switch that is only IGMPv2 capable. The intermediate switch
processes the initial v2 Join, but fails to recognize the IGMPv3 Join responses
to the Query, resulting in a dropped connection when the intermediate v2-only
switch times it out.
*Identifying issue in the kernel source*:
The issue is in this section of code (in net/ipv4/igmp.c), which is called when
an IGMP query is received (from mainline 2.6.36-rc3 gitweb):
A IGMPv3 query has a length >= 12 and no sources. This routine will exit after
line 880, setting the general query timer (random timeout between 0 and query
response time). This calls igmp_gq_timer_expire():
.. which only sends a v3 response. So if a v3 query is received, the kernel
always sends a v3 response.
IGMP queries happen once every 60 sec (per vlan), so the traffic is low. A
IGMPv3 query *is* a strict superset of a IGMPv2 query, so this patch properly
short circuit's the v3 behaviour.
One issue is that this does not address force_igmp_version=1. Then again, I've
never seen any IGMPv1 multicast equipment in the wild. However there is a lot
of v2-only equipment. If it's necessary to support the IGMPv1 case as well:
837 if (len == 8 || IGMP_V2_SEEN(in_dev) || IGMP_V1_SEEN(in_dev)) {
CodingStyle cleanups
EXPORT_SYMBOL should immediately follow the symbol declaration.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
in_dev_get() -> __in_dev_get_rcu() in a rcu protected function.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
net/mac80211/rate.c
Currently we treat IGMPv3 reports as if it were an IGMPv2/v1 report.
This is broken as IGMPv3 reports are formatted differently. So we
end up suppressing a bogus multicast group (which should be harmless
as long as the leading reserved field is zero).
In fact, IGMPv3 does not allow membership report suppression so
we should simply ignore IGMPv3 membership reports as a host.
This patch does exactly that. I kept the case statement for it
so people won't accidentally add it back thinking that we overlooked
this case.
Almost all igmp functions accessing inet->mc_list are protected by
rtnl_lock(), but there is one exception which is ip_mc_sf_allow(),
so there is a chance of either ip_mc_drop_socket or ip_mc_leave_group
remove an entry while ip_mc_sf_allow is running causing a crash.
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
We need to use next_det_device_rcu() in RCU protected section.
We also can avoid in_dev_get()/in_dev_put() overhead (code size mainly)
in rcu_read_lock() sections.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
This also needs to be optimized for large number of devices.
This patch fixes commit e36b9d16c6a6d0f59803b3ef04ff3c22c3844c10. The approach
there is to call dev_close()/dev_open() whenever the device type is changed in
order to remap the device IP multicast addresses to HW multicast addresses.
This approach suffers from 2 drawbacks:
*. It assumes tha the device is UP when calling dev_close(), or otherwise
dev_close() has no affect. It is worth to mention that initscripts (Redhat)
and sysconfig (Suse) doesn't act the same in this matter.
*. dev_close() has other side affects, like deleting entries from the routing
table, which might be unnecessary.
The fix here is to directly remap the IP multicast addresses to HW multicast
addresses for a bonding device that changes its type, and nothing else.
Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Moni Shoua <monis@voltaire.com>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb
Delete skb->rtable field
Setting rtable is not allowed, just set dst instead as rtable is an alias.
After some discussion offline with Christoph Lameter and David Stevens
regarding multicast behaviour in Linux, I'm submitting a slightly
modified patch from the one Christoph submitted earlier.
This patch provides a new socket option IP_MULTICAST_ALL.
In this case, default behaviour is _unchanged_ from the current
Linux standard. The socket option is set by default to provide
original behaviour. Sockets wishing to receive data only from
multicast groups they join explicitly will need to clear this
socket option.
Signed-off-by: Nivedita Singhvi <niv@us.ibm.com>
Signed-off-by: Christoph Lameter<cl@linux.com>
Acked-by: David Stevens <dlstevens@us.ibm.com>
This patch makes the followinf proc entries per-netns:
/proc/net/igmp
/proc/net/mcfilter
Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Acked-by: Benjamin Thery <benjamin.thery@bull.net>
Signed-off-by: Jianjun Kong <jianjun@zeuux.org>
Clean up the various different email addresses of mine listed in the code
to a single current and valid address. As Dave says his network merges
for 2.6.28 are now done this seems a good point to send them in where
they won't risk disrupting real changes.
Signed-off-by: Alan Cox <alan@redhat.com>
This patch add mc_count to struct in_device and updates
increment/decrement/initilaize of this field in IPv4 and in IPv6.
- Also printing the vfs /proc entry (/proc/net/igmp) is adjusted to
use the new mc_count.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
This patch makes the multicast socket to be per namespace.
When a network namespace is created, other than the init_net and a
multicast packet is received, the kernel goes to a hang or a kernel panic.
How to reproduce ?
* create a child network namespace
* create a pair virtual device veth
* ip link add type veth
* move one side to the pair network device to the child namespace
* ip link set netns <childpid> dev veth1
* ping -I veth0 224.0.0.1
The bug appears because the function ip_mc_init_dev does not initialize
the different multicast fields as it exits because it is not the init_net.
BUG: soft lockup - CPU#0 stuck for 61s! [avahi-daemon:2695]
Modules linked in:
irq event stamp: 50350
hardirqs last enabled at (50349): [<c03ee949>] _spin_unlock_irqrestore+0x34/0x39
hardirqs last disabled at (50350): [<c03ec639>] schedule+0x9f/0x5ff
softirqs last enabled at (45712): [<c0374d4b>] ip_setsockopt+0x8e7/0x909
softirqs last disabled at (45710): [<c03ee682>] _spin_lock_bh+0x8/0x27
Pid: 2695, comm: avahi-daemon Not tainted (2.6.27-rc2-00029-g0872073 #3)
EIP: 0060:[<c03ee47c>] EFLAGS: 00000297 CPU: 0
EIP is at __read_lock_failed+0x8/0x10
EAX: c4f38810 EBX: c4f38810 ECX: 00000000 EDX: c04cc22e
ESI: fb0000e0 EDI: 00000011 EBP: 0f02000a ESP: c4e3faa0
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
CR0: 8005003b CR2: 44618a40 CR3: 04e37000 CR4: 000006d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
[<c02311f8>] ? _raw_read_lock+0x23/0x25
[<c0390666>] ? ip_check_mc+0x1c/0x83
[<c036d478>] ? ip_route_input+0x229/0xe92
[<c022e2e4>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c0104c9c>] ? do_IRQ+0x69/0x7d
[<c0102e64>] ? restore_nocheck_notrace+0x0/0xe
[<c036fdba>] ? ip_rcv+0x227/0x505
[<c0358764>] ? netif_receive_skb+0xfe/0x2b3
[<c03588d2>] ? netif_receive_skb+0x26c/0x2b3
[<c035af31>] ? process_backlog+0x73/0xbd
[<c035a8cd>] ? net_rx_action+0xc1/0x1ae
[<c01218a8>] ? __do_softirq+0x7b/0xef
[<c0121953>] ? do_softirq+0x37/0x4d
[<c035b50d>] ? dev_queue_xmit+0x3d4/0x40b
[<c0122037>] ? local_bh_enable+0x96/0xab
[<c012181e>] ? _local_bh_enable+0x79/0x88
[<c035fcb8>] ? neigh_resolve_output+0x20f/0x239
[<c0373118>] ? ip_finish_output+0x1df/0x209
[<c0373364>] ? ip_dev_loopback_xmit+0x62/0x66
[<c0371db5>] ? ip_local_out+0x15/0x17
[<c0372013>] ? ip_push_pending_frames+0x25c/0x2bb
[<c03891b8>] ? udp_push_pending_frames+0x2bb/0x30e
[<c038a189>] ? udp_sendmsg+0x413/0x51d
[<c038a1a9>] ? udp_sendmsg+0x433/0x51d
[<c038f927>] ? inet_sendmsg+0x35/0x3f
[<c034f092>] ? sock_sendmsg+0xb8/0xd1
[<c012d554>] ? autoremove_wake_function+0x0/0x2b
[<c022e6de>] ? copy_from_user+0x32/0x5e
[<c034f238>] ? sys_sendmsg+0x18d/0x1f0
[<c0175e90>] ? pipe_write+0x3cb/0x3d7
[<c0170347>] ? do_sync_write+0xbe/0x105
[<c03503b2>] ? sys_socketcall+0x176/0x1b0
[<c01085ea>] ? syscall_trace_enter+0x6c/0x7b
[<c0102e1a>] ? syscall_call+0x7/0xb
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
