path: root/net/ipv4/inet_connection_sock.c
2011-05-24seqlock: Get rid of SEQLOCK_UNLOCKEDEric Dumazet
All static seqlock should be initialized with the lockdep friendly __SEQLOCK_UNLOCKED() macro. Remove legacy SEQLOCK_UNLOCKED() macro. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/%3C1306238888.3026.31.camel%40edumazet-laptop%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-18ipv4: Make caller provide flowi4 key to inet_csk_route_req().David S. Miller
This way the caller can get at the fully resolved fl4->{daddr,saddr} etc. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ipv4: Create inet_csk_route_child_sock().David S. Miller
This is just like inet_csk_route_req() except that it operates after we've created the new child socket. In this way we can use the new socket's cork flow for proper route key storage. This will be used by DCCP and TCP child socket creation handling. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28ipv4: Get route daddr from flow key in inet_csk_route_req().David S. Miller
Now that output route lookups update the flow with destination address selection, we can fetch it from fl4->daddr instead of rt->rt_dst Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28inet: add RCU protection to inet->optEric Dumazet
We lack proper synchronization to manipulate inet->opt ip_options Problem is ip_make_skb() calls ip_setup_cork() and ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options), without any protection against another thread manipulating inet->opt. Another thread can change inet->opt pointer and free old one under us. Use RCU to protect inet->opt (changed to inet->inet_opt). Instead of handling atomic refcounts, just copy ip_options when necessary, to avoid cache line dirtying. We cant insert an rcu_head in struct ip_options since its included in skb->cb[], so this patch is large because I had to introduce a new ip_options_rcu structure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_ethtool.c
2011-04-13Revert "tcp: disallow bind() to reuse addr/port"David S. Miller
This reverts commit c191a836a908d1dd6b40c503741f91b914de3348. It causes known regressions for programs that expect to be able to use SO_REUSEADDR to shutdown a socket, then successfully rebind another socket to the same ID. Programs such as haproxy and amavisd expect this to work. This should fix kernel bugzilla 32832. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-31ipv4: Use flowi4_init_output() in inet_connection_sock.cDavid S. Miller
2011-03-12net: Put fl4_* macros to struct flowi4 and use them again.David S. Miller
2011-03-12ipv4: Use flowi4 in public route lookup interfaces.David S. Miller
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Kill can_sleep arg to ip_route_output_flow()David S. Miller
This boolean state is now available in the flow flags. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Make final arg to ip_route_output_flow to be boolean "can_sleep"David S. Miller
Since that is what the current vague "flags" argument means. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11tcp: disallow bind() to reuse addr/portEric Dumazet
inet_csk_bind_conflict() logic currently disallows a bind() if it finds a friend socket (a socket bound on same address/port) satisfying a set of conditions : 1) Current (to be bound) socket doesnt have sk_reuse set OR 2) other socket doesnt have sk_reuse set OR 3) other socket is in LISTEN state We should add the CLOSE state in the 3) condition, in order to avoid two REUSEADDR sockets in CLOSE state with same local address/port, since this can deny further operations. Note : a prior patch tried to address the problem in a different (and buggy) way. (commit fda48a0d7a8412ced tcp: bind() fix when many ports are bound). Reported-by: Gaspar Chilingarov <gasparch@gmail.com> Reported-by: Daniel Baluta <daniel.baluta@gmail.com> Tested-by: Daniel Baluta <daniel.baluta@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-09net: optimize INET input path furtherEric Dumazet
Followup of commit b178bb3dfc30 (net: reorder struct sock fields) Optimize INET input path a bit further, by : 1) moving sk_refcnt close to sk_lock. This reduces number of dirtied cache lines by one on 64bit arches (and 64 bytes cache line size). 2) moving inet_daddr & inet_rcv_saddr at the beginning of sk (same cache line than hash / family / bound_dev_if / nulls_node) This reduces number of accessed cache lines in lookups by one, and dont increase size of inet and timewait socks. inet and tw sockets now share same place-holder for these fields. Before patch : offsetof(struct sock, sk_refcnt) = 0x10 offsetof(struct sock, sk_lock) = 0x40 offsetof(struct sock, sk_receive_queue) = 0x60 offsetof(struct inet_sock, inet_daddr) = 0x270 offsetof(struct inet_sock, inet_rcv_saddr) = 0x274 After patch : offsetof(struct sock, sk_refcnt) = 0x44 offsetof(struct sock, sk_lock) = 0x48 offsetof(struct sock, sk_receive_queue) = 0x68 offsetof(struct inet_sock, inet_daddr) = 0x0 offsetof(struct inet_sock, inet_rcv_saddr) = 0x4 compute_score() (udp or tcp) now use a single cache line per ignored item, instead of two. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15net: reserve ports for applications using fixed port numbersAmerigo Wang
(Dropped the infiniband part, because Tetsuo modified the related code, I will send a separate patch for it once this is accepted.) This patch introduces /proc/sys/net/ipv4/ip_local_reserved_ports which allows users to reserve ports for third-party applications. The reserved ports will not be used by automatic port assignments (e.g. when calling connect() or bind() with port number 0). Explicit port allocation behavior is unchanged. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-02Merge branch 'master' of ↵David S. Miller
2010-04-28Revert "tcp: bind() fix when many ports are bound"David S. Miller
This reverts two commits: fda48a0d7a8412cedacda46a9c0bf8ef9cd13559 tcp: bind() fix when many ports are bound and a follow-on fix for it: 6443bb1fc2050ca2b6585a3fa77f7833b55329ed ipv6: Fix inet6_csk_bind_conflict() It causes problems with binding listening sockets when time-wait sockets from a previous instance still are alive. It's too late to keep fiddling with this so late in the -rc series, and we'll deal with it in net-next-2.6 instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-22tcp: bind() fix when many ports are boundEric Dumazet
Port autoselection done by kernel only works when number of bound sockets is under a threshold (typically 30000). When this threshold is over, we must check if there is a conflict before exiting first loop in inet_csk_get_port() Change inet_csk_bind_conflict() to forbid two reuse-enabled sockets to bind on same (address,port) tuple (with a non ANY address) Same change for inet6_csk_bind_conflict() Reported-by: Gaspar Chilingarov <gasparch@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17tcp: account SYN-ACK timeouts & retransmissionsOctavian Purdila
Currently we don't increment SYN-ACK timeouts & retransmissions although we do increment the same stats for SYN. We seem to have lost the SYN-ACK accounting with the introduction of tcp_syn_recv_timer (commit 2248761e in the netdev-vger-cvs tree). This patch fixes this issue. In the process we also rename the v4/v6 syn/ack retransmit functions for clarity. We also add a new request_socket operations (syn_ack_timeout) so we can keep code in inet_connection_sock.c protocol agnostic. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1a: add request_values parameter for sending SYNACKWilliam Allen Simpson
Add optional function parameters associated with sending SYNACK. These parameters are not needed after sending SYNACK, and are not used for retransmission. Avoids extending struct tcp_request_sock, and avoids allocating kernel memory. Also affects DCCP as it uses common struct request_sock_ops, but this parameter is currently reserved for future use. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-19tcp: reduce SYN-ACK retrans for TCP_DEFER_ACCEPTJulian Anastasov
Change SYN-ACK retransmitting code for the TCP_DEFER_ACCEPT users to not retransmit SYN-ACKs during the deferring period if ACK from client was received. The goal is to reduce traffic during the deferring period. When the period is finished we continue with sending SYN-ACKs (at least one) but this time any traffic from client will change the request to established socket allowing application to terminate it properly. Also, do not drop acked request if sending of SYN-ACK fails. Signed-off-by: Julian Anastasov <ja@ssi.bg> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: Add sk_mark route lookup support for IPv4 listening socketsAtis Elsts
Add support for route lookup using sk_mark on IPv4 listening sockets. Signed-off-by: Atis Elsts <atis@mikrotik.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: move bsockets outside of read only beginning of struct inet_hashinfoEric Dumazet
And switch bsockets to atomic_t since it might be changed in parallel. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01inet: Fix virt-manager regression due to bind(0) changes.Stephen Hemminger
From: Stephen Hemminger <shemminger@vyatta.com> Fix regression introduced by a9d8f9110d7e953c2f2b521087a4179677843c2a ("inet: Allowing more than 64k connections and heavily optimize bind(0) time.") Based upon initial patches and feedback from Evegniy Polyakov and Eric Dumazet. From Eric Dumazet: -------------------- Also there might be a problem at line 175 if (sk->sk_reuse && sk->sk_state != TCP_LISTEN && --attempts >= 0) { spin_unlock(&head->lock); goto again; If we entered inet_csk_get_port() with a non null snum, we can "goto again" while it was not expected. -------------------- Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21inet: Allowing more than 64k connections and heavily optimize bind(0) time.Evgeniy Polyakov
With simple extension to the binding mechanism, which allows to bind more than 64k sockets (or smaller amount, depending on sysctl parameters), we have to traverse the whole bind hash table to find out empty bucket. And while it is not a problem for example for 32k connections, bind() completion time grows exponentially (since after each successful binding we have to traverse one bucket more to find empty one) even if we start each time from random offset inside the hash table. So, when hash table is full, and we want to add another socket, we have to traverse the whole table no matter what, so effectivelly this will be the worst case performance and it will be constant. Attached picture shows bind() time depending on number of already bound sockets. Green area corresponds to the usual binding to zero port process, which turns on kernel port selection as described above. Red area is the bind process, when number of reuse-bound sockets is not limited by 64k (or sysctl parameters). The same exponential growth (hidden by the green area) before number of ports reaches sysctl limit. At this time bind hash table has exactly one reuse-enbaled socket in a bucket, but it is possible that they have different addresses. Actually kernel selects the first port to try randomly, so at the beginning bind will take roughly constant time, but with time number of port to check after random start will increase. And that will have exponential growth, but because of above random selection, not every next port selection will necessary take longer time than previous. So we have to consider the area below in the graph (if you could zoom it, you could find, that there are many different times placed there), so area can hide another. Blue area corresponds to the port selection optimization. This is rather simple design approach: hashtable now maintains (unprecise and racely updated) number of currently bound sockets, and when number of such sockets becomes greater than predefined value (I use maximum port range defined by sysctls), we stop traversing the whole bind hash table and just stop at first matching bucket after random start. Above limit roughly corresponds to the case, when bind hash table is full and we turned on mechanism of allowing to bind more reuse-enabled sockets, so it does not change behaviour of other sockets. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Tested-by: Denys Fedoryschenko <denys@visp.net.lb> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29net: Fix percpu counters deadlockHerbert Xu
When we converted the protocol atomic counters such as the orphan count and the total socket count deadlocks were introduced due to the mismatch in BH status of the spots that used the percpu counter operations. Based on the diagnosis and patch by Peter Zijlstra, this patch fixes these issues by disabling BH where we may be in process context. Reported-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-14icsk: join error paths using gotoIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-01net: percpu_counter_inc() should not be called in BH-disabled sectionEric Dumazet
Based upon a lockdep report by Alexey Dobriyan. I checked all per_cpu_counter_xxx() usages in network tree, and I think all call sites are BH enabled except one in inet_csk_listen_stop(). commit dd24c00191d5e4a1ae896aafe33c6b8095ab4bd1 (net: Use a percpu_counter for orphan_count) replaced atomic_t orphan_count to a percpu_counter. atomic_inc()/atomic_dec() can be called from any context, while percpu_counter_xxx() should be called from a consistent state. For orphan_count, this context can be the BH-enabled one. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: Use a percpu_counter for orphan_countEric Dumazet
Instead of using one atomic_t per protocol, use a percpu_counter for "orphan_count", to reduce cache line contention on heavy duty network servers. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12net: ib_net pointer should depends on CONFIG_NET_NSEric Dumazet
We can shrink size of "struct inet_bind_bucket" by 50%, using read_pnet() and write_pnet() Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: clean up net/ipv4/ah4.c esp4.c fib_semantics.c inet_connection_sock.c ↵Jianjun Kong
inetpeer.c ip_output.c Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08inet: cleanup of local_port_rangeEric Dumazet
I noticed sysctl_local_port_range[] and its associated seqlock sysctl_local_port_range_lock were on separate cache lines. Moreover, sysctl_local_port_range[] was close to unrelated variables, highly modified, leading to cache misses. Moving these two variables in a structure can help data locality and moving this structure to read_mostly section helps sharing of this data among cpus. Cleanup of extern declarations (moved in include file where they belong), and use of inet_get_local_port_range() accessor instead of direct access to ports values. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01tcp: Port redirection support for TCPKOVACS Krisztian
Current TCP code relies on the local port of the listening socket being the same as the destination address of the incoming connection. Port redirection used by many transparent proxying techniques obviously breaks this, so we have to store the original destination port address. This patch extends struct inet_request_sock and stores the incoming destination port value there. It also modifies the handshake code to use that value as the source port when sending reply packets. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Make Netfilter's ip_route_me_harder() non-local address compatibleKOVACS Krisztian
Netfilter's ip_route_me_harder() tries to re-route packets either generated or re-routed by Netfilter. This patch changes ip_route_me_harder() to handle packets from non-locally-bound sockets with IP_TRANSPARENT set as local and to set the appropriate flowi flags when re-doing the routing lookup. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to IP_INC_STATS_BHPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16ipv4: prepare net initialization for IP accountingPavel Emelyanov
Some places, that deal with IP statistics already have where to get a struct net from, but use it directly, without declaring a separate variable on the stack. So, save this net on the stack for future IP_XXX_STATS macros. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/Kconfig drivers/net/wireless/rt2x00/rt2x00usb.c net/sctp/protocol.c
