path: root/net/ipv4/inetpeer.c
2007-11-12[INET]: Use list_head-s in inetpeer.cPavel Emelyanov
The inetpeer.c tracks the LRU list of inet_perr-s, but makes it by hands. Use the list_head-s for this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-20[IPV4]: Fix inetpeer gcc-4.2 warningsPatrick McHardy
CC net/ipv4/inetpeer.o net/ipv4/inetpeer.c: In function 'unlink_from_pool': net/ipv4/inetpeer.c:297: warning: the address of 'stack' will always evaluate as 'true' net/ipv4/inetpeer.c:297: warning: the address of 'stack' will always evaluate as 'true' net/ipv4/inetpeer.c: In function 'inet_getpeer': net/ipv4/inetpeer.c:409: warning: the address of 'stack' will always evaluate as 'true' net/ipv4/inetpeer.c:409: warning: the address of 'stack' will always evaluate as 'true' "Fix" by checking for != NULL. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: Optimize inet_getpeer()Eric Dumazet
1) Some sysctl vars are declared __read_mostly 2) We can avoid updating stack[] when doing an AVL lookup only. lookup() macro is extended to receive a second parameter, that may be NULL in case of a pure lookup (no need to save the AVL path). This removes unnecessary instructions, because compiler knows if this _stack parameter is NULL or not. text size of net/ipv4/inetpeer.o is 2063 bytes instead of 2107 on x86_64 Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15[NET]: reduce sizeof(struct inet_peer), cleanup, change in peer_check_expire()Eric Dumazet
1) shrink struct inet_peer on 64 bits platforms.
2006-09-28[IPV4]: inetpeer annotationsAl Viro
This one is interesting - we use net-endian value as search key, but order the tree by *host-endian* comparisons of keys. OK since we only care about lookups. Annotated inet_getpeer() and friends. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Use SLAB_PANICAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-10[IPV4] inetpeer: Get rid of volatile from peer_totalHerbert Xu
The variable peer_total is protected by a lock. The volatile marker makes no sense. This shaves off 20 bytes on i386. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[NET]: Change some "if (x) BUG();" to "BUG_ON(x);"Kris Katterjohn
This changes some simple "if (x) BUG();" statements to "BUG_ON(x);" Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV4]: Safer reassemblyHerbert Xu
Another spin of Herbert Xu's "safer ip reassembly" patch for 2.6.16. (The original patch is here: http://marc.theaimsgroup.com/?l=linux-netdev&m=112281936522415&w=2 and my only contribution is to have tested it.) This patch (optionally) does additional checks before accepting IP fragments, which can greatly reduce the possibility of reassembling fragments which originated from different IP datagrams. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arthur Kepner <akepner@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NET]: use __read_mostly on kmem_cache_t , DEFINE_SNMP_STAT pointersEric Dumazet
This patch puts mostly read only data in the right section (read_mostly), to help sharing of these data between CPUS without memory ping pongs. On one of my production machine, tcp_statistics was sitting in a heavily modified cache line, so *every* SNMP update had to force a reload. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4]: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - xfrm4_state.c: xfrm4_state_fini - remove the following unneeded EXPORT_SYMBOL's: - ip_output.c: ip_finish_output - ip_output.c: sysctl_ip_default_ttl - fib_frontend.c: ip_dev_find - inetpeer.c: inet_peer_idlock - ip_options.c: ip_options_compile - ip_options.c: ip_options_undo - net/core/request_sock.c: sysctl_max_syn_backlog Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-23[IPV4]: Fix negative timer loop with lots of ipv4 peers.Dave Johnson
From: Dave Johnson <djohnson+linux-kernel@sw.starentnetworks.com> Found this bug while doing some scaling testing that created 500K inet peers. peer_check_expire() in net/ipv4/inetpeer.c isn't using inet_peer_gc_mintime correctly and will end up creating an expire timer with less than the minimum duration, and even zero/negative if enough active peers are present. If >65K peers, the timer will be less than inet_peer_gc_mintime, and with >70K peers, the timer duration will reach zero and go negative. The timer handler will continue to schedule another zero/negative timer in a loop until peers can be aged. This can continue for at least a few minutes or even longer if the peers remain active due to arriving packets while the loop is occurring. Bug is present in both 2.4 and 2.6. Same patch will apply to both just fine. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
