path: root/net/ipv4/ip_gre.c
2006-10-11[NET]: Use hton{l,s}() for non-initializers.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: ipip and ip_gre encapsulation bugsAl Viro
Handling of ipip and ip_gre ICMP error relaying is b0rken; it accesses 8bit field + 3 reserved octets as host-endian 32bit, does comparison, subtraction and stuffs the result back. That breaks on big-endian. Fixed, made endian-clean. [ Note that this effected code is permanently commented out with and ifdef, so this error couldn't actually cause problems for anyone. -DaveM ] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[IPV4]: Get rid of redundant IPCB->opts initialisationHerbert Xu
Now that we always zero the IPCB->opts in ip_rcv, it is no longer necessary to do so before calling netif_rx for tunneled packets. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[INET]: Use port unreachable instead of proto for tunnelsHerbert Xu
This patch changes GRE and SIT to generate port unreachable instead of protocol unreachable errors when we can't find a matching tunnel for a packet. This removes the ambiguity as to whether the error is caused by no tunnel being found or by the lack of support for the given tunnel type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[XFRM]: Fix SNAT-related crash in xfrm4_output_finishPatrick McHardy
When a packet matching an IPsec policy is SNATed so it doesn't match any policy anymore it looses its xfrm bundle, which makes xfrm4_output_finish crash because of a NULL pointer dereference. This patch directs these packets to the original output path instead. Since the packets have already passed the POST_ROUTING hook, but need to start at the beginning of the original output path which includes another POST_ROUTING invocation, a flag is added to the IPCB to indicate that the packet was rerouted and doesn't need to pass the POST_ROUTING hook again. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[NET]: Convert net/{ipv4,ipv6,sched} to netdev_privPatrick McHardy
2006-01-07[NETFILTER]: Fix xfrm lookup in ip_route_me_harder/ip6_route_me_harderPatrick McHardy
ip_route_me_harder doesn't use the port numbers of the xfrm lookup and uses ip_route_input for non-local addresses which doesn't do a xfrm lookup, ip6_route_me_harder doesn't do a xfrm lookup at all. Use xfrm_decode_session and do the lookup manually, make sure both only do the lookup if the packet hasn't been transformed already. Makeing sure the lookup only happens once needs a new field in the IP6CB, which exceeds the size of skb->cb. The size of skb->cb is increased to 48b. Apparently the IPv6 mobile extensions need some more room anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV4]: reset IPCB flags when neccessaryPatrick McHardy
Reset IPSKB_XFRM_TUNNEL_SIZE flags in ipip and ip_gre hard_start_xmit function before the packet reenters IP. This is neccessary so the encapsulated packets are checked not to be oversized in xfrm4_output.c again. Reset all flags in sit when a packet changes its address family. Also remove some obsolete IPSKB flags. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NET]: Change 1500 to ETH_DATA_LEN in some filesKris Katterjohn
These patches add the header linux/if_ether.h and change 1500 to ETH_DATA_LEN in some files. Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-14[GRE]: Fix hardware checksum modificationHerbert Xu
The skb_postpull_rcsum introduced a bug to the checksum modification. Although the length pulled is offset bytes, the origin of the pulling is the GRE header, not the IP header. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[IPV4]: make two functions staticAdrian Bunk
This patch makes two needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NET]: Detect hardware rx checksum faults correctlyHerbert Xu
Here is the patch that introduces the generic skb_checksum_complete which also checks for hardware RX checksum faults. If that happens, it'll call netdev_rx_csum_fault which currently prints out a stack trace with the device name. In future it can turn off RX checksum. I've converted every spot under net/ that does RX checksum checks to use skb_checksum_complete or __skb_checksum_complete with the exceptions of: * Those places where checksums are done bit by bit. These will call netdev_rx_csum_fault directly. * The following have not been completely checked/converted: ipmr ip_vs netfilter dccp This patch is based on patches and suggestions from Stephen Hemminger and David S. Miller. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-30[NET]: fix oops after tunnel module unloadAlexey Kuznetsov
Tunnel modules used to obtain module refcount each time when some tunnel was created, which meaned that tunnel could be unloaded only after all the tunnels are deleted. Since killing old MOD_*_USE_COUNT macros this protection has gone. It is possible to return it back as module_get/put, but it looks more natural and practically useful to force destruction of all the child tunnels on module unload. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
