[ Upstream commit b12f62efb8ec0b9523bdb6c2d412c07193086de9 ]
When opt->srr_is_hit is set skb_rtable(skb) has been updated for
'nexthop' and iph->daddr should always equals to skb_rtable->rt_dst
holds, We need update iph->daddr either.
Signed-off-by: Li Wei <lw@cn.fujitsu.com>
The current code takes an unaligned pointer and does htonl() on it to
make it big-endian, then does a memcpy(). The problem is that the
compiler decides that since the pointer is to a __be32, it is legal
to optimize the copy into a processor word store. However, on an
architecture that does not handled unaligned writes in kernel space,
this produces an unaligned exception fault.
The solution is to track the pointer as a "char *" (which removes a bunch
of unpleasant casts in any case), and then just use put_unaligned_be32()
to write the value to memory.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Signed-off-by: David S. Miller <davem@zippy.davemloft.net>
At this point iph->daddr equals what rt->rt_dst would hold.
Pass in the sk_buff so that we can fetch the necessary keys from
the packet header when working with input routes.
This code block executes when opt->srr_is_hit is set. It will be
set only by ip_options_rcv_srr().
ip_options_rcv_srr() walks until it hits a matching nexthop in the SRR
option addresses, and when it matches one 1) looks up the route for
that nexthop and 2) on route lookup success it writes that nexthop
value into iph->daddr.
ip_forward_options() runs later, and again walks the SRR option
addresses looking for the option matching the destination of the route
stored in skb_rtable(). This route will be the same exact one looked
up for the nexthop by ip_options_rcv_srr().
Therefore "rt->rt_dst == iph->daddr" must be true.
All it really needs to do is record the route's source address in the
matching SRR option adddress. It need not write iph->daddr again,
since that has already been done by ip_options_rcv_srr() as detailed
above.
We already copy the 4-byte nexthop from the options block into
local variable "nexthop" for the route lookup.
Re-use that variable instead of memcpy()'ing again when assigning
to iph->daddr after the route lookup succeeds.
All call sites conditionalize the call to ip_options_rcv_srr()
with a check of opt->srr, so no need to check it again there.
We lack proper synchronization to manipulate inet->opt ip_options
Problem is ip_make_skb() calls ip_setup_cork() and
ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options),
without any protection against another thread manipulating inet->opt.
Another thread can change inet->opt pointer and free old one under us.
Use RCU to protect inet->opt (changed to inet->inet_opt).
Instead of handling atomic refcounts, just copy ip_options when
necessary, to avoid cache line dirtying.
We cant insert an rcu_head in struct ip_options since its included in
skb->cb[], so this patch is large because I had to introduce a new
ip_options_rcu structure.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Scot Doyle demonstrated ip_options_compile() could be called with an skb
without an attached route, using a setup involving a bridge, netfilter,
and forged IP packets.
Let's make ip_options_compile() and ip_options_rcv_srr() a bit more
robust, instead of changing bridge/netfilter code.
With help from Hiroaki SHIMODA.
Reported-by: Scot Doyle <lkml@scotdoyle.com>
Tested-by: Scot Doyle <lkml@scotdoyle.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Acked-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
The current handling of echoed IP timestamp options with prespecified
addresses is rather broken since the 2.2.x kernels. As far as i understand
it, it should behave like when originating packets.
Currently it will only timestamp the next free slot if:
- there is space for *two* timestamps
- some random data from the echoed packet taken as an IP is *not* a local IP
This first is caused by an off-by-one error. 'soffset' points to the next
free slot and so we only need to have 'soffset + 7 <= optlen'.
The second bug is using sptr as the start of the option, when it really is
set to 'skb_network_header(skb)'. I just use dptr instead which points to
the timestamp option.
Finally it would only timestamp for non-local IPs, which we shouldn't do.
So instead we exclude all unicast destinations, similar to what we do in
ip_options_compile().
Signed-off-by: Jan Luebbe <jluebbe@debian.org>
Related dicussion here : http://lkml.org/lkml/2010/9/3/16
Introduce a function br_parse_ip_options that will audit the
skb and possibly refill IP options before a packet enters the
IP stack. If no options are present, the function will zero out
the skb cb area so that it is not misinterpreted as options by some
unsuspecting IP layer routine. If packet consistency fails, drop it.
Signed-off-by: Bandan Das <bandan.das@stratus.com>
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
Use low order bit of skb->_skb_dst to tell dst is not refcounted.
Change _skb_dst to _skb_refdst to make sure all uses are catched.
skb_dst() returns the dst, regardless of noref bit set or not, but
with a lockdep check to make sure a noref dst is not given if current
user is not rcu protected.
New skb_dst_set_noref() helper to set an notrefcounted dst on a skb.
(with lockdep check)
skb_dst_drop() drops a reference only if skb dst was refcounted.
skb_dst_force() helper is used to force a refcount on dst, when skb
is queued and not anymore RCU protected.
Use skb_dst_force() in __sk_add_backlog(), __dev_xmit_skb() if
!IFF_XMIT_DST_RELEASE or skb enqueued on qdisc queue, in
sock_queue_rcv_skb(), in __nf_queue().
Use skb_dst_force() in dev_requeue_skb().
Note: dst_use_noref() still dirties dst, we might transform it
later to do one dirtying per jiffies.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb
Delete skb->rtable field
Setting rtable is not allowed, just set dst instead as rtable is an alias.
This patch accomplishes three minor tasks: add a new tag type for local
labeling, rename the CIPSO_V4_MAP_STD define to CIPSO_V4_MAP_TRANS and
replace some of the CIPSO "magic numbers" with constants from the header
file. The first change allows CIPSO to support full LSM labels/contexts,
not just MLS attributes. The second change brings the mapping names inline
with what userspace is using, compatibility is preserved since we don't
actually change the value. The last change is to aid readability and help
prevent mistakes.
Signed-off-by: Paul Moore <paul.moore@hp.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
What do_gettimeofday() does is to call getnstimeofday() and
to convert the result from timespec{} to timeval{}.
After that, these callers convert the result again to msec.
Use getnstimeofday() and convert the units at once.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Replace all the rest of the init_net with a proper net on the IP layer.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Pass the init_net there for now.
ip_options_compile uses inet_addr_type which requires a namespace. The
packet argument is optional, so parameter is the only way to obtain
it. Pass the init_net there for now.
This makes code a bit more uniform and straigthforward.
ip_options->is_data is assigned only and never checked. The structure is
not a part of kernel interface to the userspace. So, it is safe to remove
this field.
There is the only way to reach ip_options compile with opt != NULL:
ip_options_get_finish
opt->is_data = 1;
ip_options_compile(opt, NULL)
So, checking for is_data inside opt != NULL branch is not needed.
(Anonymous) unions can help us to avoid ugly casts.
A common cast it the (struct rtable *)skb->dst one.
Defining an union like :
union {
struct dst_entry *dst;
struct rtable *rtable;
permits to use skb->rtable in place.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
ip_options_echo is called on the packet input path after the initial
routing. The dst entry on the packet is cleared only in the several
very specific places and immidiately assigned back (may be new).
The patch extends the inet_addr_type and inet_dev_addr_type with the
network namespace pointer. That allows to access the different tables
relatively to the network namespace.
The modification of the signature function is reported in all the
callers of the inet_addr_type using the pointer to the well known
init_net.
Acked-by: Benjamin Thery <benjamin.thery@bull.net>
Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the network header, it is still legal
to touch skb->nh.raw directly if just adding to, subtracting from or setting it
to another layer header.
This patch makes two changes to protect applications from either removing or
tampering with the CIPSOv4 IP option on a socket. The first is the requirement
that applications have the CAP_NET_RAW capability to set an IPOPT_CIPSO option
on a socket; this prevents untrusted applications from setting their own
CIPSOv4 security attributes on the packets they send. The second change is to
SELinux and it prevents applications from setting any IPv4 options when there
is an IPOPT_CIPSO option already present on the socket; this prevents
applications from removing CIPSOv4 security attributes from the packets they
send.
Signed-off-by: James Morris <jmorris@namei.org>
->faddr is net-endian; annotated as such, variables inferred to be net-endian
annotated.
daddr is net-endian
argument and inferred net-endian variables in callers annotated.
ip_route_input() takes net-endian source and destination address.
* Annotated as such.
* arguments of its invocations annotated where needed.
* local helpers getting the same values passed to by it (ip_route_input_mc(),
ip_route_input_slow(), ip_handle_martian_source(), ip_mkroute_input(),
ip_mkroute_input_def(), __mkroute_input()) annotated
The value is_setbyuser from struct ip_options is never used and set
only one time (http://linux-net.osdl.org/index.php/TODO#IPV4).
This little patch removes it from the kernel source.
Signed-off-by: Louis Nyffenegger <louis.nyffenegger@gmail.com>
Changes to the core network stack to support the NetLabel subsystem. This
includes changes to the IPv4 option handling to support CIPSO labels.
Now that we always zero the IPCB->opts in ip_rcv, it is no longer
necessary to do so before calling netif_rx for tunneled packets.
Fix error point to options in ip_options_fragment(). optptr get a
error pointer to the ipv4 header, correct is pointer to ipv4 options.
Signed-off-by: Wei Yongjun <weiyj@soft.fujitsu.com>
net: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
To help in reducing the number of include dependencies, several files were
touched as they were getting needed headers indirectly for stuff they use.
Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had
linux/dccp.h include twice.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
This is the net/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in net/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This variant is needed to satisfy sparse __user annotations.
This patch contains the following possible cleanups:
- make needlessly global code static
- #if 0 the following unused global function:
- xfrm4_state.c: xfrm4_state_fini
- remove the following unneeded EXPORT_SYMBOL's:
- ip_output.c: ip_finish_output
- ip_output.c: sysctl_ip_default_ttl
- fib_frontend.c: ip_dev_find
- inetpeer.c: inet_peer_idlock
- ip_options.c: ip_options_compile
- ip_options.c: ip_options_undo
- net/core/request_sock.c: sysctl_max_syn_backlog
infrastructure for it.
Let it rip!
