[ Upstream commit f3594f0a7ea36661d7fd942facd7f31a64245f1a ]
t->err_count is used to count the link failure on tunnel and an err
will be reported to user socket in tx path if t->err_count is not 0.
udp socket could even return EHOSTUNREACH to users.
Since commit fd58156e456d ("IPIP: Use ip-tunneling code.") removed
the 'switch check' for icmp type in ipip_err(), err_count would be
increased by the icmp packet with ICMP_EXC_FRAGTIME code. an link
failure would be reported out due to this.
In Jianlin's case, when receiving ICMP_EXC_FRAGTIME a icmp packet,
udp netperf failed with the err:
send_data: data send error: No route to host (errno 113)
We expect this error reported from tunnel to socket when receiving
some certain type icmp, but not ICMP_EXC_FRAGTIME, ICMP_SR_FAILED
or ICMP_PARAMETERPROB ones.
This patch is to bring 'switch check' for icmp type back to ipip_err
so that it only reports link failure for the right type icmp, just as
in ipgre_err() and ipip6_err().
Fixes: fd58156e456d ("IPIP: Use ip-tunneling code.")
Reported-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
IP-TTL case is already handled in ip_tunnel_ioctl() API.
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Following patch create new tunnel flag which enable
tunnel metadata collection on given device.
Acked-by: Thomas Graf <tgraf@suug.ch>
make C=2 CF=-D__CHECK_ENDIAN__ net/ipv4/ipip.o
CHECK net/ipv4/ipip.c
net/ipv4/ipip.c:254:27: warning: incorrect type in assignment (different base types)
net/ipv4/ipip.c:254:27: expected restricted __be32 [addressable] [usertype] o_key
net/ipv4/ipip.c:254:27: got restricted __be16 [addressable] [usertype] i_flags
Fixes: 3b7b514f44bf ("ipip: fix a regression in ioctl")
The ipv4 code uses a mixture of coding styles. In some instances check
for NULL pointer is done as x == NULL and sometimes as !x. !x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
Don't use dev->iflink anymore.
CC: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Those are counterparts to nla_put_in_addr and nla_put_in6_addr.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
IP addresses are often stored in netlink attributes. Add generic functions
to do that.
For nla_put_in_addr, it would be nicer to pass struct in_addr but this is
not used universally throughout the kernel, in way too many places __be32 is
used to store IPv4 address.
encap.sport and encap.dport are __be16, use nla_{get,put}_be16 instead
of nla_{get,put}_u16.
Fixes the sparse warnings:
expected restricted __be16 [usertype] sport
got unsigned short
expected restricted __be16 [usertype] dport
got unsigned short
warning: incorrect type in argument 3 (different base types)
expected unsigned short [unsigned] [usertype] value
got restricted __be16 [usertype] sport
got restricted __be16 [usertype] dport
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Implement rtnl_link_ops->get_link_net() callback so that IFLA_LINK_NETNSID is
added to rtnetlink messages.
When filling netlink info, dport is being returned as flags. Fix
instances to return correct value.
Signed-off-by: Tom Herbert <therbert@google.com>
Testing xmit_more support with netperf and connected UDP sockets,
I found strange dst refcount false sharing.
Current handling of IFF_XMIT_DST_RELEASE is not optimal.
Dropping dst in validate_xmit_skb() is certainly too late in case
packet was queued by cpu X but dequeued by cpu Y
The logical point to take care of drop/force is in __dev_queue_xmit()
before even taking qdisc lock.
As Julian Anastasov pointed out, need for skb_dst() might come from some
packet schedulers or classifiers.
This patch adds new helper to cleanly express needs of various drivers
or qdiscs/classifiers.
Drivers that need skb_dst() in their ndo_start_xmit() should call
following helper in their setup instead of the prior :
dev->priv_flags &= ~IFF_XMIT_DST_RELEASE;
netif_keep_dst(dev);
Instead of using a single bit, we use two bits, one being
eventually rebuilt in bonding/team drivers.
The other one, is permanent and blocks IFF_XMIT_DST_RELEASE being
rebuilt in bonding/team. Eventually, we could add something
smarter later.
Cc: Julian Anastasov <ja@ssi.bg>
Call skb_set_inner_ipproto to set inner IP protocol to IPPROTO_IPV4
before tunnel_xmit. This is needed if UDP encapsulation (fou) is
being done.
Add netlink handling for IP tunnel encapsulation parameters and
and adjustment of MTU for encapsulation. ip_tunnel_encap is called
from ip_tunnel_xmit to actually perform FOU encapsulation.
net/core/rtnetlink.c
net/core/skbuff.c
Both conflicts were very simple overlapping changes.
ipv4_{update_pmtu,redirect} were called with tunnel's ifindex (t->dev is a
tunnel netdevice). It caused wrong route lookup and failure of pmtu update or
redirect. We should use the same ifindex that we use in ip_route_output_* in
*tunnel_xmit code. It is t->parms.link .
Signed-off-by: Dmitry Popov <ixaphire@qrator.net>
Enable the module alias hookup to allow tunnel modules to be autoloaded on demand.
This is in line with how most other netdev kinds work, and will allow userspace
to create tunnels without having CAP_SYS_MODULE.
Signed-off-by: Tom Gundersen <teg@jklm.no>
Replace some dev_kfree_skb() with kfree_skb() calls when
we drop one skb, this might help bug tracking.
Now inet_gso_segment() is stackable, its relatively easy to
implement GSO/TSO support for IPIP
Performance results, when segmentation is done after tunnel
device (as no NIC is yet enabled for TSO IPIP support) :
Before patch :
lpq83:~# ./netperf -H 7.7.9.84 -Cc
MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 7.7.9.84 () port 0 AF_INET
Recv Send Send Utilization Service Demand
Socket Socket Message Elapsed Send Recv Send Recv
Size Size Size Time Throughput local remote local remote
bytes bytes bytes secs. 10^6bits/s % S % S us/KB us/KB
87380 16384 16384 10.00 3357.88 5.09 3.70 2.983 2.167
After patch :
87380 16384 16384 10.00 7710.19 4.52 6.62 1.152 1.687
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
net/bridge/br_multicast.c
net/ipv6/sit.c
The conflicts were minor:
1) sit.c changes overlap with change to ip_tunnel_xmit() signature.
2) br_multicast.c had an overlap between computing max_delay using
msecs_to_jiffies and turning MLDV2_MRC() into an inline function
with a name using lowercase instead of uppercase letters.
3) stmmac had two overlapping changes, one which conditionally allocated
and hooked up a dma_cfg based upon the presence of the pbl OF property,
and another one handling store-and-forward DMA made. The latter of
which should not go into the new of_find_property() basic block.
Since commit 3d7b46cd20e3 (ip_tunnel: push generic protocol handling to
ip_tunnel module.), an Oops is triggered when an xfrm policy is configured on
an IPv4 over IPv4 tunnel.
xfrm4_policy_check() calls __xfrm_policy_check2(), which uses skb_dst(skb). But
this field is NULL because iptunnel_pull_header() calls skb_dst_drop(skb).
Signed-off-by: Li Hongjun <hongjun.li@6wind.com>
This patch allows to switch the netns when packet is encapsulated or
decapsulated. In other word, the encapsulated packet is received in a netns,
where the lookup is done to find the tunnel. Once the tunnel is found, the
packet is decapsulated and injecting into the corresponding interface which
stands to another netns.
When one of the two netns is removed, the tunnel is destroyed.
This is a regression introduced by
commit fd58156e456d9f68fe0448 (IPIP: Use ip-tunneling code.)
Similar to GRE tunnel, previously we only check the parameters
for SIOCADDTUNNEL and SIOCCHGTUNNEL, after that commit, the
check is moved for all commands.
So, just check for SIOCADDTUNNEL and SIOCCHGTUNNEL.
Also, the check for i_key, o_key etc. is suspicious too,
which did not exist before, reset them before passing
to ip_tunnel_ioctl().
Cc: Pravin B Shelar <pshelar@nicira.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Process skb tunnel header before sending packet to protocol handler.
this allows code sharing between gre and ovs gre modules.
Before this patch, ip_tunnel_xmit() was using the field protocol from the IP
header passed into argument.
There is no functional change, this patch prepares the support of IPv4 over
IPv4 for module sit.
Reuse common ip-tunneling code which is re-factored from GRE
module.
Following patch refactors GRE code into ip tunneling code and GRE
specific code. Common tunneling code is moved to ip_tunnel module.
ip_tunnel module is written as generic library which can be used
by different tunneling implementations.
ip_tunnel module contains following components:
- packet xmit and rcv generic code. xmit flow looks like
(gre_xmit/ipip_xmit)->ip_tunnel_xmit->ip_local_out.
- hash table of all devices.
- lookup for tunnel devices.
- control plane operations like device create, destroy, ioctl, netlink
operations code.
- registration for tunneling modules, like gre, ipip etc.
- define single pcpu_tstats dev->tstats.
- struct tnl_ptk_info added to pass parsed tunnel packet parameters.
ipip.h header is renamed to ip_tunnel.h
With recent patches from Pravin, most tunnels can't use iptunnel_xmit()
any more, due to ip_select_ident() and skb->ip_summed. But we can just
move these operations out of iptunnel_xmit(), so that tunnels can
use it again.
This by the way fixes a bug in vxlan (missing nf_reset()) for net-next.
Cc: Stephen Hemminger <stephen@networkplumber.org>
Allow IPIP to make use of tx-checksum offloading.
tunnel_ip_select_ident() is more efficient when generating ip-header
id given inner packet is of ipv4 type.
Pravin Shelar mentioned that GSO could potentially generate
wrong TX checksum if skb has fragments that are overwritten
by the user between the checksum computation and transmit.
He suggested to linearize skbs but this extra copy can be
avoided for normal tcp skbs cooked by tcp_sendmsg().
This patch introduces a new SKB_GSO_SHARED_FRAG flag, set
in skb_shinfo(skb)->gso_type if at least one frag can be
modified by the user.
Typical sources of such possible overwrites are {vm}splice(),
sendfile(), and macvtap/tun/virtio_net drivers.
Tested:
$ netperf -H 7.7.8.84
7.7.8.84 () port 0 AF_INET
Recv Send Send
bytes bytes bytes secs. 10^6bits/sec
87380 16384 16384 10.00 3959.52
$ netperf -H 7.7.8.84 -t TCP_SENDFILE
TCP SENDFILE TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 7.7.8.84 ()
port 0 AF_INET
Recv Send Send
87380 16384 16384 10.00 3216.80
Performance of the SENDFILE is impacted by the extra allocation and
copy, and because we use order-0 pages, while the TCP_STREAM uses
bigger pages.
Reported-by: Pravin Shelar <pshelar@nicira.com>
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Settings that merely control a single network device are allowed.
Either the network device is a logical network device where
restrictions make no difference or the network device is hardware NIC
that has been explicity moved from the initial network namespace.
In general policy and network stack state changes are allowed
while resource control is left unchanged.
Allow creating raw sockets.
Allow the SIOCSARP ioctl to control the arp cache.
Allow the SIOCSIFFLAG ioctl to allow setting network device flags.
Allow the SIOCSIFADDR ioctl to allow setting a netdevice ipv4 address.
Allow the SIOCSIFBRDADDR ioctl to allow setting a netdevice ipv4 broadcast address.
Allow the SIOCSIFDSTADDR ioctl to allow setting a netdevice ipv4 destination address.
Allow the SIOCSIFNETMASK ioctl to allow setting a netdevice ipv4 netmask.
Allow the SIOCADDRT and SIOCDELRT ioctls to allow adding and deleting ipv4 routes.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL and SIOCDELTUNNEL ioctls for
adding, changing and deleting gre tunnels.
adding, changing and deleting ipip tunnels.
adding, changing and deleting ipsec virtual tunnel interfaces.
Allow setting the MRT_INIT, MRT_DONE, MRT_ADD_VIF, MRT_DEL_VIF, MRT_ADD_MFC,
MRT_DEL_MFC, MRT_ASSERT, MRT_PIM, MRT_TABLE socket options on multicast routing
sockets.
Allow setting and receiving IPOPT_CIPSO, IP_OPT_SEC, IP_OPT_SID and
arbitrary ip options.
Allow setting IP_SEC_POLICY/IP_XFRM_POLICY ipv4 socket option.
Allow setting the IP_TRANSPARENT ipv4 socket option.
Allow setting the TCP_REPAIR socket option.
Allow setting the TCP_CONGESTION socket option.
This change fixes two sparse warnings triggered by casting the ip addresses
from netlink messages in an u32 instead of be32. This change corrects that
in order to resolve the sparse warnings.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
This patch add the support of 'ip link .. type ipip'.
This parameter was missing in the dump.
netdev_state_change() was called only when end points or link was updated. Now
that all parameters are advertised via netlink, we must advertise any change.
This patch also prepares the support of ipip tunnels management via rtnl. The
code which update tunnels will be put in a new function.
The defitions of for_each_ip_tunnel_rcu() are same,
so unify it. Also, don't hide the parameter 't'.
__IPTUNNEL_XMIT() is an ugly macro, convert it to a static
inline function, so make it more readable.
IPTUNNEL_XMIT() is unused, just remove it.
It is usefull for daemons that monitor link event to have the full parameters of
these interfaces when a rtnl message is sent.
It allows also to dump them via rtnetlink.
It is based on what is done for GRE tunnels.
In commit 6b78f16e4b (gre: add GSO support) we added GSO support to GRE
tunnels.
This patch does the same for IPIP tunnels.
Performance of single TCP flow over an IPIP tunnel is increased by 40%
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Willem de Bruijn <willemb@google.com>
Linux tunnels were written before RFC6040 and therefore never
implemented the corner case of ECN getting set in the outer header
and the inner header not being ready for it.
Section 4.2. Default Tunnel Egress Behaviour.
o If the inner ECN field is Not-ECT, the decapsulator MUST NOT
propagate any other ECN codepoint onwards. This is because the
inner Not-ECT marking is set by transports that rely on dropped
packets as an indication of congestion and would not understand or
respond to any other ECN codepoint [RFC4774]. Specifically:
* If the inner ECN field is Not-ECT and the outer ECN field is
CE, the decapsulator MUST drop the packet.
Not-ECT, ECT(0), or ECT(1), the decapsulator MUST forward the
outgoing packet with the ECN field cleared to Not-ECT.
This patch moves the ECN decap logic out of the individual tunnels
into a common place.
It also adds logging to allow detecting broken systems that
set ECN bits incorrectly when tunneling (or an intermediate
router might be changing the header).
Overloads rx_frame_error to keep track of ECN related error.
Thanks to Chris Wright who caught this while reviewing the new VXLAN
tunnel.
This code was tested by injecting faulty logic in other end GRE
to send incorrectly encapsulated packets.
The handlers for xfrm_tunnel are always invoked with rcu read lock
already.
In order to allow prefixed routes, we have to adjust how rt_gateway
is set and interpreted.
The new interpretation is:
1) rt_gateway == 0, destination is on-link, nexthop is iph->daddr
2) rt_gateway != 0, destination requires a nexthop gateway
Abstract the fetching of the proper nexthop value using a new
inline helper, rt_nexthop(), as suggested by Joe Perches.
Tested-by: Vijay Subramanian <subramanian.vijay@gmail.com>
This will be used so that we can compose a full flow key.
Even though we have a route in this context, we need more. In the
future the routes will be without destination address, source address,
etc. keying. One ipv4 route will cover entire subnets, etc.
In this environment we have to have a way to possess persistent storage
for redirects and PMTU information. This persistent storage will exist
in the FIB tables, and that's why we'll need to be able to rebuild a
full lookup flow key here. Using that flow key will do a fib_lookup()
and create/update the persistent entry.
With ip_rt_frag_needed() removed, we have to explicitly update PMTU
information in every ICMP error handler.
Create two helper functions to facilitate this.
1) ipv4_sk_update_pmtu()
This updates the PMTU when we have a socket context to
work with.
2) ipv4_update_pmtu()
Raw version, used when no socket context is available. For this
interface, we essentially just pass in explicit arguments for
the flow identity information we would have extracted from the
socket.
And you'll notice that ipv4_sk_update_pmtu() is simply implemented
in terms of ipv4_update_pmtu()
Note that __ip_route_output_key() is used, rather than something like
ip_route_output_flow() or ip_route_output_key(). This is because we
absolutely do not want to end up with a route that does IPSEC
encapsulation and the like. Instead, we only want the route that
would get us to the node described by the outermost IP header.
Reported-by: Steffen Klassert <steffen.klassert@secunet.com>
Fix checkpatch errors of the following type:
* ERROR: "foo * bar" should be "foo *bar"
* ERROR: "(foo*)" should be "(foo *)"
Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com>
Convert the per-cpu statistics kept for GRE, IPIP, and SIT tunnels
to use 64 bit statistics.
Use a more current kernel messaging style.
Convert a printk block to print_hex_dump.
Coalesce formats, align arguments.
Use %s, __func__ instead of embedding function names.
Some messages that were prefixed with <foo>_close are
now prefixed with <foo>_fini. Some ah4 and esp messages
are now not prefixed with "ip ".
The intent of this patch is to later add something like
#define pr_fmt(fmt) "IPv4: " fmt.
to standardize the output messages.
Text size is trivially reduced. (x86-32 allyesconfig)
$ size net/ipv4/built-in.o*
887888 31558 249696 1169142 11d6f6 net/ipv4/built-in.o.new
887934 31558 249800 1169292 11d78c net/ipv4/built-in.o.old
We can remove the rt_gateway == 0 check but we shouldn't
remove the 'dst' initialization too.
Noticed by Eric Dumazet.
