Use a more current kernel messaging style.
Convert a printk block to print_hex_dump.
Coalesce formats, align arguments.
Use %s, __func__ instead of embedding function names.
Some messages that were prefixed with <foo>_close are
now prefixed with <foo>_fini. Some ah4 and esp messages
are now not prefixed with "ip ".
The intent of this patch is to later add something like
#define pr_fmt(fmt) "IPv4: " fmt.
to standardize the output messages.
Text size is trivially reduced. (x86-32 allyesconfig)
$ size net/ipv4/built-in.o*
887888 31558 249696 1169142 11d6f6 net/ipv4/built-in.o.new
887934 31558 249800 1169292 11d78c net/ipv4/built-in.o.old
We can remove the rt_gateway == 0 check but we shouldn't
remove the 'dst' initialization too.
Noticed by Eric Dumazet.
It can never actually happen. rt_gateway is either the fully resolved
flow lookup key's destination address, or the non-zero FIB entry gateway
address.
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to
RCU_INIT_POINTER) did a lot of incorrect changes, since it did a
complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x,
y).
We miss needed barriers, even on x86, when y is not NULL.
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
drivers/net/ethernet/freescale/fsl_pq_mdio.c
net/batman-adv/translation-table.c
net/ipv6/route.c
Same fix as 731abb9cb2 for ipip and sit tunnel.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in
ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice
will now create a valid name, however the tunnel keeps a copy of the
name in the private parms structure. Fix this by copying the name back
after register_netdevice has successfully returned.
This shows up if you do a simple tunnel add, followed by a tunnel show:
$ sudo ip tunnel add mode ipip remote 10.2.20.211
$ ip tunnel
tunl0: ip/ip remote any local any ttl inherit nopmtudisc
tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit
$ sudo ip tunnel add mode sit remote 10.2.20.212
$ ip tunnel
sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16
sit%d: ioctl 89f8 failed: No such device
sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit
Cc: stable@vger.kernel.org
Signed-off-by: Ted Feng <artisdom@gmail.com>
Tunnels can force an alignment of their percpu data to reduce number of
cache lines used in fast path, or read in .ndo_get_stats()
percpu_alloc() is a very fine grained allocator, so any small hole will
be used anyway.
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
Force dev_alloc_name() to be called from register_netdevice() by
dev_get_valid_name(). That allows to remove multiple explicit
dev_alloc_name() calls.
The possibility to call dev_alloc_name in advance remains.
This also fixes veth creation regresion caused by
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Instead of rt->rt_{dst,src}
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
The idea here is this minimizes the number of places one has to edit
in order to make changes to how flows are defined and used.
drivers/net/bnx2x/bnx2x_cmn.c
Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with
CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean
that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are
limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't
allow anybody load any module not related to networking.
This patch restricts an ability of autoloading modules to netdev modules
with explicit aliases. This fixes CVE-2011-1019.
Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior
of loading netdev modules by name (without any prefix) for processes
with CAP_SYS_MODULE to maintain the compatibility with network scripts
that use autoloading netdev modules by aliases like "eth0", "wlan0".
Currently there are only three users of the feature in the upstream
kernel: ipip, ip_gre and sit.
root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) --
root@albatros:~# grep Cap /proc/$$/status
CapInh: 0000000000000000
CapPrm: fffffff800001000
CapEff: fffffff800001000
CapBnd: fffffff800001000
root@albatros:~# modprobe xfs
FATAL: Error inserting xfs
(/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted
root@albatros:~# lsmod | grep xfs
root@albatros:~# ifconfig xfs
xfs: error fetching interface information: Device not found
root@albatros:~# lsmod | grep sit
root@albatros:~# ifconfig sit
sit: error fetching interface information: Device not found
root@albatros:~# ifconfig sit0
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
sit 10457 0
tunnel4 2957 1 sit
For CAP_SYS_MODULE module loading is still relaxed:
CapPrm: ffffffffffffffff
CapEff: ffffffffffffffff
CapBnd: ffffffffffffffff
xfs 745319 0
Reference: https://lkml.org/lkml/2011/2/24/203
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
Acked-by: Kees Cook <kees.cook@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
Instead of on the stack.
If ipip is built as a module the 'ip tunnel add' command would fail because
the ipip module was not being autoloaded. Adding an alias for
the tunl0 device name cause dev_load() to autoload it when needed.
Use the macros defined for the members of flowi to clean the code up.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
After making rcu protection for tunnels (ipip, gre, sit and ip6) a bug
was introduced into the SIOCCHGTUNNEL code.
The tunnel is first unlinked, then addresses change, then it is linked
back probably into another bucket. But while changing the parms, the
hash table is unlocked to readers and they can lookup the improper tunnel.
Respective commits are b7285b79 (ipip: get rid of ipip_lock), 1507850b
(gre: get rid of ipgre_lock), 3a43be3c (sit: get rid of ipip6_lock) and
94767632 (ip6tnl: get rid of ip6_tnl_lock).
The quick fix is to wait for quiescent state to pass after unlinking,
but if it is inappropriate I can invent something better, just let me
know.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
In various situations, a device provides a packet to our stack and we
drop it before it enters protocol stack :
- softnet backlog full (accounted in /proc/net/softnet_stat)
- bad vlan tag (not accounted)
- unknown/unregistered protocol (not accounted)
We can handle a per-device counter of such dropped frames at core level,
and automatically adds it to the device provided stats (rx_dropped), so
that standard tools can be used (ifconfig, ip link, cat /proc/net/dev)
This is a generalization of commit 8990f468a (net: rx_dropped
accounting), thus reverting it.
IPIP tunnels can benefit from lockless xmits, using NETIF_F_LLTX
Bench on a 16 cpus machine (dual E5540 cpus), 16 threads sending
10000000 UDP frames via one ipip tunnel (size:200 bytes per frame)
Before patch :
real 2m53.321s
user 0m10.277s
sys 46m0.597s
After patch:
real 0m32.063s
user 0m9.237s
sys 8m16.255s
Last problem to solve is the contention on dst :
16118.00 28.3% __ip_route_output_key vmlinux
6135.00 10.8% dst_release vmlinux
3220.00 5.6% ip_finish_output vmlinux
2149.00 3.8% ip_route_output_flow vmlinux
1575.00 2.8% ip_append_data vmlinux
1481.00 2.6% ip_push_pending_frames vmlinux
1349.00 2.4% __xfrm_lookup vmlinux
1216.00 2.1% csum_partial_copy_generic vmlinux
1208.00 2.1% udp_sendmsg vmlinux
commit 3c97af99a5aa1 (ipip: percpu stats accounting) forgot the fallback
tunnel case (tunl0), and can crash pretty fast.
Maintain per_cpu tx_bytes, tx_packets, rx_bytes, rx_packets.
Other seldom used fields are kept in netdev->stats structure, possibly
unsafe.
This is a preliminary work to support lockless transmit path, and
correct RX stats, that are already unsafe.
Under load, netif_rx() can drop incoming packets but administrators dont
have a chance to spot which device needs some tuning (RPS activation for
example)
This patch adds rx_dropped accounting in vlans and tunnels.
As RTNL is held while doing tunnels inserts and deletes, we can remove
ipip_lock spinlock. My initial RCU conversion was conservative and
converted the rwlock to spinlock, with no RTNL requirement.
Use appropriate rcu annotations and modern lockdep checks as well.
tunnel4_handlers chain being scanned for each incoming packet,
make sure it doesnt share an often dirtied cache line.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
skb rxhash should be cleared when a skb is handled by a tunnel before
being delivered again, so that correct packet steering can take place.
There are other cleanups and accounting that we can factorize in a new
helper, skb_tunnel_rx()
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Same stuff as in ip_gre patch: receive hook can be called before netns
setup is done, oopsing in net_generic().
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Take advantage of the new pernet automatic storage management,
and stop using compatibility network namespace functions.
drivers/net/can/usb/ems_usb.c
RFC 2003 requires the outer header to have DF set if DF is set
on the inner header, even when PMTU discovery is off for the
tunnel. Our implementation does exactly that.
For this to work properly the IPIP gateway also needs to engate
in PMTU when the inner DF bit is set. As otherwise the original
host would not be able to carry out its PMTU successfully since
part of the path is only visible to the gateway.
Unfortunately when the tunnel PMTU discovery setting is off, we
do not collect the necessary soft state, resulting in blackholes
when the original host tries to perform PMTU discovery.
This problem is not reproducible on the IPIP gateway itself as
the inner packet usually has skb->local_df set. This is not
correctly cleared (an unrelated bug) when the packet passes
through the tunnel, which allows fragmentation to occur. For
hosts behind the IPIP gateway it is readily visible with a simple
ping.
This patch fixes the problem by performing PMTU discovery for
all packets with the inner DF bit set, regardless of the PMTU
discovery setting on the tunnel itself.
Speedup module unloading by factorizing synchronize_rcu() calls
IPIP tunnels use one rwlock to protect their hash tables.
This locking scheme can be converted to RCU for free, since netdevice
already must wait for a RCU grace period at dismantle time.
We currently dirty a cache line to update tunnel device stats
(tx_packets/tx_bytes). We better use the txq->tx_bytes/tx_packets
counters that already are present in cpu cache, in the cache
line shared with txq->_xmit_lock
This patch extends IPTUNNEL_XMIT() macro to use txq pointer
provided by the caller.
Also &tunnel->dev->stats can be replaced by &dev->stats
It seems recursion field from "struct ip_tunnel" is not anymore needed.
recursion prevention is done at the upper level (in dev_queue_xmit()),
since we use HARD_TX_LOCK protection for tunnels.
This avoids a cache line ping pong on "struct ip_tunnel" : This structure
should be now mostly read on xmit and receive paths.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb
Delete skb->rtable field
Setting rtable is not allowed, just set dst instead as rtable is an alias.
ipip_tunnel_xmit() might need skb->dst, so tell dev_hard_start_xmit()
to no release it.
The functions time_before is more robust for comparing
jiffies against other values.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Get rid of compile warning about non-const format
dev_net_set() should be the very first thing after alloc_netdev().
"ndo_" changes turned simple assignment (which is OK to do before netns
assignment) into quite non-trivial operation (which is not OK, init_net was
used). This leads to incomplete initialisation of tunnel device in netns.
BUG: unable to handle kernel NULL pointer dereference at 00000004
IP: [<c02efdb5>] ip6_tnl_exit_net+0x37/0x4f
*pde = 00000000
Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC
last sysfs file: /sys/class/net/lo/operstate
Pid: 10, comm: netns Not tainted (2.6.28-rc6 #1)
EIP: 0060:[<c02efdb5>] EFLAGS: 00010246 CPU: 0
EIP is at ip6_tnl_exit_net+0x37/0x4f
EAX: 00000000 EBX: 00000020 ECX: 00000000 EDX: 00000003
ESI: c5caef30 EDI: c782bbe8 EBP: c7909f50 ESP: c7909f48
DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068
Process netns (pid: 10, ti=c7908000 task=c7905780 task.ti=c7908000)
Stack:
c03e75e0 c7390bc8 c7909f60 c0245448 c7390bd8 c7390bf0 c7909fa8 c012577a
00000000 00000002 00000000 c0125736 c782bbe8 c7909f90 c0308fe3 c782bc04
c7390bd4 c0245406 c084b718 c04f0770 c03ad785 c782bbe8 c782bc04 c782bc0c
Call Trace:
[<c0245448>] ? cleanup_net+0x42/0x82
[<c012577a>] ? run_workqueue+0xd6/0x1ae
[<c0125736>] ? run_workqueue+0x92/0x1ae
[<c0308fe3>] ? schedule+0x275/0x285
[<c0245406>] ? cleanup_net+0x0/0x82
[<c0125ae1>] ? worker_thread+0x81/0x8d
[<c0128344>] ? autoremove_wake_function+0x0/0x33
[<c0125a60>] ? worker_thread+0x0/0x8d
[<c012815c>] ? kthread+0x39/0x5e
[<c0128123>] ? kthread+0x0/0x5e
[<c0103b9f>] ? kernel_thread_helper+0x7/0x10
Code: db e8 05 ff ff ff 89 c6 e8 dc 04 f6 ff eb 08 8b 40 04 e8 38 89 f5 ff 8b 44 9e 04 85 c0 75 f0 43 83 fb 20 75 f2 8b 86 84 00 00 00 <8b> 40 04 e8 1c 89 f5 ff e8 98 04 f6 ff 89 f0 e8 f8 63 e6 ff 5b
EIP: [<c02efdb5>] ip6_tnl_exit_net+0x37/0x4f SS:ESP 0068:c7909f48
---[ end trace 6c2f2328fccd3e0c ]---
Convert to network device ops. Needed to change to directly call
the init routine since two sides share same ops. In the process
found by inspection a device ref count leak if register_netdevice failed.
xfrm4_policy.c
Signed-off-by: Jianjun Kong <jianjun@zeuux.org>
Clean up the various different email addresses of mine listed in the code
to a single current and valid address. As Dave says his network merges
for 2.6.28 are now done this seems a good point to send them in where
they won't risk disrupting real changes.
Signed-off-by: Alan Cox <alan@redhat.com>
