path: root/net/ipv4/ipmr.c
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-05[IPV4]: Add 'rtable' field in struct sk_buff to alias 'dst' and avoid castsEric Dumazet
(Anonymous) unions can help us to avoid ugly casts. A common cast it the (struct rtable *)skb->dst one. Defining an union like : union { struct dst_entry *dst; struct rtable *rtable; }; permits to use skb->rtable in place. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_key.Denis V. Lunev
Needed to propagate it down to the ip_route_output_flow. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_dev_find.Denis V. Lunev
in_dev_find() need a namespace to pass it to fib_get_table(), so add an argument. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: ipmr sparse warningsStephen Hemminger
Get rid of some of the sparse warnings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4] net/ipv4: Use ipv4_is_<type>Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Switch users of ipv4_devconf(_all) to use the pernet onePavel Emelyanov
These are scattered over the code, but almost all the "critical" places already have the proper struct net at hand except for snmp proc showing function and routing rtnl handler. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Make rtnetlink infrastructure network namespace aware (v3)Denis V. Lunev
After this patch none of the netlink callback support anything except the initial network namespace but the rtnetlink infrastructure now handles multiple network namespaces. Changes from v2: - IPv6 addrlabel processing Changes from v1: - no need for special rtnl_unlock handling - fixed IPv6 ndisc Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make core networking code use seq_open_privatePavel Emelyanov
This concerns the ipv4 and ipv6 code mostly, but also the netlink and unix sockets. The netlink code is an example of how to use the __seq_open_private() call - it saves the net namespace on this private. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Restore old behaviour of default config valuesHerbert Xu
Previously inet devices were only constructed when addresses are added (or rarely in ipmr). Therefore the default config values they get are the ones at the time of these operations. Now that we're creating inet devices earlier, this changes the behaviour of default config values in an incompatible way (see bug #8519). This patch creates a compromise by setting the default values at the same point as before but only for those that have not been explicitly set by the user since the inet device's creation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Convert IPv4 devconf to an arrayHerbert Xu
This patch converts the ipv4_devconf config members (everything except sysctl) to an array. This allows easier manipulation which will be needed later on to provide better management of default config values. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Some more layer header conversionsArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce igmp_hdr() & friends, remove skb->h.igmphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[IPMR]: Fix bug introduced when converting to skb_network_reset_headerArnaldo Carvalho de Melo
2007-04-25[IP]: Introduce ip_hdrlen()Arnaldo Carvalho de Melo
For the common sequence "skb->nh.iph->ihl * 4", removing a good number of open coded skb->nh.iph uses, now to go after the rest... Just out of curiosity, here are the idioms found to get the same result: skb->nh.iph->ihl << 2 skb->nh.iph->ihl<<2 skb->nh.iph->ihl * 4 skb->nh.iph->ihl*4 (skb->nh.iph)->ihl * sizeof(u32) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF] ipmr: Missed one conversion to skb_network_header()Arnaldo Carvalho de Melo
We can't access skb->nh.raw directly anymore, it will become an offset. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: make seq_operations constStephen Hemminger
The seq_file operations stuff can be marked constant to get it out of dirty cache. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF] ipmr: Another skb_push related conversion to skb_reset_network_headerArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use skb_reset_network_header after skb_pushArnaldo Carvalho de Melo
Some more cases where skb->nh.iph was being set that were converted to using skb_reset_network_header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Some more simple skb_reset_network_header conversionsArnaldo Carvalho de Melo
This time of the type: skb->nh.iph = (struct iphdr *)skb->data; That is completely equivalent to: skb->nh.raw = skb->data; Wonder why people love casts... :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use skb_reset_network_header in skb_push casesArnaldo Carvalho de Melo
skb_push updates and returns skb->data, so we can just call skb_reset_network_header after the call to skb_push. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: cleanupStephen Hemminger
Add whitespace around keywords. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (45 commits) [IPV4]: Restore multipath routing after rt_next changes. [XFRM] IPV6: Fix outbound RO transformation which is broken by IPsec tunnel patch. [NET]: Reorder fields of struct dst_entry [DECNET]: Convert decnet route to use the new dst_entry 'next' pointer [IPV6]: Convert ipv6 route to use the new dst_entry 'next' pointer [IPV4]: Convert ipv4 route to use the new dst_entry 'next' pointer [NET]: Introduce union in struct dst_entry to hold 'next' pointer [DECNET]: fix misannotation of linkinfo_dn [DECNET]: FRA_{DST,SRC} are le16 for decnet [UDP]: UDP can use sk_hash to speedup lookups [NET]: Fix whitespace errors. [NET] XFRM: Fix whitespace errors. [NET] X25: Fix whitespace errors. [NET] WANROUTER: Fix whitespace errors. [NET] UNIX: Fix whitespace errors. [NET] TIPC: Fix whitespace errors. [NET] SUNRPC: Fix whitespace errors. [NET] SCTP: Fix whitespace errors. [NET] SCHED: Fix whitespace errors. [NET] RXRPC: Fix whitespace errors. ...
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate callers of csum_fold() in net/*Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: mroute annotationsAl Viro
2006-09-22[NET]: Use SLAB_PANICAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[RTNETLINK]: Use rtnl_unicast() for rtnetlink unicastsThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-25[IPV4] ipmr: ip multicast route bug fix.Alexey Kuznetsov
IP multicast route code was reusing an skb which causes use after free and double free. From: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Note, it is real skb_clone(), not alloc_skb(). Equeued skb contains the whole half-prepared netlink message plus room for the rest. It could be also skb_copy(), if we want to be puristic about mangling cloned data, but original copy is really not going to be used. Acked-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[IPV4]: Get rid of redundant IPCB->opts initialisationHerbert Xu
Now that we always zero the IPCB->opts in ip_rcv, it is no longer necessary to do so before calling netif_rx for tunneled packets. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
