path: root/net/ipv4/netfilter.c
2008-04-14[NETFILTER]: Add partial checksum validation helperPatrick McHardy
Move the UDP-Lite conntrack checksum validation to a generic helper similar to nf_checksum() and make it fall back to nf_checksum() in case the full packet is to be checksummed and hardware checksums are available. This is to be used by DCCP conntrack, which also needs to verify partial checksums. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_key.Denis V. Lunev
Needed to propagate it down to the ip_route_output_flow. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: kill nf_sysctl.cPatrick McHardy
Since there now is generic support for shared sysctl paths, the only remains are the net/netfilter and net/ipv4/netfilter paths. Move them to net/netfilter/core.c and net/ipv4/netfilter.c and kill nf_sysctl.c. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to inet_(dev_)add_type.Eric W. Biederman
The patch extends the inet_addr_type and inet_dev_addr_type with the network namespace pointer. That allows to access the different tables relatively to the network namespace. The modification of the signature function is reported in all the callers of the inet_addr_type using the pointer to the well known init_net. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: constify nf_afinfoPatrick McHardy
2008-01-28[NETFILTER]: nf_queue: move list_head/skb/id to struct nf_infoPatrick McHardy
Move common fields for queue management to struct nf_info and rename it to struct nf_queue_entry. The avoids one allocation/free per packet and simplifies the code a bit. Alternatively we could add some private room at the tail, but since all current users use identical structs this seems easier. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_queue: move queueing related functions/struct to seperate headerPatrick McHardy
2008-01-28[NETFILTER]: nf_ct_h323: remove ipv6 module dependencyPatrick McHardy
nf_conntrack_h323 needs ip6_route_output for the call forwarding filter. Add a ->route function to nf_afinfo and use that to avoid pulling in the ipv6 module. Fix the #ifdef for the IPv6 code while I'm at it - the IPv6 support is only needed when IPv6 conntrack is enabled. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Avoid skb_copy/pskb_copy/skb_realloc_headroomHerbert Xu
This patch replaces unnecessary uses of skb_copy, pskb_copy and skb_realloc_headroom by functions such as skb_make_writable and pskb_expand_head. This allows us to remove the double pointers later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-04[NETFILTER]: Fix routing of REJECT target generated packets in output chainPatrick McHardy
Packets generated by the REJECT target in the output chain have a local destination address and a foreign source address. Make sure not to use the foreign source address for the output route lookup. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate __skb_checksum_complete() and friends.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate callers of csum_fold() in net/*Al Viro
2006-12-02[NET]: Rethink mark field in struct flowiThomas Graf
Now that all protocols have been made aware of the mark field it can be moved out of the union thus simplyfing its usage. The config options in the IPv4/IPv6/DECnet subsystems to enable respectively disable mark based routing only obfuscate the code with ifdefs, the cost for the additional comparison in the flow key is insignificant, and most distributions have all these options enabled by default anyway. Therefore it makes sense to remove the config options and enable mark based routing by default. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Turn nfmark into generic markThomas Graf
nfmark is being used in various subsystems and has become the defacto mark field for all kinds of packets. Therefore it makes sense to rename it to `mark' and remove the dependency on CONFIG_NETFILTER. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[NETFILTER]: add type parameter to ip_route_me_harderSimon Horman
By adding a type parameter to ip_route_me_harder() the expensive call to inet_addr_type() can be avoided in some cases. A followup patch where ip_route_me_harder() is called from within ip_vs_out() is one such example. Signed-off-By: Simon Horman <horms@verge.net.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NETFILTER]: netfilter misc annotationsAl Viro
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Add address family specific checksum helpersPatrick McHardy
Add checksum operation which takes care of verifying the checksum and dealing with HW checksum errors and avoids multiple checksum operations by setting ip_summed to CHECKSUM_UNNECESSARY after successful verification. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Introduce infrastructure for address family specific operationsPatrick McHardy
Change the queue rerouter intrastructure to a generic usable infrastructure for address family specific operations as a base for some cleanups. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[NETFILTER]: Rename init functions.Andrew Morton
Every netfilter module uses `init' for its module_init() function and `fini' or `cleanup' for its module_exit() function. Problem is, this creates uninformative initcall_debug output and makes ctags rather useless. So go through and rename them all to $(filename)_init and $(filename)_fini. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[NETFILTER]: Fix xfrm lookup after SNATPatrick McHardy
To find out if a packet needs to be handled by IPsec after SNAT, packets are currently rerouted in POST_ROUTING and a new xfrm lookup is done. This breaks SNAT of non-unicast packets to non-local addresses because the packet is routed as incoming packet and no neighbour entry is bound to the dst_entry. In general, it seems to be a bad idea to replace the dst_entry after the packet was already sent to the output routine because its state might not match what's expected. This patch changes the xfrm lookup in POST_ROUTING to re-use the original dst_entry without routing the packet again. This means no policy routing can be used for transport mode transforms (which keep the original route) when packets are SNATed to match the policy, but it looks like the best we can do for now. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: net/ipv[46]/netfilter.c cleanupsPatrick McHardy
Don't wrap entire file in #ifdef CONFIG_NETFILTER, remove a few unneccessary includes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Handle NAT in IPsec policy checksPatrick McHardy
Handle NAT of decapsulated IPsec packets by reconstructing the struct flowi of the original packet from the conntrack information for IPsec policy checks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Fix xfrm lookup in ip_route_me_harder/ip6_route_me_harderPatrick McHardy
ip_route_me_harder doesn't use the port numbers of the xfrm lookup and uses ip_route_input for non-local addresses which doesn't do a xfrm lookup, ip6_route_me_harder doesn't do a xfrm lookup at all. Use xfrm_decode_session and do the lookup manually, make sure both only do the lookup if the packet hasn't been transformed already. Makeing sure the lookup only happens once needs a new field in the IP6CB, which exceeds the size of skb->cb. The size of skb->cb is increased to 48b. Apparently the IPv6 mobile extensions need some more room anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Move reroute-after-queue code up to the nf_queue layer.Harald Welte
The rerouting functionality is required by the core, therefore it has to be implemented by the core and not in individual queue handlers. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Move ipv4 specific code from net/core/netfilter.c to ↵Harald Welte
net/ipv4/netfilter.c Netfilter cleanup - Move ipv4 code from net/core/netfilter.c to net/ipv4/netfilter.c - Move ipv6 netfilter code from net/ipv6/ip6_output.c to net/ipv6/netfilter.c Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
