Updates the MODULE_DESCRIPTION() tags for all Netfilter modules,
actually describing what the module does and not just
"netfilter XYZ target".
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Give all Netfilter modules consistent and unique symbol names.
Make a number of variables const and/or remove unneeded casts.
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Switch the return type of match functions to boolean
Switch the "hotdrop" variables to boolean
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the common sequence "skb->nh.iph->ihl * 4", removing a good number of open
coded skb->nh.iph uses, now to go after the rest...
Just out of curiosity, here are the idioms found to get the same result:
skb->nh.iph->ihl << 2
skb->nh.iph->ihl<<2
skb->nh.iph->ihl*4
(skb->nh.iph)->ihl * sizeof(u32)
Use the x_tables functions directly to make it better visible which
parts are shared between ip_tables and ip6_tables.
The size is verified by x_tables and isn't needed by the modules anymore.
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
infrastructure for it.
Let it rip!
