Commit 9335f047fe61587ec82ff12fbb1220bcfdd32006 aka
"[NETFILTER]: ip_tables: per-netns FILTER, MANGLE, RAW"
added per-netns _view_ of iptables rules. They were shown to user, but
ignored by filtering code. Now that it's possible to at least ping loopback,
per-netns tables can affect filtering decisions.
netns is taken in case of
PRE_ROUTING, LOCAL_IN -- from in device,
POST_ROUTING, LOCAL_OUT -- from out device,
FORWARD -- from in device which should be equal to out device's netns.
This code is relatively new, so BUG_ON was plugged.
Wrappers were added to a) keep code the same from CONFIG_NET_NS=n users
(overwhelming majority), b) consolidate code in one place -- similar
changes will be done in ipv6 and arp netfilter code.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Now, iptables show and configure different set of rules in different
netnss'. Filtering decisions are still made by consulting only
init_net's set.
Changes are identical except naming so no splitting.
P.S.: one need to remove init_net checks in nf_sockopt.c and inet_create()
to see the effect.
Typical table module registers xt_table structure (i.e. packet_filter)
and link it to list during it. We can't use one template for it because
corresponding list_head will become corrupted. We also can't unregister
with template because it wasn't changed at all and thus doesn't know in
which list it is.
So, we duplicate template at the very first step of table registration.
Table modules will save it for use during unregistration time and actual
filtering.
Do it at once to not screw bisection.
P.S.: renaming i.e. packet_filter => __packet_filter is temporary until
full netnsization of table modules is done.
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
iptables matches and targets expect packets to have at least a full
IP header and a valid header length. Ignore packets sent through
raw sockets for which this isn't true as in the other tables.
- move arp_tables initial table structure definitions to arp_tables.h
similar to ip_tables and ip6_tables
- use C99 initializers
- use initializer macros where possible
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
structure names
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Clean up hook registration by makeing use of the new mass registration and
unregistration helpers.
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
infrastructure for it.
Let it rip!
