Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Move responsibility for setting the IP_NAT_RANGE_PROTO_SPECIFIED flag
to the NAT protocol, properly propagate errors and get rid of ugly
return value convention.
Move to nf_nat_proto_common and rename to nf_nat_proto_... since they're
also used by protocols that don't have port numbers.
The port rover should not get overwritten when using random mode,
otherwise other rules will also use more or less random ports.
Add generic ->in_range and ->unique_tuple ops to avoid duplicating them
again and again for future NAT modules and save a few bytes of text:
net/ipv4/netfilter/nf_nat_proto_tcp.c:
tcp_in_range | -62 (removed)
tcp_unique_tuple | -259 # 271 -> 12, # inlines: 1 -> 0, size inlines: 7 -> 0
2 functions changed, 321 bytes removed
net/ipv4/netfilter/nf_nat_proto_udp.c:
udp_in_range | -62 (removed)
udp_unique_tuple | -259 # 271 -> 12, # inlines: 1 -> 0, size inlines: 7 -> 0
net/ipv4/netfilter/nf_nat_proto_gre.c:
gre_in_range | -62 (removed)
1 function changed, 62 bytes removed
vmlinux:
5 functions changed, 704 bytes removed
