[ Upstream commit 1b97013bfb11d66f041de691de6f0fec748ce016 ]
Fix more memory leaks in ip_cmsg_send() callers. Part of them were fixed
earlier in 919483096bfe.
* udp_sendmsg one was there since the beginning when linux sources were
first added to git;
* ping_v4_sendmsg one was copy/pasted in c319b4d76b9e.
Whenever return happens in udp_sendmsg() or ping_v4_sendmsg() IP options
have to be freed if they were allocated previously.
Add label so that future callers (if any) can use it instead of kfree()
before return that is easy to forget.
Fixes: c319b4d76b9e (net: ipv4: add IPPROTO_ICMP socket kind)
Signed-off-by: Andrey Ignatov <rdna@fb.com>
commit 43a6684519ab0a6c52024b5e25322476cabad893 upstream.
We got a report of yet another bug in ping
http://www.openwall.com/lists/oss-security/2017/03/24/6
->disconnect() is not called with socket lock held.
Fix this by acquiring ping rwlock earlier.
Thanks to Daniel, Alexander and Andrey for letting us know this problem.
Fixes: c319b4d76b9e ("net: ipv4: add IPPROTO_ICMP socket kind")
Reported-by: Daniel Jiang <danieljiang0415@gmail.com>
Reported-by: Solar Designer <solar@openwall.com>
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 73d2c6678e6c3af7e7a42b1e78cd0211782ade32 ]
Andrey reported a kernel crash:
general protection fault: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 2 PID: 3880 Comm: syz-executor1 Not tainted 4.10.0-rc6+ #124
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff880060048040 task.stack: ffff880069be8000
RIP: 0010:ping_v4_push_pending_frames net/ipv4/ping.c:647 [inline]
RIP: 0010:ping_v4_sendmsg+0x1acd/0x23f0 net/ipv4/ping.c:837
RSP: 0018:ffff880069bef8b8 EFLAGS: 00010206
RAX: dffffc0000000000 RBX: ffff880069befb90 RCX: 0000000000000000
RDX: 0000000000000018 RSI: ffff880069befa30 RDI: 00000000000000c2
RBP: ffff880069befbb8 R08: 0000000000000008 R09: 0000000000000000
R10: 0000000000000002 R11: 0000000000000000 R12: ffff880069befab0
R13: ffff88006c624a80 R14: ffff880069befa70 R15: 0000000000000000
FS: 00007f6f7c716700(0000) GS:ffff88006de00000(0000) knlGS:0000000000000000
CR2: 00000000004a6f28 CR3: 000000003a134000 CR4: 00000000000006e0
Call Trace:
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744
sock_sendmsg_nosec net/socket.c:635 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:645
SYSC_sendto+0x660/0x810 net/socket.c:1687
SyS_sendto+0x40/0x50 net/socket.c:1655
entry_SYSCALL_64_fastpath+0x1f/0xc2
This is because we miss a check for NULL pointer for skb_peek() when
the queue is empty. Other places already have the same check.
Tested-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 0eab121ef8750a5c8637d51534d5e9143fb0633f ]
Prior to commit c0371da6047a ("put iov_iter into msghdr") in v3.19, there
was no check that the iovec contained enough bytes for an ICMP header,
and the read loop would walk across neighboring stack contents. Since the
iov_iter conversion, bad arguments are noticed, but the returned error is
EFAULT. Returning EINVAL is a clearer error and also solves the problem
prior to v3.19.
This was found using trinity with KASAN on v3.18:
BUG: KASAN: stack-out-of-bounds in memcpy_fromiovec+0x60/0x114 at addr ffffffc071077da0
Read of size 8 by task trinity-c2/9623
page:ffffffbe034b9a08 count:0 mapcount:0 mapping: (null) index:0x0
flags: 0x0()
page dumped because: kasan: bad access detected
CPU: 0 PID: 9623 Comm: trinity-c2 Tainted: G BU 3.18.0-dirty #15
Hardware name: Google Tegra210 Smaug Rev 1,3+ (DT)
Call trace:
[<ffffffc000209c98>] dump_backtrace+0x0/0x1ac arch/arm64/kernel/traps.c:90
[<ffffffc000209e54>] show_stack+0x10/0x1c arch/arm64/kernel/traps.c:171
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffc000f18dc4>] dump_stack+0x7c/0xd0 lib/dump_stack.c:50
[< inline >] print_address_description mm/kasan/report.c:147
[< inline >] kasan_report_error mm/kasan/report.c:236
[<ffffffc000373dcc>] kasan_report+0x380/0x4b8 mm/kasan/report.c:259
[< inline >] check_memory_region mm/kasan/kasan.c:264
[<ffffffc00037352c>] __asan_load8+0x20/0x70 mm/kasan/kasan.c:507
[<ffffffc0005b9624>] memcpy_fromiovec+0x5c/0x114 lib/iovec.c:15
[< inline >] memcpy_from_msg include/linux/skbuff.h:2667
[<ffffffc000ddeba0>] ping_common_sendmsg+0x50/0x108 net/ipv4/ping.c:674
[<ffffffc000dded30>] ping_v4_sendmsg+0xd8/0x698 net/ipv4/ping.c:714
[<ffffffc000dc91dc>] inet_sendmsg+0xe0/0x12c net/ipv4/af_inet.c:749
[< inline >] __sock_sendmsg_nosec net/socket.c:624
[< inline >] __sock_sendmsg net/socket.c:632
[<ffffffc000cab61c>] sock_sendmsg+0x124/0x164 net/socket.c:643
[< inline >] SYSC_sendto net/socket.c:1797
[<ffffffc000cad270>] SyS_sendto+0x178/0x1d8 net/socket.c:1761
CVE-2016-8399
Reported-by: Qidan He <i@flanker017.me>
Cc: stable@vger.kernel.org
[ Upstream commit 919483096bfe75dda338e98d56da91a263746a0a ]
Dmitry reported memory leaks of IP options allocated in
ip_cmsg_send() when/if this function returns an error.
Callers are responsible for the freeing.
Many thanks to Dmitry for the report and diagnostic.
Add support to allow non-local binds similar to how this was done for IPv4.
Non-local binds are very useful in emulating the Internet in a box, etc.
This add the ip_nonlocal_bind sysctl under ipv6.
Testing:
Set up nonlocal binding and receive routing on a host, e.g.:
ip -6 rule add from ::/0 iif eth0 lookup 200
ip -6 route add local 2001:0:0:1::/64 dev lo proto kernel scope host table 200
sysctl -w net.ipv6.ip_nonlocal_bind=1
Set up routing to 2001:0:0:1::/64 on peer to go to first host
ping6 -I 2001:0:0:1::1 peer-address -- to verify
Signed-off-by: Tom Herbert <tom@herbertland.com>
If we don't do that, then the poison value is left in the ->pprev
backlink.
This can cause crashes if we do a disconnect, followed by a connect().
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Wen Xu <hotdog3645@gmail.com>
The ipv4 code uses a mixture of coding styles. In some instances check
for non-NULL pointer is done as x != NULL and sometimes as x. x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
for NULL pointer is done as x == NULL and sometimes as !x. !x is
const qualifiers ease code review by making clear
which objects are not written in a function.
drivers/net/ethernet/cadence/macb.c
Overlapping changes in macb driver, mostly fixes and cleanups
in 'net' overlapping with the integration of at91_ether into
macb in 'net-next'.
1. For an IPv4 ping socket, ping_check_bind_addr does not check
the family of the socket address that's passed in. Instead,
make it behave like inet_bind, which enforces either that the
address family is AF_INET, or that the family is AF_UNSPEC and
the address is 0.0.0.0.
2. For an IPv6 ping socket, ping_check_bind_addr returns EINVAL
if the socket family is not AF_INET6. Return EAFNOSUPPORT
instead, for consistency with inet6_bind.
3. Make ping_v4_sendmsg and ping_v6_sendmsg return EAFNOSUPPORT
instead of EINVAL if an incorrect socket address structure is
passed in.
4. Make IPv6 ping sockets be IPv6-only. The code does not support
IPv4, and it cannot easily be made to support IPv4 because
the protocol numbers for ICMP and ICMPv6 are different. This
makes connect(::ffff:192.0.2.1) fail with EAFNOSUPPORT instead
of making the socket unusable.
Among other things, this fixes an oops that can be triggered by:
int s = socket(AF_INET, SOCK_DGRAM, IPPROTO_ICMP);
struct sockaddr_in6 sin6 = {
.sin6_family = AF_INET6,
.sin6_addr = in6addr_any,
bind(s, (struct sockaddr *) &sin6, sizeof(sin6));
Change-Id: If06ca86d9f1e4593c0d6df174caca3487c57a241
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
That takes care of the majority of ->sendmsg() instances - most of them
via memcpy_to_msg() or assorted getfrag() callbacks. One place where we
still keep memcpy_fromiovecend() is tipc - there we potentially read the
same data over and over; separate patch, that...
... instead of storing its ->mgs_iter.iov there
An exception is seen in ICMP ping receive path where the skb
destructor sock_rfree() tries to access a freed socket. This happens
because ping_rcv() releases socket reference with sock_put() and this
internally frees up the socket. Later icmp_rcv() will try to free the
skb and as part of this, skb destructor is called and which leads
to a kernel panic as the socket is freed already in ping_rcv().
-->|exception
-007|sk_mem_uncharge
-007|sock_rfree
-008|skb_release_head_state
-009|skb_release_all
-009|__kfree_skb
-010|kfree_skb
-011|icmp_rcv
-012|ip_local_deliver_finish
Fix this incorrect free by cloning this skb and processing this cloned
skb instead.
This patch was suggested by Eric Dumazet
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Eric Dumazet <edumazet@google.com>
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
TCP timestamping introduced MSG_ERRQUEUE handling for TCP sockets.
If the socket is of family AF_INET6, call ipv6_recv_error instead
of ip_recv_error.
This change is more complex than a single branch due to the loadable
ipv6 module. It reuses a pre-existing indirect function call from
ping. The ping code is safe to call, because it is part of the core
ipv6 module and always present when AF_INET6 sockets are active.
Fixes: 4ed2d765 (net-timestamp: TCP timestamping)
Signed-off-by: Willem de Bruijn <willemb@google.com>
It may also be worthwhile to add WARN_ON_ONCE(sk->family == AF_INET6)
to ip_recv_error.
ping_lookup() may return a wrong sock if sk_buff's and sock's protocols
dont' match. For example, sk_buff's protocol is ETH_P_IPV6, but sock's
sk_family is AF_INET, in that case, if sk->sk_bound_dev_if is zero, a wrong
sock will be returned.
the fix is to "continue" the searching, if no matching, return NULL.
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: netdev@vger.kernel.org
Signed-off-by: Jane Zhou <a17711@motorola.com>
Signed-off-by: Yiwei Zhao <gbjc64@motorola.com>
If icmp_rcv() has successfully processed the incoming ICMP datagram, we
should use consume_skb() rather than kfree_skb() because a hit on the likes
of perf -e skb:kfree_skb is not called-for.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
net.ipv4.ip_nonlocal_bind sysctl was global to all network
namespaces. This patch allows to set a different value for each
network namespace.
Signed-off-by: Vincent Bernat <vincent@bernat.im>
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Similarly, when CONFIG_SYSCTL is not set, ping_group_range should still
work, just that no one can change it. Therefore we should move it out of
sysctl_net_ipv4.c. And, it should not share the same seqlock with
ip_local_port_range.
BTW, rename it to ->ping_group_range instead.
Cc: Francois Romieu <romieu@fr.zoreil.com>
Reported-by: Stefan de Konink <stefan@konink.de>
When CONFIG_SYSCTL is not set, ip_local_port_range should still work,
just that no one can change it. Therefore we should move it out of sysctl_inet.c.
Also, rename it to ->ip_local_ports instead.
Plug a group_info refcount leak in ping_init.
group_info is only needed during initialization and
the code failed to release the reference on exit.
While here move grabbing the reference to a place
where it is actually needed.
Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com>
Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com>
Signed-off-by: xiaoming wang <xiaoming.wang@intel.com>
In case we decide in udp6_sendmsg to send the packet down the ipv4
udp_sendmsg path because the destination is either of family AF_INET or
the destination is an ipv4 mapped ipv6 address, we don't honor the
maybe specified ipv4 mapped ipv6 address in IPV6_PKTINFO.
We simply can check for this option in ip_cmsg_send because no calls to
ipv6 module functions are needed to do so.
Reported-by: Gert Doering <gert@space.net>
Cc: Tore Anderson <tore@fud.no>
Some ipv6 protocols cannot handle ipv4 addresses, so we must not allow
connecting and binding to them. sendmsg logic does already check msg->name
for this but must trust already connected sockets which could be set up
for connection to ipv4 address family.
Per-socket flag ipv6only is of no use here, as it is under users control
by setsockopt.
We currently don't report IPV6_RECVPKTINFO in cmsg access ancillary data
for IPv4 datagrams on IPv6 sockets.
This patch splits the ip6_datagram_recv_ctl into two functions, one
which handles both protocol families, AF_INET and AF_INET6, while the
ip6_datagram_recv_specific_ctl only handles IPv6 cmsg data.
ip6_datagram_recv_*_ctl never reported back any errors, so we can make
them return void. Also provide a helper for protocols which don't offer dual
personality to further use ip6_datagram_recv_ctl, which is exported to
modules.
I needed to shuffle the code for ping around a bit to make it easier to
implement dual personality for ping ipv6 sockets in future.
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Don't export ping_table or ping_v4_sendmsg. Both are only used
inside ping code.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
In commit c9e9042994d3 ("ipv4: fix possible seqlock deadlock") I left
another places where IP_INC_STATS_BH() were improperly used.
udp_sendmsg(), ping_v4_sendmsg() and tcp_v4_connect() are called from
process context, not from softirq context.
This was detected by lockdep seqlock support.
Reported-by: jongman heo <jongman.heo@samsung.com>
Fixes: 584bdf8cbdf6 ("[IPV4]: Fix "ipOutNoRoutes" counter error for TCP and UDP")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
functions
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
Pull networking fixes from David Miller:
"Mostly these are fixes for fallout due to merge window changes, as
well as cures for problems that have been with us for a much longer
period of time"
1) Johannes Berg noticed two major deficiencies in our genetlink
registration. Some genetlink protocols we passing in constant
counts for their ops array rather than something like
ARRAY_SIZE(ops) or similar. Also, some genetlink protocols were
using fixed IDs for their multicast groups.
We have to retain these fixed IDs to keep existing userland tools
working, but reserve them so that other multicast groups used by
other protocols can not possibly conflict.
In dealing with these two problems, we actually now use less state
management for genetlink operations and multicast groups.
2) When configuring interface hardware timestamping, fix several
drivers that simply do not validate that the hwtstamp_config value
is one the driver actually supports. From Ben Hutchings.
3) Invalid memory references in mwifiex driver, from Amitkumar Karwar.
4) In dev_forward_skb(), set the skb->protocol in the right order
relative to skb_scrub_packet(). From Alexei Starovoitov.
5) Bridge erroneously fails to use the proper wrapper functions to make
calls to netdev_ops->ndo_vlan_rx_{add,kill}_vid. Fix from Toshiaki
Makita.
6) When detaching a bridge port, make sure to flush all VLAN IDs to
prevent them from leaking, also from Toshiaki Makita.
7) Put in a compromise for TCP Small Queues so that deep queued devices
that delay TX reclaim non-trivially don't have such a performance
decrease. One particularly problematic area is 802.11 AMPDU in
wireless. From Eric Dumazet.
8) Fix crashes in tcp_fastopen_cache_get(), we can see NULL socket dsts
here. Fix from Eric Dumzaet, reported by Dave Jones.
9) Fix use after free in ipv6 SIT driver, from Willem de Bruijn.
10) When computing mergeable buffer sizes, virtio-net fails to take the
virtio-net header into account. From Michael Dalton.
11) Fix seqlock deadlock in ip4_datagram_connect() wrt. statistic
bumping, this one has been with us for a while. From Eric Dumazet.
12) Fix NULL deref in the new TIPC fragmentation handling, from Erik
Hugne.
13) 6lowpan bit used for traffic classification was wrong, from Jukka
Rissanen.
14) macvlan has the same issue as normal vlans did wrt. propagating LRO
disabling down to the real device, fix it the same way. From Michal
Kubecek.
15) CPSW driver needs to soft reset all slaves during suspend, from
Daniel Mack.
16) Fix small frame pacing in FQ packet scheduler, from Eric Dumazet.
17) The xen-netfront RX buffer refill timer isn't properly scheduled on
partial RX allocation success, from Ma JieYue.
18) When ipv6 ping protocol support was added, the AF_INET6 protocol
initialization cleanup path on failure was borked a little. Fix
from Vlad Yasevich.
19) If a socket disconnects during a read/recvmsg/recvfrom/etc that
blocks we can do the wrong thing with the msg_name we write back to
userspace. From Hannes Frederic Sowa. There is another fix in the
works from Hannes which will prevent future problems of this nature.
20) Fix route leak in VTI tunnel transmit, from Fan Du.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits)
genetlink: make multicast groups const, prevent abuse
genetlink: pass family to functions using groups
genetlink: add and use genl_set_err()
genetlink: remove family pointer from genl_multicast_group
genetlink: remove genl_unregister_mc_group()
hsr: don't call genl_unregister_mc_group()
quota/genetlink: use proper genetlink multicast APIs
drop_monitor/genetlink: use proper genetlink multicast APIs
genetlink: only pass array to genl_register_family_with_ops()
tcp: don't update snd_nxt, when a socket is switched from repair mode
atm: idt77252: fix dev refcnt leak
xfrm: Release dst if this dst is improper for vti tunnel
netlink: fix documentation typo in netlink_set_err()
be2net: Delete secondary unicast MAC addresses during be_close
be2net: Fix unconditional enabling of Rx interface options
net, virtio_net: replace the magic value
ping: prevent NULL pointer dereference on write to msg_name
bnx2x: Prevent "timeout waiting for state X"
bnx2x: prevent CFC attention
bnx2x: Prevent panic during DMAE timeout
A plain read() on a socket does set msg->msg_name to NULL. So check for
NULL pointer first.
Only update *addr_len when we actually fill in sockaddr, otherwise we
can return uninitialized memory from the stack to the caller in the
recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL)
checks because we only get called with a valid addr_len pointer either
from sock_common_recvmsg or inet_recvmsg.
If a blocking read waits on a socket which is concurrently shut down we
now return zero and set msg_msgnamelen to 0.
Reported-by: mpb <mpb.mail@gmail.com>
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
All seq_printf() users are using "%n" for calculating padding size,
convert them to use seq_setwidth() / seq_pad() pair.
Cc: Joe Perches <joe@perches.com>
CONFIG_IPV6=n is still a valid choice ;)
It appears we can remove dead code.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
TCP listener refactoring, part 4 :
To speed up inet lookups, we moved IPv4 addresses from inet to struct
sock_common
Now is time to do the same for IPv6, because it permits us to have fast
lookups for all kind of sockets, including upcoming SYN_RECV.
Getting IPv6 addresses in TCP lookups currently requires two extra cache
lines, plus a dereference (and memory stall).
inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6
This patch is way bigger than its IPv4 counter part, because for IPv4,
we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6,
it's not doable easily.
inet6_sk(sk)->daddr becomes sk->sk_v6_daddr
inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr
And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr
at the same offset.
We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic
macro.
- Move sysctl_local_ports from a global variable into struct netns_ipv4.
- Modify inet_get_local_port_range to take a struct net, and update all
of the callers.
- Move the initialization of sysctl_local_ports into
sysctl_net_ipv4.c:ipv4_sysctl_init_net from inet_connection_sock.c
v2:
- Ensure indentation used tabs
- Fixed ip.h so it applies cleanly to todays net-next
v3:
- Compile fixes of strange callers of inet_get_local_port_range.
This patch now successfully passes an allmodconfig build.
Removed manual inlining of inet_get_local_port_range in ipv4_local_port_range
Originally-by: Samya <samya@twitter.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
If IP_TOS or IP_TTL are specified as ancillary data, then sendmsg() sends out
packets with the specified TTL or TOS overriding the socket values specified
with the traditional setsockopt().
The struct inet_cork stores the values of TOS, TTL and priority that are
passed through the struct ipcm_cookie. If there are user-specified TOS
(tos != -1) or TTL (ttl != 0) in the struct ipcm_cookie, these values are
used to override the per-socket values. In case of TOS also the priority
is changed accordingly.
Two helper functions get_rttos and get_rtconn_flags are defined to take
into account the presence of a user specified TOS value when computing
RT_TOS and RT_CONN_FLAGS.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
net/ipv4/ping.c:286:5: sparse: symbol 'ping_check_bind_addr' was not declared. Should it be static?
net/ipv4/ping.c:355:6: sparse: symbol 'ping_set_saddr' was not declared. Should it be static?
net/ipv4/ping.c:370:6: sparse: symbol 'ping_clear_saddr' was not declared. Should it be static?
net/ipv6/ping.c:60:5: sparse: symbol 'dummy_ipv6_recv_error' was not declared. Should it be static?
net/ipv6/ping.c:64:5: sparse: symbol 'dummy_ip6_datagram_recv_ctl' was not declared. Should it be static?
net/ipv6/ping.c:69:5: sparse: symbol 'dummy_icmpv6_err_convert' was not declared. Should it be static?
net/ipv6/ping.c:73:6: sparse: symbol 'dummy_ipv6_icmp_error' was not declared. Should it be static?
net/ipv6/ping.c:75:5: sparse: symbol 'dummy_ipv6_chk_addr' was not declared. Should it be static?
net/ipv6/ping.c:201:5: sparse: symbol 'ping_v6_seq_show' was not declared. Should it be static?
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
If we don't need scope id, we should initialize it to zero.
Same for ->sin6_flowinfo.
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Lorenzo Colitti <lorenzo@google.com>
The format is based on /proc/net/icmp and /proc/net/{udp,raw}6.
Compiles and displays reasonable results with CONFIG_IPV6={n,m,y}
Couldn't figure out how to test without CONFIG_PROC_FS enabled.
Introduce a ping_seq_afinfo structure (similar to its UDP
equivalent) and use it to make some of the ping /proc functions
address-family independent. Rename the remaining ping /proc
functions from ping_* to ping_v4_*.
This adds the ability to send ICMPv6 echo requests without a
raw socket. The equivalent ability for ICMPv4 was added in
2011.
Instead of having separate code paths for IPv4 and IPv6, make
most of the code in net/ipv4/ping.c dual-stack and only add a
few IPv6-specific bits (like the protocol definition) to a new
net/ipv6/ping.c. Hopefully this will reduce divergence and/or
duplication of bugs in the future.
Caveats:
- Setting options via ancillary data (e.g., using IPV6_PKTINFO
to specify the outgoing interface) is not yet supported.
- There are no separate security settings for IPv4 and IPv6;
everything is controlled by /proc/net/ipv4/ping_group_range.
- The proc interface does not yet display IPv6 ping sockets
properly.
Tested with a patched copy of ping6 and using raw socket calls.
Compiles and works with all of CONFIG_IPV6={n,m,y}.
Currently, sock_tx_timestamp() always returns 0. The comment that
describes the sock_tx_timestamp() function wrongly says that it
returns an error when an invalid argument is passed (from commit
20d4947353be, ``net: socket infrastructure for SO_TIMESTAMPING'').
Make the function void, so that we can also remove all the unneeded
if conditions that check for such a _non-existant_ error case in the
output path.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
