path: root/net/ipv4/ping.c
2011-06-20ipv4, ping: Remove duplicate icmp.h includeJesper Juhl
Remove the duplicate inclusion of net/icmp.h from net/ipv4/ping.c Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23net: ping: cleanups ping_v4_unhash()Eric Dumazet
net/ipv4/ping.c: In function ‘ping_v4_unhash’: net/ipv4/ping.c:140:28: warning: variable ‘hslot’ set but not used Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19net: ping: fix the coding styleChangli Gao
The characters in a line should be no more than 80. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19net: ping: make local functions staticChangli Gao
As these functions are only used in this file. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17net: ping: fix build failureVasiliy Kulikov
If CONFIG_PROC_SYSCTL=n the building process fails: ping.c:(.text+0x52af3): undefined reference to `inet_get_ping_group_range_net' Moved inet_get_ping_group_range_net() to ping.c. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16net: ping: dont call udp_ioctl()Eric Dumazet
udp_ioctl() really handles UDP and UDPLite protocols. 1) It can increment UDP_MIB_INERRORS in case first_packet_length() finds a frame with bad checksum. 2) It has a dependency on sizeof(struct udphdr), not applicable to ICMP/PING If ping sockets need to handle SIOCINQ/SIOCOUTQ ioctl, this should be done differently. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15net: ping: small changesEric Dumazet
ping_table is not __read_mostly, since it contains one rwlock, and is static to ping.c ping_port_rover & ping_v4_lookup are static Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13net: ipv4: add IPPROTO_ICMP socket kindVasiliy Kulikov
This patch adds IPPROTO_ICMP socket kind. It makes it possible to send ICMP_ECHO messages and receive the corresponding ICMP_ECHOREPLY messages without any special privileges. In other words, the patch makes it possible to implement setuid-less and CAP_NET_RAW-less /bin/ping. In order not to increase the kernel's attack surface, the new functionality is disabled by default, but is enabled at bootup by supporting Linux distributions, optionally with restriction to a group or a group range (see below). Similar functionality is implemented in Mac OS X: http://www.manpagez.com/man/4/icmp/ A new ping socket is created with socket(PF_INET, SOCK_DGRAM, PROT_ICMP) Message identifiers (octets 4-5 of ICMP header) are interpreted as local ports. Addresses are stored in struct sockaddr_in. No port numbers are reserved for privileged processes, port 0 is reserved for API ("let the kernel pick a free number"). There is no notion of remote ports, remote port numbers provided by the user (e.g. in connect()) are ignored. Data sent and received include ICMP headers. This is deliberate to: 1) Avoid the need to transport headers values like sequence numbers by other means. 2) Make it easier to port existing programs using raw sockets. ICMP headers given to send() are checked and sanitized. The type must be ICMP_ECHO and the code must be zero (future extensions might relax this, see below). The id is set to the number (local port) of the socket, the checksum is always recomputed. ICMP reply packets received from the network are demultiplexed according to their id's, and are returned by recv() without any modifications. IP header information and ICMP errors of those packets may be obtained via ancillary data (IP_RECVTTL, IP_RETOPTS, and IP_RECVERR). ICMP source quenches and redirects are reported as fake errors via the error queue (IP_RECVERR); the next hop address for redirects is saved to ee_info (in network order). socket(2) is restricted to the group range specified in "/proc/sys/net/ipv4/ping_group_range". It is "1 0" by default, meaning that nobody (not even root) may create ping sockets. Setting it to "100 100" would grant permissions to the single group (to either make /sbin/ping g+s and owned by this group or to grant permissions to the "netadmins" group), "0 4294967295" would enable it for the world, "100 4294967295" would enable it for the users, but not daemons. The existing code might be (in the unlikely case anyone needs it) extended rather easily to handle other similar pairs of ICMP messages (Timestamp/Reply, Information Request/Reply, Address Mask Request/Reply etc.). Userspace ping util & patch for it: http://openwall.info/wiki/people/segoon/ping For Openwall GNU/*/Linux it was the last step on the road to the setuid-less distro. A revision of this patch (for RHEL5/OpenVZ kernels) is in use in Owl-current, such as in the 2011/03/12 LiveCD ISOs: http://mirrors.kernel.org/openwall/Owl/current/iso/ Initially this functionality was written by Pavel Kankovsky for Linux 2.4.32, but unfortunately it was never made public. All ping options (-b, -p, -Q, -R, -s, -t, -T, -M, -I), are tested with the patch. PATCH v3: - switched to flowi4. - minor changes to be consistent with raw sockets code. PATCH v2: - changed ping_debug() to pr_debug(). - removed CONFIG_IP_PING. - removed ping_seq_fops.owner field (unused for procfs). - switched to proc_net_fops_create(). - switched to %pK in seq_printf(). PATCH v1: - fixed checksumming bug. - CAP_NET_RAW may not create icmp sockets anymore. RFC v2: - minor cleanups. - introduced sysctl'able group range to restrict socket(2). Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
