path: root/net/ipv4/protocol.c
2014-09-19net: Export inet_offloads and inet6_offloadsTom Herbert
Want to be able to use these in foo-over-udp offloads, etc. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-28net: remove outdated comment for ipv4 and ipv6 protocol handlerBaker Zhang
since f9242b6b28d61295f2bf7e8adfb1060b382e5381 inet: Sanitize inet{,6} protocol demux. there are not pretended hash tables for ipv4 or ipv6 protocol handler. Signed-off-by: Baker Zhang <Baker.kernel@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-05ipv4: Disallow non-namespace aware protocols to register.David S. Miller
All in-tree ipv4 protocol implementations are now namespace aware. Therefore all the run-time checks are superfluous. Reject registry of any non-namespace aware ipv4 protocol. Eventually we'll remove prot->netns_ok and this registry time check as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-15net: Add net protocol offload registration infrustructureVlad Yasevich
Create a new data structure for IPv4 protocols that holds GRO/GSO callbacks and a new array to track the protocols that register GRO/GSO. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-19inet: Sanitize inet{,6} protocol demux.David S. Miller
Don't pretend that inet_protos[] and inet6_protos[] are hashes, thay are just a straight arrays. Remove all unnecessary hash masking. Document MAX_INET_PROTOS. Use RAW_HTABLE_SIZE when appropriate. Reported-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27net: add __rcu annotations to protocolEric Dumazet
Add __rcu annotations to : struct net_protocol *inet_protos struct net_protocol *inet6_protos And use appropriate casts to reduce sparse warnings if CONFIG_SPARSE_RCU_POINTER=y Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08net: inet_add_protocol() can use cmpxchg()Eric Dumazet
Use cmpxchg() to get rid of spinlocks in inet_add_protocol() and friends. inet_protos[] & inet6_protos[] are moved to read_mostly section Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-09headers: net/ipv[46]/protocol.c header trimAlexey Dobriyan
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: align inet_protos[] on SMPEric Dumazet
As IPPROTO_TCP is 6, it makes sense to make sure inet_protos[] array is properly cache line aligned to avoid false sharing on SMP. c0680540 b peer_total c0680544 b inet_peer_unused_head c0680560 B inet_protos On i386 this example, we can see that inet_protos[IPPROTO_TCP] shares a potentially hot (and modified) cache line. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
