Currently the behaviour of disable_xfrm is inconsistent between
locally generated and forwarded packets. For locally generated
packets disable_xfrm disables the policy lookup if it is set on
the output device, for forwarded traffic however it looks at the
input device. This makes it impossible to disable xfrm on all
devices but a dummy device and use normal routing to direct
traffic to that device.
Always use the output device when checking disable_xfrm.
During OpenVZ stress testing we found that UDP traffic with random src
can generate too much excessive rt hash growing leading finally to OOM
and kernel panics.
It was found that for 4GB i686 system (having 1048576 total pages and
225280 normal zone pages) kernel allocates the following route hash:
syslog: IP route cache hash table entries: 262144 (order: 8, 1048576
bytes) => ip_rt_max_size = 4194304 entries, i.e. max rt size is
4194304 * 256b = 1Gb of RAM > normal_zone
Attached the patch which removes HASH_HIGHMEM flag from
alloc_large_system_hash() call.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=6388
The bug is caused by ip_route_input dereferencing skb->nh.protocol of
the dummy skb passed dow from inet_rtm_getroute (Thanks Thomas for seeing
it). It only happens if the route requested is for a multicast IP
address.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
When garbage collecting route cache entries of multipath routes
in rt_garbage_collect(), entries were deleted from the hash bucket
'i' while holding a spin lock on bucket 'k' resulting in a system
hang. Delete entries, if any, from bucket 'k' instead.
Signed-off-by: Suresh Bhogavilli <sbhogavilli@verisign.com>
BUG: using smp_processor_id() in preemptible [00000001] code: rpc.statd/2408
And it _is_ a bug, but I guess we don't care enough to add preempt_disable().
Using __get_cpu_var(obj) is slightly faster than per_cpu_ptr(obj,
raw_smp_processor_id()).
1) Smaller code and memory use
For static and small objects, DEFINE_PER_CPU(type, object) is preferred over a
alloc_percpu() : Better and smaller code to access them, and no extra memory
(storing the pointer, and the percpu array of pointers)
x86_64 code before patch
mov 1237577(%rip),%rax # ffffffff803e5990 <rt_cache_stat>
not %rax # part of per_cpu machinery
mov %gs:0x3c,%edx # get cpu number
movslq %edx,%rdx # extend 32 bits cpu number to 64 bits
mov (%rax,%rdx,8),%rax # get the pointer for this cpu
incl 0x38(%rax)
x86_64 code after patch
mov $per_cpu__rt_cache_stat,%rdx
mov %gs:0x48,%rax # get percpu data offset
incl 0x38(%rax,%rdx,1)
2) False sharing avoidance for SMP :
For a small NR_CPUS, the array of per cpu pointers allocated in alloc_percpu()
can be <= 32 bytes. This let slab code gives a part of a cache line. If the
other part of this 64 bytes (or 128 bytes) cache line is used by a mostly
written object, we can have false sharing and expensive per_cpu_ptr() operations.
Size of rt_cache_stat is 64 bytes, so this patch is not a danger of a too big
increase of bss (in UP mode) or static per_cpu data for SMP
(PERCPU_ENOUGH_ROOM is currently 32768 bytes)
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
the patch below marks various variables const in net/; the goal is to
move them to the .rodata section so that they can't false-share
cachelines with things that get written to, as well as potentially
helping gcc a bit with optimisations. (these were found using a gcc
patch to warn about such variables)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
The tcp_ehash hash table gets too big on systems with really big memory.
It is worse on systems with pages larger than 4KB. It wastes memory that
could be better used. It also makes the netstat command slow because reading
/proc/net/tcp and /proc/net/tcp6 needs to go through the full hash table.
The default value should not be larger for larger page sizes. It seems
that the effect of page size is an unintended error dating back a long
time. I also wonder if the default value really should be a larger
fraction of memory for systems with more memory. While systems with
really big ram can afford more space for hash tables, it is not clear to
me that they benefit from increasing the allocation ratio for this table.
The amount of memory allocated is determined by net/ipv4/tcp.c:tcp_init and
mm/page_alloc.c:alloc_large_system_hash.
tcp_init calls alloc_large_system_hash passing parameters-
bucketsize=sizeof(struct tcp_ehash_bucket)
numentries=thash_entries
scale=(num_physpages >= 128 * 1024) ? (25-PAGE_SHIFT) : (27-PAGE_SHIFT)
limit=0
On i386, PAGE_SHIFT is 12 for a page size of 4K
On ia64, PAGE_SHIFT defaults to 14 for a page size of 16K
The num_physpages test above makes the allocation take a larger fraction
of the total memory on systems with larger memory. The threshold size
for a i386 system is 512MB. For an ia64 system with 16KB pages the
threshold is 2GB.
For smaller memory systems-
On i386, scale = (27 - 12) = 15
On ia64, scale = (27 - 14) = 13
For larger memory systems-
On i386, scale = (25 - 12) = 13
On ia64, scale = (25 - 14) = 11
For the rest of this discussion, I'll just track the larger memory case.
The default behavior has numentries=thash_entries=0, so the allocated
size is determined by either scale or by the default limit of 1/16 of
total memory.
In alloc_large_system_hash-
| numentries = (flags & HASH_HIGHMEM) ? nr_all_pages : nr_kernel_pages;
| numentries += (1UL << (20 - PAGE_SHIFT)) - 1;
| numentries >>= 20 - PAGE_SHIFT;
| numentries <<= 20 - PAGE_SHIFT;
At this point, numentries is pages for all of memory, rounded up to the
nearest megabyte boundary.
| /* limit to 1 bucket per 2^scale bytes of low memory */
| if (scale > PAGE_SHIFT)
| numentries >>= (scale - PAGE_SHIFT);
| else
| numentries <<= (PAGE_SHIFT - scale);
On i386, numentries >>= (13 - 12), so numentries is 1/8196 of
bytes of total memory.
On ia64, numentries <<= (14 - 11), so numentries is 1/2048 of
| log2qty = long_log2(numentries);
| do {
| size = bucketsize << log2qty;
bucketsize is 16, so size is 16 times numentries, rounded
down to a power of two.
On i386, size is 1/512 of bytes of total memory.
On ia64, size is 1/128 of bytes of total memory.
For smaller systems the results are
On i386, size is 1/2048 of bytes of total memory.
On ia64, size is 1/512 of bytes of total memory.
The large page effect can be removed by just replacing
the use of PAGE_SHIFT with a constant of 12 in the calls to
alloc_large_system_hash. That makes them more like the other uses of
that function from fs/inode.c and fs/dcache.c
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and
introduces __in_dev_get_rcu() to cover the second case.
1) RCU with refcnt should use in_dev_get().
2) RCU without refcnt should use __in_dev_get_rcu().
3) All others must hold RTNL and use __in_dev_get_rtnl().
There is one exception in net/ipv4/route.c which is in fact a pre-existing
race condition. I've marked it as such so that we remember to fix it.
This patch is based on suggestions and prior work by Suzanne Wood and
Paul McKenney.
One such place that can damage the dst refcnts is route.c with
CONFIG_IP_ROUTE_MULTIPATH_CACHED enabled, i don't see the user's
.config. In this new code i see that rt_intern_hash is called before
dst->refcnt is set to 1, dst is the 2nd arg to rt_intern_hash.
Arg 2 of rt_intern_hash must come with refcnt 1 as it is added to
table or dropped depending on error/add/update. One such example is
ip_mkroute_input where __mkroute_input return rth with refcnt 0 which
is provided to rt_intern_hash. ip_mkroute_output looks like a 2nd such
place. Appending untested patch for comments and review. The idea is
to put previous reference as we are going to return next result/error.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
This patch contains the following possible cleanups:
- make needlessly global code static
- #if 0 the following unused global function:
- xfrm4_state.c: xfrm4_state_fini
- remove the following unneeded EXPORT_SYMBOL's:
- ip_output.c: ip_finish_output
- ip_output.c: sysctl_ip_default_ttl
- fib_frontend.c: ip_dev_find
- inetpeer.c: inet_peer_idlock
- ip_options.c: ip_options_compile
- ip_options.c: ip_options_undo
- net/core/request_sock.c: sysctl_max_syn_backlog
In some cases, we may be generating packets with a source address that
qualifies as martian. This can happen when we're in the middle of setting
up the network, and netfilter decides to reject a packet with an RST.
The IPv4 routing code would try to print a warning and oops, because
locally generated packets do not have a valid skb->mac.raw pointer
at this point.
- rt_check_expire() fixes (an overflow occured if size of the hash
was >= 65536)
reminder of the bugfix:
The rt_check_expire() has a serious problem on machines with large
route caches, and a standard HZ value of 1000.
With default values, ie ip_rt_gc_interval = 60*HZ = 60000 ;
the loop count :
for (t = ip_rt_gc_interval << rt_hash_log; t >= 0;
overflows (t is a 31 bit value) as soon rt_hash_log is >= 16 (65536
slots in route cache hash table).
In this case, rt_check_expire() does nothing at all
- rt hash table allocated using alloc_large_system_hash() function.
- Locking abstraction
- Spinlocks moved out of rt hash table : Less memory (50%) used by rt
hash table. it's a win even on UP.
- Sizing of spinlocks table depends on NR_CPUS
I followed Thomas' proposal to see every martian destination as a case
where the ipInAddrErrors counter has to be incremented. There are
two advantages by doing so: (1) The relation between the ipInReceive
counter and all the other ipInXXX counters is more accurate in the
case the RTN_UNICAST code check fails and (2) it makes the code in
ip_route_input_slow easier.
Signed-off-by: Dietmar Eggemann <dietmar.eggemann@gmx.de>
Signed-off by: Chuck Short <zulcss@gmail.com>
This patch rectifies some rtnetlink message builders that derive the
flags from the pid. It is now explicit like the other cases
which get it right. Also fixes half a dozen dumpers which did not
set NLM_F_MULTI at all.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Ross moved. Remove the bad email address so people will find the correct
one in ./CREDITS.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
Signed-off-by: Olaf Rempel <razzor@kopf-tisch.de>
This has been brought up before.. http://lkml.org/lkml/2000/1/21/116
but didnt seem to get resolved. This morning I got someone
file a bugzilla about it breaking sysctl(8).
Signed-off-by: Dave Jones <davej@redhat.com>
Here is a revised alternative that uses BUG_ON/WARN_ON
(as suggested by Herbert Xu) to eliminate NET_CALLER.
infrastructure for it.
Let it rip!
