Wei Yongjun noticed that we may call reqsk_free on request sock objects where
the opt fields may not be initialized, fix it by introducing inet_reqsk_alloc
where we initialize ->opt to NULL and set ->pktopts to NULL in
inet6_reqsk_alloc.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Allow the use of SACK and window scaling when syncookies are used
and the client supports tcp timestamps. Options are encoded into
the timestamp sent in the syn-ack and restored from the timestamp
echo when the ack is received.
Based on earlier work by Glenn Griffin.
This patch avoids increasing the size of structs by encoding TCP
options into the least significant bits of the timestamp and
by not using any 'timestamp offset'.
The downside is that the timestamp sent in the packet after the synack
will increase by several seconds.
changes since v1:
don't duplicate timestamp echo decoding function, put it into ipv4/syncookie.c
and have ipv6/syncookies.c use it.
Feedback from Glenn Griffin: fix line indented with spaces, kill redundant if ()
Reviewed-by: Hagen Paul Pfeifer <hagen@jauu.net>
the first u32 copied from syncookie_secret is overwritten by the
minute-counter four lines below. After adjusting the destination
address, the size of syncookie_secret can be reduced accordingly.
AFAICS, the only other user of syncookie_secret[] is the ipv6
syncookie support. Because ipv6 syncookies only grab 44 bytes from
syncookie_secret[], this shouldn't affect them in any way.
With fixes from Glenn Griffin.
Acked-by: Glenn Griffin <ggriffin.kernel@gmail.com>
Updated to incorporate Eric's suggestion of using a per cpu buffer
rather than allocating on the stack. Just a two line change, but will
resend in it's entirety.
Signed-off-by: Glenn Griffin <ggriffin.kernel@gmail.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
400 bytes allocated on stack might be a litle bit too much. Using a
per_cpu var is more friendly.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Needed to propagate it down to the ip_route_output_flow.
Signed-off-by: Denis V. Lunev <den@openvz.org>
This automatically labels the TCP, Unix stream, and dccp child sockets
as well as openreqs to be at the same MLS level as the peer. This will
result in the selection of appropriately labeled IPSec Security
Associations.
This also uses the sock's sid (as opposed to the isec sid) in SELinux
enforcement of secmark in rcv_skb and postroute_last hooks.
Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com>
This labels the flows that could utilize IPSec xfrms at the points the
flows are defined so that IPSec policy and SAs at the right label can
be used.
The following protos are currently not handled, but they should
continue to be able to use single-labeled IPSec like they currently
do.
ipmr
ip_gre
ipip
igmp
sit
sctp
ip6_tunnel (IPv6 over IPv6 tunnel device)
decnet
And move it to struct inet_connection_sock. DCCP will use it in the
upcoming changesets.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Of this type, mostly:
CHECK net/ipv6/netfilter.c
net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static?
net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static?
This creates struct inet_connection_sock, moving members out of struct
tcp_sock that are shareable with other INET connection oriented
protocols, such as DCCP, that in my private tree already uses most of
these members.
The functions that operate on these members were renamed, using a
inet_csk_ prefix while not being moved yet to a new file, so as to
ease the review of these changes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Ok, this one just renames some stuff to have a better namespace and to
dissassociate it from TCP:
struct open_request -> struct request_sock
tcp_openreq_alloc -> reqsk_alloc
tcp_openreq_free -> reqsk_free
tcp_openreq_fastfree -> __reqsk_free
With this most of the infrastructure closely resembles a struct
sock methods subset.
Kept this first changeset minimal, without changing existing names to
ease peer review.
Basicaly tcp_openreq_alloc now receives the or_calltable, that in turn
has two new members:
->slab, that replaces tcp_openreq_cachep
->obj_size, to inform the size of the openreq descendant for
a specific protocol
The protocol specific fields in struct open_request were moved to a
class hierarchy, with the things that are common to all connection
oriented PF_INET protocols in struct inet_request_sock, the TCP ones
in tcp_request_sock, that is an inet_request_sock, that is an
open_request.
I.e. this uses the same approach used for the struct sock class
hierarchy, with sk_prot indicating if the protocol wants to use the
open_request infrastructure by filling in sk_prot->rsk_prot with an
or_calltable.
Results? Performance is improved and TCP v4 now uses only 64 bytes per
open request minisock, down from 96 without this patch :-)
Next changeset will rename some of the structs, fields and functions
mentioned above, struct or_calltable is way unclear, better name it
struct request_sock_ops, s/struct open_request/struct request_sock/g,
etc.
infrastructure for it.
Let it rip!
