Signed-off-by: Nikolay Borisov <kernel@kyup.com>
Pull networking fixes from David Miller:
"This looks like a lot but it's a mixture of regression fixes as well
as fixes for longer standing issues.
1) Fix on-channel cancellation in mac80211, from Johannes Berg.
2) Handle CHECKSUM_COMPLETE properly in xt_TCPMSS netfilter xtables
module, from Eric Dumazet.
3) Avoid infinite loop in UDP SO_REUSEPORT logic, also from Eric
Dumazet.
4) Avoid a NULL deref if we try to set SO_REUSEPORT after a socket is
bound, from Craig Gallek.
5) GRO key comparisons don't take lightweight tunnels into account,
from Jesse Gross.
6) Fix struct pid leak via SCM credentials in AF_UNIX, from Eric
Dumazet.
7) We need to set the rtnl_link_ops of ipv6 SIT tunnels before we
register them, otherwise the NEWLINK netlink message is missing
the proper attributes. From Thadeu Lima de Souza Cascardo.
8) Several Spectrum chip bug fixes for mlxsw switch driver, from Ido
Schimmel
9) Handle fragments properly in ipv4 easly socket demux, from Eric
Dumazet.
10) Don't ignore the ifindex key specifier on ipv6 output route
lookups, from Paolo Abeni"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (128 commits)
tcp: avoid cwnd undo after receiving ECN
irda: fix a potential use-after-free in ircomm_param_request
net: tg3: avoid uninitialized variable warning
net: nb8800: avoid uninitialized variable warning
net: vxge: avoid unused function warnings
net: bgmac: clarify CONFIG_BCMA dependency
net: hp100: remove unnecessary #ifdefs
net: davinci_cpdma: use dma_addr_t for DMA address
ipv6/udp: use sticky pktinfo egress ifindex on connect()
ipv6: enforce flowi6_oif usage in ip6_dst_lookup_tail()
netlink: not trim skb for mmaped socket when dump
vxlan: fix a out of bounds access in __vxlan_find_mac
net: dsa: mv88e6xxx: fix port VLAN maps
fib_trie: Fix shift by 32 in fib_table_lookup
net: moxart: use correct accessors for DMA memory
ipv4: ipconfig: avoid unused ic_proto_used symbol
bnxt_en: Fix crash in bnxt_free_tx_skbs() during tx timeout.
bnxt_en: Exclude rx_drop_pkts hw counter from the stack's rx_dropped counter.
bnxt_en: Ring free response from close path should use completion ring
net_sched: drr: check for NULL pointer in drr_dequeue
This patch replaces uses of the long obsolete hash interface with
ahash.
Neal reported crashes with this stack trace :
RIP: 0010:[<ffffffff8c57231b>] tcp_v4_send_ack+0x41/0x20f
CR2: 0000000000000018 CR3: 000000044005c000 CR4: 00000000001427e0
[<ffffffff8c57258e>] tcp_v4_reqsk_send_ack+0xa5/0xb4
[<ffffffff8c1a7caa>] tcp_check_req+0x2ea/0x3e0
[<ffffffff8c19e420>] tcp_rcv_state_process+0x850/0x2500
[<ffffffff8c1a6d21>] tcp_v4_do_rcv+0x141/0x330
[<ffffffff8c56cdb2>] sk_backlog_rcv+0x21/0x30
[<ffffffff8c098bbd>] tcp_recvmsg+0x75d/0xf90
[<ffffffff8c0a8700>] inet_recvmsg+0x80/0xa0
[<ffffffff8c17623e>] sock_aio_read+0xee/0x110
[<ffffffff8c066fcf>] do_sync_read+0x6f/0xa0
[<ffffffff8c0673a1>] SyS_read+0x1e1/0x290
[<ffffffff8c5ca262>] system_call_fastpath+0x16/0x1b
The problem here is the skb we provide to tcp_v4_send_ack() had to
be parked in the backlog of a new TCP fastopen child because this child
was owned by the user at the time an out of window packet arrived.
Before queuing a packet, TCP has to set skb->dev to NULL as the device
could disappear before packet is removed from the queue.
Fix this issue by using the net pointer provided by the socket (being a
timewait or a request socket).
IPv6 is immune to the bug : tcp_v6_send_response() already gets the net
pointer from the socket if provided.
Fixes: 168a8f58059a ("tcp: TCP Fast Open Server - main code path")
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Jerry Chu <hkchu@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
tcp_memcontrol.c only contains legacy memory.tcp.kmem.* file definitions
and mem_cgroup->tcp_mem init/destroy stuff. This doesn't belong to
network subsys. Let's move it to memcontrol.c. This also allows us to
reuse generic code for handling legacy memcg files.
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
There won't be any separate counters for socket memory consumed by
protocols other than TCP in the future. Remove the indirection and link
sockets directly to their owning memory cgroup.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Move the jump-label from sock_update_memcg() and sock_release_memcg() to
the callsite, and so eliminate those function calls when socket
accounting is not enabled.
This also eliminates the need for dummy functions because the calls will
be optimized away if the Kconfig options are not enabled.
This is the final part required to namespaceify the tcp
keep alive mechanism.
This is required to have full tcp keepalive mechanism namespace
support.
Different net namespaces might have different requirements as to
the keepalive time of tcp sockets. This might be required in cases
where different firewall rules are in place which require tcp
timeout sockets to be increased/decreased independently of the host.
Hannes points out that when we generate tcp reset for timewait sockets we
pretend we found no socket and pass NULL sk to tcp_vX_send_reset().
Make it cope with inet tw sockets and then provide tw sk.
This makes RSTs appear on correct interface when SO_BINDTODEVICE is used.
Packetdrill test case:
// want default route to be used, we rely on BINDTODEVICE
`ip route del 192.0.2.0/24 via 192.168.0.2 dev tun0`
0.000 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
// test case still works due to BINDTODEVICE
0.001 setsockopt(3, SOL_SOCKET, SO_BINDTODEVICE, "tun0", 4) = 0
0.100...0.200 connect(3, ..., ...) = 0
0.100 > S 0:0(0) <mss 1460,sackOK,nop,nop>
0.200 < S. 0:0(0) ack 1 win 32792 <mss 1460,sackOK,nop,nop>
0.200 > . 1:1(0) ack 1
0.210 close(3) = 0
0.210 > F. 1:1(0) ack 1 win 29200
0.300 < . 1:1(0) ack 2 win 46
// more data while in FIN_WAIT2, expect RST
1.300 < P. 1:1001(1000) ack 1 win 46
// fails without this change -- default route is used
1.301 > R 1:1(0) win 0
Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
tcp_md5_do_lookup requires a full socket, so once we extend
_send_reset() to also accept timewait socket we would have to change
if (!sk && hash_location)
to something like
if ((!sk || !sk_fullsock(sk)) && hash_location) {
} else {
(sk && sk_fullsock(sk)) tcp_md5_do_lookup()
Switch the two branches: check if we have a socket first, then
fall back to a listener lookup if we saw a md5 option (hash_location).
Allow accepted sockets to derive their sk_bound_dev_if setting from the
l3mdev domain in which the packets originated. A sysctl setting is added
to control the behavior which is similar to sk_mark and
sysctl_tcp_fwmark_accept.
This effectively allow a process to have a "VRF-global" listen socket,
with child sockets bound to the VRF device in which the packet originated.
A similar behavior can be achieved using sk_mark, but a solution using marks
is incomplete as it does not handle duplicate addresses in different L3
domains/VRFs. Allowing sockets to inherit the sk_bound_dev_if from l3mdev
domain provides a complete solution.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
drivers/net/geneve.c
Here we had an overlapping change, where in 'net' the extraneous stats
bump was being removed whilst in 'net-next' the final argument to
udp_tunnel6_xmit_skb() was being changed.
This implements SOCK_DESTROY for TCP sockets. It causes all
blocking calls on the socket to fail fast with ECONNABORTED and
causes a protocol close of the socket. It informs the other end
of the connection by sending a RST, i.e., initiating a TCP ABORT
as per RFC 793. ECONNABORTED was chosen for consistency with
FreeBSD.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
David Wilder reported crashes caused by dst reuse.
<quote David>
I am seeing a crash on a distro V4.2.3 kernel caused by a double
release of a dst_entry. In ipv4_dst_destroy() the call to
list_empty() finds a poisoned next pointer, indicating the dst_entry
has already been removed from the list and freed. The crash occurs
18 to 24 hours into a run of a network stress exerciser.
</quote>
Thanks to his detailed report and analysis, we were able to understand
the core issue.
IP early demux can associate a dst to skb, after a lookup in TCP/UDP
sockets.
When socket cache is not properly set, we want to store into
sk->sk_dst_cache the dst for future IP early demux lookups,
by acquiring a stable refcount on the dst.
Problem is this acquisition is simply using an atomic_inc(),
which works well, unless the dst was queued for destruction from
dst_release() noticing dst refcount went to zero, if DST_NOCACHE
was set on dst.
We need to make sure current refcount is not zero before incrementing
it, or risk double free as David reported.
This patch, being a stable candidate, adds two new helpers, and use
them only from IP early demux problematic paths.
It might be possible to merge in net-next skb_dst_force() and
skb_dst_force_safe(), but I prefer having the smallest patch for stable
kernels : Maybe some skb_dst_force() callers do not expect skb->dst
can suddenly be cleared.
Can probably be backported back to linux-3.6 kernels
Reported-by: David J. Wilder <dwilder@us.ibm.com>
Tested-by: David J. Wilder <dwilder@us.ibm.com>
When a passive TCP is created, we eventually call tcp_md5_do_add()
with sk pointing to the child. It is not owner by the user yet (we
will add this socket into listener accept queue a bit later anyway)
But we do own the spinlock, so amend the lockdep annotation to avoid
following splat :
[ 8451.090932] net/ipv4/tcp_ipv4.c:923 suspicious rcu_dereference_protected() usage!
[ 8451.090932]
[ 8451.090932] other info that might help us debug this:
[ 8451.090932]
[ 8451.090934]
[ 8451.090934] rcu_scheduler_active = 1, debug_locks = 1
[ 8451.090936] 3 locks held by socket_sockopt_/214795:
[ 8451.090936] #0: (rcu_read_lock){.+.+..}, at: [<ffffffff855c6ac1>] __netif_receive_skb_core+0x151/0xe90
[ 8451.090947] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff85618143>] ip_local_deliver_finish+0x43/0x2b0
[ 8451.090952] #2: (slock-AF_INET){+.-...}, at: [<ffffffff855acda5>] sk_clone_lock+0x1c5/0x500
[ 8451.090958]
[ 8451.090958] stack backtrace:
[ 8451.090960] CPU: 7 PID: 214795 Comm: socket_sockopt_
[ 8451.091215] Call Trace:
[ 8451.091216] <IRQ> [<ffffffff856fb29c>] dump_stack+0x55/0x76
[ 8451.091229] [<ffffffff85123b5b>] lockdep_rcu_suspicious+0xeb/0x110
[ 8451.091235] [<ffffffff8564544f>] tcp_md5_do_add+0x1bf/0x1e0
[ 8451.091239] [<ffffffff85645751>] tcp_v4_syn_recv_sock+0x1f1/0x4c0
[ 8451.091242] [<ffffffff85642b27>] ? tcp_v4_md5_hash_skb+0x167/0x190
[ 8451.091246] [<ffffffff85647c78>] tcp_check_req+0x3c8/0x500
[ 8451.091249] [<ffffffff856451ae>] ? tcp_v4_inbound_md5_hash+0x11e/0x190
[ 8451.091253] [<ffffffff85647170>] tcp_v4_rcv+0x3c0/0x9f0
[ 8451.091256] [<ffffffff85618143>] ? ip_local_deliver_finish+0x43/0x2b0
[ 8451.091260] [<ffffffff856181b6>] ip_local_deliver_finish+0xb6/0x2b0
[ 8451.091263] [<ffffffff85618143>] ? ip_local_deliver_finish+0x43/0x2b0
[ 8451.091267] [<ffffffff85618d38>] ip_local_deliver+0x48/0x80
[ 8451.091270] [<ffffffff85618510>] ip_rcv_finish+0x160/0x700
[ 8451.091273] [<ffffffff8561900e>] ip_rcv+0x29e/0x3d0
[ 8451.091277] [<ffffffff855c74b7>] __netif_receive_skb_core+0xb47/0xe90
Fixes: a8afca0329988 ("tcp: md5: protects md5sig_info with RCU")
Reported-by: Willem de Bruijn <willemb@google.com>
Some functions access TCP sockets without holding a lock and
might output non consistent data, depending on compiler and or
architecture.
tcp_diag_get_info(), tcp_get_info(), tcp_poll(), get_tcp4_sock() ...
Introduce sk_state_load() and sk_state_store() to fix the issues,
and more clearly document where this lack of locking is happening.
I mistakenly took wrong request sock pointer when calling tcp_move_syn()
@req_unhash is either a copy of @req, or a NULL value for
FastOpen connexions (as we do not expect to unhash the temporary
request sock from ehash table)
Fixes: 805c4bc05705 ("tcp: fix req->saved_syn race")
Cc: Ying Cai <ycai@google.com>
For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix
ireq->pktopts race"), we need to make sure we do not access
req->saved_syn unless we own the request sock.
This fixes races for listeners using TCP_SAVE_SYN option.
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
Reported-by: Ying Cai <ycai@google.com>
Multiple cpus can process duplicates of incoming ACK messages
matching a SYN_RECV request socket. This is a rare event under
normal operations, but definitely can happen.
Only one must win the race, otherwise corruption would occur.
To fix this without adding new atomic ops, we use logic in
inet_ehash_nolisten() to detect the request was present in the same
ehash bucket where we try to insert the new child.
If request socket was not found, we have to undo the child creation.
This actually removes a spin_lock()/spin_unlock() pair in
reqsk_queue_unlink() for the fast path.
At the time of commit fff326990789 ("tcp: reflect SYN queue_mapping into
SYNACK packets") we had little ways to cope with SYN floods.
We no longer need to reflect incoming skb queue mappings, and instead
can pick a TX queue based on cpu cooking the SYNACK, with normal XPS
affinities.
Note that all SYNACK retransmits were picking TX queue 0, this no longer
is a win given that SYNACK rtx are now distributed on all cpus.
Let's reduce the confusion about inet_csk_reqsk_queue_drop() :
In many cases we also need to release reference on request socket,
so add a helper to do this, reducing code size and complexity.
Fixes: 4bdc3d66147b ("tcp/dccp: fix behavior of stale SYN_RECV request sockets")
This reverts commit c69736696cf3742b37d850289dc0d7ead177bb14.
At the time of above commit, tcp_req_err() and dccp_req_err()
were dead code, as SYN_RECV request sockets were not yet in ehash table.
Real bug was fixed later in a different commit.
We need to revert to not leak a refcount on request socket.
inet_csk_reqsk_queue_drop_and_put() will be added
in following commit to make clean inet_csk_reqsk_queue_drop()
does not release the reference owned by caller.
When a TCP/DCCP listener is closed, its pending SYN_RECV request sockets
become stale, meaning 3WHS can not complete.
But current behavior is wrong :
incoming packets finding such stale sockets are dropped.
We need instead to cleanup the request socket and perform another
lookup :
- Incoming ACK will give a RST answer,
- SYN rtx might find another listener if available.
- We expedite cleanup of request sockets and old listener socket.
One 32bit hole is following skc_refcnt, use it.
skc_incoming_cpu can also be an union for request_sock rcv_wnd.
Everything should now be ready to finally allow SYN
packets processing without holding listener lock.
Tested:
3.5 Mpps SYNFLOOD. Plenty of cpu cycles available.
Next bottleneck is the refcount taken on listener,
that could be avoided if we remove SLAB_DESTROY_BY_RCU
strict semantic for listeners, and use regular RCU.
13.18% [kernel] [k] __inet_lookup_listener
9.61% [kernel] [k] tcp_conn_request
8.16% [kernel] [k] sha_transform
5.30% [kernel] [k] inet_reqsk_alloc
4.22% [kernel] [k] sock_put
3.74% [kernel] [k] tcp_make_synack
2.88% [kernel] [k] ipt_do_table
2.56% [kernel] [k] memcpy_erms
2.53% [kernel] [k] sock_wfree
2.40% [kernel] [k] tcp_v4_rcv
2.08% [kernel] [k] fib_table_lookup
1.84% [kernel] [k] tcp_openreq_init_rwin
If a listen backlog is very big (to avoid syncookies), then
the listener sk->sk_wmem_alloc is the main source of false
sharing, as we need to touch it twice per SYNACK re-transmit
and TX completion.
(One SYN packet takes listener lock once, but up to 6 SYNACK
are generated)
By attaching the skb to the request socket, we remove this
source of contention.
Tested:
listen(fd, 10485760); // single listener (no SO_REUSEPORT)
16 RX/TX queue NIC
Sustain a SYNFLOOD attack of ~320,000 SYN per second,
Sending ~1,400,000 SYNACK per second.
Perf profiles now show listener spinlock being next bottleneck.
20.29% [kernel] [k] queued_spin_lock_slowpath
10.06% [kernel] [k] __inet_lookup_established
5.12% [kernel] [k] reqsk_timer_handler
3.22% [kernel] [k] get_next_timer_interrupt
3.00% [kernel] [k] tcp_make_synack
2.77% [kernel] [k] ipt_do_table
2.70% [kernel] [k] run_timer_softirq
2.50% [kernel] [k] ip_finish_output
2.04% [kernel] [k] cascade
In this patch, we insert request sockets into TCP/DCCP
regular ehash table (where ESTABLISHED and TIMEWAIT sockets
are) instead of using the per listener hash table.
ACK packets find SYN_RECV pseudo sockets without having
to find and lock the listener.
In nominal conditions, this halves pressure on listener lock.
Note that this will allow for SO_REUSEPORT refinements,
so that we can select a listener using cpu/numa affinities instead
of the prior 'consistent hash', since only SYN packets will
apply this selection logic.
We will shrink listen_sock in the following patch to ease
code review.
Cc: Willem de Bruijn <willemb@google.com>
When request sockets are no longer in a per listener hash table
but on regular TCP ehash, we need to access listener uid
through req->rsk_listener
get_openreq6() also gets a const for its request socket argument.
We'll soon have to call tcp_v[46]_inbound_md5_hash() twice.
Also add const attribute to the socket, as it might be the
unlocked listener for SYN packets.
This fixes a typo : We want to store the NAPI id on child socket.
Presumably nobody really uses busy polling, on short lived flows.
Fixes: 3d97379a67486 ("tcp: move sk_mark_napi_id() at the right place")
While auditing TCP stack for upcoming 'lockless' listener changes,
I found I had to change fastopen_init_queue() to properly init the object
before publishing it.
Otherwise an other cpu could try to lock the spinlock before it gets
properly initialized.
Instead of adding appropriate barriers, just remove dynamic memory
allocations :
- Structure is 28 bytes on 64bit arches. Using additional 8 bytes
for holding a pointer seems overkill.
- Two listeners can share same cache line and performance would suffer.
If we really want to save few bytes, we would instead dynamically allocate
whole struct request_sock_queue in the future.
These functions do not change the listener socket.
Goal is to make sure tcp_conn_request() is not messing with
listener in a racy way.
We'll soon no longer hold listener socket lock, these
functions do not modify the socket in any way.
Factorize code to get tcp header from skb. It makes no sense
to duplicate code in callers.
Once we realize tcp_rcv_synsent_state_process() does not use
its 'len' argument and we get rid of it, then it becomes clear
this argument is no longer used in tcp_rcv_state_process()
None of these functions need to change the socket, make it
const.
This documents fact that listener lock might not be held
at the time SYNACK are sent.
When TCP new listener is done, these functions will be called
without socket lock being held. Make sure they don't change
anything.
Soon, listener socket spinlock will no longer be held,
add const arguments to tcp_v[46]_init_req() to make clear these
functions can not mess socket fields.
Neal suggested to move sk_txhash init into tcp_create_openreq_child(),
called both from IPv4 and IPv6.
This opportunity was missed in commit 58d607d3e52f ("tcp: provide
skb->hash to synack packets")
Signed-off-by: Neal Cardwell <ncardwell@google.com>
In commit b73c3d0e4f0e ("net: Save TX flow hash in sock and set in skbuf
on xmit"), Tom provided a l4 hash to most outgoing TCP packets.
We'd like to provide one as well for SYNACK packets, so that all packets
of a given flow share same txhash, to later enable bonding driver to
also use skb->hash to perform slave selection.
Note that a SYNACK retransmit shuffles the tx hash, as Tom did
in commit 265f94ff54d62 ("net: Recompute sk_txhash on negative routing
advice") for established sockets.
This has nice effect making TCP flows resilient to some kind of black
holes, even at connection establish phase.
Cc: Tom Herbert <tom@herbertland.com>
Cc: Mahesh Bandewar <maheshb@google.com>
Acked-by: Tom Herbert <tom@herbertland.com>
drivers/net/ethernet/cavium/Kconfig
The cavium conflict was overlapping dependency
changes.
In commit b357a364c57c9 ("inet: fix possible panic in
reqsk_queue_unlink()"), I missed fact that tcp_check_req()
can return the listener socket in one case, and that we must
release the request socket refcount or we leak it.
Tested:
Following packetdrill test template shows the issue
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1) = 0
+0 < S 0:0(0) win 2920 <mss 1460,sackOK,nop,nop>
+0 > S. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK>
+.002 < . 1:1(0) ack 21 win 2920
+0 > R 21:21(0)
Fixes: b357a364c57c9 ("inet: fix possible panic in reqsk_queue_unlink()")
This patch creates sk_set_txhash and eliminates protocol specific
inet_set_txhash and ip6_set_txhash. sk_set_txhash simply sets a
random number instead of performing flow dissection. sk_set_txash
is also allowed to be called multiple times for the same socket,
we'll need this when redoing the hash for negative routing advice.
Signed-off-by: Tom Herbert <tom@herbertland.com>
