Pull networking fixes from David Miller:
1) Include fixes for netrom and dsa (Fabian Frederick and Florian
Fainelli)
2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO.
3) Several SKB use after free fixes (vxlan, openvswitch, vxlan,
ip_tunnel, fou), from Li ROngQing.
4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy.
5) Use after free in virtio_net, from Michael S Tsirkin.
6) Fix flow mask handling for megaflows in openvswitch, from Pravin B
Shelar.
7) ISDN gigaset and capi bug fixes from Tilman Schmidt.
8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin.
9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov.
10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong
Wang and Eric Dumazet.
11) Don't overwrite end of SKB when parsing malformed sctp ASCONF
chunks, from Daniel Borkmann.
12) Don't call sock_kfree_s() with NULL pointers, this function also has
the side effect of adjusting the socket memory usage. From Cong Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
bna: fix skb->truesize underestimation
net: dsa: add includes for ethtool and phy_fixed definitions
openvswitch: Set flow-key members.
netrom: use linux/uaccess.h
dsa: Fix conversion from host device to mii bus
tipc: fix bug in bundled buffer reception
ipv6: introduce tcp_v6_iif()
sfc: add support for skb->xmit_more
r8152: return -EBUSY for runtime suspend
ipv4: fix a potential use after free in fou.c
ipv4: fix a potential use after free in ip_tunnel_core.c
hyperv: Add handling of IP header with option field in netvsc_set_hash()
openvswitch: Create right mask with disabled megaflows
vxlan: fix a free after use
openvswitch: fix a use after free
ipv4: dst_entry leak in ip_send_unicast_reply()
ipv4: clean up cookie_v4_check()
ipv4: share tcp_v4_save_options() with cookie_v4_check()
ipv4: call __ip_options_echo() in cookie_v4_check()
atm: simplify lanai.c by using module_pci_driver
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
TCP Small queues tries to keep number of packets in qdisc
as small as possible, and depends on a tasklet to feed following
packets at TX completion time.
Choice of tasklet was driven by latencies requirements.
Then, TCP stack tries to avoid reorders, by locking flows with
outstanding packets in qdisc in a given TX queue.
What can happen is that many flows get attracted by a low performing
TX queue, and cpu servicing TX completion has to feed packets for all of
them, making this cpu 100% busy in softirq mode.
This became particularly visible with latest skb->xmit_more support
Strategy adopted in this patch is to detect when tcp_wfree() is called
from ksoftirqd and let the outstanding queue for this flow being drained
before feeding additional packets, so that skb->ooo_okay can be set
to allow select_queue() to select the optimal queue :
Incoming ACKS are normally handled by different cpus, so this patch
gives more chance for these cpus to take over the burden of feeding
qdisc with future packets.
Tested:
lpaa23:~# ./super_netperf 1400 --google-pacing-rate 3028000 -H lpaa24 -l 3600 &
lpaa23:~# sar -n DEV 1 10 | grep eth1
06:16:18 AM eth1 595448.00 1190564.00 38381.09 1760253.12 0.00 0.00 1.00
06:16:19 AM eth1 594858.00 1189686.00 38340.76 1758952.72 0.00 0.00 0.00
06:16:20 AM eth1 597017.00 1194019.00 38480.79 1765370.29 0.00 0.00 1.00
06:16:21 AM eth1 595450.00 1190936.00 38380.19 1760805.05 0.00 0.00 0.00
06:16:22 AM eth1 596385.00 1193096.00 38442.56 1763976.29 0.00 0.00 1.00
06:16:23 AM eth1 598155.00 1195978.00 38552.97 1768264.60 0.00 0.00 0.00
06:16:24 AM eth1 594405.00 1188643.00 38312.57 1757414.89 0.00 0.00 1.00
06:16:25 AM eth1 593366.00 1187154.00 38252.16 1755195.83 0.00 0.00 0.00
06:16:26 AM eth1 593188.00 1186118.00 38232.88 1753682.57 0.00 0.00 1.00
06:16:27 AM eth1 596301.00 1192241.00 38440.94 1762733.09 0.00 0.00 0.00
Average: eth1 595457.30 1190843.50 38381.69 1760664.84 0.00 0.00 0.50
lpaa23:~# ./tc -s -d qd sh dev eth1 | grep backlog
backlog 7606336b 2513p requeues 167982
backlog 224072b 74p requeues 566
backlog 581376b 192p requeues 5598
backlog 181680b 60p requeues 1070
backlog 5305056b 1753p requeues 110166 // Here, this TX queue is attracting flows
backlog 157456b 52p requeues 1758
backlog 672216b 222p requeues 3025
backlog 60560b 20p requeues 24541
backlog 448144b 148p requeues 21258
lpaa23:~# echo 1 >/proc/sys/net/ipv4/tcp_tsq_enable_tcp_wfree_ksoftirqd_detect
Immediate jump to full bandwidth, and traffic is properly
shard on all tx queues.
06:16:46 AM eth1 1397632.00 2795397.00 90081.87 4133031.26 0.00 0.00 1.00
06:16:47 AM eth1 1396874.00 2793614.00 90032.99 4130385.46 0.00 0.00 0.00
06:16:48 AM eth1 1395842.00 2791600.00 89966.46 4127409.67 0.00 0.00 1.00
06:16:49 AM eth1 1395528.00 2791017.00 89946.17 4126551.24 0.00 0.00 0.00
06:16:50 AM eth1 1397891.00 2795716.00 90098.74 4133497.39 0.00 0.00 1.00
06:16:51 AM eth1 1394951.00 2789984.00 89908.96 4125022.51 0.00 0.00 0.00
06:16:52 AM eth1 1394608.00 2789190.00 89886.90 4123851.36 0.00 0.00 1.00
06:16:53 AM eth1 1395314.00 2790653.00 89934.33 4125983.09 0.00 0.00 0.00
06:16:54 AM eth1 1396115.00 2792276.00 89984.25 4128411.21 0.00 0.00 1.00
06:16:55 AM eth1 1396829.00 2793523.00 90030.19 4130250.28 0.00 0.00 0.00
Average: eth1 1396158.40 2792297.00 89987.09 4128439.35 0.00 0.00 0.50
lpaa23:~# tc -s -d qd sh dev eth1 | grep backlog
backlog 7900052b 2609p requeues 173287
backlog 878120b 290p requeues 589
backlog 1068884b 354p requeues 5621
backlog 996212b 329p requeues 1088
backlog 984100b 325p requeues 115316
backlog 956848b 316p requeues 1781
backlog 1080996b 357p requeues 3047
backlog 975016b 322p requeues 24571
backlog 990156b 327p requeues 21274
(All 8 TX queues get a fair share of the traffic)
TCP Small Queues (tcp_tsq_handler()) can hold one reference on
sk->sk_wmem_alloc, preventing skb->ooo_okay being set.
We should relax test done to set skb->ooo_okay to take care
of this extra reference.
Minimal truesize of skb containing one byte of payload is
SKB_TRUESIZE(1)
Without this fix, we have more chance locking flows into the wrong
transmit queue.
Lets use a proper structure to clearly document and implement
skb fast clones.
Then, we might experiment more easily alternative layouts.
This patch adds a new skb_fclone_busy() helper, used by tcp and xfrm,
to stop leaking of implementation details.
Suggested by Stephen. Also drop inline keyword and let compiler decide.
gcc 4.7.3 decides to no longer inline tcp_ecn_check_ce, so split it up.
The actual evaluation is not inlined anymore while the ECN_OK test is.
Suggested-by: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
This work adds the DataCenter TCP (DCTCP) congestion control
algorithm [1], which has been first published at SIGCOMM 2010 [2],
resp. follow-up analysis at SIGMETRICS 2011 [3] (and also, more
recently as an informational IETF draft available at [4]).
DCTCP is an enhancement to the TCP congestion control algorithm for
data center networks. Typical data center workloads are i.e.
i) partition/aggregate (queries; bursty, delay sensitive), ii) short
messages e.g. 50KB-1MB (for coordination and control state; delay
sensitive), and iii) large flows e.g. 1MB-100MB (data update;
throughput sensitive). DCTCP has therefore been designed for such
environments to provide/achieve the following three requirements:
* High burst tolerance (incast due to partition/aggregate)
* Low latency (short flows, queries)
* High throughput (continuous data updates, large file
transfers) with commodity, shallow buffered switches
The basic idea of its design consists of two fundamentals: i) on the
switch side, packets are being marked when its internal queue
length > threshold K (K is chosen so that a large enough headroom
for marked traffic is still available in the switch queue); ii) the
sender/host side maintains a moving average of the fraction of marked
packets, so each RTT, F is being updated as follows:
F := X / Y, where X is # of marked ACKs, Y is total # of ACKs
alpha := (1 - g) * alpha + g * F, where g is a smoothing constant
The resulting alpha (iow: probability that switch queue is congested)
is then being used in order to adaptively decrease the congestion
window W:
W := (1 - (alpha / 2)) * W
The means for receiving marked packets resp. marking them on switch
side in DCTCP is the use of ECN.
RFC3168 describes a mechanism for using Explicit Congestion Notification
from the switch for early detection of congestion, rather than waiting
for segment loss to occur.
However, this method only detects the presence of congestion, not
the *extent*. In the presence of mild congestion, it reduces the TCP
congestion window too aggressively and unnecessarily affects the
throughput of long flows [4].
DCTCP, as mentioned, enhances Explicit Congestion Notification (ECN)
processing to estimate the fraction of bytes that encounter congestion,
rather than simply detecting that some congestion has occurred. DCTCP
then scales the TCP congestion window based on this estimate [4],
thus it can derive multibit feedback from the information present in
the single-bit sequence of marks in its control law. And thus act in
*proportion* to the extent of congestion, not its *presence*.
Switches therefore set the Congestion Experienced (CE) codepoint in
packets when internal queue lengths exceed threshold K. Resulting,
DCTCP delivers the same or better throughput than normal TCP, while
using 90% less buffer space.
It was found in [2] that DCTCP enables the applications to handle 10x
the current background traffic, without impacting foreground traffic.
Moreover, a 10x increase in foreground traffic did not cause any
timeouts, and thus largely eliminates TCP incast collapse problems.
The algorithm itself has already seen deployments in large production
data centers since then.
We did a long-term stress-test and analysis in a data center, short
summary of our TCP incast tests with iperf compared to cubic:
This test measured DCTCP throughput and latency and compared it with
CUBIC throughput and latency for an incast scenario. In this test, 19
senders sent at maximum rate to a single receiver. The receiver simply
ran iperf -s.
The senders ran iperf -c <receiver> -t 30. All senders started
simultaneously (using local clocks synchronized by ntp).
This test was repeated multiple times. Below shows the results from a
single test. Other tests are similar. (DCTCP results were extremely
consistent, CUBIC results show some variance induced by the TCP timeouts
that CUBIC encountered.)
For this test, we report statistics on the number of TCP timeouts,
flow throughput, and traffic latency.
1) Timeouts (total over all flows, and per flow summaries):
CUBIC DCTCP
Total 3227 25
Mean 169.842 1.316
Median 183 1
Max 207 5
Min 123 0
Stddev 28.991 1.600
Timeout data is taken by measuring the net change in netstat -s
"other TCP timeouts" reported. As a result, the timeout measurements
above are not restricted to the test traffic, and we believe that it
is likely that all of the "DCTCP timeouts" are actually timeouts for
non-test traffic. We report them nevertheless. CUBIC will also include
some non-test timeouts, but they are drawfed by bona fide test traffic
timeouts for CUBIC. Clearly DCTCP does an excellent job of preventing
TCP timeouts. DCTCP reduces timeouts by at least two orders of
magnitude and may well have eliminated them in this scenario.
2) Throughput (per flow in Mbps):
CUBIC DCTCP
Mean 521.684 521.895
Median 464 523
Max 776 527
Min 403 519
Stddev 105.891 2.601
Fairness 0.962 0.999
Throughput data was simply the average throughput for each flow
reported by iperf. By avoiding TCP timeouts, DCTCP is able to
achieve much better per-flow results. In CUBIC, many flows
experience TCP timeouts which makes flow throughput unpredictable and
unfair. DCTCP, on the other hand, provides very clean predictable
throughput without incurring TCP timeouts. Thus, the standard deviation
of CUBIC throughput is dramatically higher than the standard deviation
of DCTCP throughput.
Mean throughput is nearly identical because even though cubic flows
suffer TCP timeouts, other flows will step in and fill the unused
bandwidth. Note that this test is something of a best case scenario
for incast under CUBIC: it allows other flows to fill in for flows
experiencing a timeout. Under situations where the receiver is issuing
requests and then waiting for all flows to complete, flows cannot fill
in for timed out flows and throughput will drop dramatically.
3) Latency (in ms):
CUBIC DCTCP
Mean 4.0088 0.04219
Median 4.055 0.0395
Max 4.2 0.085
Min 3.32 0.028
Stddev 0.1666 0.01064
Latency for each protocol was computed by running "ping -i 0.2
<receiver>" from a single sender to the receiver during the incast
test. For DCTCP, "ping -Q 0x6 -i 0.2 <receiver>" was used to ensure
that traffic traversed the DCTCP queue and was not dropped when the
queue size was greater than the marking threshold. The summary
statistics above are over all ping metrics measured between the single
sender, receiver pair.
The latency results for this test show a dramatic difference between
CUBIC and DCTCP. CUBIC intentionally overflows the switch buffer
which incurs the maximum queue latency (more buffer memory will lead
to high latency.) DCTCP, on the other hand, deliberately attempts to
keep queue occupancy low. The result is a two orders of magnitude
reduction of latency with DCTCP - even with a switch with relatively
little RAM. Switches with larger amounts of RAM will incur increasing
amounts of latency for CUBIC, but not for DCTCP.
4) Convergence and stability test:
This test measured the time that DCTCP took to fairly redistribute
bandwidth when a new flow commences. It also measured DCTCP's ability
to remain stable at a fair bandwidth distribution. DCTCP is compared
with CUBIC for this test.
At the commencement of this test, a single flow is sending at maximum
rate (near 10 Gbps) to a single receiver. One second after that first
flow commences, a new flow from a distinct server begins sending to
the same receiver as the first flow. After the second flow has sent
data for 10 seconds, the second flow is terminated. The first flow
sends for an additional second. Ideally, the bandwidth would be evenly
shared as soon as the second flow starts, and recover as soon as it
stops.
The results of this test are shown below. Note that the flow bandwidth
for the two flows was measured near the same time, but not
simultaneously.
DCTCP performs nearly perfectly within the measurement limitations
of this test: bandwidth is quickly distributed fairly between the two
flows, remains stable throughout the duration of the test, and
recovers quickly. CUBIC, in contrast, is slow to divide the bandwidth
fairly, and has trouble remaining stable.
CUBIC DCTCP
Seconds Flow 1 Flow 2 Seconds Flow 1 Flow 2
0 9.93 0 0 9.92 0
0.5 9.87 0 0.5 9.86 0
1 8.73 2.25 1 6.46 4.88
1.5 7.29 2.8 1.5 4.9 4.99
2 6.96 3.1 2 4.92 4.94
2.5 6.67 3.34 2.5 4.93 5
3 6.39 3.57 3 4.92 4.99
3.5 6.24 3.75 3.5 4.94 4.74
4 6 3.94 4 5.34 4.71
4.5 5.88 4.09 4.5 4.99 4.97
5 5.27 4.98 5 4.83 5.01
5.5 4.93 5.04 5.5 4.89 4.99
6 4.9 4.99 6 4.92 5.04
6.5 4.93 5.1 6.5 4.91 4.97
7 4.28 5.8 7 4.97 4.97
7.5 4.62 4.91 7.5 4.99 4.82
8 5.05 4.45 8 5.16 4.76
8.5 5.93 4.09 8.5 4.94 4.98
9 5.73 4.2 9 4.92 5.02
9.5 5.62 4.32 9.5 4.87 5.03
10 6.12 3.2 10 4.91 5.01
10.5 6.91 3.11 10.5 4.87 5.04
11 8.48 0 11 8.49 4.94
11.5 9.87 0 11.5 9.9 0
SYN/ACK ECT test:
This test demonstrates the importance of ECT on SYN and SYN-ACK packets
by measuring the connection probability in the presence of competing
flows for a DCTCP connection attempt *without* ECT in the SYN packet.
The test was repeated five times for each number of competing flows.
Competing Flows 1 | 2 | 4 | 8 | 16
Mean Connection Probability 1 | 0.67 | 0.45 | 0.28 | 0
Median Connection Probability 1 | 0.65 | 0.45 | 0.25 | 0
As the number of competing flows moves beyond 1, the connection
probability drops rapidly.
Enabling DCTCP with this patch requires the following steps:
DCTCP must be running both on the sender and receiver side in your
data center, i.e.:
sysctl -w net.ipv4.tcp_congestion_control=dctcp
Also, ECN functionality must be enabled on all switches in your
data center for DCTCP to work. The default ECN marking threshold (K)
heuristic on the switch for DCTCP is e.g., 20 packets (30KB) at
1Gbps, and 65 packets (~100KB) at 10Gbps (K > 1/7 * C * RTT, [4]).
In above tests, for each switch port, traffic was segregated into two
queues. For any packet with a DSCP of 0x01 - or equivalently a TOS of
0x04 - the packet was placed into the DCTCP queue. All other packets
were placed into the default drop-tail queue. For the DCTCP queue,
RED/ECN marking was enabled, here, with a marking threshold of 75 KB.
More details however, we refer you to the paper [2] under section 3).
There are no code changes required to applications running in user
space. DCTCP has been implemented in full *isolation* of the rest of
the TCP code as its own congestion control module, so that it can run
without a need to expose code to the core of the TCP stack, and thus
nothing changes for non-DCTCP users.
Changes in the CA framework code are minimal, and DCTCP algorithm
operates on mechanisms that are already available in most Silicon.
The gain (dctcp_shift_g) is currently a fixed constant (1/16) from
the paper, but we leave the option that it can be chosen carefully
to a different value by the user.
In case DCTCP is being used and ECN support on peer site is off,
DCTCP falls back after 3WHS to operate in normal TCP Reno mode.
ss {-4,-6} -t -i diag interface:
... dctcp wscale:7,7 rto:203 rtt:2.349/0.026 mss:1448 cwnd:2054
ssthresh:1102 ce_state 0 alpha 15 ab_ecn 0 ab_tot 735584
send 10129.2Mbps pacing_rate 20254.1Mbps unacked:1822 retrans:0/15
reordering:101 rcv_space:29200
... dctcp-reno wscale:7,7 rto:201 rtt:0.711/1.327 ato:40 mss:1448
cwnd:10 ssthresh:1102 fallback_mode send 162.9Mbps pacing_rate
325.5Mbps rcv_rtt:1.5 rcv_space:29200
More information about DCTCP can be found in [1-4].
[1] http://simula.stanford.edu/~alizade/Site/DCTCP.html
[2] http://simula.stanford.edu/~alizade/Site/DCTCP_files/dctcp-final.pdf
[3] http://simula.stanford.edu/~alizade/Site/DCTCP_files/dctcp_analysis-full.pdf
[4] http://tools.ietf.org/html/draft-bensley-tcpm-dctcp-00
Joint work with Florian Westphal and Glenn Judd.
Signed-off-by: Glenn Judd <glenn.judd@morganstanley.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
DataCenter TCP (DCTCP) determines cwnd growth based on ECN information
and ACK properties, e.g. ACK that updates window is treated differently
than DUPACK.
Also DCTCP needs information whether ACK was delayed ACK. Furthermore,
DCTCP also implements a CE state machine that keeps track of CE markings
of incoming packets.
Therefore, extend the congestion control framework to provide these
event types, so that DCTCP can be properly implemented as a normal
congestion algorithm module outside of the core stack.
Joint work with Daniel Borkmann and Glenn Judd.
This patch adds a flag to TCP congestion algorithms that allows
for requesting to mark IPv4/IPv6 sockets with transport as ECN
capable, that is, ECT(0), when required by a congestion algorithm.
It is currently used and needed in DataCenter TCP (DCTCP), as it
requires both peers to assert ECT on all IP packets sent - it
uses ECN feedback (i.e. CE, Congestion Encountered information)
from switches inside the data center to derive feedback to the
end hosts.
Therefore, simply add a new flag to icsk_ca_ops. Note that DCTCP's
algorithm/behaviour slightly diverges from RFC3168, therefore this
is only (!) enabled iff the assigned congestion control ops module
has requested this. By that, we can tightly couple this logic really
only to the provided congestion control ops.
Our goal is to access no more than one cache line access per skb in
a write or receive queue when doing the various walks.
After recent TCP_SKB_CB() reorganizations, it is almost done.
Last part is tcp_skb_pcount() which currently uses
skb_shinfo(skb)->gso_segs, which is a terrible choice, because it needs
3 cache lines in current kernel (skb->head, skb->end, and
shinfo->gso_segs are all in 3 different cache lines, far from skb->cb)
This very simple patch reuses space currently taken by tcp_tw_isn
only in input path, as tcp_skb_pcount is only needed for skb stored in
write queue.
This considerably speeds up tcp_ack(), granted we avoid shinfo->tx_flags
to get SKBTX_ACK_TSTAMP, which seems possible.
This also speeds up all sack processing in general.
This speeds up tcp_sendmsg() because it no longer has to access/dirty
shinfo.
TCP maintains lists of skb in write queue, and in receive queues
(in order and out of order queues)
Scanning these lists both in input and output path usually requires
access to skb->next, TCP_SKB_CB(skb)->seq, and TCP_SKB_CB(skb)->end_seq
These fields are currently in two different cache lines, meaning we
waste lot of memory bandwidth when these queues are big and flows
have either packet drops or packet reorders.
We can move TCP_SKB_CB(skb)->header at the end of TCP_SKB_CB, because
this header is not used in fast path. This allows TCP to search much faster
in the skb lists.
Even with regular flows, we save one cache line miss in fast path.
Thanks to Christoph Paasch for noticing we need to cleanup
skb->cb[] (IPCB/IP6CB) before entering IP stack in tx path,
and that I forgot IPCB use in tcp_v4_hnd_req() and tcp_v4_save_options().
While profiling TCP stack, I noticed one useless atomic operation
in tcp_sendmsg(), caused by skb_header_release().
It turns out all current skb_header_release() users have a fresh skb,
that no other user can see, so we can avoid one atomic operation.
Introduce __skb_header_release() to clearly document this.
This gave me a 1.5 % improvement on TCP_RR workload.
icsk_rto is a 32bit field, and icsk_backoff can reach 15 by default,
or more if some sysctl (eg tcp_retries2) are changed.
Better use 64bit to perform icsk_rto << icsk_backoff operations
As Joe Perches suggested, add a helper for this.
Yuchung spotted the tcp_v4_err() case.
The TCP_SKB_CB(skb)->when field no longer exists as of recent change
7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when"). And in any case,
tcp_fragment() is called on already-transmitted packets from the
__tcp_retransmit_skb() call site, so copying timestamps of any kind
in this spot is quite sensible.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Reported-by: Yuchung Cheng <ycheng@google.com>
After commit 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution"),
we no longer need to maintain timestamps in two different fields.
TCP_SKB_CB(skb)->when can be removed, as same information sits in skb_mstamp.stamp_jiffies
Acked-by: Yuchung Cheng <ycheng@google.com>
Replace uses of get_cpu_var for address calculation through this_cpu_ptr.
Cc: netdev@vger.kernel.org
Cc: Eric Dumazet <edumazet@google.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Make sure we use the correct address-family-specific function for
handling MTU reductions from within tcp_release_cb().
Previously AF_INET6 sockets were incorrectly always using the IPv6
code path when sometimes they were handling IPv4 traffic and thus had
an IPv4 dst.
Diagnosed-by: Willem de Bruijn <willemb@google.com>
Fixes: 563d34d057862 ("tcp: dont drop MTU reduction indications")
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
We don't know right timestamp for repaired skb-s. Wrong RTT estimations
isn't good, because some congestion modules heavily depends on it.
This patch adds the TCPCB_REPAIRED flag, which is included in
TCPCB_RETRANS.
Thanks to Eric for the advice how to fix this issue.
This patch fixes the warning:
[ 879.562947] WARNING: CPU: 0 PID: 2825 at net/ipv4/tcp_input.c:3078 tcp_ack+0x11f5/0x1380()
[ 879.567253] CPU: 0 PID: 2825 Comm: socket-tcpbuf-l Not tainted 3.16.0-next-20140811 #1
[ 879.567829] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 879.568177] 0000000000000000 00000000c532680c ffff880039643d00 ffffffff817aa2d2
[ 879.568776] 0000000000000000 ffff880039643d38 ffffffff8109afbd ffff880039d6ba80
[ 879.569386] ffff88003a449800 000000002983d6bd 0000000000000000 000000002983d6bc
[ 879.569982] Call Trace:
[ 879.570264] [<ffffffff817aa2d2>] dump_stack+0x4d/0x66
[ 879.570599] [<ffffffff8109afbd>] warn_slowpath_common+0x7d/0xa0
[ 879.570935] [<ffffffff8109b0ea>] warn_slowpath_null+0x1a/0x20
[ 879.571292] [<ffffffff816d0a05>] tcp_ack+0x11f5/0x1380
[ 879.571614] [<ffffffff816d10bd>] tcp_rcv_established+0x1ed/0x710
[ 879.571958] [<ffffffff816dc9da>] tcp_v4_do_rcv+0x10a/0x370
[ 879.572315] [<ffffffff81657459>] release_sock+0x89/0x1d0
[ 879.572642] [<ffffffff816c81a0>] do_tcp_setsockopt.isra.36+0x120/0x860
[ 879.573000] [<ffffffff8110a52e>] ? rcu_read_lock_held+0x6e/0x80
[ 879.573352] [<ffffffff816c8912>] tcp_setsockopt+0x32/0x40
[ 879.573678] [<ffffffff81654ac4>] sock_common_setsockopt+0x14/0x20
[ 879.574031] [<ffffffff816537b0>] SyS_setsockopt+0x80/0xf0
[ 879.574393] [<ffffffff817b40a9>] system_call_fastpath+0x16/0x1b
[ 879.574730] ---[ end trace a17cbc38eb8c5c00 ]---
v2: moving setting of skb->when for repaired skb-s in tcp_write_xmit,
where it's set for other skb-s.
Fixes: 431a91242d8d ("tcp: timestamp SYN+DATA messages")
Fixes: 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution")
Cc: Pavel Emelyanov <xemul@parallels.com>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Bytestream timestamps are correlated with a single byte in the skbuff,
recorded in skb_shinfo(skb)->tskey. When fragmenting skbuffs, ensure
that the tskey is set for the fragment in which the tskey falls
(seqno <= tskey < end_seqno).
The original implementation did not address fragmentation in
tcp_fragment or tso_fragment. Add code to inspect the sequence numbers
and move both tskey and the relevant tx_flags if necessary.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Since Yuchung's 9b44190dc11 (tcp: refactor F-RTO), tcp_enter_cwr is always
called with set_ssthresh = 1. Thus, we can remove this argument from
tcp_enter_cwr. Further, as we remove this one, tcp_init_cwnd_reduction
is then always called with set_ssthresh = true, and so we can get rid of
this argument as well.
Cc: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
The undo code assumes that, upon entering loss recovery, TCP
1) always retransmit something
2) the retransmission never fails locally (e.g., qdisc drop)
so undo_marker is set in tcp_enter_recovery() and undo_retrans is
incremented only when tcp_retransmit_skb() is successful.
When the assumption is broken because TCP's cwnd is too small to
retransmit or the retransmit fails locally. The next (DUP)ACK
would incorrectly revert the cwnd and the congestion state in
tcp_try_undo_dsack() or tcp_may_undo(). Subsequent (DUP)ACKs
may enter the recovery state. The sender repeatedly enter and
(incorrectly) exit recovery states if the retransmits continue to
fail locally while receiving (DUP)ACKs.
The fix is to initialize undo_retrans to -1 and start counting on
the first retransmission. Always increment undo_retrans even if the
retransmissions fail locally because they couldn't cause DSACKs to
undo the cwnd reduction.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
For a connected socket we can precompute the flow hash for setting
in skb->hash on output. This is a performance advantage over
calculating the skb->hash for every packet on the connection. The
computation is done using the common hash algorithm to be consistent
with computations done for packets of the connection in other states
where thers is no socket (e.g. time-wait, syn-recv, syn-cookies).
This patch adds sk_txhash to the sock structure. inet_set_txhash and
ip6_set_txhash functions are added which are called from points in
TCP and UDP where socket moves to established state.
skb_set_hash_from_sk is a function which sets skb->hash from the
sock txhash value. This is called in UDP and TCP transmit path when
transmitting within the context of a socket.
Tested: ran super_netperf with 200 TCP_RR streams over a vxlan
interface (in this case skb_get_hash called on every TX packet to
create a UDP source port).
Before fix:
95.02% CPU utilization
154/256/505 90/95/99% latencies
1.13042e+06 tps
Time in functions:
0.28% skb_flow_dissect
0.21% __skb_get_hash
After fix:
94.95% CPU utilization
156/254/485 90/95/99% latencies
1.15447e+06
Neither __skb_get_hash nor skb_flow_dissect appear in perf
Signed-off-by: Tom Herbert <therbert@google.com>
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
Fix to a problem observed when losing a FIN segment that does not
contain data. In such situations, TLP is unable to recover from
*any* tail loss and instead adds at least PTO ms to the
retransmission process, i.e., RTO = RTO + PTO.
Signed-off-by: Per Hurtig <per.hurtig@kau.se>
Acked-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
tcp_fragment can be called from process context (from tso_fragment).
Add a new gfp parameter to allow it to preserve atomic memory if
possible.
Reviewed-by: Christoph Paasch <christoph.paasch@uclouvain.be>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull core locking updates from Ingo Molnar:
"The main changes in this cycle were:
- reduced/streamlined smp_mb__*() interface that allows more usecases
and makes the existing ones less buggy, especially in rarer
architectures
- add rwsem implementation comments
- bump up lockdep limits"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
rwsem: Add comments to explain the meaning of the rwsem's count field
lockdep: Increase static allocations
arch: Mass conversion of smp_mb__*()
arch,doc: Convert smp_mb__*()
arch,xtensa: Convert smp_mb__*()
arch,x86: Convert smp_mb__*()
arch,tile: Convert smp_mb__*()
arch,sparc: Convert smp_mb__*()
arch,sh: Convert smp_mb__*()
arch,score: Convert smp_mb__*()
arch,s390: Convert smp_mb__*()
arch,powerpc: Convert smp_mb__*()
arch,parisc: Convert smp_mb__*()
arch,openrisc: Convert smp_mb__*()
arch,mn10300: Convert smp_mb__*()
arch,mips: Convert smp_mb__*()
arch,metag: Convert smp_mb__*()
arch,m68k: Convert smp_mb__*()
arch,m32r: Convert smp_mb__*()
arch,ia64: Convert smp_mb__*()
Experience with the recent e114a710aa50 ("tcp: fix cwnd limited
checking to improve congestion control") has shown that there are
common cases where that commit can cause cwnd to be much larger than
necessary. This leads to TSO autosizing cooking skbs that are too
large, among other things.
The main problems seemed to be:
(1) That commit attempted to predict the future behavior of the
connection by looking at the write queue (if TSO or TSQ limit
sending). That prediction sometimes overestimated future outstanding
packets.
(2) That commit always allowed cwnd to grow to twice the number of
outstanding packets (even in congestion avoidance, where this is not
needed).
This commit improves both of these, by:
(1) Switching to a measurement-based approach where we explicitly
track the largest number of packets in flight during the past window
("max_packets_out"), and remember whether we were cwnd-limited at the
moment we finished sending that flight.
(2) Only allowing cwnd to grow to twice the number of outstanding
packets ("max_packets_out") in slow start. In congestion avoidance
mode we now only allow cwnd to grow if it was fully utilized.
To avoid large code duplication in IPv6, we need to first simplify
the complicate SYN-ACK sending code in tcp_v4_conn_request().
To use tcp_v4(6)_send_synack() to send all SYN-ACKs, we need to
initialize the mini socket's receive window before trying to
create the child socket and/or building the SYN-ACK packet. So we move
that initialization from tcp_make_synack() to tcp_v4_conn_request()
as a new function tcp_openreq_init_req_rwin().
After this refactoring the SYN-ACK sending code is simpler and easier
to implement Fast Open for IPv6.
Signed-off-by: Daniel Lee <longinus00@gmail.com>
Signed-off-by: Jerry Chu <hkchu@google.com>
Consolidate various cookie checking and generation code to simplify
the fast open processing. The main goal is to reduce code duplication
in tcp_v4_conn_request() for IPv6 support.
Removes two experimental sysctl flags TFO_SERVER_ALWAYS and
TFO_SERVER_COOKIE_NOT_CHKD used primarily for developmental debugging
purposes.
drivers/net/ethernet/altera/altera_sgdma.c
net/netlink/af_netlink.c
net/sched/cls_api.c
net/sched/sch_api.c
The netlink conflict dealt with moving to netlink_capable() and
netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations
in non-init namespaces. These were simple transformations from
netlink_capable to netlink_ns_capable.
The Altera driver conflict was simply code removal overlapping some
void pointer cast cleanups in net-next.
Commit e114a710aa505 ("tcp: fix cwnd limited checking to improve
congestion control") obsoleted in_flight parameter from
tcp_is_cwnd_limited() and its callers.
This patch does the removal as promised.
Yuchung discovered tcp_is_cwnd_limited() was returning false in
slow start phase even if the application filled the socket write queue.
All congestion modules take into account tcp_is_cwnd_limited()
before increasing cwnd, so this behavior limits slow start from
probing the bandwidth at full speed.
The problem is that even if write queue is full (aka we are _not_
application limited), cwnd can be under utilized if TSO should auto
defer or TCP Small queues decided to hold packets.
So the in_flight can be kept to smaller value, and we can get to the
point tcp_is_cwnd_limited() returns false.
With TCP Small Queues and FQ/pacing, this issue is more visible.
We fix this by having tcp_cwnd_validate(), which is supposed to track
such things, take into account unsent_segs, the number of segs that we
are not sending at the moment due to TSO or TSQ, but intend to send
real soon. Then when we are cwnd-limited, remember this fact while we
are processing the window of ACKs that comes back.
For example, suppose we have a brand new connection with cwnd=10; we
are in slow start, and we send a flight of 9 packets. By the time we
have received ACKs for all 9 packets we want our cwnd to be 18.
We implement this by setting tp->lsnd_pending to 9, and
considering ourselves to be cwnd-limited while cwnd is less than
twice tp->lsnd_pending (2*9 -> 18).
This makes tcp_is_cwnd_limited() more understandable, by removing
the GSO/TSO kludge, that tried to work around the issue.
Note the in_flight parameter can be removed in a followup cleanup
patch.
Both TLP and Fast Open call __tcp_retransmit_skb() instead of
tcp_retransmit_skb() to avoid changing tp->retrans_out.
This has the side effect of missing SNMP counters increments as well
as tcp_info tcpi_total_retrans updates.
Fix this by moving the stats increments of into __tcp_retransmit_skb()
In commit 0e280af026a5 ("tcp: introduce TCPSpuriousRtxHostQueues SNMP
counter") we added a logic to detect when a packet was retransmitted
while the prior clone was still in a qdisc or driver queue.
We are now confident we can do better, and catch the problem before
we fragment a TSO packet before retransmit, or in TLP path.
This patch fully exploits the logic by simply canceling the spurious
retransmit.
Original packet is in a queue and will eventually leave the host.
This helps to avoid network collapses when some events make the RTO
estimations very wrong, particularly when dealing with huge number of
sockets with synchronized blast.
Make tcp_cwnd_application_limited() static and move it from tcp_input.c to
tcp_output.c
Signed-off-by: Weiping Pan <wpan@redhat.com>
Mostly scripted conversion of the smp_mb__* barriers.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org
ip_queue_xmit() assumes the skb it has to transmit is attached to an
inet socket. Commit 31c70d5956fc ("l2tp: keep original skb ownership")
changed l2tp to not change skb ownership and thus broke this assumption.
One fix is to add a new 'struct sock *sk' parameter to ip_queue_xmit(),
so that we do not assume skb->sk points to the socket used by l2tp
tunnel.
Fixes: 31c70d5956fc ("l2tp: keep original skb ownership")
Reported-by: Zhan Jianyu <nasa4836@gmail.com>
Tested-by: Zhan Jianyu <nasa4836@gmail.com>
There is no need to allocate 15 bytes in excess for a SYNACK packet,
as it contains no data, only headers.
SYNACK are always generated in softirq context, and contain a single
segment, we can use TCP_INC_STATS_BH()
After commit d4589926d7a9 (tcp: refine TSO splits), tcp_nagle_check() does
not use parameter mss_now anymore.
Signed-off-by: Weiping Pan <panweiping3@gmail.com>
drivers/net/usb/r8152.c
drivers/net/xen-netback/netback.c
Both the r8152 and netback conflicts were simple overlapping
changes.
Lars Persson reported following deadlock :
-000 |M:0x0:0x802B6AF8(asm) <-- arch_spin_lock
-001 |tcp_v4_rcv(skb = 0x8BD527A0) <-- sk = 0x8BE6B2A0
-002 |ip_local_deliver_finish(skb = 0x8BD527A0)
-003 |__netif_receive_skb_core(skb = 0x8BD527A0, ?)
-004 |netif_receive_skb(skb = 0x8BD527A0)
-005 |elk_poll(napi = 0x8C770500, budget = 64)
-006 |net_rx_action(?)
-007 |__do_softirq()
-008 |do_softirq()
-009 |local_bh_enable()
-010 |tcp_rcv_established(sk = 0x8BE6B2A0, skb = 0x87D3A9E0, th = 0x814EBE14, ?)
-011 |tcp_v4_do_rcv(sk = 0x8BE6B2A0, skb = 0x87D3A9E0)
-012 |tcp_delack_timer_handler(sk = 0x8BE6B2A0)
-013 |tcp_release_cb(sk = 0x8BE6B2A0)
-014 |release_sock(sk = 0x8BE6B2A0)
-015 |tcp_sendmsg(?, sk = 0x8BE6B2A0, ?, ?)
-016 |sock_sendmsg(sock = 0x8518C4C0, msg = 0x87D8DAA8, size = 4096)
-017 |kernel_sendmsg(?, ?, ?, ?, size = 4096)
-018 |smb_send_kvec()
-019 |smb_send_rqst(server = 0x87C4D400, rqst = 0x87D8DBA0)
-020 |cifs_call_async()
-021 |cifs_async_writev(wdata = 0x87FD6580)
-022 |cifs_writepages(mapping = 0x852096E4, wbc = 0x87D8DC88)
-023 |__writeback_single_inode(inode = 0x852095D0, wbc = 0x87D8DC88)
-024 |writeback_sb_inodes(sb = 0x87D6D800, wb = 0x87E4A9C0, work = 0x87D8DD88)
-025 |__writeback_inodes_wb(wb = 0x87E4A9C0, work = 0x87D8DD88)
-026 |wb_writeback(wb = 0x87E4A9C0, work = 0x87D8DD88)
-027 |wb_do_writeback(wb = 0x87E4A9C0, force_wait = 0)
-028 |bdi_writeback_workfn(work = 0x87E4A9CC)
-029 |process_one_work(worker = 0x8B045880, work = 0x87E4A9CC)
-030 |worker_thread(__worker = 0x8B045880)
-031 |kthread(_create = 0x87CADD90)
-032 |ret_from_kernel_thread(asm)
Bug occurs because __tcp_checksum_complete_user() enables BH, assuming
it is running from softirq context.
Lars trace involved a NIC without RX checksum support but other points
are problematic as well, like the prequeue stuff.
Problem is triggered by a timer, that found socket being owned by user.
tcp_release_cb() should call tcp_write_timer_handler() or
tcp_delack_timer_handler() in the appropriate context :
BH disabled and socket lock held, but 'owned' field cleared,
as if they were running from timer handlers.
Fixes: 6f458dfb4092 ("tcp: improve latencies of timer triggered events")
Reported-by: Lars Persson <lars.persson@axis.com>
Tested-by: Lars Persson <lars.persson@axis.com>
All skb in socket write queue should be properly timestamped.
In case of FastOpen, we special case the SYN+DATA 'message' as we
queue in socket wrote queue the two fallback skbs:
1) SYN message by itself.
2) DATA segment by itself.
We should make sure these skbs have proper timestamps.
Add a WARN_ON_ONCE() to eventually catch future violations.
Cc: Neal Cardwell <ncardwell@google.com>
Usage of skb->tstamp should remain private to TCP stack
(only set on packets on write queue, not on cloned ones)
Otherwise, packets given to loopback interface with a non null tstamp
can confuse netif_rx() / net_timestamp_check()
Other possibility would be to clear tstamp in loopback_xmit(),
as done in skb_scrub_packet()
Reported-by: Willem de Bruijn <willemb@google.com>
Can be invoked from non-BH context.
Based upon a patch by Eric Dumazet.
Fixes: f19c29e3e391 ("tcp: snmp stats for Fast Open, SYN rtx, and data pkts")
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
net/ipv6/sit.c
The SIT driver conflict consists of a bug fix being done by hand
in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper
was created (netdev_alloc_pcpu_stats()) which takes care of this.
The two wireless conflicts were overlapping changes.
Add the following snmp stats:
TCPFastOpenActiveFail: Fast Open attempts (SYN/data) failed beacuse
the remote does not accept it or the attempts timed out.
TCPSynRetrans: number of SYN and SYN/ACK retransmits to break down
retransmissions into SYN, fast-retransmits, timeout retransmits, etc.
TCPOrigDataSent: number of outgoing packets with original data (excluding
retransmission but including data-in-SYN). This counter is different from
TcpOutSegs because TcpOutSegs also tracks pure ACKs. TCPOrigDataSent is
more useful to track the TCP retransmission rate.
Change TCPFastOpenActive to track only successful Fast Opens to be symmetric to
TCPFastOpenPassive.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Signed-off-by: Lawrence Brakmo <brakmo@google.com>
RTT may be bogus with tall loss probe (TLP) when a packet
is retransmitted and latter (s)acked without TCPCB_SACKED_RETRANS flag.
For example, TLP calls __tcp_retransmit_skb() instead of
tcp_retransmit_skb(). The skb timestamps are updated but the sacked
flag is not marked with TCPCB_SACKED_RETRANS. As a result we'll
get bogus RTT in tcp_clean_rtx_queue() or in tcp_sacktag_one() on
spurious retransmission.
The fix is to apply the sticky flag TCP_EVER_RETRANS to enforce Karn's
check on RTT sampling. However this will disable F-RTO if timeout occurs
after TLP, by resetting undo_marker in tcp_enter_loss(). We relax this
check to only if any pending retransmists are still in-flight.
Upcoming congestion controls for TCP require usec resolution for RTT
estimations. Millisecond resolution is simply not enough these days.
FQ/pacing in DC environments also require this change for finer control
and removal of bimodal behavior due to the current hack in
tcp_update_pacing_rate() for 'small rtt'
TCP_CONG_RTT_STAMP is no longer needed.
As Julian Anastasov pointed out, we need to keep user compatibility :
tcp_metrics used to export RTT and RTTVAR in msec resolution,
so we added RTT_US and RTTVAR_US. An iproute2 patch is needed
to use the new attributes if provided by the kernel.
In this example ss command displays a srtt of 32 usecs (10Gbit link)
lpk51:~# ./ss -i dst lpk52
Netid State Recv-Q Send-Q Local Address:Port Peer
Address:Port
tcp ESTAB 0 1 10.246.11.51:42959
10.246.11.52:64614
cubic wscale:6,6 rto:201 rtt:0.032/0.001 ato:40 mss:1448
cwnd:10 send
3620.0Mbps pacing_rate 7240.0Mbps unacked:1 rcv_rtt:993 rcv_space:29559
Updated iproute2 ip command displays :
lpk51:~# ./ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 274us rttvar 213us source
10.246.11.51
Old binary displays :
lpk51:~# ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 250us rttvar 125us source
10.246.11.51
With help from Julian Anastasov, Stephen Hemminger and Yuchung Cheng
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Larry Brakmo <brakmo@google.com>
Cc: Julian Anastasov <ja@ssi.bg>
