path: root/net/ipv4/tcp_timer.c
2012-03-12net: ipv4: Standardize prefixes for message loggingJoe Perches
Add #define pr_fmt(fmt) as appropriate. Add "IPv4: ", "TCP: ", and "IPsec: " to appropriate files. Standardize on "UDPLite: " for appropriate uses. Some prefixes were previously "UDPLITE: " and "UDP-Lite: ". Add KBUILD_MODNAME ": " to icmp and gre. Remove embedded prefixes as appropriate. Add missing "\n" to pr_info in gre.c. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-01net: Disambiguate kernel messageArun Sharma
Some of our machines were reporting: TCP: too many of orphaned sockets even when the number of orphaned sockets was well below the limit. We print a different message depending on whether we're out of TCP memory or there are too many orphaned sockets. Also move the check out of line and cleanup the messages that were printed. Signed-off-by: Arun Sharma <asharma@fb.com> Suggested-by: Mohan Srinivasan <mohan@fb.com> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: David Miller <davem@davemloft.net> Cc: Glauber Costa <glommer@parallels.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19net: fix assignment of 0/1 to bool variables.Rusty Russell
DaveM said: Please, this kind of stuff rots forever and not using bool properly drives me crazy. Joe Perches <joe@perches.com> gave me the spatch script: @@ bool b; @@ -b = 0 +b = false @@ bool b; @@ -b = 1 +b = true I merely installed coccinelle, read the documentation and took credit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-12foundations of per-cgroup memory pressure controlling.Glauber Costa
This patch replaces all uses of struct sock fields' memory_pressure, memory_allocated, sockets_allocated, and sysctl_mem to acessor macros. Those macros can either receive a socket argument, or a mem_cgroup argument, depending on the context they live in. Since we're only doing a macro wrapping here, no performance impact at all is expected in the case where we don't have cgroups disabled. Signed-off-by: Glauber Costa <glommer@parallels.com> Reviewed-by: Hiroyouki Kamezawa <kamezawa.hiroyu@jp.fujitsu.com> CC: David S. Miller <davem@davemloft.net> CC: Eric W. Biederman <ebiederm@xmission.com> CC: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-11net: use IS_ENABLED(CONFIG_IPV6)Eric Dumazet
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-24TCP: remove TCP_DEBUGFlavio Leitner
It was enabled by default and the messages guarded by the define are useful. Signed-off-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-20tcp: Remove debug macro of TCP_CHECK_TIMERShan Wei
Now, TCP_CHECK_TIMER is not used for debuging, it does nothing. And, it has been there for several years, maybe 6 years. Remove it to keep code clearer. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-17tcp: use correct counters in CA_CWR state tooIlpo Järvinen
As CWR is stronger than CA_Disorder state, we can miscount SACK/Reno failure into other timeouts. Not a bad problem as it can happen only due to ECN, FRTO detecting spurious RTO or xmit error which are the only callers of tcp_enter_cwr. And even then losses and RTO must still follow thereafter to actually end up into the relevant code paths. Compile tested. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-09-28net-2.6: SYN retransmits: Add new parameter to retransmits_timed_out()Damian Lukowski
Fixes kernel Bugzilla Bug 18952 This patch adds a syn_set parameter to the retransmits_timed_out() routine and updates its callers. If not set, TCP_RTO_MIN is taken as the calculation basis as before. If set, TCP_TIMEOUT_INIT is used instead, so that sysctl_syn_retries represents the actual amount of SYN retransmissions in case no SYNACKs are received when establishing a new connection. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-08-30tcp: Add TCP_USER_TIMEOUT socket option.Jerry Chu
This patch provides a "user timeout" support as described in RFC793. The socket option is also needed for the the local half of RFC5482 "TCP User Timeout Option". TCP_USER_TIMEOUT is a TCP level socket option that takes an unsigned int, when > 0, to specify the maximum amount of time in ms that transmitted data may remain unacknowledged before TCP will forcefully close the corresponding connection and return ETIMEDOUT to the application. If 0 is given, TCP will continue to use the system default. Increasing the user timeouts allows a TCP connection to survive extended periods without end-to-end connectivity. Decreasing the user timeouts allows applications to "fail fast" if so desired. Otherwise it may take upto 20 minutes with the current system defaults in a normal WAN environment. The socket option can be made during any state of a TCP connection, but is only effective during the synchronized states of a connection (ESTABLISHED, FIN-WAIT-1, FIN-WAIT-2, CLOSE-WAIT, CLOSING, or LAST-ACK). Moreover, when used with the TCP keepalive (SO_KEEPALIVE) option, TCP_USER_TIMEOUT will overtake keepalive to determine when to close a connection due to keepalive failure. The option does not change in anyway when TCP retransmits a packet, nor when a keepalive probe will be sent. This option, like many others, will be inherited by an acceptor from its listener. Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25tcp: Combat per-cpu skew in orphan tests.David S. Miller
As reported by Anton Blanchard when we use percpu_counter_read_positive() to make our orphan socket limit checks, the check can be off by up to num_cpus_online() * batch (which is 32 by default) which on a 128 cpu machine can be as large as the default orphan limit itself. Fix this by doing the full expensive sum check if the optimized check triggers. Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27TCP: avoid to send keepalive probes if receiving dataFlavio Leitner
RFC 1122 says the following: ... Keep-alive packets MUST only be sent when no data or acknowledgement packets have been received for the connection within an interval. ... The acknowledgement packet is reseting the keepalive timer but the data packet isn't. This patch fixes it by checking the timestamp of the last received data packet too when the keepalive timer expires. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13net: sk_dst_cache RCUificationEric Dumazet
With latest CONFIG_PROVE_RCU stuff, I felt more comfortable to make this work. sk->sk_dst_cache is currently protected by a rwlock (sk_dst_lock) This rwlock is readlocked for a very small amount of time, and dst entries are already freed after RCU grace period. This calls for RCU again :) This patch converts sk_dst_lock to a spinlock, and use RCU for readers. __sk_dst_get() is supposed to be called with rcu_read_lock() or if socket locked by user, so use appropriate rcu_dereference_check() condition (rcu_read_lock_held() || sock_owned_by_user(sk)) This patch avoids two atomic ops per tx packet on UDP connected sockets, for example, and permits sk_dst_lock to be much less dirtied. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-18net: TCP thin linear timeoutsAndreas Petlund
This patch will make TCP use only linear timeouts if the stream is thin. This will help to avoid the very high latencies that thin stream suffer because of exponential backoff. This mechanism is only active if enabled by iocontrol or syscontrol and the stream is identified as thin. A maximum of 6 linear timeouts is tried before exponential backoff is resumed. Signed-off-by: Andreas Petlund <apetlund@simula.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-17tcp: account SYN-ACK timeouts & retransmissionsOctavian Purdila
Currently we don't increment SYN-ACK timeouts & retransmissions although we do increment the same stats for SYN. We seem to have lost the SYN-ACK accounting with the introduction of tcp_syn_recv_timer (commit 2248761e in the netdev-vger-cvs tree). This patch fixes this issue. In the process we also rename the v4/v6 syn/ack retransmit functions for clarity. We also add a new request_socket operations (syn_ack_timeout) so we can keep code in inet_connection_sock.c protocol agnostic. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08tcp: Stalling connections: Move timeout calculation routineDamian Lukowski
This patch moves retransmits_timed_out() from include/net/tcp.h to tcp_timer.c, where it is used. Reported-by: Frederic Leroy <fredo@starox.org> Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20net: Fix for dst_negative_adviceKrishna Kumar
dst_negative_advice() should check for changed dst and reset sk_tx_queue_mapping accordingly. Pass sock to the callers of dst_negative_advice. (sk_reset_txq is defined just for use by dst_negative_advice. The only way I could find to get around this is to move dst_negative_() from dst.h to dst.c, include sock.h in dst.c, etc) Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01Revert Backoff [v3]: Calculate TCP's connection close threshold as a time value.Damian Lukowski
RFC 1122 specifies two threshold values R1 and R2 for connection timeouts, which may represent a number of allowed retransmissions or a timeout value. Currently linux uses sysctl_tcp_retries{1,2} to specify the thresholds in number of allowed retransmissions. For any desired threshold R2 (by means of time) one can specify tcp_retries2 (by means of number of retransmissions) such that TCP will not time out earlier than R2. This is the case, because the RTO schedule follows a fixed pattern, namely exponential backoff. However, the RTO behaviour is not predictable any more if RTO backoffs can be reverted, as it is the case in the draft "Make TCP more Robust to Long Connectivity Disruptions" (http://tools.ietf.org/html/draft-zimmermann-tcp-lcd). In the worst case TCP would time out a connection after 3.2 seconds, if the initial RTO equaled MIN_RTO and each backoff has been reverted. This patch introduces a function retransmits_timed_out(N), which calculates the timeout of a TCP connection, assuming an initial RTO of MIN_RTO and N unsuccessful, exponentially backed-off retransmissions. Whenever timeout decisions are made by comparing the retransmission counter to some value N, this function can be used, instead. The meaning of tcp_retries2 will be changed, as many more RTO retransmissions can occur than the value indicates. However, it yields a timeout which is similar to the one of an unpatched, exponentially backing off TCP in the same scenario. As no application could rely on an RTO greater than MIN_RTO, there should be no risk of a regression. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01Revert Backoff [v3]: Revert RTO on ICMP destination unreachableDamian Lukowski
Here, an ICMP host/network unreachable message, whose payload fits to TCP's SND.UNA, is taken as an indication that the RTO retransmission has not been lost due to congestion, but because of a route failure somewhere along the path. With true congestion, a router won't trigger such a message and the patched TCP will operate as standard TCP. This patch reverts one RTO backoff, if an ICMP host/network unreachable message, whose payload fits to TCP's SND.UNA, arrives. Based on the new RTO, the retransmission timer is reset to reflect the remaining time, or - if the revert clocked out the timer - a retransmission is sent out immediately. Backoffs are only reverted, if TCP is in RTO loss recovery, i.e. if there have been retransmissions and reversible backoffs, already. Changes from v2: 1) Renaming of skb in tcp_v4_err() moved to another patch. 2) Reintroduced tcp_bound_rto() and __tcp_set_rto(). 3) Fixed code comments. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-28tcp: keepalive cleanupsEric Dumazet
Introduce keepalive_probes(tp) helper, and use it, like keepalive_time_when(tp) and keepalive_intvl_when(tp) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02tcp: cleanup ca_state mess in tcp_timerIlpo Järvinen
Redundant checks made indentation impossible to follow. However, it might be useful to make this ca_state+is_sack indexed array. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-18tcp: Stop scaring users with "treason uncloaked!"Matt Mackall
The original message was unhelpful and extremely alarming to our poor users, despite its charm. Make it less frightening. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: Use a percpu_counter for orphan_countEric Dumazet
Instead of using one atomic_t per protocol, use a percpu_counter for "orphan_count", to reduce cache line contention on heavy duty network servers. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: clean up net/ipv4/ip_fragment.c tcp_timer.c ip_input.cJianjun Kong
Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/ipv4/ net/ipv6/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
2008-10-28net: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-07net: wrap sk->sk_backlog_rcv()Peter Zijlstra
Wrap calling sk->sk_backlog_rcv() in a function. This will allow extending the generic sk_backlog_rcv behaviour. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to NET_INC_STATS_BHPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03tcp: de-bloat a bit with factoring NET_INC_STATS_BH outPavel Emelyanov
There are some places in TCP that select one MIB index to bump snmp statistics like this: if (<something>) NET_INC_STATS_BH(<some_id>); else if (<something_else>) NET_INC_STATS_BH(<some_other_id>); ... else NET_INC_STATS_BH(<default_id>); or in a more tricky but still similar way. On the other hand, this NET_INC_STATS_BH is a camouflaged increment of percpu variable, which is not that small. Factoring those cases out de-bloats 235 bytes on non-preemptible i386 config and drives parts of the code into 80 columns. add/remove: 0/0 grow/shrink: 0/7 up/down: 0/-235 (-235) function old new delta tcp_fastretrans_alert 1437 1424 -13 tcp_dsack_set 137 124 -13 tcp_xmit_retransmit_queue 690 676 -14 tcp_try_undo_recovery 283 265 -18 tcp_sacktag_write_queue 1550 1515 -35 tcp_update_reordering 162 106 -56 tcp_retransmit_timer 990 904 -86 Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
2008-06-12tcp: Revert 'process defer accept as established' changes.David S. Miller
This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87 ("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38 ("tcp: Fix slab corruption with ipv6 and tcp6fuzz"). This change causes several problems, first reported by Ingo Molnar as a distcc-over-loopback regression where connections were getting stuck. Ilpo Järvinen first spotted the locking problems. The new function added by this code, tcp_defer_accept_check(), only has the child socket locked, yet it is modifying state of the parent listening socket. Fixing that is non-trivial at best, because we can't simply just grab the parent listening socket lock at this point, because it would create an ABBA deadlock. The normal ordering is parent listening socket --> child socket, but this code path would require the reverse lock ordering. Next is a problem noticed by Vitaliy Gusev, he noted: ---------------------------------------- >--- a/net/ipv4/tcp_timer.c >+++ b/net/ipv4/tcp_timer.c >@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data) > goto death; > } > >+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) { >+ tcp_send_active_reset(sk, GFP_ATOMIC); >+ goto death; Here socket sk is not attached to listening socket's request queue. tcp_done() will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should release this sk) as socket is not DEAD. Therefore socket sk will be lost for freeing. ---------------------------------------- Finally, Alexey Kuznetsov argues that there might not even be any real value or advantage to these new semantics even if we fix all of the bugs: ---------------------------------------- Hiding from accept() sockets with only out-of-order data only is the only thing which is impossible with old approach. Is this really so valuable? My opinion: no, this is nothing but a new loophole to consume memory without control. ---------------------------------------- So revert this thing for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[TCP]: Format addresses appropriately in debug messages.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[IPV4]: Use NIPQUAD_FMT to format ipv4 addresses.YOSHIFUJI Hideaki
And use %u to format port. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[TCP]: TCP_DEFER_ACCEPT updates - process as establishedPatrick McManus
Change TCP_DEFER_ACCEPT implementation so that it transitions a connection to ESTABLISHED after handshake is complete instead of leaving it in SYN-RECV until some data arrvies. Place connection in accept queue when first data packet arrives from slow path. Benefits: - established connection is now reset if it never makes it to the accept queue - diagnostic state of established matches with the packet traces showing completed handshake - TCP_DEFER_ACCEPT timeouts are expressed in seconds and can now be enforced with reasonable accuracy instead of rounding up to next exponential back-off of syn-ack retry. Signed-off-by: Patrick McManus <mcmanus@ducksong.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Do not purge sk_forward_alloc entirely in tcp_delack_timer().David S. Miller
Otherwise we beat heavily on the global tcp_memory atomics when all of the sockets in the system are slowly sending perioding packet clumps. Noticed and suggested by Eric Dumazet. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET] CORE: Introducing new memory accounting interface.Hideo Aoki
This patch introduces new memory accounting functions for each network protocol. Most of them are renamed from memory accounting functions for stream protocols. At the same time, some stream memory accounting functions are removed since other functions do same thing. Renaming: sk_stream_free_skb() -> sk_wmem_free_skb() __sk_stream_mem_reclaim() -> __sk_mem_reclaim() sk_stream_mem_reclaim() -> sk_mem_reclaim() sk_stream_mem_schedule -> __sk_mem_schedule() sk_stream_pages() -> sk_mem_pages() sk_stream_rmem_schedule() -> sk_rmem_schedule() sk_stream_wmem_schedule() -> sk_wmem_schedule() sk_charge_skb() -> sk_mem_charge() Removeing sk_stream_rfree(): consolidates into sock_rfree() sk_stream_set_owner_r(): consolidates into skb_set_owner_r() sk_stream_mem_schedule() The following functions are added. sk_has_account(): check if the protocol supports accounting sk_mem_uncharge(): do the opposite of sk_mem_charge() In addition, to achieve consolidation, updating sk_wmem_queued is removed from sk_mem_charge(). Next, to consolidate memory accounting functions, this patch adds memory accounting calls to network core functions. Moreover, present memory accounting call is renamed to new accounting call. Finally we replace present memory accounting calls with new interface in TCP and SCTP. Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Hideo Aoki <haoki@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Avoid a divide in tcp_mtu_probing()Eric Dumazet
tcp_mtu_to_mss() being signed, compiler might emit an integer divide to compute tcp_mtu_to_mss()/2 . Using a right shift is OK here and less expensive. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Move mss variable in tcp_mtu_probing()David S. Miller
Down into the only scope where it is used. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: tcp_write_timeout.c cleanupEric Dumazet
Before submiting a patch to change a divide to a right shift, I felt necessary to create a helper function tcp_mtu_probing() to reduce length of lines exceeding 100 chars in tcp_write_timeout(). Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP]: Move sack_ok access to obviously named funcs & cleanupIlpo Järvinen
Previously code had IsReno/IsFack defined as macros that were local to tcp_input.c though sack_ok field has user elsewhere too for the same purpose. This changes them to static inlines as preferred according the current coding style and unifies the access to sack_ok across multiple files. Magic bitops of sack_ok for FACK and DSACK are also abstracted to functions with appropriate names. Note: - One sack_ok = 1 remains but that's self explanary, i.e., it enables sack - Couple of !IsReno cases are changed to tcp_is_sack - There were no users for IsDSack => I dropped it Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
