path: root/net/ipv4/tunnel4.c
2008-06-05[IPV4] TUNNEL4: Fix incoming packet length check for inter-protocol tunnel.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-16[SIT]: Allow for IPPROTO_IPV6 protocol in namespaces.Pavel Emelyanov
This makes sit-generated traffic enter the namespace. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IPIP]: Allow for IPPROTO_IPIP protocol in namespaces.Pavel Emelyanov
This one was disabled by default for sanity. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[INET]: Cleanup the xfrm4_tunnel_(un)registerPavel Emelyanov
Both check for the family to select an appropriate tunnel list. Consolidate this check and make the for() loop more readable. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[INET]: Add missed tunnel64_err handlerPavel Emelyanov
The tunnel64_protocol uses the tunnel4_protocol's err_handler and thus calls the tunnel4_protocol's handlers. This is not very good, as in case of (icmp) error the wrong error handlers will be called (e.g. ipip ones instead of sit) and this won't be noticed at all, because the error is not reported. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-13[IPSEC]: Changing API of xfrm4_tunnel_register.Kazunori MIYAZAWA
This patch changes xfrm4_tunnel register and deregister interface to prepare for solving the conflict of device tunnels with inter address family IPsec tunnel. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[INET]: Move no-tunnel ICMP error to tunnel4/tunnel6Herbert Xu
This patch moves the sending of ICMP messages when there are no IPv4/IPv6 tunnels present to tunnel4/tunnel6 respectively. Please note that for now if xfrm4_tunnel/xfrm6_tunnel is loaded then no ICMP messages will ever be sent. This is similar to how we handle AH/ESP/IPCOMP. This move fixes the bug where we always send an ICMP message when there is no ip6_tunnel device present for a given packet even if it is later handled by IPsec. It also causes ICMP messages to be sent when no IPIP tunnel is present. I've decided to use the "port unreachable" ICMP message over the current value of "address unreachable" (and "protocol unreachable" by GRE) because it is not ambiguous unlike the other ones which can be triggered by other conditions. There seems to be no standard specifying what value must be used so this change should be OK. In fact we should change GRE to use this value as well. Incidentally, this patch also fixes a fairly serious bug in xfrm6_tunnel where we don't check whether the embedded IPv6 header is present before dereferencing it for the inside source address. This patch is inspired by a previous patch by Hugo Santos <hsantos@av.it.pt>. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[INET]: Introduce tunnel4/tunnel6Herbert Xu
Basically this patch moves the generic tunnel protocol stuff out of xfrm4_tunnel/xfrm6_tunnel and moves it into the new files of tunnel4.c and tunnel6 respectively. The reason for this is that the problem that Hugo uncovered is only the tip of the iceberg. The real problem is that when we removed the dependency of ipip on xfrm4_tunnel we didn't really consider the module case at all. For instance, as it is it's possible to build both ipip and xfrm4_tunnel as modules and if the latter is loaded then ipip simply won't load. After considering the alternatives I've decided that the best way out of this is to restore the dependency of ipip on the non-xfrm-specific part of xfrm4_tunnel. This is acceptable IMHO because the intention of the removal was really to be able to use ipip without the xfrm subsystem. This is still preserved by this patch. So now both ipip/xfrm4_tunnel depend on the new tunnel4.c which handles the arbitration between the two. The order of processing is determined by a simple integer which ensures that ipip gets processed before xfrm4_tunnel. The situation for ICMP handling is a little bit more complicated since we may not have enough information to determine who it's for. It's not a big deal at the moment since the xfrm ICMP handlers are basically no-ops. In future we can deal with this when we look at ICMP caching in general. The user-visible change to this is the removal of the TUNNEL Kconfig prompts. This makes sense because it can only be used through IPCOMP as it stands. The addition of the new modules shouldn't introduce any problems since module dependency will cause them to be loaded. Oh and I also turned some unnecessary pskb's in IPv6 related to this patch to skb's. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
