Steffen reported that the recent change to add oif to dst lookups breaks
the VTI use case. The problem is that with the oif set in the flow struct
the comparison to the nh_oif is triggered. Fix by splitting the
FLOWI_FLAG_VRFSRC into 2 flags -- one that triggers the vrf device cache
bypass (FLOWI_FLAG_VRFSRC) and another telling the lookup to not compare
nh oif (FLOWI_FLAG_SKIP_NH_OIF).
Fixes: 42a7b32b73d6 ("xfrm: Add oif to dst lookups")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
For unconnected UDP sockets using a VRF device lookup source address
based on VRF table. This allows the UDP header to be properly setup
before showing up at the VRF device via the dst.
Signed-off-by: Shrijeet Mukherjee <shm@cumulusnetworks.com>
Multicast dst are not cached. They carry DST_NOCACHE.
As mentioned in commit f8864972126899 ("ipv4: fix dst race in
sk_dst_get()"), these dst need special care before caching them
into a socket.
Caching them is allowed only if their refcnt was not 0, ie we
must use atomic_inc_not_zero()
Also, we must use READ_ONCE() to fetch sk->sk_rx_dst, as mentioned
in commit d0c294c53a771 ("tcp: prevent fetching dst twice in early demux
code")
Fixes: 421b3885bf6d ("udp: ipv4: Add udp early demux")
Tested-by: Gregory Hoggarth <Gregory.Hoggarth@alliedtelesis.co.nz>
Reported-by: Gregory Hoggarth <Gregory.Hoggarth@alliedtelesis.co.nz>
Reported-by: Alex Gartrell <agartrell@fb.com>
Cc: Michal Kubeček <mkubecek@suse.cz>
421b3885bf6d56391297844f43fb7154a6396e12 "udp: ipv4: Add udp early
demux" introduced a regression that allowed sockets bound to INADDR_ANY
to receive packets from multicast groups that the socket had not joined.
For example a socket that had joined 224.168.2.9 could also receive
packets from 225.168.2.9 despite not having joined that group if
ip_early_demux is enabled.
Fix this by calling ip_check_mc_rcu() in udp_v4_early_demux() to verify
that the multicast packet is indeed ours.
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru>
We have two problems in UDP stack related to bogus checksums :
1) We return -EAGAIN to application even if receive queue is not empty.
This breaks applications using edge trigger epoll()
2) Under UDP flood, we can loop forever without yielding to other
processes, potentially hanging the host, especially on non SMP.
This patch is an attempt to make things better.
We might in the future add extra support for rt applications
wanting to better control time spent doing a recv() in a hostile
environment. For example we could validate checksums before queuing
packets in socket receive queue.
Cc: Willem de Bruijn <willemb@google.com>
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
The ipv4 code uses a mixture of coding styles. In some instances check
for non-NULL pointer is done as x != NULL and sometimes as x. x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
for NULL pointer is done as x == NULL and sometimes as !x. !x is
const qualifiers ease code review by making clear
which objects are not written in a function.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
In the unlikely event that skb_get_hash is unable to deduce a hash
in udp_flow_src_port we use a consistent random value instead.
This is specified in GRE/UDP draft section 3.2.1:
https://tools.ietf.org/html/draft-ietf-tsvwg-gre-in-udp-encap-04
Signed-off-by: Tom Herbert <therbert@google.com>
Add ip_cmsg_recv_offset function which takes an offset argument
that indicates the starting offset in skb where data is being received
from. This will be useful in the case of UDP and provided checksum
to user space.
ip_cmsg_recv is an inline call to ip_cmsg_recv_offset with offset of
zero.
Move convert_csum from udp_sock to inet_sock. This allows the
possibility that we can use convert checksum for different types
of sockets and also allows convert checksum to be enabled from
inet layer (what we'll want to do when enabling IP_CHECKSUM cmsg).
The compute_score functions are a bit difficult to read.
Neaten them a bit to reduce object sizes and make them a
bit more intelligible.
Return early to avoid indentation and avoid unnecessary
initializations.
(allyesconfig, but w/ -O2 and no profiling)
$ size net/ipv[46]/udp.o.*
28680 1184 25 29889 74c1 net/ipv4/udp.o.new
28756 1184 25 29965 750d net/ipv4/udp.o.old
17600 1010 2 18612 48b4 net/ipv6/udp.o.new
17632 1010 2 18644 48d4 net/ipv6/udp.o.old
Standardize function pointer uses.
Convert calling style from:
(*foo)(args...);
to:
foo(args...);
Other miscellanea:
o Add braces around loops with single ifs on multiple lines
o Realign arguments around these functions
o Invert logic in if to return immediately.
Use the more common dynamic_debug capable net_dbg_ratelimited
and remove the LIMIT_NETDEBUG macro.
All messages are still ratelimited.
Some KERN_<LEVEL> uses are changed to KERN_DEBUG.
This may have some negative impact on messages that were
emitted at KERN_INFO that are not not enabled at all unless
DEBUG is defined or dynamic_debug is enabled. Even so,
these messages are now _not_ emitted by default.
This also eliminates the use of the net_msg_warn sysctl
"/proc/sys/net/core/warnings". For backward compatibility,
the sysctl is not removed, but it has no function. The extern
declaration of net_msg_warn is removed from sock.h and made
static in net/core/sysctl_net_core.c
Miscellanea:
o Update the sysctl documentation
o Remove the embedded uses of pr_fmt
o Coalesce format fragments
o Realign arguments
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
As NIC multicast filtering isn't perfect, and some platforms are
quite content to spew broadcasts, we should not trigger an event
for skb:kfree_skb when we do not have a match for such an incoming
datagram. We do though want to avoid sweeping the matter under the
rug entirely, so increment a suitable statistic.
This incorporates feedback from David L. Stevens, Karl Neiss and Eric
Dumazet.
V3 - use bool per David Miller
Signed-off-by: Rick Jones <rick.jones2@hp.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
else is unnecessary after return 0 in __udp4_lib_rcv()
Since sock_efree and sock_demux are essentially the same code for non-TCP
sockets and the case where CONFIG_INET is not defined we can combine the
code or replace the call to sock_edemux in several spots. As a result we
can avoid a bit of unnecessary code or code duplication.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Add support for doing CHECKSUM_UNNECESSARY to CHECKSUM_COMPLETE
conversion in UDP tunneling path.
In the normal UDP path, we call skb_checksum_try_convert after locating
the UDP socket. The check is that checksum conversion is enabled for
the socket (new flag in UDP socket) and that checksum field is
non-zero.
In the UDP GRO path, we call skb_gro_checksum_try_convert after
checksum is validated and checksum field is non-zero. Since this is
already in GRO we assume that checksum conversion is always wanted.
Implement GRO for UDPv6. Add UDP checksum verification in gro_receive
for both UDP4 and UDP6 calling skb_gro_checksum_validate_zero_check.
Replace open codings of (((u64) <x> * <y>) >> 32) with reciprocal_scale().
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
It hasn't been used since commit 0fd7bac(net: relax rcvbuf limits).
Signed-off-by: Sorin Dumitru <sorin@returnze.ro>
Many multicast sources can have the same port which can result in a very
large list when hashing by port only. Hash by address and port instead
if this is the case. This makes multicast more similar to unicast.
On a 24-core machine receiving from 500 multicast sockets on the same
port, before this patch 80% of system CPU was used up by spin locking
and only ~25% of packets were successfully delivered.
With this patch, all packets are delivered and kernel overhead is ~8%
system CPU on spinlocks.
Signed-off-by: David Held <drheld@google.com>
Switch to using sk_nulls_for_each which shortens the code and makes it
easier to update.
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
Add MIB counters for rcvbuferrors in UDP to help diagnose problems.
Signed-off-by: James M Leddy <james.leddy@redhat.com>
Its too easy to add thousand of UDP sockets on a particular bucket,
and slow down an innocent multicast receiver.
Early demux is supposed to be an optimization, we should avoid spending
too much time in it.
It is interesting to note __udp4_lib_demux_lookup() only tries to
match first socket in the chain.
10 is the threshold we already have in __udp4_lib_lookup() to switch
to secondary hash.
Fixes: 421b3885bf6d5 ("udp: ipv4: Add udp early demux")
Reported-by: David Held <drheld@google.com>
Cc: Shawn Bohrer <sbohrer@rgmadvisors.com>
Added a new netif feature for GSO_UDP_TUNNEL_CSUM. This indicates
that a device is capable of computing the UDP checksum in the
encapsulating header of a UDP tunnel.
Added udp_set_csum and udp6_set_csum functions to set UDP checksums
in packets. These are for simple UDP packets such as those that might
be created in UDP tunnels.
RFC 6935 permits zero checksums to be used in IPv6 however this is
recommended only for certain tunnel protocols, it does not make
checksums completely optional like they are in IPv4.
This patch restricts the use of IPv6 zero checksums that was previously
intoduced. no_check6_tx and no_check6_rx have been added to control
the use of checksums in UDP6 RX and TX path. The normal
sk_no_check_{rx,tx} settings are not used (this avoids ambiguity when
dealing with a dual stack socket).
A helper function has been added (udp_set_no_check6) which can be
called by tunnel impelmentations to all zero checksums (send on the
socket, and accept them as valid).
Define separate fields in the sock structure for configuring disabling
checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx.
The SO_NO_CHECK socket option only affects sk_no_check_tx. Also,
removed UDP_CSUM_* defines since they are no longer necessary.
Missing a colon on definition use is a bit odd so
change the macro for the 32 bit case to declare an
__attribute__((unused)) and __deprecated variable.
The __deprecated attribute will cause gcc to emit
an error if the variable is actually used.
ip_local_port_range is already per netns, so should ip_local_reserved_ports
be. And since it is none by default we don't actually need it when we don't
enable CONFIG_SYSCTL.
By the way, rename inet_is_reserved_local_port() to inet_is_local_reserved_port()
Moving validation of UDP checksum to be done in UDP not encap layer.
Call skb_checksum_init instead of private functions.
In case we decide in udp6_sendmsg to send the packet down the ipv4
udp_sendmsg path because the destination is either of family AF_INET or
the destination is an ipv4 mapped ipv6 address, we don't honor the
maybe specified ipv4 mapped ipv6 address in IPV6_PKTINFO.
We simply can check for this option in ip_cmsg_send because no calls to
ipv6 module functions are needed to do so.
Reported-by: Gert Doering <gert@space.net>
Cc: Tore Anderson <tore@fud.no>
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This patch removes the net_random and net_srandom macros and replaces
them with direct calls to the prandom ones. As new commits only seem to
use prandom_u32 there is no use to keep them around.
This change makes it easier to grep for users of prandom_u32.
Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com>
drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c
net/ipv6/ip6_tunnel.c
net/ipv6/ip6_vti.c
ipv6 tunnel statistic bug fixes conflicting with consolidation into
generic sw per-cpu net stats.
qlogic conflict between queue counting bug fix and the addition
of multiple MAC address support.
VM to VM GSO traffic is broken if it goes through VXLAN or GRE
tunnel and the physical NIC on the host supports hardware VXLAN/GRE
GSO offload (e.g. bnx2x and next-gen mlx4).
Two issues -
(VXLAN) VM traffic has SKB_GSO_DODGY and SKB_GSO_UDP_TUNNEL with
SKB_GSO_TCP/UDP set depending on the inner protocol. GSO header
integrity check fails in udp4_ufo_fragment if inner protocol is
TCP. Also gso_segs is calculated incorrectly using skb->len that
includes tunnel header. Fix: robust check should only be applied
to the inner packet.
(VXLAN & GRE) Once GSO header integrity check passes, NULL segs
is returned and the original skb is sent to hardware. However the
tunnel header is already pulled. Fix: tunnel header needs to be
restored so that hardware can perform GSO properly on the original
packet.
Signed-off-by: Wei-Chun Chao <weichunc@plumgrid.com>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2013-12-19
1) Use the user supplied policy index instead of a generated one
if present. From Fan Du.
2) Make xfrm migration namespace aware. From Fan Du.
3) Make the xfrm state and policy locks namespace aware. From Fan Du.
4) Remove ancient sleeping when the SA is in acquire state,
we now queue packets to the policy instead. This replaces the
sleeping code.
5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the
posibility to sleep. The sleeping code is gone, so remove it.
6) Check user specified spi for IPComp. Thr spi for IPcomp is only
16 bit wide, so check for a valid value. From Fan Du.
7) Export verify_userspi_info to check for valid user supplied spi ranges
with pfkey and netlink. From Fan Du.
8) RFC3173 states that if the total size of a compressed payload and the IPComp
header is not smaller than the size of the original payload, the IP datagram
must be sent in the original non-compressed form. These packets are dropped
by the inbound policy check because they are not transformed. Document the need
to set 'level use' for IPcomp to receive such packets anyway. From Fan Du.
Please pull or let me know if there are problems.
