path: root/net/ipv4/udplite.c
2010-12-16net: fix nulls list corruptions in sk_prot_allocOctavian Purdila
Special care is taken inside sk_port_alloc to avoid overwriting skc_node/skc_nulls_node. We should also avoid overwriting skc_bind_node/skc_portaddr_node. The patch fixes the following crash: BUG: unable to handle kernel paging request at fffffffffffffff0 IP: [<ffffffff812ec6dd>] udp4_lib_lookup2+0xad/0x370 [<ffffffff812ecc22>] __udp4_lib_lookup+0x282/0x360 [<ffffffff812ed63e>] __udp4_lib_rcv+0x31e/0x700 [<ffffffff812bba45>] ? ip_local_deliver_finish+0x65/0x190 [<ffffffff812bbbf8>] ? ip_local_deliver+0x88/0xa0 [<ffffffff812eda35>] udp_rcv+0x15/0x20 [<ffffffff812bba45>] ip_local_deliver_finish+0x65/0x190 [<ffffffff812bbbf8>] ip_local_deliver+0x88/0xa0 [<ffffffff812bb2cd>] ip_rcv_finish+0x32d/0x6f0 [<ffffffff8128c14c>] ? netif_receive_skb+0x99c/0x11c0 [<ffffffff812bb94b>] ip_rcv+0x2bb/0x350 [<ffffffff8128c14c>] netif_receive_skb+0x99c/0x11c0 Signed-off-by: Leonard Crestez <lcrestez@ixiacom.com> Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07udp: dynamically size hash tables at boot timeEric Dumazet
UDP_HTABLE_SIZE was initialy defined to 128, which is a bit small for several setups. 4000 active UDP sockets -> 32 sockets per chain in average. An incoming frame has to lookup all sockets to find best match, so long chains hurt latency. Instead of a fixed size hash table that cant be perfect for every needs, let UDP stack choose its table size at boot time like tcp/ip route, using alloc_large_system_hash() helper Add an optional boot parameter, uhash_entries=x so that an admin can force a size between 256 and 65536 if needed, like thash_entries and rhash_entries. dmesg logs two new lines : [ 0.647039] UDP hash table entries: 512 (order: 0, 4096 bytes) [ 0.647099] UDP Lite hash table entries: 512 (order: 0, 4096 bytes) Maximal size on 64bit arches would be 65536 slots, ie 1 MBytes for non debugging spinlocks. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29udp: RCU handling for Unicast packets.Eric Dumazet
Goals are : 1) Optimizing handling of incoming Unicast UDP frames, so that no memory writes should happen in the fast path. Note: Multicasts and broadcasts still will need to take a lock, because doing a full lockless lookup in this case is difficult. 2) No expensive operations in the socket bind/unhash phases : - No expensive synchronize_rcu() calls. - No added rcu_head in socket structure, increasing memory needs, but more important, forcing us to use call_rcu() calls, that have the bad property of making sockets structure cold. (rcu grace period between socket freeing and its potential reuse make this socket being cold in CPU cache). David did a previous patch using call_rcu() and noticed a 20% impact on TCP connection rates. Quoting Cristopher Lameter : "Right. That results in cacheline cooldown. You'd want to recycle the object as they are cache hot on a per cpu basis. That is screwed up by the delayed regular rcu processing. We have seen multiple regressions due to cacheline cooldown. The only choice in cacheline hot sensitive areas is to deal with the complexity that comes with SLAB_DESTROY_BY_RCU or give up on RCU." - Because udp sockets are allocated from dedicated kmem_cache, use of SLAB_DESTROY_BY_RCU can help here. Theory of operation : --------------------- As the lookup is lockfree (using rcu_read_lock()/rcu_read_unlock()), special attention must be taken by readers and writers. Use of SLAB_DESTROY_BY_RCU is tricky too, because a socket can be freed, reused, inserted in a different chain or in worst case in the same chain while readers could do lookups in the same time. In order to avoid loops, a reader must check each socket found in a chain really belongs to the chain the reader was traversing. If it finds a mismatch, lookup must start again at the begining. This *restart* loop is the reason we had to use rdlock for the multicast case, because we dont want to send same message several times to the same socket. We use RCU only for fast path. Thus, /proc/net/udp still takes spinlocks. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29udp: introduce struct udp_table and multiple spinlocksEric Dumazet
UDP sockets are hashed in a 128 slots hash table. This hash table is protected by *one* rwlock. This rwlock is readlocked each time an incoming UDP message is handled. This rwlock is writelocked each time a socket must be inserted in hash table (bind time), or deleted from this table (close time) This is not scalable on SMP machines : 1) Even in read mode, lock() and unlock() are atomic operations and must dirty a contended cache line, shared by all cpus. 2) A writer might be starved if many readers are 'in flight'. This can happen on a machine with some NIC receiving many UDP messages. User process can be delayed a long time at socket creation/dismantle time. This patch prepares RCU migration, by introducing 'struct udp_table and struct udp_hslot', and using one spinlock per chain, to reduce contention on central rwlock. Introducing one spinlock per chain reduces latencies, for port randomization on heavily loaded UDP servers. This also speedup bindings to specific ports. udp_lib_unhash() was uninlined, becoming to big. Some cleanups were done to ease review of following patch (RCUification of UDP Unicast lookups) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put udplite statistics on struct netPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-28[UDP]: Remove owner from udp_seq_afinfo.Denis V. Lunev
Move it to udp_seq_afinfo->seq_fops as should be. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-28[UDP]: Place file operations directly into udp_seq_afinfo.Denis V. Lunev
No need to have separate never-used variable. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-28[UDP]: Move seq_ops from udp_iter_state to udp_seq_afinfo.Denis V. Lunev
No need to create seq_operations for each instance of 'netstat'. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-28[SOCK]: Drop inuse pcounter from struct proto (v2).Pavel Emelyanov
An uppercut - do not use the pcounter on struct proto. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: Enable TCP/UDP/ICMP inside namespace.Denis V. Lunev
2008-03-24[NETNS][UDP-Lite]: Register /proc/net/udplite(6) in a namespace.Pavel Emelyanov
UDP-Lite sockets are displayed in another files, rather than UDP ones, so make the present in namespaces as well. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[UDP-Lite]: Clean up proc creation a bit.Pavel Emelyanov
Just introduce a helper to remove ifdefs from inside the udplite4_register function. This will help to make the next patch nicer. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[UDP]: Make full use of proto.h.udp_hash innovation.Pavel Emelyanov
After this we have only udp_lib_get_port to get the port and two stubs for ipv4 and ipv6. No difference in udp and udplite except for initialized h.udp_hash member. I tried to find a graceful way to drop the only difference between udp_v4_get_port and udp_v6_get_port (i.e. the rcv_saddr comparison routine), but adding one more callback on the struct proto didn't appear such :( Maybe later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NETNS][IPV6] udp6 - make proc per namespaceDaniel Lezcano
The proc init/exit functions take a new network namespace parameter in order to register/unregister /proc/net/udp6 for a namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[UDP]: Revert udplite and code split.David S. Miller
This reverts commit db1ed684f6c430c4cdad67d058688b8a1b5e607c ("[IPV6] UDP: Rename IPv6 UDP files."), commit 8be8af8fa4405652e6c0797db5465a4be8afb998 ("[IPV4] UDP: Move IPv4-specific bits to other file.") and commit e898d4db2749c6052072e9bc4448e396cbdeb06a ("[UDP]: Allow users to configure UDP-Lite."). First, udplite is of such small cost, and it is a core protocol just like TCP and normal UDP are. We spent enormous amounts of effort to make udplite share as much code with core UDP as possible. All of that work is less valuable if we're just going to slap a config option on udplite support. It is also causing build failures, as reported on linux-next, showing that the changeset was not tested very well. In fact, this is the second build failure resulting from the udplite change. Finally, the config options provided was a bool, instead of a modular option. Meaning the udplite code does not even get build tested by allmodconfig builds, and furthermore the user is not presented with a reasonable modular build option which is particularly needed by distribution vendors. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[IPV4] UDP: Move IPv4-specific bits to other file.YOSHIFUJI Hideaki
Move IPv4-specific UDP bits from net/ipv4/udp.c into (new) net/ipv4/udp_ipv4.c. Rename net/ipv4/udplite.c to net/ipv4/udplite_ipv4.c. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[IPV4] UDP,UDPLITE: Sparse: {__udp4_lib,udp,udplite}_err() are of void.YOSHIFUJI Hideaki
Fix following sparse warnings: | net/ipv4/udp.c:421:2: warning: returning void-valued expression | net/ipv4/udplite.c:38:2: warning: returning void-valued expression Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-11-07[IPV4]: Use the {DEFINE|REF}_PROTO_INUSE infrastructureEric Dumazet
Trivial patch to make "tcp,udp,udplite,raw" protocols uses the fast "inuse sockets" infrastructure Each protocol use then a static percpu var, instead of a dynamic one. This saves some ram and some cpu cycles Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[UDP]: Randomize port selection.Stephen Hemminger
This patch causes UDP port allocation to be randomized like TCP. The earlier code would always choose same port (ie first empty list). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[UDP]: Revert 2-pass hashing changes.David S. Miller
This reverts changesets: 6aaf47fa48d3c44280810b1b470261d340e4ed87 b7b5f487ab39bc10ed0694af35651a03d9cb97ff de34ed91c4ffa4727964a832c46e624dd1495cf5 fc038410b4b1643766f8033f4940bcdb1dace633 There are still some correctness issues recently discovered which do not have a known fix that doesn't involve doing a full hash table scan on port bind. So revert for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[UDP]: Fix AF-specific references in AF-agnostic code.David S. Miller
__udp_lib_port_inuse() cannot make direct references to inet_sk(sk)->rcv_saddr as that is ipv4 specific state and this code is used by ipv6 too. Use an operations vector to solve this, and this also paves the way for ipv6 support for non-wild saddr hashing in UDP. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[UDP]: Clean up UDP-Lite receive checksumHerbert Xu
This patch eliminates some duplicate code for the verification of receive checksums between UDP-Lite and UDP. It does this by introducing __skb_checksum_complete_head which is identical to __skb_checksum_complete_head apart from the fact that it takes a length parameter rather than computing the first skb->len bytes. As a result UDP-Lite will be able to use hardware checksum offload for packets which do not use partial coverage checksums. It also means that UDP-Lite loopback no longer does unnecessary checksum verification. If any NICs start support UDP-Lite this would also start working automatically. This patch removes the assumption that msg_flags has MSG_TRUNC clear upon entry in recvmsg. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Possible cleanups.Adrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global functions statis: - ipv4/tcp.c: __tcp_alloc_md5sig_pool() - ipv4/tcp_ipv4.c: tcp_v4_reqsk_md5_lookup() - ipv4/udplite.c: udplite_rcv() - ipv4/udplite.c: udplite_err() - make the following needlessly global structs static: - ipv4/tcp_ipv4.c: tcp_request_sock_ipv4_ops - ipv4/tcp_ipv4.c: tcp_sock_ipv4_specific - ipv6/tcp_ipv6.c: tcp_request_sock_ipv6_ops - net/ipv{4,6}/udplite.c: remove inline's from static functions (gcc should know best when to inline them) Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
