[ Upstream commit 73f156a6e8c1074ac6327e0abd1169e95eb66463 ]
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ]
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
By default, DSCP is copying during encapsulation.
Copying the DSCP in IPsec tunneling may be a bit dangerous because packets with
different DSCP may get reordered relative to each other in the network and then
dropped by the remote IPsec GW if the reordering becomes too big compared to the
replay window.
It is possible to avoid this copy with netfilter rules, but it's very convenient
to be able to configure it for each SA directly.
This patch adds a toogle for this purpose. By default, it's not set to maintain
backward compatibility.
Field flags in struct xfrm_usersa_info is full, hence I add a new attribute.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Same problem as IPv6
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
This function will be used in next GRE_GSO patch. This patch does
not change any functionality.
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Incorporated David and Steffen's comments.
Add hook for rx-path xfmr4_mode_tunnel for VTI tunnel module.
Signed-off-by: Saurabh Mohan <saurabh.mohan@vyatta.com>
Reviewed-by: Stephen Hemminger <shemminger@vyatta.com>
Niccolo Belli reported ipsec crashes in case we handle a frame without
mac header (atm in his case)
Before copying mac header, better make sure it is present.
Bugzilla reference: https://bugzilla.kernel.org/show_bug.cgi?id=42809
Reported-by: Niccolò Belli <darkbasic@linuxsystems.it>
Tested-by: Niccolò Belli <darkbasic@linuxsystems.it>
Always go through a new ip4_dst_hoplimit() helper, just like ipv6.
This allowed several simplifications:
1) The interim dst_metric_hoplimit() can go as it's no longer
userd.
2) The sysctl_ip_default_ttl entry no longer needs to use
ipv4_doint_and_flush, since the sysctl is not cached in
routing cache metrics any longer.
3) ipv4_doint_and_flush no longer needs to be exported and
therefore can be marked static.
When ipv4_doint_and_flush_strategy was removed some time ago,
the external declaration in ip.h was mistakenly left around
so kill that off too.
We have to move the sysctl_ip_default_ttl declaration into
ipv4's route cache definition header net/route.h, because
currently net/ip.h (where the declaration lives now) has
a back dependency on net/route.h
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
When generating the ip header for the transformed packet we just copy
the frag_off field of the ip header from the original packet to the ip
header of the new generated packet. If we receive a packet as a chain
of fragments, all but the last of the new generated packets have the
IP_MF flag set. We have to mask the frag_off field to only keep the
IP_DF flag from the original packet. This got lost with git commit
36cf9acf93e8561d9faec24849e57688a81eb9c5 ("[IPSEC]: Separate
inner/outer mode processing on output")
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org>
It appears that I've managed to create two different functions both
called xfrm6_tunnel_output. This is because we have the plain tunnel
encapsulation named xfrmX_tunnel as well as the tunnel-mode encapsulation
which lives in the files xfrmX_mode_tunnel.c.
This patch renames functions from the latter to use the xfrmX_mode_tunnel
prefix to avoid name-space conflicts.
With inter-family transforms the inner mode differs from the outer
mode. Attempting to handle both sides from the same function means
that it needs to handle both IPv4 and IPv6 which creates duplication
and confusion.
This patch separates the two parts on the input path so that each
function deals with one family only.
In particular, the functions xfrm4_extract_inut/xfrm6_extract_inut
moves the pertinent fields from the IPv4/IPv6 IP headers into a
neutral format stored in skb->cb. This is then used by the inner mode
input functions to modify the inner IP header. In this way the input
function no longer has to know about the outer address family.
and confusion.
This patch separates the two parts on the output path so that each
In particular, the functions xfrm4_extract_output/xfrm6_extract_output
neutral format stored in skb->cb. This is then used by the outer mode
output functions to write the outer IP header. In this way the output
function no longer has to know about the inner address family.
Since the extract functions are only called by tunnel modes (the only
modes that can support inter-family transforms), I've also moved the
xfrm*_tunnel_check_size calls into them. This allows the correct ICMP
message to be sent as opposed to now where you might call icmp_send
with an IPv6 packet and vice versa.
This patch changes the prototype of ipv4_copy_dscp and ipv6_copy_dscp so
that they directly take the outer DSCP rather than the outer IP header.
This will help us to unify the code for inter-family tunnels.
Currently BEET mode does not reinject the packet back into the stack
like tunnel mode does. Since BEET should behave just like tunnel mode
this is incorrect.
This patch fixes this by introducing a flags field to xfrm_mode that
tells the IPsec code whether it should terminate and reinject the packet
back into the stack.
It then sets the flag for BEET and tunnel mode.
I've also added a number of missing BEET checks elsewhere where we check
whether a given mode is a tunnel or not.
This patch moves the setting of the IP length and checksum fields out of
the transforms and into the xfrmX_output functions. This would help future
efforts in merging the transforms themselves.
It also adds an optimisation to ipcomp due to the fact that the transport
offset is guaranteed to be zero.
The IPv6 calling convention for x->mode->output is more general and could
help an eventual protocol-generic x->type->output implementation. This
patch adopts it for IPv4 as well and modifies the IPv4 type output functions
accordingly.
It also rewrites the IPv6 mac/transport header calculation to be based off
the network header where practical.
This patch changes the calling convention so that on entry from
x->mode->output and before entry into x->type->output skb->data
will point to the payload instead of the IP header.
This is essentially a redistribution of skb_push/skb_pull calls
with the aim of minimising them on the common path of tunnel +
ESP.
It'll also let us use the same calling convention between IPv4
and IPv6 with the next patch.
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and
skb->mac to skb->mac_header, to match the names of the associated helpers
(skb[_[re]set]_{transport,network,mac}_header).
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Now the skb->nh union has just one member, .raw, i.e. it is just like the
skb->mac union, strange, no? I'm just leaving it like that till the transport
layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or
->mac_header_offset?), ditto for ->{h,nh}.
skb_push updates and returns skb->data, so we can just call
skb_reset_network_header after the call to skb_push.
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
For the places where we need a pointer to the mac header, it is still legal to
touch skb->mac.raw directly if just adding to, subtracting from or setting it
to another layer header.
This one also converts some more cases to skb_reset_mac_header() that my
regex missed as it had no spaces before nor after '=', ugh.
Add whitespace around keywords.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Please consider applying, this was found on your latest
net-2.6 tree while playing around with that ip_hdr() + turn
skb->nh/h/mac pointers as offsets on 64 bits idea :-)
Add missing break when CONFIG_IPV6=n.
This is the patch to support IPv6 over IPv4 IPsec
Signed-off-by: Miika Komu <miika@iki.fi>
Signed-off-by: Diego Beltrami <Diego.Beltrami@hiit.fi>
Signed-off-by: Kazunori Miyazawa <miyazawa@linux-ipv6.org>
Expose IPSEC modes output path to take an xfrm state as input param.
This makes it consistent with the input mode processing (which already
takes the xfrm state as a param).
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
Now that we always zero the IPCB->opts in ip_rcv, it is no longer
necessary to do so before calling netif_rx for tunneled packets.
This patch adds the structure xfrm_mode. It is meant to represent
the operations carried out by transport/tunnel modes.
By doing this we allow additional encapsulation modes to be added
without clogging up the xfrm_input/xfrm_output paths.
Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and
BEET modes.
