path: root/net/ipv4/xfrm4_output.c
2015-10-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/ipv6/xfrm6_output.c net/openvswitch/flow_netlink.c net/openvswitch/vport-gre.c net/openvswitch/vport-vxlan.c net/openvswitch/vport.c net/openvswitch/vport.h The openvswitch conflicts were overlapping changes. One was the egress tunnel info fix in 'net' and the other was the vport ->send() op simplification in 'net-next'. The xfrm6_output.c conflicts was also a simplification overlapping a bug fix. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-19xfrm: Fix pmtu discovery for local generated packets.Steffen Klassert
Commit 044a832a777 ("xfrm: Fix local error reporting crash with interfamily tunnels") moved the setting of skb->protocol behind the last access of the inner mode family to fix an interfamily crash. Unfortunately now skb->protocol might not be set at all, so we fail dispatch to the inner address family. As a reault, the local error handler is not called and the mtu value is not reported back to userspace. We fix this by setting skb->protocol on message size errors before we call xfrm_local_error. Fixes: 044a832a7779c ("xfrm: Fix local error reporting crash with interfamily tunnels") Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2015-10-08dst: Pass net into dst->outputEric W. Biederman
The network namespace is already passed into dst_output pass it into dst->output lwt->output and friends. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-08net: Pass net into dst_output and remove dst_output_okfnEric W. Biederman
Replace dst_output_okfn with dst_output Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: Add blank lines in callers of netfilter hooksEric W. Biederman
In code review it was noticed that I had failed to add some blank lines in places where they are customarily used. Taking a second look at the code I have to agree blank lines would be nice so I have added them here. Reported-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: Pass net into okfnEric W. Biederman
This is immediately motivated by the bridge code that chains functions that call into netfilter. Without passing net into the okfns the bridge code would need to guess about the best expression for the network namespace to process packets in. As net is frequently one of the first things computed in continuation functions after netfilter has done it's job passing in the desired network namespace is in many cases a code simplification. To support this change the function dst_output_okfn is introduced to simplify passing dst_output as an okfn. For the moment dst_output_okfn just silently drops the struct net. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: Pass struct net into the netfilter hooksEric W. Biederman
Pass a network namespace parameter into the netfilter hooks. At the call site of the netfilter hooks the path a packet is taking through the network stack is well known which allows the network namespace to be easily and reliabily. This allows the replacement of magic code like "dev_net(state->in?:state->out)" that appears at the start of most netfilter hooks with "state->net". In almost all cases the network namespace passed in is derived from the first network device passed in, guaranteeing those paths will not see any changes in practice. The exceptions are: xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm) ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp) ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp) ipv4/raw.c:raw_send_hdrinc() sock_net(sk) ipv6/ip6_output.c:ip6_xmit() sock_net(sk) ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev) ipv6/raw.c:raw6_send_hdrinc() sock_net(sk) br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev In all cases these exceptions seem to be a better expression for the network namespace the packet is being processed in then the historic "dev_net(in?in:out)". I am documenting them in case something odd pops up and someone starts trying to track down what happened. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17net: Merge dst_output and dst_output_skEric W. Biederman
Add a sock paramter to dst_output making dst_output_sk superfluous. Add a skb->sk parameter to all of the callers of dst_output Have the callers of dst_output_sk call dst_output. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-07netfilter: Pass socket pointer down through okfn().David Miller
On the output paths in particular, we have to sometimes deal with two socket contexts. First, and usually skb->sk, is the local socket that generated the frame. And second, is potentially the socket used to control a tunneling socket, such as one the encapsulates using UDP. We do not want to disassociate skb->sk when encapsulating in order to fix this, because that would break socket memory accounting. The most extreme case where this can cause huge problems is an AF_PACKET socket transmitting over a vxlan device. We hit code paths doing checks that assume they are dealing with an ipv4 socket, but are actually operating upon the AF_PACKET one. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-09xfrm: Fix local error reporting crash with interfamily tunnelsSteffen Klassert
We set the outer mode protocol too early. As a result, the local error handler might dispatch to the wrong address family and report the error to a wrong socket type. We fix this by setting the outer protocol to the skb after we accessed the inner mode for the last time, right before we do the atcual encapsulation where we switch finally to the outer mode. Reported-by: Chris Ruehl <chris.ruehl@gtsys.com.hk> Tested-by: Chris Ruehl <chris.ruehl@gtsys.com.hk> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/bonding/bond_alb.c drivers/net/ethernet/altera/altera_msgdma.c drivers/net/ethernet/altera/altera_sgdma.c net/ipv6/xfrm6_output.c Several cases of overlapping changes. The xfrm6_output.c has a bug fix which overlaps the renaming of skb->local_df to skb->ignore_df. In the Altera TSE driver cases, the register access cleanups in net-next overlapped with bug fixes done in net. Similarly a bug fix to send ALB packets in the bonding driver using the right source address overlaps with cleanups in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Conflicts: net/ipv4/ip_vti.c Steffen Klassert says: ==================== pull request (net): ipsec 2014-05-15 This pull request has a merge conflict in net/ipv4/ip_vti.c between commit 8d89dcdf80d8 ("vti: don't allow to add the same tunnel twice") and commit a32452366b72 ("vti4:Don't count header length twice"). It can be solved like it is done in linux-next. 1) Fix a ipv6 xfrm output crash when a packet is rerouted by netfilter to not use IPsec. 2) vti4 counts some header lengths twice leading to an incorrect device mtu. Fix this by counting these headers only once. 3) We don't catch the case if an unsupported protocol is submitted to the xfrm protocol handlers, this can lead to NULL pointer dereferences. Fix this by adding the appropriate checks. 4) vti6 may unregister pernet ops twice on init errors. Fix this by removing one of the calls to do it only once. From Mathias Krause. 5) Set the vti tunnel mark before doing a lookup in the error handlers. Otherwise we don't find the correct xfrm state. ==================== The conflict in ip_vti.c was simple, 'net' had a commit removing a line from vti_tunnel_init() and this tree being merged had a commit adding a line to the same location. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-12net: rename local_df to ignore_dfWANG Cong
As suggested by several people, rename local_df to ignore_df, since it means "ignore df bit if it is set". Cc: Maciej Żenczykowski <maze@google.com> Cc: Florian Westphal <fw@strlen.de> Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-15ipv4: add a sock pointer to dst->output() path.Eric Dumazet
In the dst->output() path for ipv4, the code assumes the skb it has to transmit is attached to an inet socket, specifically via ip_mc_output() : The sk_mc_loop() test triggers a WARN_ON() when the provider of the packet is an AF_PACKET socket. The dst->output() method gets an additional 'struct sock *sk' parameter. This needs a cascade of changes so that this parameter can be propagated from vxlan to final consumer. Fixes: 8f646c922d55 ("vxlan: keep original skb ownership") Reported-by: lucien xin <lucien.xin@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-07xfrm: Fix crash with ipv6 IPsec tunnel and NAT.Steffen Klassert
The ipv6 xfrm output path is not aware that packets can be rerouted by NAT to not use IPsec. We crash in this case because we expect to have a xfrm state at the dst_entry. This crash happens if the ipv6 layer does IPsec and NAT or if we have an interfamily IPsec tunnel with ipv4 NAT. We fix this by checking for a NAT rerouted packet in each address family and dst_output() to the new destination in this case. Reported-by: Martin Pelikan <martin.pelikan@gmail.com> Tested-by: Martin Pelikan <martin.pelikan@gmail.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-08-26xfrm: revert ipv4 mtu determination to dst_mtuHannes Frederic Sowa
In commit 0ea9d5e3e0e03a63b11392f5613378977dae7eca ("xfrm: introduce helper for safe determination of mtu") I switched the determination of ipv4 mtus from dst_mtu to ip_skb_dst_mtu. This was an error because in case of IP_PMTUDISC_PROBE we fall back to the interface mtu, which is never correct for ipv4 ipsec. This patch partly reverts 0ea9d5e3e0e03a63b11392f5613378977dae7eca ("xfrm: introduce helper for safe determination of mtu"). Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-08-14xfrm: introduce helper for safe determination of mtuHannes Frederic Sowa
skb->sk socket can be of AF_INET or AF_INET6 address family. Thus we always have to make sure we a referring to the correct interpretation of skb->sk. We only depend on header defines to query the mtu, so we don't introduce a new dependency to ipv6 by this change. Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-08-14xfrm: make local error reporting more robustHannes Frederic Sowa
In xfrm4 and xfrm6 we need to take care about sockets of the other address family. This could happen because a 6in4 or 4in6 tunnel could get protected by ipsec. Because we don't want to have a run-time dependency on ipv6 when only using ipv4 xfrm we have to embed a pointer to the correct local_error function in xfrm_state_afinet and look it up when returning an error depending on the socket address family. Thanks to vi0ss for the great bug report: <https://bugzilla.kernel.org/show_bug.cgi?id=58691> v2: a) fix two more unsafe interpretations of skb->sk as ipv6 socket (xfrm6_local_dontfrag and __xfrm6_output) v3: a) add an EXPORT_SYMBOL_GPL(xfrm_local_error) to fix a link error when building ipv6 as a module (thanks to Steffen Klassert) Reported-by: <vi0oss@gmail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2011-07-01xfrm4: Don't call icmp_send on local errorSteffen Klassert
Calling icmp_send() on a local message size error leads to an incorrect update of the path mtu. So use ip_local_error() instead to notify the socket about the error. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-10xfrm: Assign the inner mode output function to the dst entrySteffen Klassert
As it is, we assign the outer modes output function to the dst entry when we create the xfrm bundle. This leads to two problems on interfamily scenarios. We might insert ipv4 packets into ip6_fragment when called from xfrm6_output. The system crashes if we try to fragment an ipv4 packet with ip6_fragment. This issue was introduced with git commit ad0081e4 (ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed). The second issue is, that we might insert ipv4 packets in netfilter6 and vice versa on interfamily scenarios. With this patch we assign the inner mode output function to the dst entry when we create the xfrm bundle. So xfrm4_output/xfrm6_output from the inner mode is used and the right fragmentation and netfilter functions are called. We switch then to outer mode with the output_finish functions. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-25netfilter: ipv4: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The semantic patch that was used: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_COND |nf_hook )( -PF_INET, +NFPROTO_IPV4, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[IPSEC]: Fix inter address family IPsec tunnel handling.Kazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Remove nhoff from xfrm_inputHerbert Xu
The nhoff field isn't actually necessary in xfrm_input. For tunnel mode transforms we now throw away the output IP header so it makes no sense to fill in the nexthdr field. For transport mode we can now let the function transport_finish do the setting and it knows where the nexthdr field is. The only other thing that needs the nexthdr field to be set is the header extraction code. However, we can simply move the protocol extraction out of the generic header extraction. We want to minimise the amount of info we have to carry around between transforms as this simplifies the resumption process for async crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Merge most of the output pathHerbert Xu
As part of the work on asynchrnous cryptographic operations, we need to be able to resume from the spot where they occur. As such, it helps if we isolate them to one spot. This patch moves most of the remaining family-specific processing into the common output code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Add ip_local_outHerbert Xu
Most callers of the LOCAL_OUT chain will set the IP packet length and header checksum before doing so. They also share the same output function dst_output. This patch creates a new function called ip_local_out which does all of that and converts the appropriate users over to it. Apart from removing duplicate code, it will also help in merging the IPsec output path once the same thing is done for IPv6. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Separate inner/outer mode processing on outputHerbert Xu
With inter-family transforms the inner mode differs from the outer mode. Attempting to handle both sides from the same function means that it needs to handle both IPv4 and IPv6 which creates duplication and confusion. This patch separates the two parts on the output path so that each function deals with one family only. In particular, the functions xfrm4_extract_output/xfrm6_extract_output moves the pertinent fields from the IPv4/IPv6 IP headers into a neutral format stored in skb->cb. This is then used by the outer mode output functions to write the outer IP header. In this way the output function no longer has to know about the inner address family. Since the extract functions are only called by tunnel modes (the only modes that can support inter-family transforms), I've also moved the xfrm*_tunnel_check_size calls into them. This allows the correct ICMP message to be sent as opposed to now where you might call icmp_send with an IPv6 packet and vice versa. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Rename mode to outer_mode and add inner_modeHerbert Xu
This patch adds a new field to xfrm states called inner_mode. The existing mode object is renamed to outer_mode. This is the first part of an attempt to fix inter-family transforms. As it is we always use the outer family when determining which mode to use. As a result we may end up shoving IPv4 packets into netfilter6 and vice versa. What we really want is to use the inner family for the first part of outbound processing and the outer family for the second part. For inbound processing we'd use the opposite pairing. I've also added a check to prevent silly combinations such as transport mode with inter-family transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Add missing BEET checksHerbert Xu
Currently BEET mode does not reinject the packet back into the stack like tunnel mode does. Since BEET should behave just like tunnel mode this is incorrect. This patch fixes this by introducing a flags field to xfrm_mode that tells the IPsec code whether it should terminate and reinject the packet back into the stack. It then sets the flag for BEET and tunnel mode. I've also added a number of missing BEET checks elsewhere where we check whether a given mode is a tunnel or not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move IP length/checksum setting out of transformsHerbert Xu
This patch moves the setting of the IP length and checksum fields out of the transforms and into the xfrmX_output functions. This would help future efforts in merging the transforms themselves. It also adds an optimisation to ipcomp due to the fact that the transport offset is guaranteed to be zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move common output code to xfrm_outputHerbert Xu
Most of the code in xfrm4_output_one and xfrm6_output_one are identical so this patch moves them into a common xfrm_output function which will live in net/xfrm. In fact this would seem to fix a bug as on IPv4 we never reset the network header after a transform which may upset netfilter later on. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPSEC]: output mode to take an xfrm state as input paramJamal Hadi Salim
Expose IPSEC modes output path to take an xfrm state as input param. This makes it consistent with the input mode processing (which already takes the xfrm state as a param). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-08[NET] gso: Add skb_is_gsoHerbert Xu
This patch adds the wrapper function skb_is_gso which can be used instead of directly testing skb_shinfo(skb)->gso_size. This makes things a little nicer and allows us to change the primary key for indicating whether an skb is GSO (if we ever want to do that). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[IPSEC]: Handle GSO packetsHerbert Xu
This patch segments GSO packets received by the IPsec stack. This can happen when a NIC driver injects GSO packets into the stack which are then forwarded to another host. The primary application of this is going to be Xen where its backend driver may inject GSO packets into dom0. Of course this also can be used by other virtualisation schemes such as VMWare or UML since the tap device could be modified to inject GSO packets received through splice. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-29[IPSEC]: Fix IP ID selectionHerbert Xu
I was looking through the xfrm input/output code in order to abstract out the address family specific encapsulation/decapsulation code. During that process I found this bug in the IP ID selection code in xfrm4_output.c. At that point dst is still the xfrm_dst for the current SA which represents an internal flow as far as the IPsec tunnel is concerned. Since the IP ID is going to sit on the outside of the encapsulated packet, we obviously want the external flow which is just dst->child. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[XFRM]: Fix SNAT-related crash in xfrm4_output_finishPatrick McHardy
When a packet matching an IPsec policy is SNATed so it doesn't match any policy anymore it looses its xfrm bundle, which makes xfrm4_output_finish crash because of a NULL pointer dereference. This patch directs these packets to the original output path instead. Since the packets have already passed the POST_ROUTING hook, but need to start at the beginning of the original output path which includes another POST_ROUTING invocation, a flag is added to the IPCB to indicate that the packet was rerouted and doesn't need to pass the POST_ROUTING hook again. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Redo policy lookups after NAT when neccessaryPatrick McHardy
When NAT changes the key used for the xfrm lookup it needs to be done again. If a new policy is returned in POST_ROUTING the packet needs to be passed to xfrm4_output_one manually after all hooks were called because POST_ROUTING is called with fixed okfn (ip_finish_output). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Fix xfrm lookup in ip_route_me_harder/ip6_route_me_harderPatrick McHardy
ip_route_me_harder doesn't use the port numbers of the xfrm lookup and uses ip_route_input for non-local addresses which doesn't do a xfrm lookup, ip6_route_me_harder doesn't do a xfrm lookup at all. Use xfrm_decode_session and do the lookup manually, make sure both only do the lookup if the packet hasn't been transformed already. Makeing sure the lookup only happens once needs a new field in the IP6CB, which exceeds the size of skb->cb. The size of skb->cb is increased to 48b. Apparently the IPv6 mobile extensions need some more room anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[XFRM]: Netfilter IPsec output hooksPatrick McHardy
Call netfilter hooks before IPsec transforms. Packets visit the FORWARD/LOCAL_OUT and POST_ROUTING hook before the first encapsulation and the LOCAL_OUT and POST_ROUTING hook before each following tunnel mode transform. Patch from Herbert Xu <herbert@gondor.apana.org.au>: Move the loop from dst_output into xfrm4_output/xfrm6_output since they're the only ones who need to it. xfrm{4,6}_output_one() processes the first SA all subsequent transport mode SAs and is called in a loop that calls the netfilter hooks between each two calls. In order to avoid the tail call issue, I've added the inline function nf_hook which is nf_hook_slow plus the empty list check. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[IPSEC]: Add XFRM_STATE_NOPMTUDISC flagHerbert Xu
This patch adds the flag XFRM_STATE_NOPMTUDISC for xfrm states. It is similar to the nopmtudisc on IPIP/GRE tunnels. It only has an effect on IPv4 tunnel mode states. For these states, it will ensure that the DF flag is always cleared. This is primarily useful to work around ICMP blackholes. In future this flag could also allow a larger MTU to be set within the tunnel just like IPIP/GRE tunnels. This could be useful for short haul tunnels where temporary fragmentation outside the tunnel is desired over smaller fragments inside the tunnel. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
