path: root/net/ipv4/xfrm4_output.c
2008-03-24[IPSEC]: Fix inter address family IPsec tunnel handling.Kazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Remove nhoff from xfrm_inputHerbert Xu
The nhoff field isn't actually necessary in xfrm_input. For tunnel mode transforms we now throw away the output IP header so it makes no sense to fill in the nexthdr field. For transport mode we can now let the function transport_finish do the setting and it knows where the nexthdr field is. The only other thing that needs the nexthdr field to be set is the header extraction code. However, we can simply move the protocol extraction out of the generic header extraction. We want to minimise the amount of info we have to carry around between transforms as this simplifies the resumption process for async crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Merge most of the output pathHerbert Xu
As part of the work on asynchrnous cryptographic operations, we need to be able to resume from the spot where they occur. As such, it helps if we isolate them to one spot. This patch moves most of the remaining family-specific processing into the common output code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Add ip_local_outHerbert Xu
Most callers of the LOCAL_OUT chain will set the IP packet length and header checksum before doing so. They also share the same output function dst_output. This patch creates a new function called ip_local_out which does all of that and converts the appropriate users over to it. Apart from removing duplicate code, it will also help in merging the IPsec output path once the same thing is done for IPv6. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Separate inner/outer mode processing on outputHerbert Xu
With inter-family transforms the inner mode differs from the outer mode. Attempting to handle both sides from the same function means that it needs to handle both IPv4 and IPv6 which creates duplication and confusion. This patch separates the two parts on the output path so that each function deals with one family only. In particular, the functions xfrm4_extract_output/xfrm6_extract_output moves the pertinent fields from the IPv4/IPv6 IP headers into a neutral format stored in skb->cb. This is then used by the outer mode output functions to write the outer IP header. In this way the output function no longer has to know about the inner address family. Since the extract functions are only called by tunnel modes (the only modes that can support inter-family transforms), I've also moved the xfrm*_tunnel_check_size calls into them. This allows the correct ICMP message to be sent as opposed to now where you might call icmp_send with an IPv6 packet and vice versa. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Rename mode to outer_mode and add inner_modeHerbert Xu
This patch adds a new field to xfrm states called inner_mode. The existing mode object is renamed to outer_mode. This is the first part of an attempt to fix inter-family transforms. As it is we always use the outer family when determining which mode to use. As a result we may end up shoving IPv4 packets into netfilter6 and vice versa. What we really want is to use the inner family for the first part of outbound processing and the outer family for the second part. For inbound processing we'd use the opposite pairing. I've also added a check to prevent silly combinations such as transport mode with inter-family transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Add missing BEET checksHerbert Xu
Currently BEET mode does not reinject the packet back into the stack like tunnel mode does. Since BEET should behave just like tunnel mode this is incorrect. This patch fixes this by introducing a flags field to xfrm_mode that tells the IPsec code whether it should terminate and reinject the packet back into the stack. It then sets the flag for BEET and tunnel mode. I've also added a number of missing BEET checks elsewhere where we check whether a given mode is a tunnel or not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move IP length/checksum setting out of transformsHerbert Xu
This patch moves the setting of the IP length and checksum fields out of the transforms and into the xfrmX_output functions. This would help future efforts in merging the transforms themselves. It also adds an optimisation to ipcomp due to the fact that the transport offset is guaranteed to be zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move common output code to xfrm_outputHerbert Xu
Most of the code in xfrm4_output_one and xfrm6_output_one are identical so this patch moves them into a common xfrm_output function which will live in net/xfrm. In fact this would seem to fix a bug as on IPv4 we never reset the network header after a transform which may upset netfilter later on. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPSEC]: output mode to take an xfrm state as input paramJamal Hadi Salim
Expose IPSEC modes output path to take an xfrm state as input param. This makes it consistent with the input mode processing (which already takes the xfrm state as a param). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-08[NET] gso: Add skb_is_gsoHerbert Xu
This patch adds the wrapper function skb_is_gso which can be used instead of directly testing skb_shinfo(skb)->gso_size. This makes things a little nicer and allows us to change the primary key for indicating whether an skb is GSO (if we ever want to do that). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[IPSEC]: Handle GSO packetsHerbert Xu
This patch segments GSO packets received by the IPsec stack. This can happen when a NIC driver injects GSO packets into the stack which are then forwarded to another host. The primary application of this is going to be Xen where its backend driver may inject GSO packets into dom0. Of course this also can be used by other virtualisation schemes such as VMWare or UML since the tap device could be modified to inject GSO packets received through splice. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-29[IPSEC]: Fix IP ID selectionHerbert Xu
I was looking through the xfrm input/output code in order to abstract out the address family specific encapsulation/decapsulation code. During that process I found this bug in the IP ID selection code in xfrm4_output.c. At that point dst is still the xfrm_dst for the current SA which represents an internal flow as far as the IPsec tunnel is concerned. Since the IP ID is going to sit on the outside of the encapsulated packet, we obviously want the external flow which is just dst->child. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[XFRM]: Fix SNAT-related crash in xfrm4_output_finishPatrick McHardy
When a packet matching an IPsec policy is SNATed so it doesn't match any policy anymore it looses its xfrm bundle, which makes xfrm4_output_finish crash because of a NULL pointer dereference. This patch directs these packets to the original output path instead. Since the packets have already passed the POST_ROUTING hook, but need to start at the beginning of the original output path which includes another POST_ROUTING invocation, a flag is added to the IPCB to indicate that the packet was rerouted and doesn't need to pass the POST_ROUTING hook again. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Redo policy lookups after NAT when neccessaryPatrick McHardy
When NAT changes the key used for the xfrm lookup it needs to be done again. If a new policy is returned in POST_ROUTING the packet needs to be passed to xfrm4_output_one manually after all hooks were called because POST_ROUTING is called with fixed okfn (ip_finish_output). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Fix xfrm lookup in ip_route_me_harder/ip6_route_me_harderPatrick McHardy
ip_route_me_harder doesn't use the port numbers of the xfrm lookup and uses ip_route_input for non-local addresses which doesn't do a xfrm lookup, ip6_route_me_harder doesn't do a xfrm lookup at all. Use xfrm_decode_session and do the lookup manually, make sure both only do the lookup if the packet hasn't been transformed already. Makeing sure the lookup only happens once needs a new field in the IP6CB, which exceeds the size of skb->cb. The size of skb->cb is increased to 48b. Apparently the IPv6 mobile extensions need some more room anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[XFRM]: Netfilter IPsec output hooksPatrick McHardy
Call netfilter hooks before IPsec transforms. Packets visit the FORWARD/LOCAL_OUT and POST_ROUTING hook before the first encapsulation and the LOCAL_OUT and POST_ROUTING hook before each following tunnel mode transform. Patch from Herbert Xu <herbert@gondor.apana.org.au>: Move the loop from dst_output into xfrm4_output/xfrm6_output since they're the only ones who need to it. xfrm{4,6}_output_one() processes the first SA all subsequent transport mode SAs and is called in a loop that calls the netfilter hooks between each two calls. In order to avoid the tail call issue, I've added the inline function nf_hook which is nf_hook_slow plus the empty list check. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[IPSEC]: Add XFRM_STATE_NOPMTUDISC flagHerbert Xu
This patch adds the flag XFRM_STATE_NOPMTUDISC for xfrm states. It is similar to the nopmtudisc on IPIP/GRE tunnels. It only has an effect on IPv4 tunnel mode states. For these states, it will ensure that the DF flag is always cleared. This is primarily useful to work around ICMP blackholes. In future this flag could also allow a larger MTU to be set within the tunnel just like IPIP/GRE tunnels. This could be useful for short haul tunnels where temporary fragmentation outside the tunnel is desired over smaller fragments inside the tunnel. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
