[ Upstream commit 9fa5fdf291c9b58b1cb8b4bb2a0ee57efa21d635 ]
tcp_splice_data_recv has two lengths to consider: the len parameter it
gets from tcp_read_sock, which specifies the amount of data in the skb,
and rd_desc->count, which is the amount of data the splice caller still
wants. Currently it passes just the latter to skb_splice_bits, which then
splices min(rd_desc->count, skb->len - offset) bytes.
Most of the time this is fine, except when the skb contains urgent data.
In that case len goes only up to the urgent byte and is less than
skb->len - offset. By ignoring len tcp_splice_data_recv may a) splice
data tcp_read_sock told it not to, b) return to tcp_read_sock a value > len.
Now, tcp_read_sock doesn't handle used > len and leaves the socket in a
bad state (both sk_receive_queue and copied_seq are bad at that point)
resulting in duplicated data and corruption.
Fix by passing min(rd_desc->count, len) to skb_splice_bits.
Signed-off-by: Dimitris Michailidis <dm@chelsio.com>
Acked-by: Eric Dumazet <dada1@cosmosbay.com>
[ Upstream commit 33966dd0e2f68f26943cd9ee93ec6abbc6547a8e ]
As spotted by Willy Tarreau, current splice() from tcp socket to pipe is not
optimal. It processes at most one segment per call.
This results in low performance and very high overhead due to syscall rate
when splicing from interfaces which do not support LRO.
Willy provided a patch inside tcp_splice_read(), but a better fix
is to let tcp_read_sock() process as many segments as possible, so
that tcp_rcv_space_adjust() and tcp_cleanup_rbuf() are called less
often.
With this change, splice() behaves like tcp_recvmsg(), being able
to consume many skbs in one system call. With typical 1460 bytes
of payload per frame, that means splice(SPLICE_F_NONBLOCK) can return
16*1460 = 23360 bytes.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
[ Upstream commit e408b8dcb5ce42243a902205005208e590f28454 ]
Commit 93821778def10ec1e69aa3ac10adee975dad4ff3 (udp: Fix rcv socket
locking) accidentally removed sk_drops increments for UDP IPV4
sockets.
This field can be used to detect incorrect sizing of socket receive
buffers.
[ Upstream commit 7b5e56f9d635643ad54f2f42e69ad16b80a2cff1 ]
The UDP header pointer assignment must happen after calling
pskb_may_pull(). As pskb_may_pull() can potentially alter the SKB
buffer.
This was exposted by running multicast traffic through the NIU driver,
as it won't prepull the protocol headers into the linear area on
receive.
Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk>
[ Upstream commit 9d8dba6c979fa99c96938c869611b9a23b73efa9 ]
Signed-off-by: Benjamin Zores <benjamin.zores@alcatel-lucent.fr>
Upstream commit 71320af:
An old bug crept back into the ICMP/ICMPv6 conntrack protocols: the timeout
values are defined as unsigned longs, the sysctl's maxsize is set to
sizeof(unsigned int). Use unsigned int for the timeout values as in the
other conntrack protocols.
Reported-by: Jean-Mickael Guerin <jean-mickael.guerin@6wind.com>
[ Upstream commit: 4f7d54f59bc470f0aaa932f747a95232d7ebf8b1 ]
Currently, setting SPLICE_F_NONBLOCK on splice from a TCP socket
results in masking of EOF (RDHUP) and error conditions on the socket
by an -EAGAIN return. Move the NONBLOCK check in tcp_splice_read()
to be after the EOF and error checks to fix this.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
The commit e099a173573ce1ba171092aee7bb3c72ea686e59
(netfilter: netns nat: per-netns NAT table) renamed the
nat_table from __nat_table to nat_table without updating the
__RW_LOCK_UNLOCKED(__nat_table.lock).
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
This patch addresses a book-keeping issue in tcp_vegas.c. At present
tcp_vegas does separate book-keeping of cwnd based on packet sequence
numbers. A mismatch can develop between this book-keeping and
tp->snd_cwnd due, for example, to delayed acks acking multiple
packets. When vegas transitions to reno operation (e.g. following
loss), then this mismatch leads to incorrect behaviour (akin to a cwnd
backoff). This seems mostly to affect operation at low cwnds where
delayed acking can lead to a significant fraction of cwnd being
covered by a single ack, leading to the book-keeping mismatch. This
patch modifies the congestion avoidance update to avoid the need for
separate book-keeping while leaving vegas congestion avoidance
functionally unchanged. A secondary advantage of this modification is
that the use of fixed-point (via V_PARAM_SHIFT) and 64 bit arithmetic
is no longer necessary, simplifying the code.
Some example test measurements with the patched code (confirming no functional
change in the congestion avoidance algorithm) can be seen at:
http://www.hamilton.ie/doug/vegaspatch/
Signed-off-by: Doug Leith <doug.leith@nuim.ie>
This patch fixes a bug in tcp_vegas.c. At the moment this code leaves
ssthresh untouched. However, this means that the vegas congestion
control algorithm is effectively unable to reduce cwnd below the
ssthresh value (if the vegas update lowers the cwnd below ssthresh,
then slow start is activated to raise it back up). One example where
this matters is when during slow start cwnd overshoots the link
capacity and a flow then exits slow start with ssthresh set to a value
above where congestion avoidance would like to adjust it.
I should have noticed this earlier... :-) The previous solution
to URG+GSO/TSO will cause SACK block tcp_fragment to do zig-zig
patterns, or even worse, a steep downward slope into packet
counting because each skb pcount would be truncated to pcount
of 2 and then the following fragments of the later portion would
restore the window again.
Basically this reverts "tcp: Do not use TSO/GSO when there is
urgent data" (33cf71cee1). It also removes some unnecessary code
from tcp_current_mss that didn't work as intented either (could
be that something was changed down the road, or it might have
been broken since the dawn of time) because it only works once
urg is already written while this bug shows up starting from
~64k before the urg point.
The retransmissions already are split to mss sized chunks, so
only new data sending paths need splitting in case they have
a segment otherwise suitable for gso/tso. The actually check
can be improved to be more narrow but since this is late -rc
already, I'll postpone thinking the more fine-grained things.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
This patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=12014
Since most (if not all) implementations of TSO and even the in-kernel
software GSO do not update the urgent pointer when splitting a large
segment, it is necessary to turn off TSO/GSO for all outgoing traffic
with the URG pointer set.
Looking at tcp_current_mss (and the preceding comment) I even think
this was the original intention. However, this approach is insufficient,
because TSO/GSO is turned off only for newly created frames, not for
frames which were already pending at the arrival of a message with
MSG_OOB set. These frames were created when TSO/GSO was enabled,
so they may be large, and they will have the urgent pointer set
in tcp_transmit_skb().
With this patch, such large packets will be fragmented again before
going to the transmit routine.
As a side note, at least the following NICs are known to screw up
the urgent pointer in the TCP header when doing TSO:
Intel 82566MM (PCI ID 8086:1049)
Intel 82566DC (PCI ID 8086:104b)
Intel 82541GI (PCI ID 8086:1076)
Broadcom NetXtreme II BCM5708 (PCI ID 14e4:164c)
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
inet_sk_rebuild_header() does a new route lookup if the dst_entry
associated with a socket becomes stale. However inet_sk_rebuild_header()
didn't use struct flowi->flags, causing the route lookup to
fail for foreign-bound IP_TRANSPARENT sockets, causing an error
state to be set for the sockets in question.
Signed-off-by: Balazs Scheidler <bazsi@balabit.hu>
udp_sendmsg() didn't fill struct flowi->flags, which means that
the route lookup would fail for non-local IPs even if the
IP_TRANSPARENT sockopt was set.
This prevents sendto() to work properly for UDP sockets, whereas
bind(foreign-ip) + connect() + send() worked fine.
Similarly to IPv6 ip6_mr_init() (fixed last week), the order of cleanup
operations in the error/exit section of ip_mr_init() is completely
inversed. It should be the other way around.
Also a del_timer() is missing in the error path.
I should have guessed last week that this same error existed in ipmr.c
too, as ip6mr.c is largely inspired by ipmr.c.
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
Failure to pass netns_ok check is SILENT, except some MIB counter is
incremented somewhere.
And adding "netns_ok = 1" (after long head-scratching session) is
usually the last step in making some protocol netns-ready...
This patch fixes a minor bug in tcp_htcp.c which has been
highlighted by Lachlan Andrew and Lawrence Stewart. Currently, the
time since the last congestion event, which is stored in variable
last_cong, is reset whenever there is a state change into
TCP_CA_Open. This includes transitions of the type
TCP_CA_Open->TCP_CA_Disorder->TCP_CA_Open which are not associated
with backoff of cwnd. The patch changes last_cong to be updated
only on transitions into TCP_CA_Open that occur after experiencing
the congestion-related states TCP_CA_Loss, TCP_CA_Recovery,
TCP_CA_CWR.
icmpmsg_put() can happily corrupt kernel memory, using a static
table and forgetting to reset an array index in a loop.
Remove the static array since its not safe without proper locking.
Vito Caputo noticed that tcp_recvmsg() returns immediately from
partial reads when MSG_PEEK is used. In particular, this means that
SO_RCVLOWAT is not respected.
Simply remove the test. And this matches the behavior of several
other systems, including BSD.
selector
While adding MIGRATE support to strongSwan, Andreas Steffen noticed that
the selectors provided in XFRM_MSG_ACQUIRE have their family field
uninitialized (those in MIGRATE do have their family set).
Looking at the code, this is because the af-specific init_tempsel()
(called via afinfo->init_tempsel() in xfrm_init_tempsel()) do not set
the value.
Reported-by: Andreas Steffen <andreas.steffen@strongswan.org>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Current UDP multicast delivery is not namespace aware.
Acked-by: Pavel Emelyanov <xemul@openvz.org>
unsigned buf_len cannot be negative
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Paul Moore <paul.moore@hp.com>
David Miller noticed that commit
33ad798c924b4a1afad3593f2796d465040aadd5 '(tcp: options clean up')
did not move the req->cookie_ts check.
This essentially disabled commit 4dfc2817025965a2fc78a18c50f540736a6b5c24
'[Syncookies]: Add support for TCP options via timestamps.'.
This restores the original logic.
This is not our bug! Sadly some devices cannot cope with the change
of TCP option ordering which was a result of the recent rewrite of
the option code (not that there was some particular reason steming
from the rewrite for the reordering) though any ordering of TCP
options is perfectly legal. Thus we restore the original ordering
to allow interoperability with/through such broken devices and add
some warning about this trap. Since the reordering just happened
without any particular reason, this change shouldn't cost us
anything.
There are already couple of known failure reports (within close
proximity of the last release), so the problem might be more
wide-spread than a single device. And other reports which may
be due to the same problem though the symptoms were less obvious.
Analysis of one of the case revealed (with very high probability)
that sack capability cannot be negotiated as the first option
(SYN never got a response).
Reported-by: Aldo Maggi <sentiniate@tiscali.it>
Tested-by: Aldo Maggi <sentiniate@tiscali.it>
While looking for the recent "sack issue" I also read all eff_sacks
usage that was played around by some relevant commit. I found
out that there's another thing that is asking for a fix (unrelated
to the "sack issue" though).
This feature has probably very little significance in practice.
Opposite direction timeout with bidirectional tcp comes to me as
the most likely scenario though there might be other cases as
well related to non-data segments we send (e.g., response to the
opposite direction segment). Also some ACK losses or option space
wasted for other purposes is necessary to prevent the earlier
SACK feedback getting to the sender.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
netfilter: replace old NF_ARP calls with NFPROTO_ARP
netfilter: fix compilation error with NAT=n
netfilter: xt_recent: use proc_create_data()
netfilter: snmp nat leaks memory in case of failure
netfilter: xt_iprange: fix range inversion match
netfilter: netns: use NFPROTO_NUMPROTO instead of NUMPROTO for tables array
netfilter: ctnetlink: remove obsolete NAT dependency from Kconfig
pkt_sched: sch_generic: Fix oops in sch_teql
dccp: Port redirection support for DCCP
tcp: Fix IPv6 fallout from 'Port redirection support for TCP'
netdev: change name dropping error codes
ipvs: Update CONFIG_IP_VS_IPV6 description and help text
(Supplements: ee999d8b9573df1b547aacdc6d79f86eb79c25cd)
NFPROTO_ARP actually has a different value from NF_ARP, so ensure all
callers use the new value so that packets _do_ get delivered to the
registered hooks.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)
ipv4: Add a missing rcu_assign_pointer() in routing cache.
[netdrvr] ibmtr: PCMCIA IBMTR is ok on 64bit
xen-netfront: Avoid unaligned accesses to IP header
lmc: copy_*_user under spinlock
[netdrvr] myri10ge, ixgbe: remove broken select INTEL_IOATDMA
Some code here depends on CONFIG_KMOD to not try to load
protocol modules or similar, replace by CONFIG_MODULES
where more than just request_module depends on CONFIG_KMOD
and and also use try_then_request_module in ebtables.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
rt_intern_hash() is doing an update of a RCU guarded hash chain
without using rcu_assign_pointer() or equivalent barrier.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits)
decnet: Fix compiler warning in dn_dev.c
IPV6: Fix default gateway criteria wrt. HIGH/LOW preference radv option
net/802/fc.c: Fix compilation warnings
netns: correct mib stats in ip6_route_me_harder()
netns: fix net_generic array leak
rt2x00: fix regression introduced by "mac80211: free up 2 bytes in skb->cb"
rtl8187: Add USB ID for Belkin F5D7050 with RTL8187B chip
p54usb: Device ID updates
mac80211: fixme for kernel-doc
ath9k/mac80211: disallow fragmentation in ath9k, report to userspace
libertas : Remove unused variable warning for "old_channel" from cmd.c
mac80211: Fix scan RX processing oops
orinoco: fix unsafe locking in spectrum_cs_suspend
orinoco: fix unsafe locking in orinoco_cs_resume
cfg80211: fix debugfs error handling
mac80211: fix debugfs netdev rename
iwlwifi: fix ct kill configuration for 5350
mac80211: fix HT information element parsing
p54: Fix compilation problem on PPC
mac80211: fix debugfs lockup
name and nlen parameters passed to ->strategy hook are unused, remove
them. In general ->strategy hook should know what it's doing, and don't
do something tricky for which, say, pointer to original userspace array
may be needed (name).
Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ]
Cc: Matt Mackall <mpm@selenic.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
nf_nat
This patch removes the module dependency between ctnetlink and
nf_nat by means of an indirect call that is initialized when
nf_nat is loaded. Now, nf_conntrack_netlink only requires
nf_conntrack and nfnetlink.
This patch puts nfnetlink_parse_nat_setup_hook into the
nf_conntrack_core to avoid dependencies between ctnetlink,
nf_conntrack_ipv4 and nf_conntrack_ipv6.
This patch also introduces the function ctnetlink_change_nat
that is only invoked from the creation path. Actually, the
nat handling cannot be invoked from the update path since
this is not allowed. By introducing this function, we remove
the useless nat handling in the update path and we avoid
deadlock-prone code.
This patch also adds the required EAGAIN logic for nfnetlink.
Nir Tzachar <nir.tzachar@gmail.com> reported a warning when sending
fragments over loopback with NAT:
[ 6658.338121] WARNING: at net/ipv4/netfilter/nf_nat_standalone.c:89 nf_nat_fn+0x33/0x155()
The reason is that defragmentation is skipped for already tracked connections.
This is wrong in combination with NAT and ip_conntrack actually had some ifdefs
to avoid this behaviour when NAT is compiled in.
The entire "optimization" may seem a bit silly, for now simply restoring the
lost #ifdef is the easiest solution until we can come up with something better.
qlge: Fix page size ifdef test.
net: Rationalise email address: Network Specific Parts
dsa: fix compile bug on s390
netns: mib6 section fixlet
enic: Fix Kconfig headline description
de2104x: wrong MAC address fix
s390: claw compile fixlet
net: export genphy_restart_aneg
cxgb3: extend copyrights to 2008
cxgb3: update driver version
net/phy: add missing kernel-doc
pktgen: fix skb leak in case of failure
mISDN/dsp_cmx.c: fix size checks
misdn: use nonseekable_open()
net: fix driver build errors due to missing net/ip6_checksum.h include
Clean up the various different email addresses of mine listed in the code
to a single current and valid address. As Dave says his network merges
for 2.6.28 are now done this seems a good point to send them in where
they won't risk disrupting real changes.
Signed-off-by: Alan Cox <alan@redhat.com>
Brown paper bag error of calling memset with sizeof(p) instead
of sizeof(*p).
- use typeful helpers for IFLA_GRE_LOCAL/IFLA_GRE_REMOTE
- replace magic value by FIELD_SIZEOF
- use MODULE_ALIAS_RTNL_LINK macro
The flags are dumped twice, the keys not at all.
This patch accomplishes three minor tasks: add a new tag type for local
labeling, rename the CIPSO_V4_MAP_STD define to CIPSO_V4_MAP_TRANS and
replace some of the CIPSO "magic numbers" with constants from the header
file. The first change allows CIPSO to support full LSM labels/contexts,
not just MLS attributes. The second change brings the mapping names inline
with what userspace is using, compatibility is preserved since we don't
actually change the value. The last change is to aid readability and help
prevent mistakes.
Previous work enabled the use of address based NetLabel selectors, which while
highly useful, brought the potential for additional per-packet overhead when
used. This patch attempts to solve that by applying NetLabel socket labels
when sockets are connect()'d. This should alleviate the per-packet NetLabel
labeling for all connected sockets (yes, it even works for connected DGRAM
sockets).
Reviewed-by: James Morris <jmorris@namei.org>
This patch builds upon the new NetLabel address selector functionality by
providing the NetLabel KAPI and CIPSO engine support needed to enable the
new packet-based labeling. The only new addition to the NetLabel KAPI at
this point is shown below:
* int netlbl_skbuff_setattr(skb, family, secattr)
... and is designed to be called from a Netfilter hook after the packet's
IP header has been populated such as in the FORWARD or LOCAL_OUT hooks.
This patch also provides the necessary SELinux hooks to support this new
functionality. Smack support is not currently included due to uncertainty
regarding the permissions needed to expand the Smack network access controls.
NetLabel has always had a list of backpointers in the CIPSO DOI definition
structure which pointed to the NetLabel LSM domain mapping structures which
referenced the CIPSO DOI struct. The rationale for this was that when an
administrator removed a CIPSO DOI from the system all of the associated
NetLabel LSM domain mappings should be removed as well; a list of
backpointers made this a simple operation.
Unfortunately, while the backpointers did make the removal easier they were
a bit of a mess from an implementation point of view which was making
further development difficult. Since the removal of a CIPSO DOI is a
realtively rare event it seems to make sense to remove this backpointer
list as the optimization was hurting us more then it was helping. However,
we still need to be able to track when a CIPSO DOI definition is being used
so replace the backpointer list with a reference count. In order to
preserve the current functionality of removing the associated LSM domain
mappings when a CIPSO DOI is removed we walk the LSM domain mapping table,
removing the relevant entries.
While looking at UDP port randomization, I noticed it
was litle bit pessimistic, not looking at type of sockets
(IPV6/IPV4) and not looking at bound addresses if any.
We should perform same tests than when binding to a
specific port.
This permits a cleanup of udp_lib_get_port()
Maybe it's just me but I guess those md5 people made a mess
out of it by having *_md5_hash_* to use daddr, saddr order
instead of the one that is natural (and equal to what csum
functions use). For the segment were sending, the original
addresses are reversed so buff's saddr == skb's daddr and
vice-versa.
Maybe I can finally proceed with unification of some code
after fixing it first... :-)
This patch makes the RX/TX byte counters for IPIP, GRE and SIT more
consistent. Previously we included the external IP headers on the
way out but not when the packet is inbound.
The new scheme is to count payload only in both directions. For
IPIP and SIT this simply means the exclusion of the external IP
header. For GRE this means that we exclude the GRE header as
well.
This patch adds support for Ethernet over GRE encapsulation.
This is exposed to user-space with a new link type of "gretap"
instead of "gre". It will create an ARPHRD_ETHER device in
lieu of the usual ARPHRD_IPGRE.
Note that to preserver backwards compatibility all Transparent
Ethernet Bridging packets are passed to an ARPHRD_IPGRE tunnel
if its key matches and there is no ARPHRD_ETHER device whose
key matches more closely.
This patch adds a netlink interface that will eventually displace
the existing ioctl interface. It utilises the elegant rtnl_link_ops
mechanism.
This also means that user-space no longer needs to rely on the
tunnel interface being of type GRE to identify GRE tunnels. The
identification can now occur using rtnl_link_ops.
