[ Upstream commit e337e24d6624e74a558aa69071e112a65f7b5758 ]
If in either of the above functions inet_csk_route_child_sock() or
__inet_inherit_port() fails, the newsk will not be freed:
unreferenced object 0xffff88022e8a92c0 (size 1592):
comm "softirq", pid 0, jiffies 4294946244 (age 726.160s)
hex dump (first 32 bytes):
0a 01 01 01 0a 01 01 02 00 00 00 00 a7 cc 16 00 ................
02 00 03 01 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff8153d190>] kmemleak_alloc+0x21/0x3e
[<ffffffff810ab3e7>] kmem_cache_alloc+0xb5/0xc5
[<ffffffff8149b65b>] sk_prot_alloc.isra.53+0x2b/0xcd
[<ffffffff8149b784>] sk_clone_lock+0x16/0x21e
[<ffffffff814d711a>] inet_csk_clone_lock+0x10/0x7b
[<ffffffff814ebbc3>] tcp_create_openreq_child+0x21/0x481
[<ffffffff814e8fa5>] tcp_v4_syn_recv_sock+0x3a/0x23b
[<ffffffff814ec5ba>] tcp_check_req+0x29f/0x416
[<ffffffff814e8e10>] tcp_v4_do_rcv+0x161/0x2bc
[<ffffffff814eb917>] tcp_v4_rcv+0x6c9/0x701
[<ffffffff814cea9f>] ip_local_deliver_finish+0x70/0xc4
[<ffffffff814cec20>] ip_local_deliver+0x4e/0x7f
[<ffffffff814ce9f8>] ip_rcv_finish+0x1fc/0x233
[<ffffffff814cee68>] ip_rcv+0x217/0x267
[<ffffffff814a7bbe>] __netif_receive_skb+0x49e/0x553
[<ffffffff814a7cc3>] netif_receive_skb+0x50/0x82
This happens, because sk_clone_lock initializes sk_refcnt to 2, and thus
a single sock_put() is not enough to free the memory. Additionally, things
like xfrm, memcg, cookie_values,... may have been initialized.
We have to free them properly.
This is fixed by forcing a call to tcp_done(), ending up in
inet_csk_destroy_sock, doing the final sock_put(). tcp_done() is necessary,
because it ends up doing all the cleanup on xfrm, memcg, cookie_values,
xfrm,...
Before calling tcp_done, we have to set the socket to SOCK_DEAD, to
force it entering inet_csk_destroy_sock. To avoid the warning in
inet_csk_destroy_sock, inet_num has to be set to 0.
As inet_csk_destroy_sock does a dec on orphan_count, we first have to
increase it.
Calling tcp_done() allows us to remove the calls to
tcp_clear_xmit_timer() and tcp_cleanup_congestion_control().
A similar approach is taken for dccp by calling dccp_done().
This is in the kernel since 093d282321 (tproxy: fix hash locking issue
when using port redirection in __inet_inherit_port()), thus since
version >= 2.6.37.
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
ip_check_defrag() might be called from af_packet within the
RX path where shared SKBs are used, so it must not modify
the input SKB before it has unshared it for defragmentation.
Use skb_copy_bits() to get the IP header and only pull in
everything later.
The same is true for the other caller in macvlan as it is
called from dev->rx_handler which can also get a shared SKB.
Reported-by: Eric Leblond <eric@regit.org>
Cc: stable@vger.kernel.org
Add logic to verify that a port comparison byte code operation
actually has the second inet_diag_bc_op from which we read the port
for such operations.
Previously the code blindly referenced op[1] without first checking
whether a second inet_diag_bc_op struct could fit there. So a
malicious user could make the kernel read 4 bytes beyond the end of
the bytecode array by claiming to have a whole port comparison byte
code (2 inet_diag_bc_op structs) when in fact the bytecode was not
long enough to hold both.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Add logic to check the address family of the user-supplied conditional
and the address family of the connection entry. We now do not do
prefix matching of addresses from different address families (AF_INET
vs AF_INET6), except for the previously existing support for having an
IPv4 prefix match an IPv4-mapped IPv6 address (which this commit
maintains as-is).
This change is needed for two reasons:
(1) The addresses are different lengths, so comparing a 128-bit IPv6
prefix match condition to a 32-bit IPv4 connection address can cause
us to unwittingly walk off the end of the IPv4 address and read
garbage or oops.
(2) The IPv4 and IPv6 address spaces are semantically distinct, so a
simple bit-wise comparison of the prefixes is not meaningful, and
would lead to bogus results (except for the IPv4-mapped IPv6 case,
which this commit maintains).
Add logic to validate INET_DIAG_BC_S_COND and INET_DIAG_BC_D_COND
operations.
Previously we did not validate the inet_diag_hostcond, address family,
address length, and prefix length. So a malicious user could make the
kernel read beyond the end of the bytecode array by claiming to have a
whole inet_diag_hostcond when the bytecode was not long enough to
contain a whole inet_diag_hostcond of the given address family. Or
they could make the kernel read up to about 27 bytes beyond the end of
a connection address by passing a prefix length that exceeded the
length of addresses of the given family.
Fix inet_diag to be aware of the fact that AF_INET6 TCP connections
instantiated for IPv4 traffic and in the SYN-RECV state were actually
created with inet_reqsk_alloc(), instead of inet6_reqsk_alloc(). This
means that for such connections inet6_rsk(req) returns a pointer to a
random spot in memory up to roughly 64KB beyond the end of the
request_sock.
With this bug, for a server using AF_INET6 TCP sockets and serving
IPv4 traffic, an inet_diag user like `ss state SYN-RECV` would lead to
inet_diag_fill_req() causing an oops or the export to user space of 16
bytes of kernel memory as a garbage IPv6 address, depending on where
the garbage inet6_rsk(req) pointed.
If SYN-ACK partially acks SYN-data, the client retransmits the
remaining data by tcp_retransmit_skb(). This increments lost recovery
state variables like tp->retrans_out in Open state. If loss recovery
happens before the retransmission is acked, it triggers the WARN_ON
check in tcp_fastretrans_alert(). For example: the client sends
SYN-data, gets SYN-ACK acking only ISN, retransmits data, sends
another 4 data packets and get 3 dupacks.
Since the retransmission is not caused by network drop it should not
update the recovery state variables. Further the server may return a
smaller MSS than the cached MSS used for SYN-data, so the retranmission
needs a loop. Otherwise some data will not be retransmitted until timeout
or other loss recovery events.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Recent network changes allowed high order pages being used
for skb fragments.
This uncovered a bug in do_tcp_sendpages() which was assuming its caller
provided an array of order-0 page pointers.
We only have to deal with a single page in this function, and its order
is irrelevant.
Reported-by: Willy Tarreau <w@1wt.eu>
Tested-by: Willy Tarreau <w@1wt.eu>
Name of pimreg devices are built from following format :
char name[IFNAMSIZ]; // IFNAMSIZ == 16
sprintf(name, "pimreg%u", mrt->id);
We must therefore limit mrt->id to 9 decimal digits
or risk a buffer overflow and a crash.
Restrict table identifiers in [0 ... 999999999] interval.
Reported-by: Chen Gang <gang.chen@asianux.com>
inet_getpeer_v4() can return NULL under OOM conditions, and while
inet_peer_xrlim_allow() is OK with a NULL peer, inet_putpeer() will
crash.
This code path now uses the same idiom as the others from:
1d861aa4b3fb08822055345f480850205ffe6170 ("inet: Minimize use of
cached route inetpeer.").
Starting from 3.6 we cache output routes for
multicasts only when using route to 224/4. For local receivers
we can set RTCF_LOCAL flag depending on the membership but
in such case we use maddr and saddr which are not caching
keys as before. Additionally, we can not use same place to
cache routes that differ in RTCF_LOCAL flag value.
Fix it by caching only RTCF_MULTICAST entries
without RTCF_LOCAL (send-only, no loopback). As a side effect,
we avoid unneeded lookup for fnhe when not caching because
multicasts are not redirected and they do not learn PMTU.
Thanks to Maxime Bizon for showing the caching
problems in __mkroute_output for 3.6 kernels: different
RTCF_LOCAL flag in cache can lead to wrong ip_mc_output or
ip_output call and the visible problem is that traffic can
not reach local receivers via loopback.
Reported-by: Maxime Bizon <mbizon@freebox.fr>
Tested-by: Maxime Bizon <mbizon@freebox.fr>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec
Steffen Klassert says:
This pull request is intended for 3.7 and contains a single patch to
fix the IPsec gc threshold value for ipv4.
order-5 allocations can fail with current kernels, we should
try vmalloc() as well.
Reported-by: Julien Tinnes <jln@google.com>
Currently if a socket was repaired with a few packet in a write queue,
a kernel bug may be triggered:
kernel BUG at net/ipv4/tcp_output.c:2330!
RIP: 0010:[<ffffffff8155784f>] tcp_retransmit_skb+0x5ff/0x610
According to the initial realization v3.4-rc2-963-gc0e88ff,
all skb-s should look like already posted. This patch fixes code
according with this sentence.
Here are three points, which were not done in the initial patch:
1. A tcp send head should not be changed
2. Initialize TSO state of a skb
3. Reset the retransmission time
This patch moves logic from tcp_sendmsg to tcp_write_xmit. A packet
passes the ussual way, but isn't sent to network. This patch solves
all described problems and handles tcp_sendpages.
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
With the latest kernel there are two things that must be done post decryption
so that the packet are forwarded.
1. Remove the mark from the packet. This will cause the packet to not match
the ipsec-policy again. However doing this causes the post-decryption check to
fail also and the packet will get dropped. (cat /proc/net/xfrm_stat).
2. Remove the sp association in the skbuff so that no policy check is done on
the packet for VTI tunnels.
Due to #2 above we must now do a security-policy check in the vti rcv path
prior to resetting the mark in the skbuff.
Signed-off-by: Saurabh Mohan <saurabh.mohan@vyatta.com>
Reported-by: Ruben Herold <ruben@puettmann.net>
We added support for RFC 5961 in latest kernels but TCP fails
to perform exhaustive check of ACK sequence.
We can update our view of peer tsval from a frame that is
later discarded by tcp_ack()
This makes timestamps enabled sessions vulnerable to injection of
a high tsval : peers start an ACK storm, since the victim
sends a dupack each time it receives an ACK from the other peer.
As tcp_validate_incoming() is called before tcp_ack(), we should
not peform tcp_replace_ts_recent() from it, and let callers do it
at the right time.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: Romain Francoise <romain@orebokech.com>
The xfrm gc threshold value depends on ip_rt_max_size. This
value was set to INT_MAX with the routing cache removal patch,
so we start doing garbage collecting when we have INT_MAX/2
IPsec routes cached. Fix this by going back to the static
threshold of 1024 routes.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
(1<<optname) is undefined behavior in C with a negative optname or
optname larger than 31. In those cases the result of the shift is
not necessarily zero (e.g., on x86).
This patch simplifies the code with a switch statement on optname.
It also allows the compiler to generate better code (e.g., using a
64-bit mask).
Signed-off-by: Xi Wang <xi.wang@gmail.com>
We've observed that in case if UDP diag module is not
supported in kernel the netlink returns NLMSG_DONE without
notifying a caller that handler is missed.
This patch makes __inet_diag_dump to return error code instead.
So as example it become possible to detect such situation
and handle it gracefully on userspace level.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
CC: David Miller <davem@davemloft.net>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Pavel Emelyanov <xemul@parallels.com>
When sending data into a tcp socket in repair state we should check
for the amount of data being 0 explicitly. Otherwise we'll have an skb
with seq == end_seq in rcv queue, but tcp doesn't expect this to happen
(in particular a warn_on in tcp_recvmsg shoots).
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Reported-by: Giorgos Mavrikas <gmavrikas@gmail.com>
Fix double sizeof when parsing IPv6 address from
user space because it breaks get/del by specific IPv6 address.
Problem noticed by David Binderman:
https://bugzilla.kernel.org/show_bug.cgi?id=49171
Reading TCP stats when using TCP Illinois congestion control algorithm
can cause a divide by zero kernel oops.
The division by zero occur in tcp_illinois_info() at:
do_div(t, ca->cnt_rtt);
where ca->cnt_rtt can become zero (when rtt_reset is called)
Steps to Reproduce:
1. Register tcp_illinois:
# sysctl -w net.ipv4.tcp_congestion_control=illinois
2. Monitor internal TCP information via command "ss -i"
# watch -d ss -i
3. Establish new TCP conn to machine
Either it fails at the initial conn, or else it needs to wait
for a loss or a reset.
This is only related to reading stats. The function avg_delay() also
performs the same divide, but is guarded with a (ca->cnt_rtt > 0) at its
calling point in update_params(). Thus, simply fix tcp_illinois_info().
Function tcp_illinois_info() / get_info() is called without
socket lock. Thus, eliminate any race condition on ca->cnt_rtt
by using a local stack variable. Simply reuse info.tcpv_rttcnt,
as its already set to ca->cnt_rtt.
Function avg_delay() is not affected by this race condition, as
its called with the socket lock.
Cc: Petr Matousek <pmatouse@redhat.com>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Pablo Neira Ayuso says:
The following patchset contains fixes for your net tree, two of them
are due to relatively recent changes, one has been a longstanding bug,
they are:
* Fix incorrect usage of rt_gateway in the H.323 helper, from
Julian Anastasov.
* Skip re-route in nf_nat code for ICMP traffic. If CONFIG_XFRM is
enabled, we waste cycles to look up for the route again. This problem
seems to be there since really long time. From Ulrich Weber.
* Fix mismatching section in nf_conntrack_reasm, from Hein Tibosch.
ICMP tuples have id in src and type/code in dst.
So comparing src.u.all with dst.u.all will always fail here
and ip_xfrm_me_harder() is called for every ICMP packet,
even if there was no NAT.
Signed-off-by: Ulrich Weber <ulrich.weber@sophos.com>
A packet with an invalid ack_seq may cause a TCP Fast Open socket to switch
to the unexpected TCP_CLOSING state, triggering a BUG_ON kernel panic.
When a FIN packet with an invalid ack_seq# arrives at a socket in
the TCP_FIN_WAIT1 state, rather than discarding the packet, the current
code will accept the FIN, causing state transition to TCP_CLOSING.
This may be a small deviation from RFC793, which seems to say that the
packet should be dropped. Unfortunately I did not expect this case for
Fast Open hence it will trigger a BUG_ON panic.
It turns out there is really nothing bad about a TFO socket going into
TCP_CLOSING state so I could just remove the BUG_ON statements. But after
some thought I think it's better to treat this case like TCP_SYN_RECV
and return a RST to the confused peer who caused the unacceptable ack_seq
to be generated in the first place.
Signed-off-by: H.K. Jerry Chu <hkchu@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Add a bit TCPI_OPT_SYN_DATA (32) to the socket option TCP_INFO:tcpi_options.
It's set if the data in SYN (sent or received) is acked by SYN-ACK. Server or
client application can use this information to check Fast Open success rate.
tcp_ioctl() tries to take into account if tcp socket received a FIN
to report correct number bytes in receive queue.
But its flaky because if the application ate the last skb,
we return 1 instead of 0.
Correct way to detect that FIN was received is to test SOCK_DONE.
Reported-by: Elliot Hughes <enh@google.com>
Cc: Tom Herbert <therbert@google.com>
Currently we can not flush cached pmtu/redirect informations via
the ipv4_sysctl_rtcache_flush sysctl. We need to check the rt_genid
of the old route and reset the nh exeption if the old route is
expired when we bind a new route to a nh exeption.
Use be32_to_cpu instead of htonl to keep sparse happy.
Signed-off-by: Stephen Hemminger <shemminger@vyatta.org>
After commit e2446eaa ("tcp_v4_send_reset: binding oif to iif in no
sock case").. tcp resets are always lost, when routing is asymmetric.
Yes, backing out that patch will result in misrouting of resets for
dead connections which used interface binding when were alive, but we
actually cannot do anything here. What's died that's died and correct
handling normal unbound connections is obviously a priority.
Comment to comment:
> This has few benefits:
> 1. tcp_v6_send_reset already did that.
It was done to route resets for IPv6 link local addresses. It was a
mistake to do so for global addresses. The patch fixes this as well.
Actually, the problem appears to be even more serious than guaranteed
loss of resets. As reported by Sergey Soloviev <sol@eqv.ru>, those
misrouted resets create a lot of arp traffic and huge amount of
unresolved arp entires putting down to knees NAT firewalls which use
asymmetric routing.
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
If the rc_dereference of tcp_fastopen_ctx ever fails then we copy 16 bytes
of kernel stack into the proc result.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Sparse complains about RTA_MARK which is should be host order according
to include file and usage in iproute.
net/ipv4/route.c:2223:46: warning: incorrect type in argument 3 (different base types)
net/ipv4/route.c:2223:46: expected restricted __be32 [usertype] value
net/ipv4/route.c:2223:46: got unsigned int [unsigned] [usertype] flowic_mark
Add flag to request that output route should be
returned with known rt_gateway, in case we want to use
it as nexthop for neighbour resolving.
The returned route can be cached as follows:
- in NH exception: because the cached routes are not shared
with other destinations
- in FIB NH: when using gateway because all destinations for
NH share same gateway
As last option, to return rt_gateway!=0 we have to
set DST_NOCACHE.
Add new flag to remember when route is via gateway.
We will use it to allow rt_gateway to contain address of
directly connected host for the cases when DST_NOCACHE is
used or when the NH exception caches per-destination route
without DST_NOCACHE flag, i.e. when routes are not used for
other destinations. By this way we force the neighbour
resolving to work with the routed destination but we
can use different address in the packet, feature needed
for IPVS-DR where original packet for virtual IP is routed
via route to real IP.
Avoid checking nh_pcpu_rth_output in fast path,
abort fib_info creation on alloc_percpu failure.
After the change "Adjust semantics of rt->rt_gateway"
(commit f8126f1d51) rt_gateway can be 0 but ip_forward() compares
it directly with nexthop. What we want here is to check if traffic
is to directly connected nexthop and to fail if using gateway.
After "Cache input routes in fib_info nexthops" (commit
d2d68ba9fe) and "Elide fib_validate_source() completely when possible"
(commit 7a9bc9b81a) we can not send ICMP redirects. It seems we
should not cache the RTCF_DOREDIRECT flag in nh_rth_input because
the same fib_info can be used for traffic that is not redirected,
eg. from other input devices or from sources that are not in same subnet.
As result, we have to disable the caching of RTCF_DOREDIRECT
flag and to force source validation for the case when forwarding
traffic to the input device. If traffic comes from directly connected
source we allow redirection as it was done before both changes.
Avoid setting RTCF_DOREDIRECT if IN_DEV_TX_REDIRECTS
is disabled, this can avoid source address validation and to
help caching the routes.
(commit f8126f1d51) we should make sure our ICMP_REDIR_HOST messages
contain daddr instead of 0.0.0.0 when target is directly connected.
We report cached pmtu values even if they are already expired.
Change this to not report these values after they are expired
and fix a race in the expire time calculation, as suggested by
Eric Dumazet.
reported pmtu
When a local tool like tracepath tries to send packets bigger than
the device mtu, we create a nh exeption and set the pmtu to device
mtu. The device mtu does not expire, so check if the device mtu is
smaller than the reported pmtu and don't crerate a nh exeption in
that case.
Some protocols, like IPsec still cache routes. So we need to invalidate
the old route on pmtu events to avoid the reuse of stale routes.
We also need to update the mtu and expire time of the route if we already
use a nh exception route, otherwise we ignore newly learned pmtu values
after the first expiration.
With this patch we always invalidate or update the route on pmtu events.
Pull networking changes from David Miller:
"The most important bit in here is the fix for input route caching from
Eric Dumazet, it's a shame we couldn't fully analyze this in time for
3.6 as it's a 3.6 regression introduced by the routing cache removal.
Anyways, will send quickly to -stable after you pull this in.
Other changes of note:
1) Fix lockdep splats in team and bonding, from Eric Dumazet.
2) IPV6 adds link local route even when there is no link local
address, from Nicolas Dichtel.
3) Fix ixgbe PTP implementation, from Jacob Keller.
4) Fix excessive stack usage in cxgb4 driver, from Vipul Pandya.
5) MAC length computed improperly in VLAN demux, from Antonio
Quartulli."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (26 commits)
ipv6: release reference of ip6_null_entry's dst entry in __ip6_del_rt
Remove noisy printks from llcp_sock_connect
tipc: prevent dropped connections due to rcvbuf overflow
silence some noisy printks in irda
team: set qdisc_tx_busylock to avoid LOCKDEP splat
bonding: set qdisc_tx_busylock to avoid LOCKDEP splat
sctp: check src addr when processing SACK to update transport state
sctp: fix a typo in prototype of __sctp_rcv_lookup()
ipv4: add a fib_type to fib_info
can: mpc5xxx_can: fix section type conflict
can: peak_pcmcia: fix error return code
can: peak_pci: fix error return code
cxgb4: Fix build error due to missing linux/vmalloc.h include.
bnx2x: fix ring size for 10G functions
cxgb4: Dynamically allocate memory in t4_memory_rw() and get_vpd_params()
ixgbe: add support for X540-AT1
ixgbe: fix poll loop for FDIRCTRL.INIT_DONE bit
ixgbe: fix PTP ethtool timestamping function
ixgbe: (PTP) Fix PPS interrupt code
ixgbe: Fix PTP X540 SDP alignment code for PPS signal
commit d2d68ba9fe8 (ipv4: Cache input routes in fib_info nexthops.)
introduced a regression for forwarding.
This was hard to reproduce but the symptom was that packets were
delivered to local host instead of being forwarded.
David suggested to add fib_type to fib_info so that we dont
inadvertently share same fib_info for different purposes.
With help from Julian Anastasov who provided very helpful
hints, reproduced here :
<quote>
Can it be a problem related to fib_info reuse
from different routes. For example, when local IP address
is created for subnet we have:
broadcast 192.168.0.255 dev DEV proto kernel scope link src
192.168.0.1
192.168.0.0/24 dev DEV proto kernel scope link src 192.168.0.1
local 192.168.0.1 dev DEV proto kernel scope host src 192.168.0.1
The "dev DEV proto kernel scope link src 192.168.0.1" is
a reused fib_info structure where we put cached routes.
The result can be same fib_info for 192.168.0.255 and
192.168.0.0/24. RTN_BROADCAST is cached only for input
routes. Incoming broadcast to 192.168.0.255 can be cached
and can cause problems for traffic forwarded to 192.168.0.0/24.
So, this patch should solve the problem because it
separates the broadcast from unicast traffic.
And the ip_route_input_slow caching will work for
local and broadcast input routes (above routes 1 and 3) just
because they differ in scope and use different fib_info.
</quote>
Many thanks to Chris Clayton for his patience and help.
Reported-by: Chris Clayton <chris2553@googlemail.com>
Bisected-by: Chris Clayton <chris2553@googlemail.com>
Reported-by: Dave Jones <davej@redhat.com>
Cc: Julian Anastasov <ja@ssi.bg>
Tested-by: Chris Clayton <chris2553@googlemail.com>
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
Needed for VXLAN.
Use be16 consistently when looking at flags.
Add GRO capability to IPv4 GRE tunnels, using the gro_cells
infrastructure.
Tested using IPv4 and IPv6 TCP traffic inside this tunnel, and
checking GRO is building large packets.
skb with CHECKSUM_NONE cant currently be handled by GRO, and
we notice this deep in GRO stack in tcp[46]_gro_receive()
But there are cases where GRO can be a benefit, even with a lack
of checksums.
This preliminary work is needed to add GRO support
to tunnels.
