initialization.
Join all-node multicast group after assignment of dev->ip6_ptr
because it must be assigned when ipv6_dev_mc_inc() is called.
This fixes Bug#7817, reported by <gernoth@informatik.uni-erlangen.de>.
Closes: 7817
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
It is important that we only assign dev->ip{,6}_ptr
only after all portions of the inet{,6} are setup.
Otherwise we can receive packets before the multicast
spinlocks et al. are initialized.
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
This patch contains the changes to net/ipv6/addrconf.c to remove sit
specific code if the sit driver is not selected.
Signed-off-by: Joerg Roedel <joro-lkml@zlug.org>
inet_rcv_saddr() returns net-endian
IFA_F_HOMEADDRESS is introduced for Mobile IPv6 Home Addresses on
Mobile Node.
The IFA_F_HOMEADDRESS flag should be set for Mobile IPv6 Home
Addresses for 2 purposes. 1) We need to check this on receipt of
Type 2 Routing Header (RFC3775 Secion 6.4), 2) We prefer Home
Address(es) in source address selection (RFC3484 Section 5 Rule 4).
Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp>
IFA_F_NODAD flag, similar to IN6_IFF_NODAD in BSDs, is introduced
to skip DAD.
This flag should be set to Mobile IPv6 Home Address(es) on Mobile
Node because DAD would fail if we should perform DAD; our Home Agent
protects our Home Address(es).
We do not always need proxy NDP functionality even we
enable forwarding.
iproute2 doesn't provide the NLM_F_CREATE flag when adding addresses,
it is assumed to be implied. The existing code issues a check on
said flag when the modify operation fails (likely due to ENOENT)
before continueing to create it, this leads to a hard to predict
result, therefore the NLM_F_CREATE check is removed.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Same behaviour as IPv4, using IFF_UP is a no-no anyway.
Replaces INET6_IFADDR_RTA_SPACE with a new function calculating
the total required message size for all address messages.
Replaces the struct in6_rtmsg based interface orignating from
the ioctl interface with a struct fib6_config based on. Allows
changing the interface without breaking the ioctl interface
and avoids passing on tons of parameters.
The recently introduced struct nl_info is used to pass on
netlink authorship information for notifications.
Provide a simple ip6_ins_rt() for the majority of users and
an alternative for the exception via netlink. Avoids code
obfuscation.
Provide a simple ip6_del_rt() for the majority of users and
obfuscation.
Change net/core, ipv4 and ipv6 sysctl variables to __read_mostly.
Couldn't actually measure any performance increase while testing (.3%
I consider noise), but seems like the right thing to do.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Fixes a wrong use of current->pid as netlink pid.
This is how IPv4 handles this case too.
Based upon a patch from Andrew Morton.
Adds support for policy routing rules including a new
local table for routes with a local destination.
Adds the framework to support multiple IPv6 routing tables.
Currently all automatically generated routes are put into the
same table. This could be changed at a later point after
considering the produced locking overhead.
ipv6_add_addr allocates a struct inet6_ifaddr and a dstentry, but it
doesn't install the dstentry in ifa->rt until after it releases the
addrconf_hash_lock. This means other CPUs will be able to see the new
address while it hasn't been initialized completely yet.
One possible fix would be to grab the ifp->lock spinlock when
creating the address struct; a simpler fix is to just move the
assignment.
Acked-by: jbeulich@novell.com
Acked-by: okir@suse.de
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
The ifa lock is expected to be taken in BH context (by addrconf timers)
so we must disable BH when accessing it from user context.
Based on MIPL2 kernel patch.
Signed-off-by: Noriaki YAKAMIYA <takamiya@po.ntts.co.jp>
We also do not try regenarating new temporary address corresponding to an
address with infinite preferred lifetime.
RTM_{ADD,DEL}MSG message
In the source address selection, the address must be sorted
from global to node-local.
But, ifp->scope is different from the scope for source address
selection.
2001::1 fe80::1 ::1
ifp->scope 0 0x02 0x01
ipv6_addr_src_scope(&ifp->addr) 0x0e 0x02 0x01
So, we need to use ipv6_addr_src_scope(&ifp->addr) for sorting.
And, for backward compatibility, addresses should be sorted from
new one to old one.
Acked-by: Brian Haley <brian.haley@hp.com>
If IPv6 addresses are ordered by scope, then ipv6_dev_get_saddr() can
break-out of the device addr_list for() loop when the candidate source
address scope is less than the destination address scope.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
CONFIG_IPV6_PRIVACY
We need to update hiscore.rule even if we don't enable CONFIG_IPV6_PRIVACY,
because we have more less significant rule; longest match.
Two additional labels (RFC 3484, sec. 10.3) for IPv6 addreses
are defined to make a distinction between global unicast
addresses and Unique Local Addresses (fc00::/7, RFC 4193) and
Teredo (2001::/32, RFC 4380). It is necessary to avoid attempts
of connection that would either fail (eg. fec0:: to 2001:feed::)
or be sub-optimal (2001:0:: to 2001:feed::).
Signed-off-by: Łukasz Stelmach <stlman@poczta.fm>
This patch fixes RTNLGRP_IPV6_IFINFO netlink notifications. Issue
pointed out by Patrick McHardy <kaber@trash.net>.
Acked-by: Patrick McHardy <kaber@trash.net>
The kernel's implementation of notifier chains is unsafe. There is no
protection against entries being added to or removed from a chain while the
chain is in use. The issues were discussed in this thread:
http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2
We noticed that notifier chains in the kernel fall into two basic usage
classes:
"Blocking" chains are always called from a process context
and the callout routines are allowed to sleep;
"Atomic" chains can be called from an atomic context and
the callout routines are not allowed to sleep.
We decided to codify this distinction and make it part of the API. Therefore
this set of patches introduces three new, parallel APIs: one for blocking
notifiers, one for atomic notifiers, and one for "raw" notifiers (which is
really just the old API under a new name). New kinds of data structures are
used for the heads of the chains, and new routines are defined for
registration, unregistration, and calling a chain. The three APIs are
explained in include/linux/notifier.h and their implementation is in
kernel/sys.c.
With atomic and blocking chains, the implementation guarantees that the chain
links will not be corrupted and that chain callers will not get messed up by
entries being added or removed. For raw chains the implementation provides no
guarantees at all; users of this API must provide their own protections. (The
idea was that situations may come up where the assumptions of the atomic and
blocking APIs are not appropriate, so it should be possible for users to
handle these things in their own way.)
There are some limitations, which should not be too hard to live with. For
atomic/blocking chains, registration and unregistration must always be done in
a process context since the chain is protected by a mutex/rwsem. Also, a
callout routine for a non-raw chain must not try to register or unregister
entries on its own chain. (This did happen in a couple of places and the code
had to be changed to avoid it.)
Since atomic chains may be called from within an NMI handler, they cannot use
spinlocks for synchronization. Instead we use RCU. The overhead falls almost
entirely in the unregister routine, which is okay since unregistration is much
less frequent that calling a chain.
Here is the list of chains that we adjusted and their classifications. None
of them use the raw API, so for the moment it is only a placeholder.
ATOMIC CHAINS
arch/i386/kernel/traps.c: i386die_chain
arch/ia64/kernel/traps.c: ia64die_chain
arch/powerpc/kernel/traps.c: powerpc_die_chain
arch/sparc64/kernel/traps.c: sparc64die_chain
arch/x86_64/kernel/traps.c: die_chain
drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list
kernel/panic.c: panic_notifier_list
kernel/profile.c: task_free_notifier
net/bluetooth/hci_core.c: hci_notifier
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain
net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain
net/ipv6/addrconf.c: inet6addr_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_chain
net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain
net/netlink/af_netlink.c: netlink_chain
BLOCKING CHAINS
arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain
arch/s390/kernel/process.c: idle_chain
arch/x86_64/kernel/process.c idle_notifier
drivers/base/memory.c: memory_chain
drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list
drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list
drivers/macintosh/adb.c: adb_client_list
drivers/macintosh/via-pmu.c sleep_notifier_list
drivers/macintosh/via-pmu68k.c sleep_notifier_list
drivers/macintosh/windfarm_core.c wf_client_list
drivers/usb/core/notify.c usb_notifier_list
drivers/video/fbmem.c fb_notifier_list
kernel/cpu.c cpu_chain
kernel/module.c module_notify_list
kernel/profile.c munmap_notifier
kernel/profile.c task_exit_notifier
kernel/sys.c reboot_notifier_list
net/core/dev.c netdev_chain
net/decnet/dn_dev.c: dnaddr_chain
net/ipv4/devinet.c: inetaddr_chain
It's possible that some of these classifications are wrong. If they are,
please let us know or submit a patch to fix them. Note that any chain that
gets called very frequently should be atomic, because the rwsem read-locking
used for blocking chains is very likely to incur cache misses on SMP systems.
(However, if the chain's callout routines may sleep then the chain cannot be
atomic.)
The patch set was written by Alan Stern and Chandra Seetharaman, incorporating
material written by Keith Owens and suggestions from Paul McKenney and Andrew
Morton.
[jes@sgi.com: restructure the notifier chain initialization macros]
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Signed-off-by: Jes Sorensen <jes@sgi.com>
Here are some possible (and trivial) cleanups.
- use kzalloc() where possible
- invert allocation failure test like
if (object) {
/* Rest of function here */
to
if (object == NULL)
return NULL;
Signed-off-by: Ingo Oeser <ioe-lkml@rameria.de>
This controls whether we accept Prefix Information in RAs.
This controls whether we accept default router information
in RAs.
RFC 3041 describes an algorithm to generate random interface
identifier. In RFC 3041bis, it is allowed to use different
algorithm than one described in RFC 3041.
So, let's use our standard pseudo random algorithm to simplify
our implementation.
