[backport of net-next 6d0bfe22611602f36617bc7aa2ffa1bbb2f54c67]
This adds the ability to send ICMPv6 echo requests without a
raw socket. The equivalent ability for ICMPv4 was added in
2011.
Instead of having separate code paths for IPv4 and IPv6, make
most of the code in net/ipv4/ping.c dual-stack and only add a
few IPv6-specific bits (like the protocol definition) to a new
net/ipv6/ping.c. Hopefully this will reduce divergence and/or
duplication of bugs in the future.
Caveats:
- Setting options via ancillary data (e.g., using IPV6_PKTINFO
to specify the outgoing interface) is not yet supported.
- There are no separate security settings for IPv4 and IPv6;
everything is controlled by /proc/net/ipv4/ping_group_range.
- The proc interface does not yet display IPv6 ping sockets
properly.
Tested with a patched copy of ping6 and using raw socket calls.
Compiles and works with all of CONFIG_IPV6={n,m,y}.
Bug 1412141
Change-Id: I0081b4654dd54b12c8f233e00e18943582aa2142
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
[lorenzo@google.com: backported to 3.4]
(cherry picked from commit 1f0675844e3b63a765e5bd32bc5af051ccd951c0)
Reviewed-on: http://git-master/r/336269
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
include/net/ipv6.h
net/ipv4/af_inet.c
net/ipv4/icmp.c
net/ipv4/ping.c
net/ipv6/Makefile
net/ipv6/af_inet6.c
net/ipv6/icmp.c
Change-Id: I6300756942bcf23f4745400c53fdb33301e9815f
Reviewed-on: http://git-master/r/337764
Reviewed-by: Om Prakash Singh <omp@nvidia.com>
Tested-by: Om Prakash Singh <omp@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Signed-off-by: Chia-chi Yeh <chiachi@android.com>
Introduce a new socket ioctl, SIOCKILLADDR, that nukes all sockets
bound to the same local address. This is useful in situations with
dynamic IPs, to kill stuck connections.
Signed-off-by: Brian Swetland <swetland@google.com>
net: fix tcp_v4_nuke_addr
Signed-off-by: Dima Zavin <dima@android.com>
net: ipv4: Fix a spinlock recursion bug in tcp_v4_nuke.
We can't hold the lock while calling to tcp_done(), so we drop
it before calling. We then have to start at the top of the chain again.
net: ipv4: Fix race in tcp_v4_nuke_addr().
To fix a recursive deadlock in 2.6.29, we stopped holding the hash table lock
across tcp_done() calls. This fixed the deadlock, but introduced a race where
the socket could die or change state.
Fix: Before unlocking the hash table, we grab a reference to the socket. We
can then unlock the hash table without risk of the socket going away. We then
lock the socket, which is safe because it is pinned. We can then call
tcp_done() without recursive deadlock and without race. Upon return, we unlock
the socket and then unpin it, killing it.
Change-Id: Idcdae072b48238b01bdbc8823b60310f1976e045
Signed-off-by: Robert Love <rlove@google.com>
Acked-by: Dima Zavin <dima@android.com>
ipv4: disable bottom halves around call to tcp_done().
Signed-off-by: Colin Cross <ccross@android.com>
ipv4: Move sk_error_report inside bh_lock_sock in tcp_v4_nuke_addr
When sk_error_report is called, it wakes up the user-space thread, which then
calls tcp_close. When the tcp_close is interrupted by the tcp_v4_nuke_addr
ioctl thread running tcp_done, it leaks 392 bytes and triggers a WARN_ON.
This patch moves the call to sk_error_report inside the bh_lock_sock, which
matches the locking used in tcp_v4_err.
With CONFIG_ANDROID_PARANOID_NETWORK, require specific uids/gids to instantiate
network sockets.
paranoid networking: Use in_egroup_p() to check group membership
The previous group_search() caused trouble for partners with module builds.
in_egroup_p() is also cleaner.
Signed-off-by: Nick Pelly <npelly@google.com>
Fix 2.6.29 build.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
net: Fix compilation of the IPv6 module
Fix compilation of the IPv6 module -- current->euid does not exist anymore,
current_euid() is what needs to be used.
Signed-off-by: Steinar H. Gunderson <sesse@google.com>
Following patch refactors GRE code into ip tunneling code and GRE
specific code. Common tunneling code is moved to ip_tunnel module.
ip_tunnel module is written as generic library which can be used
by different tunneling implementations.
ip_tunnel module contains following components:
- packet xmit and rcv generic code. xmit flow looks like
(gre_xmit/ipip_xmit)->ip_tunnel_xmit->ip_local_out.
- hash table of all devices.
- lookup for tunnel devices.
- control plane operations like device create, destroy, ioctl, netlink
operations code.
- registration for tunneling modules, like gre, ipip etc.
- define single pcpu_tstats dev->tstats.
- struct tnl_ptk_info added to pass parsed tunnel packet parameters.
ipip.h header is renamed to ip_tunnel.h
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
This patch requires multicast interface-scoped addresses to supply a
sin6_scope_id. Because the sin6_scope_id is now also correctly used
in case of interface-scoped multicast traffic this enables one to use
interface scoped addresses over interfaces which are not targeted by the
default multicast route (the route has to be put there manually, though).
getsockname() and getpeername() now return the correct sin6_scope_id in
case of interface-local mc addresses.
v2:
a) rebased ontop of patch 1/4 (now uses ipv6_addr_props)
v3:
a) reverted changes for ipv6_addr_props
v4:
a) unchanged
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>dave
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Allow privileged users in any user namespace to bind to
privileged sockets in network namespaces they control.
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Settings that merely control a single network device are allowed.
Either the network device is a logical network device where
restrictions make no difference or the network device is hardware NIC
that has been explicity moved from the initial network namespace.
In general policy and network stack state changes are allowed while
resource control is left unchanged.
Allow the SIOCSIFADDR ioctl to add ipv6 addresses.
Allow the SIOCDIFADDR ioctl to delete ipv6 addresses.
Allow the SIOCADDRT ioctl to add ipv6 routes.
Allow the SIOCDELRT ioctl to delete ipv6 routes.
Allow creation of ipv6 raw sockets.
Allow setting the IPV6_JOIN_ANYCAST socket option.
Allow setting the IPV6_FL_A_RENEW parameter of the IPV6_FLOWLABEL_MGR
socket option.
Allow setting the IPV6_TRANSPARENT socket option.
Allow setting the IPV6_HOPOPTS socket option.
Allow setting the IPV6_RTHDRDSTOPTS socket option.
Allow setting the IPV6_DSTOPTS socket option.
Allow setting the IPV6_IPSEC_POLICY socket option.
Allow setting the IPV6_XFRM_POLICY socket option.
Allow sending packets with the IPV6_2292HOPOPTS control message.
Allow sending packets with the IPV6_2292DSTOPTS control message.
Allow sending packets with the IPV6_RTHDRDSTOPTS control message.
Allow setting the multicast routing socket options on non multicast
routing sockets.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, and SIOCDELTUNNEL ioctls for
setting up, changing and deleting tunnels over ipv6.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, SIOCDELTUNNEL ioctls for
setting up, changing and deleting ipv6 over ipv4 tunnels.
Allow the SIOCADDPRL, SIOCDELPRL, SIOCCHGPRL ioctls for adding,
deleting, and changing the potential router list for ISATAP tunnels.
Sing GSO support is now separate, pull it out of the module
and make it its own init call.
Remove the cleanup functions as they are no longer called.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Separate IPv6 offload functionality into its own file
in preparation for the move out of the module
Switch IPv6 protocol to using the new GRO/GSO calls and data.
Convert to using the new GSO/GRO registration mechanism and new
packet offload structure.
It seems IPV6_GRO_CB(skb)->proto can be destroyed in skb_gro_receive()
if a new skb is allocated (to serve as an anchor for frag_list)
We copy NAPI_GRO_CB() only (not the IPV6 specific part) in :
*NAPI_GRO_CB(nskb) = *NAPI_GRO_CB(p);
So we leave IPV6_GRO_CB(nskb)->proto to 0 (fresh skb allocation) instead
of IPPROTO_TCP (6)
ipv6_gro_complete() isnt able to call ops->gro_complete()
[ tcp6_gro_complete() ]
Fix this by moving proto in NAPI_GRO_CB() and getting rid of
IPV6_GRO_CB
Cc: Herbert Xu <herbert@gondor.apana.org.au>
IPv4 side of the problem was addressed in commit a9e050f4e7f9d
(net: tcp: GRO should be ECN friendly)
This patch does the same, but for IPv6 : A Traffic Class mismatch
doesnt mean flows are different, but instead should force a flush
of previous packets.
This patch removes artificial packet reordering problem.
ipv6_opt_accepted() returns a bool, and can use const pointers
ipv6_addr_equal(), ipv6_addr_any(), ipv6_addr_loopback(),
ipv6_addr_orchid() return a bool.
Add #define pr_fmt(fmt) as appropriate.
Add "IPv6: " to appropriate files.
Convert printk(KERN_<LEVEL> to pr_<level> (but not KERN_DEBUG).
Standardize on "%s: " not "%s(): " when emitting __func__.
Use "%s: ", __func__ instead of embedding function name.
Coalesce formats, align arguments.
ADDRCONF output is now prefixed with "IPv6: "
af_inet6.c:80: ERROR: do not initialise statics to 0 or NULL
af_inet6.c:259: ERROR: spaces required around that '=' (ctx:VxV)
af_inet6.c:394: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:412: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:422: ERROR: do not use assignment in if condition
af_inet6.c:425: ERROR: do not use assignment in if condition
af_inet6.c:433: ERROR: do not use assignment in if condition
af_inet6.c:437: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:446: ERROR: spaces required around that '=' (ctx:VxV)
af_inet6.c:478: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:485: ERROR: that open brace { should be on the previous line
af_inet6.c:485: ERROR: space required before the open parenthesis '('
af_inet6.c:513: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:629: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:647: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:687: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:709: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:1073: ERROR: space required before the open parenthesis '('
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
Name them in a "backward compatible" manner, i.e. reuse or not
are still 1 and 0 respectively. The reuse value of 2 means that
the socket with it will forcibly reuse everyone else's port.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
sysctl no longer requires explicit creation of directories. The neigh
directory is always populated with at least a default entry so this
should cause no user visible changes.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Currently, it is not easily possible to get TOS/DSCP value of packets from
an incoming TCP stream. The mechanism is there, IP_PKTOPTIONS getsockopt
with IP_RECVTOS set, the same way as incoming TTL can be queried. This is
not actually implemented for TOS, though.
This patch adds this functionality, both for IPv4 (IP_PKTOPTIONS) and IPv6
(IPV6_2292PKTOPTIONS). For IPv4, like in the IP_RECVTTL case, the value of
the TOS field is stored from the other party's ACK.
This is needed for proxies which require DSCP transparency. One such example
is at http://zph.bratcheda.org/.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
This patch allows each namespace to independently set up
its levels for tcp memory pressure thresholds. This patch
alone does not buy much: we need to make this values
per group of process somehow. This is achieved in the
patches that follows in this patchset.
Signed-off-by: Glauber Costa <glommer@parallels.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
CC: David S. Miller <davem@davemloft.net>
CC: Eric W. Biederman <ebiederm@xmission.com>
C assignment can handle struct in6_addr copying.
v2: add couple missing conversions in drivers
split unexporting netdev_fix_features()
implemented %pNF
convert sock::sk_route_(no?)caps
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Reading /proc/net/snmp6 on a machine with a lot of cpus is very
expensive (can be ~88000 us).
This is because ICMPV6MSG MIB uses 4096 bytes per cpu, and folding
values for all possible cpus can read 16 Mbytes of memory (32MBytes on
non x86 arches)
ICMP messages are not considered as fast path on a typical server, and
eventually few cpus handle them anyway. We can afford an atomic
operation instead of using percpu data.
This saves 4096 bytes per cpu and per network namespace.
This makes native ipv6 bind follow the precedent set by:
- native ipv4 bind behaviour
- dual stack ipv4-mapped ipv6 bind behaviour.
This does allow an unpriviledged process to spoof its source IPv6
address, just like it currently can spoof its source IPv4 address
(for example when using UDP).
Signed-off-by: Maciej Żenczykowski <maze@google.com>
ipv6_gro_receive() doesn't update the protocol ops after pulling
the ext headers. It looks like a typo.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
Reinhard Max also pointed out that the error should EAFNOSUPPORT according
to POSIX.
The Linux manpages have it as EINVAL, some other OSes (Minix, HPUX, perhaps BSD) use
EAFNOSUPPORT. Windows uses WSAEFAULT according to MSDN.
Other protocols error values in their af bind() methods in current mainline git as far
as a brief look shows:
EAFNOSUPPORT: atm, appletalk, l2tp, llc, phonet, rxrpc
EINVAL: ax25, bluetooth, decnet, econet, ieee802154, iucv, netlink, netrom, packet, rds, rose, unix, x25,
No check?: can/raw, ipv6/raw, irda, l2tp/l2tp_ip
Ciao, Marcus
Signed-off-by: Marcus Meissner <meissner@suse.de>
Cc: Reinhard Max <max@suse.de>
Same check as for IPv4, also do for IPv6.
(If you passed in a IPv4 sockaddr_in here, the sizeof check
in the line before would have triggered already though.)
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
Create two sets of port member accessors, one set prefixed by fl4_*
and the other prefixed by fl6_*
This will let us to create AF optimal flow instances.
It will work because every context in which we access the ports,
we have to be fully aware of which AF the flowi is anyways.
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
Route lookups follow a general pattern in the ipv6 code wherein
we first find the non-IPSEC route, potentially override the
flow destination address due to ipv6 options settings, and then
finally make an IPSEC search using either xfrm_lookup() or
__xfrm_lookup().
__xfrm_lookup() is used when we want to generate a blackhole route
if the key manager needs to resolve the IPSEC rules (in this case
-EREMOTE is returned and the original 'dst' is left unchanged).
Otherwise plain xfrm_lookup() is used and when asynchronous IPSEC
resolution is necessary, we simply fail the lookup completely.
All of these cases are encapsulated into two routines,
ip6_dst_lookup_flow and ip6_sk_dst_lookup_flow. The latter of which
handles unconnected UDP datagram sockets.
Quoting Ben Hutchings: we presumably won't be defining features that
can only be enabled on 64-bit architectures.
Occurences found by `grep -r` on net/, drivers/net, include/
[ Move features and vlan_features next to each other in
struct netdev, as per Eric Dumazet's suggestion -DaveM ]
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
IS_ERR() already implies unlikely(), so it can be omitted here.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
Signed-off-by: Balazs Scheidler <bazsi@balabit.hu>
Signed-off-by: KOVACS Krisztian <hidden@balabit.hu>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
and inet_sendpage()
a new boolean flag no_autobind is added to structure proto to avoid the autobind
calls when the protocol is TCP. Then sock_rps_record_flow() is called int the
TCP's sendmsg() and sendpage() pathes.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
include/net/inet_common.h | 4 ++++
include/net/sock.h | 1 +
include/net/tcp.h | 8 ++++----
net/ipv4/af_inet.c | 15 +++++++++------
net/ipv4/tcp.c | 11 +++++------
net/ipv4/tcp_ipv4.c | 3 +++
net/ipv6/af_inet6.c | 8 ++++----
net/ipv6/tcp_ipv6.c | 3 +++
8 files changed, 33 insertions(+), 20 deletions(-)
In preparation for 64bit snmp counters for some mibs,
add an 'align' parameter to snmp_mib_init(), instead
of assuming mibs only contain 'unsigned long' fields.
Callers can use __alignof__(type) to provide correct
alignment.
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
CC: Vlad Yasevich <vladislav.yasevich@hp.com>
There are more than a dozen occurrences of following code in the
IPv6 stack:
if (opt && opt->srcrt) {
struct rt0_hdr *rt0 = (struct rt0_hdr *) opt->srcrt;
ipv6_addr_copy(&final, &fl.fl6_dst);
ipv6_addr_copy(&fl.fl6_dst, rt0->addr);
final_p = &final;
Replace those with a helper. Note that the helper overrides final_p
in all cases. This is ok as final_p was previously initialized to
NULL when declared.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ar9170/usb.c
drivers/scsi/iscsi_tcp.c
net/ipv4/ipmr.c
As per RFC 3493 the default multicast hops setting
for a socket should be "1" just like ipv4.
Ironically we have a IPV6_DEFAULT_MCASTHOPS macro
it just wasn't being used.
Reported-by: Elliot Hughes <enh@google.com>
Finally add support to detect a local IPV6_DONTFRAG event
and return the relevant data to the user if they've enabled
IPV6_RECVPATHMTU on the socket. The next recvmsg() will
return no data, but have an IPV6_PATHMTU as ancillary data.
Signed-off-by: Brian Haley <brian.haley@hp.com>
