This change allows to consider an anycast address valid as source address
when given via an IPV6_PKTINFO or IPV6_2292PKTINFO ancillary data item.
So, when sending a datagram with ancillary data, the unicast and anycast
addresses are handled in the same way.
- Adds ipv6_chk_acast_addr_src() to check if an anycast address is link-local
on given interface or is global.
- Uses it in ip6_datagram_send_ctl().
Signed-off-by: Francois-Xavier Le Bail <fx.lebail@yahoo.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Some ipv6 protocols cannot handle ipv4 addresses, so we must not allow
connecting and binding to them. sendmsg logic does already check msg->name
for this but must trust already connected sockets which could be set up
for connection to ipv4 address family.
Per-socket flag ipv6only is of no use here, as it is under users control
by setsockopt.
We currently don't report IPV6_RECVPKTINFO in cmsg access ancillary data
for IPv4 datagrams on IPv6 sockets.
This patch splits the ip6_datagram_recv_ctl into two functions, one
which handles both protocol families, AF_INET and AF_INET6, while the
ip6_datagram_recv_specific_ctl only handles IPv6 cmsg data.
ip6_datagram_recv_*_ctl never reported back any errors, so we can make
them return void. Also provide a helper for protocols which don't offer dual
personality to further use ip6_datagram_recv_ctl, which is exported to
modules.
I needed to shuffle the code for ping around a bit to make it easier to
implement dual personality for ping ipv6 sockets in future.
Reported-by: Gert Doering <gert@space.net>
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2013-12-19
1) Use the user supplied policy index instead of a generated one
if present. From Fan Du.
2) Make xfrm migration namespace aware. From Fan Du.
3) Make the xfrm state and policy locks namespace aware. From Fan Du.
4) Remove ancient sleeping when the SA is in acquire state,
we now queue packets to the policy instead. This replaces the
sleeping code.
5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the
posibility to sleep. The sleeping code is gone, so remove it.
6) Check user specified spi for IPComp. Thr spi for IPcomp is only
16 bit wide, so check for a valid value. From Fan Du.
7) Export verify_userspi_info to check for valid user supplied spi ranges
with pfkey and netlink. From Fan Du.
8) RFC3173 states that if the total size of a compressed payload and the IPComp
header is not smaller than the size of the original payload, the IP datagram
must be sent in the original non-compressed form. These packets are dropped
by the inbound policy check because they are not transformed. Document the need
to set 'level use' for IPcomp to receive such packets anyway. From Fan Du.
Please pull or let me know if there are problems.
This patch is following b579035ff766c9412e2b92abf5cab794bff102b6
"ipv6: remove old conditions on flow label sharing"
Since there is no reason to restrict a label to a
destination, we should not erase the destination value of a
socket with the value contained in the flow label storage.
This patch allows to really have the same flow label to more
than one destination.
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility
to sleep until the needed states are resolved. This code is gone,
so FLOWI_FLAG_CAN_SLEEP is not needed anymore.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Offenders don't have port numbers, so set it to 0.
functions
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
TCP listener refactoring, part 4 :
To speed up inet lookups, we moved IPv4 addresses from inet to struct
sock_common
Now is time to do the same for IPv6, because it permits us to have fast
lookups for all kind of sockets, including upcoming SYN_RECV.
Getting IPv6 addresses in TCP lookups currently requires two extra cache
lines, plus a dereference (and memory stall).
inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6
This patch is way bigger than its IPv4 counter part, because for IPv4,
we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6,
it's not doable easily.
inet6_sk(sk)->daddr becomes sk->sk_v6_daddr
inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr
And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr
at the same offset.
We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic
macro.
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
udp6_sock_seq_show and raw6_sock_seq_show are identical, except
the UDP version displays ports and the raw version displays the
protocol. Refactor most of the code in these two functions into
a new common ip6_dgram_sock_seq_show function, in preparation
for using it to display ICMPv6 sockets as well.
Also reduce the indentation in parts of include/net/transp_v6.h
to improve readability.
Compiles and displays reasonable results with CONFIG_IPV6={n,m,y}
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
v4:
a) unchanged
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch requires multicast interface-scoped addresses to supply a
sin6_scope_id. Because the sin6_scope_id is now also correctly used
in case of interface-scoped multicast traffic this enables one to use
interface scoped addresses over interfaces which are not targeted by the
default multicast route (the route has to be put there manually, though).
getsockname() and getpeername() now return the correct sin6_scope_id in
case of interface-local mc addresses.
v2:
a) rebased ontop of patch 1/4 (now uses ipv6_addr_props)
v3:
a) reverted changes for ipv6_addr_props
v4:
a) unchanged
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>dave
drivers/net/ethernet/intel/e1000e/ethtool.c
drivers/net/vmxnet3/vmxnet3_drv.c
drivers/net/wireless/iwlwifi/dvm/tx.c
net/ipv6/route.c
The ipv6 route.c conflict is simple, just ignore the 'net' side change
as we fixed the same problem in 'net-next' by eliminating cached
neighbours from ipv6 routes.
The e1000e conflict is an addition of a new statistic in the ethtool
code, trivial.
The vmxnet3 conflict is about one change in 'net' removing a guarding
conditional, whilst in 'net-next' we had a netdev_info() conversion.
The iwlwifi conflict is dealing with a WARN_ON() conversion in
'net-next' vs. a revert happening in 'net'.
ip6_datagram_recv_ctl and ip6_datagram_send_ctl are used for handling IPv6
ancillary data. Since ip6_datagram_send_ctl is already publicly exported for
use in modules, ip6_datagram_recv_ctl should also be available to support
ancillary data in the receive path.
Signed-off-by: Tom Parkin <tparkin@katalix.com>
Signed-off-by: James Chapman <jchapman@katalix.com>
The datagram_*_ctl functions in net/ipv6/datagram.c are IPv6-specific. Since
datagram_send_ctl is publicly exported it should be appropriately named to
reflect the fact that it's for IPv6 only.
Commit 7a3198a8 ("ipv6: helper function to get tclass") introduced
ipv6_tclass(), but similar function is already available as
ipv6_get_dsfield().
We might be able to call ipv6_tclass() from ipv6_get_dsfield(),
but it is confusing to have two versions.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
In ipv6_recv_error(), addr_offset points to daddr field of the ip header.
To get ipv6 header, use container_of() macro instead of substracting magic
number (24).
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Settings that merely control a single network device are allowed.
Either the network device is a logical network device where
restrictions make no difference or the network device is hardware NIC
that has been explicity moved from the initial network namespace.
In general policy and network stack state changes are allowed while
resource control is left unchanged.
Allow the SIOCSIFADDR ioctl to add ipv6 addresses.
Allow the SIOCDIFADDR ioctl to delete ipv6 addresses.
Allow the SIOCADDRT ioctl to add ipv6 routes.
Allow the SIOCDELRT ioctl to delete ipv6 routes.
Allow creation of ipv6 raw sockets.
Allow setting the IPV6_JOIN_ANYCAST socket option.
Allow setting the IPV6_FL_A_RENEW parameter of the IPV6_FLOWLABEL_MGR
socket option.
Allow setting the IPV6_TRANSPARENT socket option.
Allow setting the IPV6_HOPOPTS socket option.
Allow setting the IPV6_RTHDRDSTOPTS socket option.
Allow setting the IPV6_DSTOPTS socket option.
Allow setting the IPV6_IPSEC_POLICY socket option.
Allow setting the IPV6_XFRM_POLICY socket option.
Allow sending packets with the IPV6_2292HOPOPTS control message.
Allow sending packets with the IPV6_2292DSTOPTS control message.
Allow sending packets with the IPV6_RTHDRDSTOPTS control message.
Allow setting the multicast routing socket options on non multicast
routing sockets.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, and SIOCDELTUNNEL ioctls for
setting up, changing and deleting tunnels over ipv6.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, SIOCDELTUNNEL ioctls for
setting up, changing and deleting ipv6 over ipv4 tunnels.
Allow the SIOCADDPRL, SIOCDELPRL, SIOCCHGPRL ioctls for adding,
deleting, and changing the potential router list for ISATAP tunnels.
#if defined(CONFIG_FOO) || defined(CONFIG_FOO_MODULE)
can be replaced by
#if IS_ENABLED(CONFIG_FOO)
Signed-off-by: Cong Wang <amwang@redhat.com>
Mostly bool conversions, some inline removals and const additions.
For implementing other protocols on top of IPv6, such as L2TPv3's IP
encapsulation over ipv6, we'd like to call some IPv6 functions which
are not currently exported. This patch exports them.
Signed-off-by: Chris Elston <celston@katalix.com>
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
datagram.c:101: ERROR: "(foo*)" should be "(foo *)"
datagram.c:521: ERROR: space required before the open parenthesis '('
datagram.c:830: WARNING: braces {} are not necessary for single statement blocks
datagram.c:849: WARNING: braces {} are not necessary for single statement blocks
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
Implement helper inline function to get traffic class from IPv6 header.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
make C=2 CF="-D__CHECK_ENDIAN__" M=net
And fix flowi4_init_output() prototype for sport
C assignment can handle struct in6_addr copying.
This just makes it possible to spoof source IPv6 address on a socket
without having to create and bind a new socket for every source IP
we wish to spoof.
Signed-off-by: Maciej Żenczykowski <maze@google.com>
The pointer to mtu_info is taken from the common buffer
of the skb, thus it can't be a NULL pointer. This patch
removes this check on mtu_info.
Allow transparent sockets to be less restrictive about
the source ip of ipv6 udp packets being sent.
Google-Bug-Id: 5018138
CC: "Erik Kline" <ek@google.com>
CC: "Lorenzo Colitti" <lorenzo@google.com>
When support for binding to 'mapped INADDR_ANY (::ffff.0.0.0.0)' was added
in 0f8d3c7ac3693d7b6c731bf2159273a59bf70e12 the rest of the code
wasn't told so now it's possible to bind IPv6 datagram socket to
::ffff.0.0.0.0, connect it to another IPv4 address and it will all
work except for getsockhame() which does not return the local address
as expected.
To give getsockname() something to work with check for 'mapped INADDR_ANY'
when connecting and update the in-core source addresses appropriately.
Signed-off-by: Max Matveev <makc@redhat.com>
Create two sets of port member accessors, one set prefixed by fl4_*
and the other prefixed by fl6_*
This will let us to create AF optimal flow instances.
It will work because every context in which we access the ports,
we have to be fully aware of which AF the flowi is anyways.
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
Route lookups follow a general pattern in the ipv6 code wherein
we first find the non-IPSEC route, potentially override the
flow destination address due to ipv6 options settings, and then
finally make an IPSEC search using either xfrm_lookup() or
__xfrm_lookup().
__xfrm_lookup() is used when we want to generate a blackhole route
if the key manager needs to resolve the IPSEC rules (in this case
-EREMOTE is returned and the original 'dst' is left unchanged).
Otherwise plain xfrm_lookup() is used and when asynchronous IPSEC
resolution is necessary, we simply fail the lookup completely.
All of these cases are encapsulated into two routines,
ip6_dst_lookup_flow and ip6_sk_dst_lookup_flow. The latter of which
handles unconnected UDP datagram sockets.
Support for IPV6_RECVORIGDSTADDR sockopt for UDP sockets were contributed by
Harry Mason.
Signed-off-by: Balazs Scheidler <bazsi@balabit.hu>
Signed-off-by: KOVACS Krisztian <hidden@balabit.hu>
commit 30fff923 introduced in linux-2.6.33 (udp: bind() optimisation)
added a secondary hash on UDP, hashed on (local addr, local port).
Problem is that following sequence :
fd = socket(...)
connect(fd, &remote, ...)
not only selects remote end point (address and port), but also sets
local address, while UDP stack stored in secondary hash table the socket
while its local address was INADDR_ANY (or ipv6 equivalent)
Sequence is :
- autobind() : choose a random local port, insert socket in hash tables
[while local address is INADDR_ANY]
- connect() : set remote address and port, change local address to IP
given by a route lookup.
When an incoming UDP frame comes, if more than 10 sockets are found in
primary hash table, we switch to secondary table, and fail to find
socket because its local address changed.
One solution to this problem is to rehash datagram socket if needed.
We add a new rehash(struct socket *) method in "struct proto", and
implement this method for UDP v4 & v6, using a common helper.
This rehashing only takes care of secondary hash table, since primary
hash (based on local port only) is not changed.
Reported-by: Krzysztof Piotr Oledzki <ole@ans.pl>
Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl>
There are more than a dozen occurrences of following code in the
IPv6 stack:
if (opt && opt->srcrt) {
struct rt0_hdr *rt0 = (struct rt0_hdr *) opt->srcrt;
ipv6_addr_copy(&final, &fl.fl6_dst);
ipv6_addr_copy(&fl.fl6_dst, rt0->addr);
final_p = &final;
Replace those with a helper. Note that the helper overrides final_p
in all cases. This is ok as final_p was previously initialized to
NULL when declared.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ar9170/usb.c
drivers/scsi/iscsi_tcp.c
net/ipv4/ipmr.c
I noticed when I added support for IPV6_DONTFRAG that if you set
IPV6_RECVERR and tried to send a UDP packet larger than 64K to an
IPv6 destination, you'd correctly get an EMSGSIZE, but reading from
MSG_ERRQUEUE returned the incorrect address in the cmsg:
struct msghdr:
msg_name 0x7fff8f3c96d0
msg_namelen 28
struct sockaddr_in6:
sin6_family 10
sin6_port 7639
sin6_flowinfo 0
sin6_addr ::ffff:38.32.0.0
sin6_scope_id 0 ((null))
It should have returned this in my case:
struct msghdr:
msg_name 0x7fffd866b510
msg_namelen 28
sin6_family 10
sin6_port 7639
sin6_flowinfo 0
sin6_addr 2620:0:a09:e000:21f:29ff:fe57:f88b
The problem is that ipv6_recv_error() assumes that if the error
wasn't generated by ICMPv6, it's an IPv4 address sitting there,
and proceeds to create a v4-mapped address from it.
Change ipv6_icmp_error() and ipv6_local_error() to set skb->protocol
to htons(ETH_P_IPV6) so that ipv6_recv_error() knows the address
sitting right after the extended error is IPv6, else it will
incorrectly map the first octet into an IPv4-mapped IPv6 address
in the cmsg structure returned in a recvmsg() call to obtain
the error.
Signed-off-by: Brian Haley <brian.haley@hp.com>
To unsubscribe from this list: send the line "unsubscribe netdev" in
the body of a message to majordomo@vger.kernel.org
More majordomo info at http://vger.kernel.org/majordomo-info.html
Finally add support to detect a local IPV6_DONTFRAG event
and return the relevant data to the user if they've enabled
IPV6_RECVPATHMTU on the socket. The next recvmsg() will
return no data, but have an IPV6_PATHMTU as ancillary data.
Add dontfrag argument to relevant functions for
IPV6_DONTFRAG support, as well as allowing the value
to be passed-in via ancillary cmsg data.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Avoids touching device refcount in datagram_send_ctl(), thanks to RCU
In order to have better cache layouts of struct sock (separate zones
for rx/tx paths), we need this preliminary patch.
Goal is to transfert fields used at lookup time in the first
read-mostly cache line (inside struct sock_common) and move sk_refcnt
to a separate cache line (only written by rx path)
This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr,
sport and id fields. This allows a future patch to define these
fields as macros, like sk_refcnt, without name clashes.
Might as well use the ipv6_addr_set_v4mapped() inline we created last
year.
Atis Elsts wrote:
> Not sure if there is need to fill the mark from skb in tunnel xmit functions. In any case, it's not done for GRE or IPIP tunnels at the moment.
Ok, I'll just drop that part, I'm not sure what should be done in this case.
> Also, in this patch you are doing that for SIT (v6-in-v4) tunnels only, and not doing it for v4-in-v6 or v6-in-v6 tunnels. Any reason for that?
I just sent that patch out too quickly, here's a better one with the updates.
Add support for IPv6 route lookups using sk_mark.
