[ Upstream commit 45f6fad84cc305103b28d73482b344d7f5b76f39 ]
This patch addresses multiple problems :
UDP/RAW sendmsg() need to get a stable struct ipv6_txoptions
while socket is not locked : Other threads can change np->opt
concurrently. Dmitry posted a syzkaller
(http://github.com/google/syzkaller) program desmonstrating
use-after-free.
Starting with TCP/DCCP lockless listeners, tcp_v6_syn_recv_sock()
and dccp_v6_request_recv_sock() also need to use RCU protection
to dereference np->opt once (before calling ipv6_dup_options())
This patch adds full RCU protection to np->opt
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Use the more common dynamic_debug capable net_dbg_ratelimited
and remove the LIMIT_NETDEBUG macro.
All messages are still ratelimited.
Some KERN_<LEVEL> uses are changed to KERN_DEBUG.
This may have some negative impact on messages that were
emitted at KERN_INFO that are not not enabled at all unless
DEBUG is defined or dynamic_debug is enabled. Even so,
these messages are now _not_ emitted by default.
This also eliminates the use of the net_msg_warn sysctl
"/proc/sys/net/core/warnings". For backward compatibility,
the sysctl is not removed, but it has no function. The extern
declaration of net_msg_warn is removed from sock.h and made
static in net/core/sysctl_net_core.c
Miscellanea:
o Update the sysctl documentation
o Remove the embedded uses of pr_fmt
o Coalesce format fragments
o Realign arguments
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
In rfc4942 and rfc2460 I cannot find anything which would implicate to
drop packets which have only padding in tlv.
Current behaviour breaks TAHI Test v6LC.1.2.6.
Problem was intruduced in:
9b905fe6843 "ipv6/exthdrs: strict Pad1 and PadN check"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Router Alert option is very small and we can store the value
itself in the skb.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Sing GSO support is now separate, pull it out of the module
and make it its own init call.
Remove the cleanup functions as they are no longer called.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
UDP offload needs some additional functions to be in the static kernel
for it work correclty. Move those functions into the core.
Move the exthdr offload functionality into a separeate
file in preparate for moving it out of the module
Switch IPv6 protocol to using the new GRO/GSO calls and data.
Create a new data structure for IPv6 protocols that holds GRO/GSO
callbacks and a new array to track the protocols that register GRO/GSO.
#if defined(CONFIG_FOO) || defined(CONFIG_FOO_MODULE)
can be replaced by
#if IS_ENABLED(CONFIG_FOO)
Signed-off-by: Cong Wang <amwang@redhat.com>
Adding casts of objects to the same type is unnecessary
and confusing for a human reader.
For example, this cast:
int y;
int *p = (int *)&y;
I used the coccinelle script below to find and remove these
unnecessary casts. I manually removed the conversions this
script produces of casts with __force and __user.
type T;
T *p;
- (T *)p
+ p
The following tightens the padding check from commit
c1412fce7eccae62b4de22494f6ab3ff8a90c0c6 :
* Take into account combinations of consecutive Pad1 and PadN.
* Catch the corner case of when only padding is present in the
header, when the extention header length is 0 (i.e., 8 bytes).
In this case, the header would have exactly 6 bytes of padding:
: Next Header : Hdr Ext Len=0 : :
: Padding (Pad1 or PadN) :
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
Mostly bool conversions, some inline removals and const additions.
The padding destination or hop-by-hop option is called Pad1 and not Pad0.
See RFC2460 (4.2) or the IANA ipv6-parameters registry:
http://www.iana.org/assignments/ipv6-parameters/ipv6-parameters.xml
For implementing other protocols on top of IPv6, such as L2TPv3's IP
encapsulation over ipv6, we'd like to call some IPv6 functions which
are not currently exported. This patch exports them.
Signed-off-by: Chris Elston <celston@katalix.com>
Signed-off-by: James Chapman <jchapman@katalix.com>
Added strict checking of PadN, as PadN can be used to increase header
size and thus push the protocol header into the 2nd fragment.
PadN is used to align the options within the Hop-by-Hop or
Destination Options header to 64-bit boundaries. The maximum valid
size is thus 7 bytes.
RFC 4942 recommends to actively check the "payload" itself and
ensure that it contains only zeroes.
See also RFC 4942 section 2.1.9.5.
exthdrs.c:726: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
exthdrs.c:741: ERROR: "(foo*)" should be "(foo *)"
exthdrs.c:744: ERROR: "(foo**)" should be "(foo **)"
exthdrs.c:746: ERROR: "(foo**)" should be "(foo **)"
exthdrs.c:748: ERROR: "(foo**)" should be "(foo **)"
exthdrs.c:750: ERROR: "(foo**)" should be "(foo **)"
exthdrs.c:755: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
exthdrs.c:896: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
C assignment can handle struct in6_addr copying.
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
ipv6_destopt_rcv() runs with rcu_read_lock(), so there is no need to
take a temporay reference on dst_entry, even if skb is freed by
ip6_parse_tlv()
Use __in6_dev_get() instead of in6_dev_get()/in6_dev_put()
There are more than a dozen occurrences of following code in the
IPv6 stack:
if (opt && opt->srcrt) {
struct rt0_hdr *rt0 = (struct rt0_hdr *) opt->srcrt;
ipv6_addr_copy(&final, &fl.fl6_dst);
ipv6_addr_copy(&fl.fl6_dst, rt0->addr);
final_p = &final;
Replace those with a helper. Note that the helper overrides final_p
in all cases. This is ok as final_p was previously initialized to
NULL when declared.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Dunno, what was the idea, it wasn't used for a long time.
This fixes CERT-FI FICORA #341748
Discovered by Olli Jarva and Tuomo Untinen from the CROSS
project at Codenomicon Ltd.
Just like in CVE-2007-4567, we can't rely upon skb_dst() being
non-NULL at this point. We fixed that in commit
e76b2b2567b83448c2ee85a896433b96150c92e6 ("[IPV6]: Do no rely on
skb->dst before it is assigned.")
However commit 483a47d2fe794328d29950fe00ce26dd405d9437 ("ipv6: added
net argument to IP6_INC_STATS_BH") put a new version of the same bug
into this function.
Complicating analysis further, this bug can only trigger when network
namespaces are enabled in the build. When namespaces are turned off,
the dev_net() does not evaluate it's argument, so the dereference
would not occur.
So, for a long time, namespaces couldn't be turned on unless SYSFS was
disabled. Therefore, this code has largely been disabled except by
people turning it on explicitly for namespace development.
With help from Eugene Teo <eugene@redhat.com>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Denis V. Lunev <den@openvz.org>
net/netfilter/nf_conntrack_proto_tcp.c
Signed-off-by: Denis V. Lunev <den@parallels.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Looks if the address is belonging to the network namespace, otherwise
discard the address for the check.
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
This patch factorize the code for the differents init functions for rthdr,
nodata, destopt in a single function exthdrs_init.
This function returns an error so the af_inet6 module can check correctly
the initialization.
We have a number of copies of dst_discard scattered around the place
which all do the same thing, namely free a packet on the input or
output paths.
This patch deletes all of them except dst_discard and points all the
users to it.
The only non-trivial bit is decnet where it returns an error.
However, conceptually this is identical to the blackhole functions
used in IPv4 and IPv6 which do not return errors. So they should
either all return errors or all return zero. For now I've stuck with
the majority and picked zero as the return value.
It doesn't really matter in practice since few if any driver would
react differently depending on a zero return value or NET_RX_DROP.
With all the users of the double pointers removed from the IPv6 input path,
this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input
handlers.
This patch replaces unnecessary uses of skb_copy by pskb_expand_head
on the IPv6 input path.
This allows us to remove the double pointers later.
Based on <draft-ietf-ipv6-deprecate-rh0-00.txt>.
The "fix" for emerging security threat was overkill and it broke
basic semantic of IPv6 routing header processing. We should assume
RT0 (or even RT2, depends on configuration) as "unknown" RH type so
that we
- silently ignore the routing header if segleft == 0
- send ICMPv6 Parameter Problem message back to the sender,
otherwise.
This patch makes MIPv6 loadable module named "mip6".
Here is a modprobe.conf(5) example to load it automatically
when user application uses XFRM state for MIPv6:
alias xfrm-type-10-43 mip6
alias xfrm-type-10-60 mip6
Some MIPv6 feature is not included by this modular, however,
it should not be affected to other features like either IPsec
or IPv6 with and without the patch.
We may discuss XFRM, MH (RAW socket) and ancillary data/sockopt
separately for future work.
Loadable features:
* MH receiving check (to send ICMP error back)
* RO header parsing and building (i.e. RH2 and HAO in DSTOPTS)
* XFRM policy/state database handling for RO
These are NOT covered as loadable:
* Home Address flags and its rule on source address selection
* XFRM sub policy (depends on its own kernel option)
* XFRM functions to receive RO as IPv6 extension header
* MH sending/receiving through raw socket if user application
opens it (since raw socket allows to do so)
* RH2 sending as ancillary data
* RH2 operation with setsockopt(2)
Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
Because skb->dst is assigned in ip6_route_input(), it is really
bad to use it in hop-by-hop option handler(s).
Closes: Bug #8450 (Eric Sesterhenn <snakebyte@gmx.de>)
Spring cleaning time...
There seems to be a lot of places in the network code that have
extra bogus semicolons after conditionals. Most commonly is a
bogus semicolon after: switch() { }
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes
on 64bit architectures, allowing us to combine the 4 bytes hole left by the
layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4
64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN...
Many calculations that previously required that skb->{transport,network,
mac}_header be first converted to a pointer now can be done directly, being
meaningful as offsets or pointers.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and
skb->mac to skb->mac_header, to match the names of the associated helpers
(skb[_[re]set]_{transport,network,mac}_header).
