path: root/net/ipv6/icmp.c
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put fl6_* macros to struct flowi6 and use them again.David S. Miller
2011-03-12ipv6: Convert to use flowi6 where applicable.David S. Miller
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02xfrm: Return dst directly from xfrm_lookup()David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv6: Make icmp route lookup code a bit clearer.David S. Miller
The route lookup code in icmpv6_send() is slightly tricky as a result of having to handle all of the requirements of RFC 4301 host relookups. Pull the route resolution into a seperate function, so that the error handling and route reference counting is hopefully easier to see and contained wholly within this new routine. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-04inetpeer: Move ICMP rate limiting state into inet_peer entries.David S. Miller
Like metrics, the ICMP rate limiting bits are cached state about a destination. So move it into the inet_peer entries. If an inet_peer cannot be bound (the reason is memory allocation failure or similar), the policy is to allow. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-09ipv6: fix ICMP6_MIB_OUTERRORSEric Dumazet
In commit 1f8438a85366 (icmp: Account for ICMP out errors), I did a typo on IPV6 side, using ICMP6_MIB_OUTMSGS instead of ICMP6_MIB_OUTERRORS Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23IPv6: Add dontfrag argument to relevant functionsBrian Haley
Add dontfrag argument to relevant functions for IPV6_DONTFRAG support, as well as allowing the value to be passed-in via ancillary cmsg data. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03icmp: Account for ICMP out errorsEric Dumazet
When ip_append() fails because of socket limit or memory shortage, increment ICMP_MIB_OUTERRORS counter, so that "netstat -s" can report these errors. LANG=C netstat -s | grep "ICMP messages failed" 0 ICMP messages failed For IPV6, implement ICMP6_MIB_OUTERRORS counter as well. # grep Icmp6OutErrors /proc/net/dev_snmp6/* /proc/net/dev_snmp6/eth0:Icmp6OutErrors 0 /proc/net/dev_snmp6/lo:Icmp6OutErrors 0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-18ipv6: drop unused "dev" arg of icmpv6_send()Alexey Dobriyan
Dunno, what was the idea, it wasn't used for a long time. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18ipv6: remove stale MIB definitionsAlexey Dobriyan
ICMP6 MIB statistics was per-netns for quite a time. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
2009-08-13inet6: Conversion from u8 to intGerrit Renker
This replaces assignments of the type "int on LHS" = "u8 on RHS" with simpler code. The LHS can express all of the unsigned right hand side values, hence the assigned value can not be negative. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27net: fix xfrm reverse flow lookup for icmp6Jiri Pirko
This patch fixes the xfrm reverse flow lookup for icmp6 so that icmp6 packets don't get lost over ipsec tunnels. Similar patch is in RHEL5 kernel for a quite long time and I do not see why it isn't in mainline. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: lookup in netnsAlexey Dobriyan
Pass netns to xfrm_lookup()/__xfrm_lookup(). For that pass netns to flow_cache_lookup() and resolver callback. Take it from socket or netdevice. Stub DECnet to init_net. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19include/net net/ - csum_partial - remove unnecessary castsJoe Perches
The first argument to csum_partial is const void * casts to char/u8 * are not necessary Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-28net: reduce structures when XFRM=nAlexey Dobriyan
ifdef out * struct sk_buff::sp (pointer) * struct dst_entry::xfrm (pointer) * struct sock::sk_policy (2 pointers) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: added net argument to ICMP6MSGIN_INC_STATS_BHDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: added net argument to ICMP6_INC_STATS_BHDenis V. Lunev
2008-10-08netns: add net parameter to IP6_INC_STATSDenis V. Lunev
2008-08-23icmp: icmp_sk() should not use smp_processor_id() in preemptible codeDenis V. Lunev
Pass namespace into icmp_xmit_lock, obtain socket inside and return it as a result for caller. Thanks Alexey Dobryan for this report: Steps to reproduce: CONFIG_PREEMPT=y CONFIG_DEBUG_PREEMPT=y tracepath <something> BUG: using smp_processor_id() in preemptible [00000000] code: tracepath/3205 caller is icmp_sk+0x15/0x30 Pid: 3205, comm: tracepath Not tainted 2.6.27-rc4 #1 Call Trace: [<ffffffff8031af14>] debug_smp_processor_id+0xe4/0xf0 [<ffffffff80409405>] icmp_sk+0x15/0x30 [<ffffffff8040a17b>] icmp_send+0x4b/0x3f0 [<ffffffff8025a415>] ? trace_hardirqs_on_caller+0xd5/0x160 [<ffffffff8025a4ad>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff8023a475>] ? local_bh_enable_ip+0x95/0x110 [<ffffffff804285b9>] ? _spin_unlock_bh+0x39/0x40 [<ffffffff8025a26c>] ? mark_held_locks+0x4c/0x90 [<ffffffff8025a4ad>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff8025a415>] ? trace_hardirqs_on_caller+0xd5/0x160 [<ffffffff803e91b4>] ip_fragment+0x8d4/0x900 [<ffffffff803e7030>] ? ip_finish_output2+0x0/0x290 [<ffffffff803e91e0>] ? ip_finish_output+0x0/0x60 [<ffffffff803e6650>] ? dst_output+0x0/0x10 [<ffffffff803e922c>] ip_finish_output+0x4c/0x60 [<ffffffff803e92e3>] ip_output+0xa3/0xf0 [<ffffffff803e68d0>] ip_local_out+0x20/0x30 [<ffffffff803e753f>] ip_push_pending_frames+0x27f/0x400 [<ffffffff80406313>] udp_push_pending_frames+0x233/0x3d0 [<ffffffff804067d1>] udp_sendmsg+0x321/0x6f0 [<ffffffff8040d155>] inet_sendmsg+0x45/0x80 [<ffffffff803b967f>] sock_sendmsg+0xdf/0x110 [<ffffffff8024a100>] ? autoremove_wake_function+0x0/0x40 [<ffffffff80257ce5>] ? validate_chain+0x415/0x1010 [<ffffffff8027dc10>] ? __do_fault+0x140/0x450 [<ffffffff802597d0>] ? __lock_acquire+0x260/0x590 [<ffffffff803b9e55>] ? sockfd_lookup_light+0x45/0x80 [<ffffffff803ba50a>] sys_sendto+0xea/0x120 [<ffffffff80428e42>] ? _spin_unlock_irqrestore+0x42/0x80 [<ffffffff803134bc>] ? __up_read+0x4c/0xb0 [<ffffffff8024e0c6>] ? up_read+0x26/0x30 [<ffffffff8020b8bb>] system_call_fastpath+0x16/0x1b icmp6_sk() is similar. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-01icmp: fix units for ratelimitStephen Hemminger
Convert the sysctl values for icmp ratelimit to use milliseconds instead of jiffies which is based on kernel configured HZ. Internal kernel jiffies are not a proper unit for any userspace API. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-03[IPV6]: Simplify IPv6 control sockets creation.Denis V. Lunev
Do this by replacing sock_create_kern with inet_ctl_sock_create. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[ICMP]: Ensure that ICMP relookup maintains status quoHerbert Xu
The ICMP relookup path is only meant to modify behaviour when appropriate IPsec policies are in place and marked as requiring relookups. It is certainly not meant to modify behaviour when IPsec policies don't exist at all. However, due to an oversight on the error paths existing behaviour may in fact change should one of the relookup steps fail. This patch corrects this by redirecting all errors on relookup failures to the previous code path. That is, if the initial xfrm_lookup let the packet pass, we will stand by that decision should the relookup fail due to an error. This should be safe from a security point-of-view because compliant systems must install a default deny policy so the packet would'nt have passed in that case. Many thanks to Julian Anastasov for pointing out this error. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/s2io.c
2008-04-02[IPV6]: Fix ICMP relookup error path dst leakHerbert Xu
When we encounter an error while looking up the dst the second time we need to drop the first dst. This patch is pretty much the same as the one for IPv4. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-25[IPV6]: Optimize hop-limit determination.YOSHIFUJI Hideaki
Last part of hop-limit determination is always: hoplimit = dst_metric(dst, RTAX_HOPLIMIT); if (hoplimit < 0) hoplimit = ipv6_get_hoplimit(dst->dev). Let's consolidate it as ip6_dst_hoplimit(dst). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-05[NETNS][IPV6] icmp6 - make icmpv6_socket per namespaceBenjamin Thery
This patch make the changes necessary to support network namespaces in ICMPv6. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05[NETNS][IPV6] route6 - add netns parameter to ip6_route_outputDaniel Lezcano
Add an netns parameter to ip6_route_output. That will allow to access to the right routing table for outgoing traffic. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[IPV6]: Make ndisc_flow_init() common for later use.YOSHIFUJI Hideaki
For later use, this patch is renaming ndisc_flow_init() to icmpv6_flow_init() and putting it in common place. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-04[IPV6] SYSCTL: complete initialization for sysctl table in subsystem code.YOSHIFUJI Hideaki
Move initialization bits for subsystem sysctl tables to appropriate functions. - route - icmp Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-03ipv6: fix inet6_init/icmpv6_cleanup sections mismatchAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[NETNS]: Make icmpv6_sk per namespace.Denis V. Lunev
All preparations are done. Now just add a hook to perform an initialization on namespace startup and replace icmpv6_sk macro with proper inline call. Actual namespace the packet belongs too will be passed later along with the one for the routing. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[NETNS]: icmp(v6)_sk should not pin a namespace.Denis V. Lunev
So, change icmp(v6)_sk creation/disposal to the scheme used in the netlink for rtnl, i.e. create a socket in the context of the init_net and assign the namespace without getting a referrence later. Also use sk_release_kernel instead of sock_release to properly destroy such sockets. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[ICMP]: Allocate data for __icmp(v6)_sk dynamically.Denis V. Lunev
Own __icmp(v6)_sk should be present in each namespace. So, it should be allocated dynamically. Though, alloc_percpu does not fit the case as it implies additional dereferrence for no bonus. Allocate data for pointers just like __percpu_alloc_mask does and place pointers to struct sock into this array. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[ICMP]: Pass proper ICMP socket into icmp(v6)_xmit_(un)lock.Denis V. Lunev
We have to get socket lock inside icmp(v6)_xmit_lock/unlock. The socket is get from global variable now. When this code became namespaces, one should pass a namespace and get socket from it. Though, above is useless. Socket is available in the caller, just pass it inside. This saves a bit of code now and saves more later. add/remove: 0/0 grow/shrink: 1/3 up/down: 1/-169 (-168) function old new delta icmp_rcv 718 719 +1 icmpv6_rcv 2343 2303 -40 icmp_send 1566 1518 -48 icmp_reply 549 468 -81 Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
