path: root/net/ipv6/inet6_connection_sock.c
2008-04-14[SOCK]: Add some notes about per-bind-bucket sock lookup.Pavel Emelyanov
I was asked about "why don't we perform a sk_net filtering in bind_conflict calls, like we do in other sock lookup places" for a couple of times. Can we please add a comment about why we do not need one? Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6] __inet6_csk_dst_store(): fix check-after-useAdrian Bunk
The Coverity checker spotted that we have already oops'ed if "dst" was NULL. Since "dst" being NULL doesn't seem to be possible at this point this patch removes the NULL check. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Acked-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV6] XFRM: Fix connected socket to use transformation.Noriaki TAKAMIYA
When XFRM policy and state are ready after TCP connection is started, the traffic should be transformed immediately, however it does not on IPv6 TCP. It depends on a dst cache replacement policy with connected socket. It seems that the replacement is always done for IPv4, however, on IPv6 case it is done only when routing cookie is changed. This patch fix that non-transformation dst can be changed to transformation one. This behavior is required by MIPv6 and improves IPv6 IPsec. Fixes by Masahide NAKAMURA. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-26[TCP]: Restore SKB socket owner setting in tcp_transmit_skb().David S. Miller
Revert 931731123a103cfb3f70ac4b7abfc71d94ba1f03 We can't elide the skb_set_owner_w() here because things like certain netfilter targets (such as owner MATCH) need a socket to be set on the SKB for correct operation. Thanks to Jan Engelhardt and other netfilter list members for pointing this out. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: Don't set SKB owner in tcp_transmit_skb().David S. Miller
The data itself is already charged to the SKB, doing the skb_set_owner_w() just generates a lot of noise and extra atomics we don't really need. Lmbench improvements on lat_tcp are minimal: before: TCP latency using localhost: 23.2701 microseconds TCP latency using localhost: 23.1994 microseconds TCP latency using localhost: 23.2257 microseconds after: TCP latency using localhost: 22.8380 microseconds TCP latency using localhost: 22.9465 microseconds TCP latency using localhost: 22.8462 microseconds Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: annotate inet6_csk_search_req()Al Viro
2006-09-22[IPV6]: Cache source address as well in ipv6_pinfo{}.YOSHIFUJI Hideaki
Based on MIPL2 kernel patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Add flow labelingVenkat Yekkirala
This labels the flows that could utilize IPSec xfrms at the points the flows are defined so that IPSec policy and SAs at the right label can be used. The following protos are currently not handled, but they should continue to be able to use single-labeled IPSec like they currently do. ipmr ip_gre ipip igmp sit sctp ip6_tunnel (IPv6 over IPv6 tunnel device) decnet Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[IPV6]: Audit all ip6_dst_lookup/ip6_dst_store callsHerbert Xu
The current users of ip6_dst_lookup can be divided into two classes: 1) The caller holds no locks and is in user-context (UDP). 2) The caller does not want to lookup the dst cache at all. The second class covers everyone except UDP because most people do the cache lookup directly before calling ip6_dst_lookup. This patch adds ip6_sk_dst_lookup for the first class. Similarly ip6_dst_store users can be divded into those that need to take the socket dst lock and those that don't. This patch adds __ip6_dst_store for those (everyone except UDP/datagram) that don't need an extra lock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IPV6]: Added GSO support for TCPv6 [NET]: Generalise TSO-specific bits from skb_setup_caps [IPV6]: Added GSO support for TCPv6 [IPV6]: Remove redundant length check on input [NETFILTER]: SCTP conntrack: fix crash triggered by packet without chunks [TG3]: Update version and reldate [TG3]: Add TSO workaround using GSO [TG3]: Turn on hw fix for ASF problems [TG3]: Add rx BD workaround [TG3]: Add tg3_netif_stop() in vlan functions [TCP]: Reset gso_segs if packet is dodgy
2006-06-30[IPV6]: Added GSO support for TCPv6Herbert Xu
This patch adds GSO support for IPv6 and TCPv6. This is based on a patch by Ananda Raju <Ananda.Raju@neterion.com>. His original description is: This patch enables TSO over IPv6. Currently Linux network stacks restricts TSO over IPv6 by clearing of the NETIF_F_TSO bit from "dev->features". This patch will remove this restriction. This patch will introduce a new flag NETIF_F_TSO6 which will be used to check whether device supports TSO over IPv6. If device support TSO over IPv6 then we don't clear of NETIF_F_TSO and which will make the TCP layer to create TSO packets. Any device supporting TSO over IPv6 will set NETIF_F_TSO6 flag in "dev->features" along with NETIF_F_TSO. In case when user disables TSO using ethtool, NETIF_F_TSO will get cleared from "dev->features". So even if we have NETIF_F_TSO6 we don't get TSO packets created by TCP layer. SKB_GSO_TCPV4 renamed to SKB_GSO_TCP to make it generic GSO packet. SKB_GSO_UDPV4 renamed to SKB_GSO_UDP as UFO is not a IPv4 feature. UFO is supported over IPv6 also The following table shows there is significant improvement in throughput with normal frames and CPU usage for both normal and jumbo. -------------------------------------------------- | | 1500 | 9600 | | ------------------|-------------------| | | thru CPU | thru CPU | -------------------------------------------------- | TSO OFF | 2.00 5.5% id | 5.66 20.0% id | -------------------------------------------------- | TSO ON | 2.63 78.0 id | 5.67 39.0% id | -------------------------------------------------- Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-10[IPV6]: skb leakage in inet6_csk_xmitAlexey Kuznetsov
inet6_csk_xit does not free skb when routing fails. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV6]: small cleanupsAdrian Bunk
This patch contains the following cleanups: - addrconf.c: make addrconf_dad_stop() static - inet6_connection_sock.c should #include <net/inet6_connection_sock.h> for getting the prototypes of it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise some functionsArnaldo Carvalho de Melo
Using sk->sk_protocol instead of IPPROTO_TCP. Will be used by DCCPv6 in the next changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_rsk()Arnaldo Carvalho de Melo
And inet6_rsk_offset in inet_request_sock, for the same reasons as inet_sock's pinfo6 member. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise tcp_v6_search_req & tcp_v6_synq_addArnaldo Carvalho de Melo
More work is needed tho to introduce inet6_request_sock from tcp6_request_sock, in the same layout considerations as ipv6_pinfo in inet_sock, next changeset will do that. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
