[ Upstream commit 864e2a1f8aac05effac6063ce316b480facb46ff ]
When syzkaller team brought us a C repro for the crash [1] that
had been reported many times in the past, I finally could find
the root cause.
If FlowLabel info is merged by fl6_merge_options(), we leave
part of the opt_space storage provided by udp/raw/l2tp with random value
in opt_space.tot_len, unless a control message was provided at sendmsg()
time.
Then ip6_setup_cork() would use this random value to perform a kzalloc()
call. Undefined behavior and crashes.
Fix is to properly set tot_len in fl6_merge_options()
At the same time, we can also avoid consuming memory and cpu cycles
to clear it, if every option is copied via a kmemdup(). This is the
change in ip6_setup_cork().
[1]
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 0 PID: 6613 Comm: syz-executor0 Not tainted 4.14.0-rc4+ #127
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
task: ffff8801cb64a100 task.stack: ffff8801cc350000
RIP: 0010:ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168
RSP: 0018:ffff8801cc357550 EFLAGS: 00010203
RAX: dffffc0000000000 RBX: ffff8801cc357748 RCX: 0000000000000010
RDX: 0000000000000002 RSI: ffffffff842bd1d9 RDI: 0000000000000014
RBP: ffff8801cc357620 R08: ffff8801cb17f380 R09: ffff8801cc357b10
R10: ffff8801cb64a100 R11: 0000000000000000 R12: ffff8801cc357ab0
R13: ffff8801cc357b10 R14: 0000000000000000 R15: ffff8801c3bbf0c0
FS: 00007f9c5c459700(0000) GS:ffff8801db200000(0000) knlGS:0000000000000000
CR2: 0000000020324000 CR3: 00000001d1cf2000 CR4: 00000000001406f0
DR0: 0000000020001010 DR1: 0000000000000000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000600
Call Trace:
ip6_make_skb+0x282/0x530 net/ipv6/ip6_output.c:1729
udpv6_sendmsg+0x2769/0x3380 net/ipv6/udp.c:1340
inet_sendmsg+0x11f/0x5e0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
SYSC_sendto+0x358/0x5a0 net/socket.c:1750
SyS_sendto+0x40/0x50 net/socket.c:1718
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4520a9
RSP: 002b:00007f9c5c458c08 EFLAGS: 00000216 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 00000000004520a9
RDX: 0000000000000001 RSI: 0000000020fd1000 RDI: 0000000000000016
RBP: 0000000000000086 R08: 0000000020e0afe4 R09: 000000000000001c
R10: 0000000000000000 R11: 0000000000000216 R12: 00000000004bb1ee
R13: 00000000ffffffff R14: 0000000000000016 R15: 0000000000000029
Code: e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85 ea 0f 00 00 48 8d 79 04 48 b8 00 00 00 00 00 fc ff df 45 8b 74 24 04 48 89 fa 48 c1 ea 03 <0f> b6 14 02 48 89 f8 83 e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85
RIP: ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168 RSP: ffff8801cc357550
In the sendmsg function of UDP, raw, ICMP and l2tp sockets, we use local
variables like hlimits, tclass, opt and dontfrag and pass them to corresponding
functions like ip6_make_skb, ip6_append_data and xxx_push_pending_frames.
This is not a good practice and makes it hard to add new parameters.
This fix introduces a new struct ipcm6_cookie similar to ipcm_cookie in
ipv4 and include the above mentioned variables. And we only pass the
pointer to this structure to corresponding functions. This makes it easier
to add new parameters in the future and makes the function cleaner.
Signed-off-by: Wei Wang <weiwan@google.com>
Process socket-level control messages by invoking
__sock_cmsg_send in ip6_datagram_send_ctl for control messages on
the SOL_SOCKET layer.
This makes sure whenever ip6_datagram_send_ctl is called for
udp and raw, we also process socket-level control messages.
This is a bit uglier than IPv4, since IPv6 does not have
something like ipcm_cookie. Perhaps we can later create
a control message cookie for IPv6?
Note that this commit interprets new control messages that
were ignored before. As such, this commit does not change
the behavior of IPv6 control messages.
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Willem de Bruijn <willemb@google.com>
Silence lockdep false positive about rcu_dereference() being
used in the wrong context.
First one should use rcu_dereference_protected() as we own the spinlock.
Second one should be a normal assignation, as no barrier is needed.
Fixes: 18367681a10bd ("ipv6 flowlabel: Convert np->ipv6_fl_list to RCU.")
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This patch divides the IPv6 flow label space into two ranges:
0-7ffff is reserved for flow label manager, 80000-fffff will be
used for creating auto flow labels (per RFC6438). This only affects how
labels are set on transmit, it does not affect receive. This range split
can be disbaled by systcl.
Background:
IPv6 flow labels have been an unmitigated disappointment thus far
in the lifetime of IPv6. Support in HW devices to use them for ECMP
is lacking, and OSes don't turn them on by default. If we had these
we could get much better hashing in IPv6 networks without resorting
to DPI, possibly eliminating some of the motivations to to define new
encaps in UDP just for getting ECMP.
Unfortunately, the initial specfications of IPv6 did not clarify
how they are to be used. There has always been a vague concept that
these can be used for ECMP, flow hashing, etc. and we do now have a
good standard how to this in RFC6438. The problem is that flow labels
can be either stateful or stateless (as in RFC6438), and we are
presented with the possibility that a stateless label may collide
with a stateful one. Attempts to split the flow label space were
rejected in IETF. When we added support in Linux for RFC6438, we
could not turn on flow labels by default due to this conflict.
This patch splits the flow label space and should give us
a path to enabling auto flow labels by default for all IPv6 packets.
This is an API change so we need to consider compatibility with
existing deployment. The stateful range is chosen to be the lower
values in hopes that most uses would have chosen small numbers.
Once we resolve the stateless/stateful issue, we can proceed to
look at enabling RFC6438 flow labels by default (starting with
scaled testing).
Signed-off-by: Tom Herbert <tom@herbertland.com>
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
hold_net and release_net were an idea that turned out to be useless.
The code has been disabled since 2008. Kill the code it is long past due.
Use spin_lock_bh in ip6_fl_purge() to prevent following potentially
deadlock scenario between ip6_fl_purge() and ip6_fl_gc() timer.
[ INFO: inconsistent lock state ]
3.19.0 #1 Not tainted
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
swapper/5/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
(ip6_fl_lock){+.?...}, at: [<ffffffff8171155d>] ip6_fl_gc+0x2d/0x180
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff810ee9a0>] __lock_acquire+0x4a0/0x10b0
[<ffffffff810efd54>] lock_acquire+0xc4/0x2b0
[<ffffffff81751d2d>] _raw_spin_lock+0x3d/0x80
[<ffffffff81711798>] ip6_flowlabel_net_exit+0x28/0x110
[<ffffffff815f9759>] ops_exit_list.isra.1+0x39/0x60
[<ffffffff815fa320>] cleanup_net+0x100/0x1e0
[<ffffffff810ad80a>] process_one_work+0x20a/0x830
[<ffffffff810adf4b>] worker_thread+0x11b/0x460
[<ffffffff810b42f4>] kthread+0x104/0x120
[<ffffffff81752bfc>] ret_from_fork+0x7c/0xb0
irq event stamp: 84640
hardirqs last enabled at (84640): [<ffffffff81752080>] _raw_spin_unlock_irq+0x30/0x50
hardirqs last disabled at (84639): [<ffffffff81751eff>] _raw_spin_lock_irq+0x1f/0x80
softirqs last enabled at (84628): [<ffffffff81091ad1>] _local_bh_enable+0x21/0x50
softirqs last disabled at (84629): [<ffffffff81093b7d>] irq_exit+0x12d/0x150
Possible unsafe locking scenario:
CPU0
lock(ip6_fl_lock);
<Interrupt>
lock(ip6_fl_lock);
*** DEADLOCK ***
Signed-off-by: Jan Stancek <jstancek@redhat.com>
This change has no functional impact and simply addresses some coding
style issues detected by checkpatch. Specifically this change
adjusts "if" statements which also include the assignment of a
variable.
No changes to the resultant object files result as determined by objdiff.
Using a single fixed string is smaller code size than using
a format and many string arguments.
Reduces overall code size a little.
$ size net/ipv4/igmp.o* net/ipv6/mcast.o* net/ipv6/ip6_flowlabel.o*
34269 7012 14824 56105 db29 net/ipv4/igmp.o.new
34315 7012 14824 56151 db57 net/ipv4/igmp.o.old
30078 7869 13200 51147 c7cb net/ipv6/mcast.o.new
30105 7869 13200 51174 c7e6 net/ipv6/mcast.o.old
11434 3748 8580 23762 5cd2 net/ipv6/ip6_flowlabel.o.new
11491 3748 8580 23819 5d0b net/ipv6/ip6_flowlabel.o.old
The "else" block is on several lines and use bracket.
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
This patch removes some blank lines between the end of a function
definition and the EXPORT_SYMBOL_GPL macro in order to prevent
checkpatch warning that EXPORT_SYMBOL must immediately follow
a function.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
This replaces 6 identical code snippets with a call to a new
static inline function.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
These include are here since kernel 2.2.7, but probably never used.
With the introduction of IPV6_FL_F_REFLECT, there is no guarantee of
flow label unicity. This patch introduces a new sysctl to protect the old
behaviour, enable by default.
Changelog of V3:
* rename ip6_flowlabel_consistency to flowlabel_consistency
* use net_info_ratelimited()
* checkpatch cleanups
This information is already available via IPV6_FLOWINFO
of IPV6_2292PKTOPTIONS, and them a filtering to get the flow label
information. But it is probably logical and easier for users to add this
here, and to control both sent/received flow label values with the
IPV6_FLOWLABEL_MGR option.
With this option, the socket will reply with the flow label value read
on received packets.
The goal is to have a connection with the same flow label in both
direction of the communication.
Changelog of V4:
* Do not erase the flow label on the listening socket. Use pktopts to
store the received value
This patch removes the net_random and net_srandom macros and replaces
them with direct calls to the prandom ones. As new commits only seem to
use prandom_u32 there is no use to keep them around.
This change makes it easier to grep for users of prandom_u32.
Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Fixes a suspicious rcu derference warning.
Cc: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Take ip6_fl_lock before to read and update
a label.
v2: protect only the relevant code
Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
If the last RFC 6437 does not give any constraints
for lifetime of flow labels, the previous RFC 3697
spoke of a minimum of 120 seconds between
reattribution of a flow label.
The maximum linger is currently set to 60 seconds
and does not allow this configuration without
CAP_NET_ADMIN right.
This patch increase the maximum linger to 150
seconds, allowing more flexibility to standard
users.
It is already possible to set/put/renew a label
with IPV6_FLOWLABEL_MGR and setsockopt. This patch
add the possibility to get information about this
label (current value, time before expiration, etc).
It helps application to take decision for a renew
or a release of the label.
v2:
* Add spin_lock to prevent race condition
* return -ENOENT if no result found
* check if flr_action is GET
v3:
* move the spin_lock to protect only the
relevant code
The code of flow label in Linux Kernel follows
the rules of RFC 1809 (an informational one) for
conditions on flow label sharing. There rules are
not in the last proposed standard for flow label
(RFC 6437), or in the previous one (RFC 3697).
Since this code does not follow any current or
old standard, we can remove it.
With this removal, the ipv6_opt_cmp function is
now a dead code and it can be removed too.
Changelog to v1:
* add justification for the change
* remove the condition on IPv6 options
[ Remove ipv6_hdr_cmp and it is now unused as well. -DaveM ]
Commit 18367681a10b (ipv6 flowlabel: Convert np->ipv6_fl_list to RCU.)
omitted proper __rcu annotations.
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
This patch fixes the following RCU warning:
[ 51.680236] ===============================
[ 51.681914] [ INFO: suspicious RCU usage. ]
[ 51.683610] 3.8.0-rc6-next-20130206-sasha-00028-g83214f7-dirty #276 Tainted: G W
[ 51.686703] -------------------------------
[ 51.688281] net/ipv6/ip6_flowlabel.c:671 suspicious rcu_dereference_check() usage!
we should use rcu_dereference_bh() when we hold rcu_read_lock_bh().
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
drivers/net/ethernet/intel/e1000e/ethtool.c
drivers/net/vmxnet3/vmxnet3_drv.c
drivers/net/wireless/iwlwifi/dvm/tx.c
net/ipv6/route.c
The ipv6 route.c conflict is simple, just ignore the 'net' side change
as we fixed the same problem in 'net-next' by eliminating cached
neighbours from ipv6 routes.
The e1000e conflict is an addition of a new statistic in the ethtool
code, trivial.
The vmxnet3 conflict is about one change in 'net' removing a guarding
conditional, whilst in 'net-next' we had a netdev_info() conversion.
The iwlwifi conflict is dealing with a WARN_ON() conversion in
'net-next' vs. a revert happening in 'net'.
The datagram_*_ctl functions in net/ipv6/datagram.c are IPv6-specific. Since
datagram_send_ctl is publicly exported it should be appropriately named to
reflect the fact that it's for IPv6 only.
Signed-off-by: Tom Parkin <tparkin@katalix.com>
Signed-off-by: James Chapman <jchapman@katalix.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Settings that merely control a single network device are allowed.
Either the network device is a logical network device where
restrictions make no difference or the network device is hardware NIC
that has been explicity moved from the initial network namespace.
In general policy and network stack state changes are allowed while
resource control is left unchanged.
Allow the SIOCSIFADDR ioctl to add ipv6 addresses.
Allow the SIOCDIFADDR ioctl to delete ipv6 addresses.
Allow the SIOCADDRT ioctl to add ipv6 routes.
Allow the SIOCDELRT ioctl to delete ipv6 routes.
Allow creation of ipv6 raw sockets.
Allow setting the IPV6_JOIN_ANYCAST socket option.
Allow setting the IPV6_FL_A_RENEW parameter of the IPV6_FLOWLABEL_MGR
socket option.
Allow setting the IPV6_TRANSPARENT socket option.
Allow setting the IPV6_HOPOPTS socket option.
Allow setting the IPV6_RTHDRDSTOPTS socket option.
Allow setting the IPV6_DSTOPTS socket option.
Allow setting the IPV6_IPSEC_POLICY socket option.
Allow setting the IPV6_XFRM_POLICY socket option.
Allow sending packets with the IPV6_2292HOPOPTS control message.
Allow sending packets with the IPV6_2292DSTOPTS control message.
Allow sending packets with the IPV6_RTHDRDSTOPTS control message.
Allow setting the multicast routing socket options on non multicast
routing sockets.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, and SIOCDELTUNNEL ioctls for
setting up, changing and deleting tunnels over ipv6.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, SIOCDELTUNNEL ioctls for
setting up, changing and deleting ipv6 over ipv4 tunnels.
Allow the SIOCADDPRL, SIOCDELPRL, SIOCCHGPRL ioctls for adding,
deleting, and changing the potential router list for ISATAP tunnels.
There is a dereference before checking for NULL bug here. Generally
free() functions should accept NULL pointers. For example, fl_create()
can pass a NULL pointer to fl_free() on the error path.
Correct a long standing omission and use struct pid in the owner
field of struct ip6_flowlabel when the share type is IPV6_FL_S_PROCESS.
This guarantees we don't have issues when pid wraparound occurs.
Use a kuid_t in the owner field of struct ip6_flowlabel when the
share type is IPV6_FL_S_USER to add user namespace support.
In /proc/net/ip6_flowlabel capture the current pid namespace when
opening the file and release the pid namespace when the file is
closed ensuring we print the pid owner value that is meaning to
the reader of the file. Similarly use from_kuid_munged to print
uid values that are meaningful to the reader of the file.
This requires exporting pid_nr_ns so that ipv6 can continue to built
as a module. Yoiks what silliness
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Mostly bool conversions, some inline removals and const additions.
For implementing other protocols on top of IPv6, such as L2TPv3's IP
encapsulation over ipv6, we'd like to call some IPv6 functions which
are not currently exported. This patch exports them.
Signed-off-by: Chris Elston <celston@katalix.com>
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
C assignment can handle struct in6_addr copying.
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
Allow transparent sockets to be less restrictive about
the source ip of ipv6 udp packets being sent.
Google-Bug-Id: 5018138
Signed-off-by: Maciej Żenczykowski <maze@google.com>
CC: "Erik Kline" <ek@google.com>
CC: "Lorenzo Colitti" <lorenzo@google.com>
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
Add dontfrag argument to relevant functions for
IPV6_DONTFRAG support, as well as allowing the value
to be passed-in via ancillary cmsg data.
Signed-off-by: Brian Haley <brian.haley@hp.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Generated with the following semantic patch
struct net *n1;
struct net *n2;
- n1 == n2
+ net_eq(n1, n2)
struct net *n1;
struct net *n2;
- n1 != n2
+ !net_eq(n1, n2)
applied over {include,net,drivers/net}.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
