path: root/net/ipv6/ip6_input.c
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: ipv6: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The semantic patch that was used: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_THRESH |nf_hook )( -PF_INET6, +NFPROTO_IPV6, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-02-18ipv6: drop unused "dev" arg of icmpv6_send()Alexey Dobriyan
Dunno, what was the idea, it wasn't used for a long time. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
2009-07-06ipv6: correct return on ipv6_rcv() packet dropMark Smith
The routine ipv6_rcv() uses magic number 0 for a return when it drops a packet. This corresponds to NET_RX_SUCCESS, which is obviously incorrect. Correct this by using NET_RX_DROP instead. ps. It isn't exactly clear who the IPv6 maintainers are, apologies if I've missed any. Signed-off-by: Mark Smith <markzzzsmith@yahoo.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26inet: Call skb_orphan before tproxy activatesHerbert Xu
As transparent proxying looks up the socket early and assigns it to the skb for later processing, we must drop any existing socket ownership prior to that in order to distinguish between the case where tproxy is active and where it is not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27ipv6: Plug sk_buff leak in ipv6_rcv (net/ipv6/ip6_input.c)Jesper Nilsson
Commit 778d80be52699596bf70e0eb0761cf5e1e46088d (ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface) seems to have introduced a leak of sk_buff's for ipv6 traffic, at least in some configurations where idev is NULL, or when ipv6 is disabled via sysctl. The problem is that if the first condition of the if-statement returns non-NULL, it returns an skb with only one reference, and when the other conditions apply, execution jumps to the "out" label, which does not call kfree_skb for it. To plug this leak, change to use the "drop" label instead. (this relies on it being ok to call kfree_skb on NULL) This also allows us to avoid calling rcu_read_unlock here, and removes the only user of the "out" label. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27IPv6: Fix multicast routing bugs.Thomas Goff
This patch addresses the IPv6 multicast routing issues described below. It was tested with XORP 1.4/1.5 as the IPv6 PIM-SM routing daemon against FreeBSD peers. net/ipv6/ip6_input.c: - Don't try to forward link-local multicast packets. - Don't reset skb2->dev before calling ip6_mr_input() so packets can be identified as coming from the PIM register vif properly. net/ipv6/ip6mr.c: - Fix incoming PIM register messages processing: * The IPv6 pseudo-header should be included when checksumming PIM messages (RFC 4601 section 4.9; RFC 3973 section 4.7.1). * Packets decapsulated from PIM register messages should have skb->protocol ETH_P_IPV6. - Enable/disable IPv6 multicast forwarding on the corresponding interface when a routing daemon adds/removes a multicast virtual interface. - Remove incorrect skb_pull() to fix userspace signaling. - Enable/disable global IPv6 multicast forwarding when an IPv6 multicast routing socket is opened/closed. net/ipv6/route.c: - Don't use strict routing logic for packets decapsulated from PIM register messages (similar to disabling rp_filter for the IPv4 case). Signed-off-by: Thomas Goff <thomas.goff@boeing.com> Reviewed-by: Fred Templin <fred.l.templin@boeing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: added net argument to IP6_INC_STATS_BHDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19ipv6 netns: Make several "global" sysctl variables namespace aware.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface.YOSHIFUJI Hideaki
2008-06-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl4965-base.c
2008-06-19ipv6: Drop packets for loopback address from outside of the box.YOSHIFUJI Hideaki
[ Based upon original report and patch by Karsten Keil. Karsten has verified that this fixes the TAHI test case "ICMPv6 test v6LC.5.1.2 Part F". -DaveM ] Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-11[IPV6]: Kill several warnings without CONFIG_IPV6_MROUTE.YOSHIFUJI Hideaki
Pointed out by Andrew Morton <akpm@linux-foundation.org>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-05[IPV6] MROUTE: Support multicast forwarding.YOSHIFUJI Hideaki
Based on ancient patch by Mickael Hoerdt <hoerdt@clarinet.u-strasbg.fr>, which is available at <http://www-r2.u-strasbg.fr/~hoerdt/dev/linux_ipv6_mforwarding/patch-linux-ipv6-mforwarding-0.1a>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/s2io.c
2008-03-31[IPV6] MCAST: Ensure to check multicast listener(s).YOSHIFUJI Hideaki
In ip6_mc_input(), we need to check whether we have listener(s) for the packet. After commit ae7bf20a6316272acfcaef5d265b18aaa54b41e4, all packets for multicast destinations are delivered to upper layer if IFF_PROMISC or IFF_ALLMULTI is set. In fact, bug was rather ancient; the original (before the commit) intent of the dev->flags check was to skip the ipv6_chk_mcast_addr() call, assuming L2 filters packets appropriately, but it was even not true. Let's explicitly check our multicast list. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05[NETNS][IPV6] ip6_input - enable ipv6_rcv to handle several network namespaceDaniel Lezcano
The different subsystem of ipv6 are ready for namespaces, so let's activate it for ipv6_rcv. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPv6] RAW: Compact the API for the kernelPavel Emelyanov
Same as in the previous patch for ipv4, compact the API and hide hash table and rwlock inside the raw.c file. Plus fix some "bad" places from checkpatch.pl point of view (assignments inside if()). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Replace sk_buff ** with sk_buff * in input handlersHerbert Xu
With all the users of the double pointers removed from the IPv6 input path, this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input handlers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Uninline netfilter okfnsPatrick McHardy
Uninline netfilter okfns for those cases where gcc can generate tail-calls. Before: text data bss dec hex filename 8994153 1016524 524652 10535329 a0c1a1 vmlinux After: text data bss dec hex filename 8992761 1016524 524652 10533937 a0bc31 vmlinux ------------------------------------------------------- -1392 All cases have been verified to generate tail-calls with and without netfilter. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Dynamically allocate the loopback device, part 1.Daniel Lezcano
This patch replaces all occurences to the static variable loopback_dev to a pointer loopback_dev. That provides the mindless, trivial, uninteressting change part for the dynamic allocation for the loopback. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-By: Kirill Korotaev <dev@sw.ru> Acked-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-14[IPV6]: Reverse sense of promisc tests in ip6_mc_inputCorey Mutter
Reverse the sense of the promiscuous-mode tests in ip6_mc_input(). Signed-off-by: Corey Mutter <crm-netdev@mutternet.com> Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header_lenArnaldo Carvalho de Melo
For the common sequence "skb->h.raw - skb->nh.raw", similar to skb->mac_len, that is precalculated tho, don't think we need to bloat skb with one more member, so just use this new helper, reducing the number of non-skbuff.h references to the layer headers even more. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-04[IPv6]: Exclude truncated packets from InHdrErrors statisticsMitsuru Chinen
Incoming trancated packets are counted as not only InTruncatedPkts but also InHdrErrors. They should be counted as InTruncatedPkts only. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[IPV6]: Per-interface statistics support.YOSHIFUJI Hideaki
For IP MIB (RFC4293). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-12-02[IPV6]: Introduce ip6_dst_idev() to get inet6_dev{} stored in dst_entry{}.YOSHIFUJI Hideaki
Otherwise, we will see a lot of casts... Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[IPV6]: Allow to replace skbuff by TLV parser.Masahide NAKAMURA
In receiving Mobile IPv6 home address option which is a TLV carried by destination options header, kernel will try to mangle source adderss of packet. Think of cloned skbuff it is required to replace it by the parser just like routing header case. This is a framework to achieve that to allow TLV parser to replace inbound skbuff pointer. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-24[IPV6]: Clean skb cb on IPv6 input.Guillaume Chazarain
Clear the accumulated junk in IP6CB when starting to handle an IPV6 packet. Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-30[IPV6]: Remove redundant length check on inputHerbert Xu
We don't need to check skb->len when we're just about to call pskb_may_pull since that checks it for us. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-18[IPV6]: Clean up hop-by-hop options handler.YOSHIFUJI Hideaki
- Removed unused argument (nhoff) for ipv6_parse_hopopts(). - Make ipv6_parse_hopopts() to align with other extension header handlers. - Removed pointless assignment (hdr), which is not used afterwards. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV4/6]: Netfilter IPsec input hooksPatrick McHardy
When the innermost transform uses transport mode the decapsulated packet is not visible to netfilter. Pass the packet through the PRE_ROUTING and LOCAL_IN hooks again before handing it to upper layer protocols to make netfilter-visibility symetrical to the output path. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV6]: Move nextheader offset to the IP6CBPatrick McHardy
Move nextheader offset to the IP6CB to make it possible to pass a packet to ip6_input_finish multiple times and have it skip already parsed headers. As a nice side effect this gets rid of the manual hopopts skipping in ip6_input_finish. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09[NETFILTER]: Add nf_conntrack subsystem.Yasuyuki Kozakai
The existing connection tracking subsystem in netfilter can only handle ipv4. There were basically two choices present to add connection tracking support for ipv6. We could either duplicate all of the ipv4 connection tracking code into an ipv6 counterpart, or (the choice taken by these patches) we could design a generic layer that could handle both ipv4 and ipv6 and thus requiring only one sub-protocol (TCP, UDP, etc.) connection tracking helper module to be written. In fact nf_conntrack is capable of working with any layer 3 protocol. The existing ipv4 specific conntrack code could also not deal with the pecularities of doing connection tracking on ipv6, which is also cured here. For example, these issues include: 1) ICMPv6 handling, which is used for neighbour discovery in ipv6 thus some messages such as these should not participate in connection tracking since effectively they are like ARP messages 2) fragmentation must be handled differently in ipv6, because the simplistic "defrag, connection track and NAT, refrag" (which the existing ipv4 connection tracking does) approach simply isn't feasible in ipv6 3) ipv6 extension header parsing must occur at the correct spots before and after connection tracking decisions, and there were no provisions for this in the existing connection tracking design 4) ipv6 has no need for stateful NAT The ipv4 specific conntrack layer is kept around, until all of the ipv4 specific conntrack helpers are ported over to nf_conntrack and it is feature complete. Once that occurs, the old conntrack stuff will get placed into the feature-removal-schedule and we will fully kill it off 6 months later. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-08-29[IPV4/6]: Check if packet was actually delivered to a raw socket to decide ↵Patrick McHardy
whether to send an ICMP unreachable Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
