[ Upstream commit 72b43d0898e97f588293b4a24b33c58c46633d81 ]
Linux IPv6 forwards unicast packets, which are link layer multicasts...
The hole was present since day one. I was 100% this check is there, but it is not.
The problem shows itself, f.e. when Microsoft Network Load Balancer runs on a network.
This software resolves IPv6 unicast addresses to multicast MAC addresses.
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
This patch modifies IPsec6 to fragment IPv6 packets that are
locally generated as needed.
This version of the patch only fragments in tunnel mode, so that fragment
headers will not be obscured by ESP in transport mode.
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
drivers/net/qlcnic/qlcnic_init.c
net/ipv4/ip_output.c
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
Special care should be taken when slow path is hit in ip_fragment() :
When walking through frags, we transfert truesize ownership from skb to
frags. Then if we hit a slow_path condition, we must undo this or risk
uncharging frags->truesize twice, and in the end, having negative socket
sk_wmem_alloc counter, or even freeing socket sooner than expected.
Many thanks to Nick Bowler, who provided a very clean bug report and
test program.
Thanks to Jarek for reviewing my first patch and providing a V2
While Nick bisection pointed to commit 2b85a34e911 (net: No more
expensive sock_hold()/sock_put() on each tx), underlying bug is older
(2.6.12-rc5)
A side effect is to extend work done in commit b2722b1c3a893e
(ip_fragment: also adjust skb->truesize for packets not owned by a
socket) to ipv6 as well.
Reported-and-bisected-by: Nick Bowler <nbowler@elliptictech.com>
Tested-by: Nick Bowler <nbowler@elliptictech.com>
CC: Jarek Poplawski <jarkao2@gmail.com>
CC: Patrick McHardy <kaber@trash.net>
SKBs can be "fragmented" in two ways, via a page array (called
skb_shinfo(skb)->frags[]) and via a list of SKBs (called
skb_shinfo(skb)->frag_list).
Since skb_has_frags() tests the latter, it's name is confusing
since it sounds more like it's testing the former.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Currently we disallow GSO packets on the IPv6 forward path.
This patch fixes this.
Note that I discovered that our existing GSO MTU checks (e.g.,
IPv4 forwarding) are buggy in that they skip the check altogether,
when they really should be checking gso_size + header instead.
I have also been lazy here in that I haven't bothered to segment
the GSO packet by hand before generating an ICMP message. Someone
should add that to be 100% correct.
Reported-by: Ralf Baechle <ralf@linux-mips.org>
This patch adds support for multiple independant multicast routing instances,
named "tables".
Userspace multicast routing daemons can bind to a specific table instance by
issuing a setsockopt call using a new option MRT6_TABLE. The table number is
stored in the raw socket data and affects all following ip6mr setsockopt(),
getsockopt() and ioctl() calls. By default, a single table (RT6_TABLE_DFLT)
is created with a default routing rule pointing to it. Newly created pim6reg
devices have the table number appended ("pim6regX"), with the exception of
devices created in the default table, which are named just "pim6reg" for
compatibility reasons.
Packets are directed to a specific table instance using routing rules,
similar to how regular routing rules work. Currently iif, oif and mark
are supported as keys, source and destination addresses could be supported
additionally.
Example usage:
- bind pimd/xorp/... to a specific table:
uint32_t table = 123;
setsockopt(fd, SOL_IPV6, MRT6_TABLE, &table, sizeof(table));
- create routing rules directing packets to the new table:
# ip -6 mrule add iif eth0 lookup 123
# ip -6 mrule add oif eth0 lookup 123
net/bridge/br_device.c
net/bridge/br_forward.c
We dereference "sk" unconditionally elsewhere in the function.
This was left over from: b30bd282 "ip6_xmit: remove unnecessary NULL
ptr check". According to that commit message, "the sk argument to
ip6_xmit is never NULL nowadays since the skb->priority assigment
expects a valid socket."
drivers/net/e100.c
drivers/net/e1000e/netdev.c
Finally add support to detect a local IPV6_DONTFRAG event
and return the relevant data to the user if they've enabled
IPV6_RECVPATHMTU on the socket. The next recvmsg() will
return no data, but have an IPV6_PATHMTU as ancillary data.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Add dontfrag argument to relevant functions for
IPV6_DONTFRAG support, as well as allowing the value
to be passed-in via ancillary cmsg data.
field less than IPV6_MIN_MTU
According to RFC2460, PMTU is set to the IPv6 Minimum Link
MTU (1280) and a fragment header should always be included
after a node receiving Too Big message reporting PMTU is
less than the IPv6 Minimum Link MTU.
After receiving a ICMPv6 Too Big message reporting PMTU is
less than the IPv6 Minimum Link MTU, sctp *can't* send any
data/control chunk that total length including IPv6 head
and IPv6 extend head is less than IPV6_MIN_MTU(1280 bytes).
The failure occured in p6_fragment(), about reason
see following(take SHUTDOWN chunk for example):
sctp_packet_transmit (SHUTDOWN chunk, len=16 byte)
|------sctp_v6_xmit (local_df=0)
|------ip6_xmit
|------ip6_output (dst_allfrag is ture)
|------ip6_fragment
In ip6_fragment(), for local_df=0, drops the the packet
and returns EMSGSIZE.
The patch fixes it with adding check length of skb->len.
In this case, Ipv6 not to fragment upper protocol data,
just only add a fragment header before it.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
drivers/net/wireless/iwlwifi/iwl-6000.c
net/core/dev.c
Documentation/feature-removal-schedule.txt
net/ipv6/netfilter/ip6t_REJECT.c
net/netfilter/xt_limit.c
Since Xtables is now reentrant/nestable, the cloned packet can also go
through Xtables and be subject to rules itself.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
xt_TEE can be used to clone and reroute a packet. This can for
example be used to copy traffic at a router for logging purposes
to another dedicated machine.
References: http://www.gossamer-threads.com/lists/iptables/devel/68781
ip6_xmit() is used by upper transport protocol.
As Herbert Xu said: we should be able to simply replace ipfragok
with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function)
has droped ipfragok and set local_df value properly.
The patch kills the ipfragok parameter of .queue_xmit().
So the change of commit 77e2f1(ipv6: Fix ip6_xmit to
send fragments if ipfragok is true) is not needed.
So the patch remove them.
Eric Paris got following trace with a linux-next kernel
[ 14.203970] BUG: using smp_processor_id() in preemptible [00000000]
code: avahi-daemon/2093
[ 14.204025] caller is netif_rx+0xfa/0x110
[ 14.204035] Call Trace:
[ 14.204064] [<ffffffff81278fe5>] debug_smp_processor_id+0x105/0x110
[ 14.204070] [<ffffffff8142163a>] netif_rx+0xfa/0x110
[ 14.204090] [<ffffffff8145b631>] ip_dev_loopback_xmit+0x71/0xa0
[ 14.204095] [<ffffffff8145b892>] ip_mc_output+0x192/0x2c0
[ 14.204099] [<ffffffff8145d610>] ip_local_out+0x20/0x30
[ 14.204105] [<ffffffff8145d8ad>] ip_push_pending_frames+0x28d/0x3d0
[ 14.204119] [<ffffffff8147f1cc>] udp_push_pending_frames+0x14c/0x400
[ 14.204125] [<ffffffff814803fc>] udp_sendmsg+0x39c/0x790
[ 14.204137] [<ffffffff814891d5>] inet_sendmsg+0x45/0x80
[ 14.204149] [<ffffffff8140af91>] sock_sendmsg+0xf1/0x110
[ 14.204189] [<ffffffff8140dc6c>] sys_sendmsg+0x20c/0x380
[ 14.204233] [<ffffffff8100ad82>] system_call_fastpath+0x16/0x1b
While current linux-2.6 kernel doesnt emit this warning, bug is latent
and might cause unexpected failures.
ip_dev_loopback_xmit() runs in process context, preemption enabled, so
must call netif_rx_ni() instead of netif_rx(), to make sure that we
process pending software interrupt.
Same change for ip6_dev_loopback_xmit()
Reported-by: Eric Paris <eparis@redhat.com>
Similar to how IPv4's ip_output.c works, have ip6_output also check
the IPSKB_REROUTED flag. It will be set from xt_TEE for cloned packets
since Xtables can currently only deal with a single packet in flight
at a time.
[Patrick: changed to use an IP6SKB value instead of IPSKB]
Patrick McHardy notes: "We used to invoke IPv4 POST_ROUTING after
fragmentation as well just to defragment the packets in conntrack
immediately afterwards, but that got changed during the
netfilter-ipsec integration. Ideally IPv6 would behave like IPv4."
This patch makes it so. Sending an oversized frame (e.g. `ping6
-s64000 -c1 ::1`) will now show up in POSTROUTING as a single skb
rather than multiple ones.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The semantic patch that was used:
// <smpl>
(NF_HOOK
|NF_HOOK_THRESH
|nf_hook
-PF_INET6,
+NFPROTO_IPV6,
// </smpl>
Clients will set their MTU to 1280 if they receive a
ICMPV6_PKT_TOOBIG message with an MTU less than 1280.
To allow encapsulating of packets over a 1280 link
we should always accept packets with a size of 1280
for forwarding even if the path has a lower MTU and
fragment the encapsulated packets afterwards.
In case a forwarded packet is not going to be encapsulated
a ICMPV6_PKT_TOOBIG msg will still be send by ip6_fragment()
with the correct MTU.
Signed-off-by: Ulrich Weber <uweber@astaro.com>
Dunno, what was the idea, it wasn't used for a long time.
When we have L3 tunnels with different inner/outer families
(i.e. IPV4/IPV6) which use a multicast address as the outer tunnel
destination address, multicast packets will be loopbacked back to the
sending socket even if IP*_MULTICAST_LOOP is set to disabled.
The mc_loop flag is present in the family specific part of the socket
(e.g. the IPv4 or IPv4 specific part). setsockopt sets the inner
family mc_loop flag. When the packet is pushed through the L3 tunnel
it will eventually be processed by the outer family which if different
will check the flag in a different part of the socket then it was set.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Christoph Lameter pointed out that packet drops at qdisc level where not
accounted in SNMP counters. Only if application sets IP_RECVERR, drops
are reported to user (-ENOBUFS errors) and SNMP counters updated.
IP_RECVERR is used to enable extended reliable error message passing,
but these are not needed to update system wide SNMP stats.
This patch changes things a bit to allow SNMP counters to be updated,
regardless of IP_RECVERR being set or not on the socket.
Example after an UDP tx flood
# netstat -s
IP:
1487048 outgoing packets dropped
Udp:
SndbufErrors: 1487048
send() syscalls, do however still return an OK status, to not
break applications.
Note : send() manual page explicitly says for -ENOBUFS error :
"The output queue for a network interface was full.
This generally indicates that the interface has stopped sending,
but may be caused by transient congestion.
(Normally, this does not occur in Linux. Packets are just silently
dropped when a device queue overflows.) "
This is not true for IP_RECVERR enabled sockets : a send() syscall
that hit a qdisc drop returns an ENOBUFS error.
Many thanks to Christoph, David, and last but not least, Alexey !
qdisc drops should be notified to IP_RECVERR enabled sockets, as done in IPV4.
This replaces assignments of the type "int on LHS" = "u8 on RHS" with
simpler code. The LHS can express all of the unsigned right hand side
values, hence the assigned value can not be negative.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
drivers/net/wireless/orinoco/main.c
- move ipv6_select_ident() inline function to ipv6.h and remove the unused
skb argument
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
- fix gso_size setting for ipv6 fragment to be a multiple of 8 bytes.
After commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
we do not take any more references on sk->sk_refcnt on outgoing packets.
I forgot to delete two __sock_put() from ip_push_pending_frames()
and ip6_push_pending_frames().
Reported-by: Emil S Tantilov <emils.tantilov@gmail.com>
Tested-by: Emil S Tantilov <emils.tantilov@gmail.com>
One of the problem with sock memory accounting is it uses
a pair of sock_hold()/sock_put() for each transmitted packet.
This slows down bidirectional flows because the receive path
also needs to take a refcount on socket and might use a different
cpu than transmit path or transmit completion path. So these
two atomic operations also trigger cache line bounces.
We can see this in tx or tx/rx workloads (media gateways for example),
where sock_wfree() can be in top five functions in profiles.
We use this sock_hold()/sock_put() so that sock freeing
is delayed until all tx packets are completed.
As we also update sk_wmem_alloc, we could offset sk_wmem_alloc
by one unit at init time, until sk_free() is called.
Once sk_free() is called, we atomic_dec_and_test(sk_wmem_alloc)
to decrement initial offset and atomicaly check if any packets
are in flight.
skb_set_owner_w() doesnt call sock_hold() anymore
sock_wfree() doesnt call sock_put() anymore, but check if sk_wmem_alloc
reached 0 to perform the final freeing.
Drawback is that a skb->truesize error could lead to unfreeable sockets, or
even worse, prematurely calling __sk_free() on a live socket.
Nice speedups on SMP. tbench for example, going from 2691 MB/s to 2711 MB/s
on my 8 cpu dev machine, even if tbench was not really hitting sk_refcnt
contention point. 5 % speedup on a UDP transmit workload (depends
on number of flows), lowering TX completion cpu usage.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and
OutMcastOctets:
http://tools.ietf.org/html/rfc4293
But it seems we don't track those in any way that easy to separate from other
protocols. This patch adds those missing counters to the stats file. Tested
successfully by me
With help from Eric Dumazet.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
As the options passed to ip6_append_data may be ephemeral, we need
to duplicate it for corking. This patch applies the simplest fix
which is to memdup all the relevant bits.
Preliminary work to make IPv6 multicast forwarding netns-aware.
Make IPv6 multicast forwarding mroute6_socket per-namespace,
moves it into struct netns_ipv6.
At the moment, mroute6_socket is only referenced in init_net.
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
ifdef out
* struct sk_buff::sp (pointer)
* struct dst_entry::xfrm (pointer)
* struct sock::sk_policy (2 pointers)
Signed-off-by: Denis V. Lunev <den@openvz.org>
This fixes kernel bugzilla 11469: "TUN with 1024 neighbours:
ip6_dst_lookup_tail NULL crash"
dst->neighbour is not necessarily hooked up at this point
in the processing path, so blindly dereferencing it is
the wrong thing to do. This NULL check exists in other
similar paths and this case was just an oversight.
Also fix the completely wrong and confusing indentation
here while we're at it.
Based upon a patch by Evgeniy Polyakov.
