[ Upstream commit 69d2c86766da2ded2b70281f1bf242cb0d58a778 ]
vr.mifi is indirectly controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
net/ipv6/ip6mr.c:1845 ip6mr_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
net/ipv6/ip6mr.c:1919 ip6mr_compat_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
Fix this by sanitizing vr.mifi before using it to index mrt->vif_table'
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[ Upstream commit 848235edb5c93ed086700584c8ff64f6d7fc778d ]
Currently, raw6_sk(sk)->ip6mr_table is set unconditionally during
ip6_mroute_setsockopt(MRT6_TABLE). A subsequent attempt at the same
setsockopt will fail with -ENOENT, since we haven't actually created
that table.
A similar fix for ipv4 was included in commit 5e1859fbcc3c ("ipv4: ipmr:
various fixes and cleanups").
Fixes: d1db275dd3f6 ("ipv6: ip6mr: support multiple tables")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit 4adfa79fc254efb7b0eb3cd58f62c2c3f805f1ba ]
When we dump the ip6mr mfc entries via proc, we initialize an iterator
with the table to dump but we don't clear the cache pointer which might
be initialized from a prior read on the same descriptor that ended. This
can result in lock imbalance (an unnecessary unlock) leading to other
crashes and hangs. Clear the cache pointer like ipmr does to fix the issue.
Thanks for the reliable reproducer.
Here's syzbot's trace:
WARNING: bad unlock balance detected!
4.15.0-rc3+ #128 Not tainted
syzkaller971460/3195 is trying to release lock (mrt_lock) at:
[<000000006898068d>] ipmr_mfc_seq_stop+0xe1/0x130 net/ipv6/ip6mr.c:553
but there are no more locks to release!
1 lock held by syzkaller971460/3195:
#0: (&p->lock){+.+.}, at: [<00000000744a6565>] seq_read+0xd5/0x13d0
fs/seq_file.c:165
stack backtrace:
CPU: 1 PID: 3195 Comm: syzkaller971460 Not tainted 4.15.0-rc3+ #128
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_unlock_imbalance_bug+0x12f/0x140 kernel/locking/lockdep.c:3561
__lock_release kernel/locking/lockdep.c:3775 [inline]
lock_release+0x5f9/0xda0 kernel/locking/lockdep.c:4023
__raw_read_unlock include/linux/rwlock_api_smp.h:225 [inline]
_raw_read_unlock+0x1a/0x30 kernel/locking/spinlock.c:255
traverse+0x3bc/0xa00 fs/seq_file.c:135
seq_read+0x96a/0x13d0 fs/seq_file.c:189
proc_reg_read+0xef/0x170 fs/proc/inode.c:217
do_loop_readv_writev fs/read_write.c:673 [inline]
do_iter_read+0x3db/0x5b0 fs/read_write.c:897
compat_readv+0x1bf/0x270 fs/read_write.c:1140
do_compat_preadv64+0xdc/0x100 fs/read_write.c:1189
C_SYSC_preadv fs/read_write.c:1209 [inline]
compat_SyS_preadv+0x3b/0x50 fs/read_write.c:1203
do_syscall_32_irqs_on arch/x86/entry/common.c:327 [inline]
do_fast_syscall_32+0x3ee/0xf9d arch/x86/entry/common.c:389
entry_SYSENTER_compat+0x51/0x60 arch/x86/entry/entry_64_compat.S:125
RIP: 0023:0xf7f73c79
RSP: 002b:00000000e574a15c EFLAGS: 00000292 ORIG_RAX: 000000000000014d
RAX: ffffffffffffffda RBX: 000000000000000f RCX: 0000000020a3afb0
RDX: 0000000000000001 RSI: 0000000000000067 RDI: 0000000000000000
RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
BUG: sleeping function called from invalid context at lib/usercopy.c:25
in_atomic(): 1, irqs_disabled(): 0, pid: 3195, name: syzkaller971460
INFO: lockdep is turned off.
Google 01/01/2011
Call Trace:
___might_sleep+0x2b2/0x470 kernel/sched/core.c:6060
__might_sleep+0x95/0x190 kernel/sched/core.c:6013
__might_fault+0xab/0x1d0 mm/memory.c:4525
_copy_to_user+0x2c/0xc0 lib/usercopy.c:25
copy_to_user include/linux/uaccess.h:155 [inline]
seq_read+0xcb4/0x13d0 fs/seq_file.c:279
WARNING: CPU: 1 PID: 3195 at lib/usercopy.c:26 _copy_to_user+0xb5/0xc0
lib/usercopy.c:26
Reported-by: syzbot <bot+eceb3204562c41a438fa1f2335e0fe4f6886d669@syzkaller.appspotmail.com>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
This change allows us to later indicate to rtnetlink core that certain
doit functions should be called without acquiring rtnl_mutex.
This change should have no effect, we simply replace the last (now
unused) calcit argument with the new flag.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Add Netlink notifications on cache reports in ip6mr, in addition to the
existing mrt6msg sent to mroute6_sk.
Send RTM_NEWCACHEREPORT notifications to RTNLGRP_IPV6_MROUTE_R.
MSGTYPE, MIF_ID, SRC_ADDR and DST_ADDR Netlink attributes contain the
same data as their equivalent fields in the mrt6msg header.
PKT attribute is the packet sent to mroute6_sk, without the added
mrt6msg header.
Suggested-by: Ryan Halbrook <halbrook@arista.com>
Signed-off-by: Julien Gomes <julien@arista.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
Network devices can allocate reasources and private memory using
netdev_ops->ndo_init(). However, the release of these resources
can occur in one of two different places.
Either netdev_ops->ndo_uninit() or netdev->destructor().
The decision of which operation frees the resources depends upon
whether it is necessary for all netdev refs to be released before it
is safe to perform the freeing.
netdev_ops->ndo_uninit() presumably can occur right after the
NETDEV_UNREGISTER notifier completes and the unicast and multicast
address lists are flushed.
netdev->destructor(), on the other hand, does not run until the
netdev references all go away.
Further complicating the situation is that netdev->destructor()
almost universally does also a free_netdev().
This creates a problem for the logic in register_netdevice().
Because all callers of register_netdevice() manage the freeing
of the netdev, and invoke free_netdev(dev) if register_netdevice()
fails.
If netdev_ops->ndo_init() succeeds, but something else fails inside
of register_netdevice(), it does call ndo_ops->ndo_uninit(). But
it is not able to invoke netdev->destructor().
This is because netdev->destructor() will do a free_netdev() and
then the caller of register_netdevice() will do the same.
However, this means that the resources that would normally be released
by netdev->destructor() will not be.
Over the years drivers have added local hacks to deal with this, by
invoking their destructor parts by hand when register_netdevice()
fails.
Many drivers do not try to deal with this, and instead we have leaks.
Let's close this hole by formalizing the distinction between what
private things need to be freed up by netdev->destructor() and whether
the driver needs unregister_netdevice() to perform the free_netdev().
netdev->priv_destructor() performs all actions to free up the private
resources that used to be freed by netdev->destructor(), except for
free_netdev().
netdev->needs_free_netdev is a boolean that indicates whether
free_netdev() should be done at the end of unregister_netdevice().
Now, register_netdevice() can sanely release all resources after
ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit()
and netdev->priv_destructor().
And at the end of unregister_netdevice(), we invoke
netdev->priv_destructor() and optionally call free_netdev().
Both conflict were simple overlapping changes.
In the kaweth case, Eric Dumazet's skb_cow() bug fix overlapped the
conversion of the driver in net-next to use in-netdev stats.
Andrey Konovalov reported a BUG caused by the ip6mr code which is caused
because we call unregister_netdevice_many for a device that is already
being destroyed. In IPv4's ipmr that has been resolved by two commits
long time ago by introducing the "notify" parameter to the delete
function and avoiding the unregister when called from a notifier, so
let's do the same for ip6mr.
The trace from Andrey:
kernel BUG at net/core/dev.c:6813!
invalid opcode: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 1165 Comm: kworker/u4:3 Not tainted 4.11.0-rc7+ #251
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs
01/01/2011
Workqueue: netns cleanup_net
task: ffff880069208000 task.stack: ffff8800692d8000
RIP: 0010:rollback_registered_many+0x348/0xeb0 net/core/dev.c:6813
RSP: 0018:ffff8800692de7f0 EFLAGS: 00010297
RAX: ffff880069208000 RBX: 0000000000000002 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88006af90569
RBP: ffff8800692de9f0 R08: ffff8800692dec60 R09: 0000000000000000
R10: 0000000000000006 R11: 0000000000000000 R12: ffff88006af90070
R13: ffff8800692debf0 R14: dffffc0000000000 R15: ffff88006af90000
FS: 0000000000000000(0000) GS:ffff88006cb00000(0000)
knlGS:0000000000000000
CR2: 00007fe7e897d870 CR3: 00000000657e7000 CR4: 00000000000006e0
Call Trace:
unregister_netdevice_many.part.105+0x87/0x440 net/core/dev.c:7881
unregister_netdevice_many+0xc8/0x120 net/core/dev.c:7880
ip6mr_device_event+0x362/0x3f0 net/ipv6/ip6mr.c:1346
notifier_call_chain+0x145/0x2f0 kernel/notifier.c:93
__raw_notifier_call_chain kernel/notifier.c:394
raw_notifier_call_chain+0x2d/0x40 kernel/notifier.c:401
call_netdevice_notifiers_info+0x51/0x90 net/core/dev.c:1647
call_netdevice_notifiers net/core/dev.c:1663
rollback_registered_many+0x919/0xeb0 net/core/dev.c:6841
unregister_netdevice_many net/core/dev.c:7880
default_device_exit_batch+0x4fa/0x640 net/core/dev.c:8333
ops_exit_list.isra.4+0x100/0x150 net/core/net_namespace.c:144
cleanup_net+0x5a8/0xb40 net/core/net_namespace.c:463
process_one_work+0xc04/0x1c10 kernel/workqueue.c:2097
worker_thread+0x223/0x19c0 kernel/workqueue.c:2231
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x31/0x40 arch/x86/entry/entry_64.S:430
Code: 3c 32 00 0f 85 70 0b 00 00 48 b8 00 02 00 00 00 00 ad de 49 89
47 78 e9 93 fe ff ff 49 8d 57 70 49 8d 5f 78 eb 9e e8 88 7a 14 fe <0f>
0b 48 8b 9d 28 fe ff ff e8 7a 7a 14 fe 48 b8 00 00 00 00 00
RIP: rollback_registered_many+0x348/0xeb0 RSP: ffff8800692de7f0
---[ end trace e0b29c57e9b3292c ]---
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Refactor inet6_netconf_notify_devconf to take the event as an input arg.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Commit 5e1859fbcc3c ("ipv4: ipmr: various fixes and cleanups") fixed
the issue for ipv4 ipmr:
ip_mroute_setsockopt() & ip_mroute_getsockopt() should not
access/set raw_sk(sk)->ipmr_table before making sure the socket
is a raw socket, and protocol is IGMP
The same fix should be done for ipv6 ipmr as well.
This patch can fix the panic caused by overwriting the same offset
as ipmr_table as in raw_sk(sk) when accessing other type's socket
by ip_mroute_setsockopt().
Signed-off-by: Xin Long <lucien.xin@gmail.com>
All callers of rt6_fill_node pass 0 for nowait arg. Remove the arg and
simplify rt6_fill_node accordingly.
rt6_fill_node passes the nowait of 0 to ip6mr_get_route. Remove the
nowait arg from it as well.
While working with ipmr, we noticed that it is impossible to determine
if an entry is actually unresolved or its IIF interface has disappeared
(e.g. virtual interface got deleted). These entries look almost
identical to user-space when dumping or receiving notifications. So in
order to recognize them add a new RTNH_F_UNRESOLVED flag which is set when
sending an unresolved cache entry to user-space.
Suggested-by: Roopa Prabhu <roopa@cumulusnetworks.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Since the commit below the ipmr/ip6mr rtnl_unicast() code uses the portid
instead of the previous dst_pid which was copied from in_skb's portid.
Since the skb is new the portid is 0 at that point so the packets are sent
to the kernel and we get scheduling while atomic or a deadlock (depending
on where it happens) by trying to acquire rtnl two times.
Also since this is RTM_GETROUTE, it can be triggered by a normal user.
Here's the sleeping while atomic trace:
[ 7858.212557] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:620
[ 7858.212748] in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper/0
[ 7858.212881] 2 locks held by swapper/0/0:
[ 7858.213013] #0: (((&mrt->ipmr_expire_timer))){+.-...}, at: [<ffffffff810fbbf5>] call_timer_fn+0x5/0x350
[ 7858.213422] #1: (mfc_unres_lock){+.....}, at: [<ffffffff8161e005>] ipmr_expire_process+0x25/0x130
[ 7858.213807] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.8.0-rc7+ #179
[ 7858.213934] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 7858.214108] 0000000000000000 ffff88005b403c50 ffffffff813a7804 0000000000000000
[ 7858.214412] ffffffff81a1338e ffff88005b403c78 ffffffff810a4a72 ffffffff81a1338e
[ 7858.214716] 000000000000026c 0000000000000000 ffff88005b403ca8 ffffffff810a4b9f
[ 7858.215251] Call Trace:
[ 7858.215412] <IRQ> [<ffffffff813a7804>] dump_stack+0x85/0xc1
[ 7858.215662] [<ffffffff810a4a72>] ___might_sleep+0x192/0x250
[ 7858.215868] [<ffffffff810a4b9f>] __might_sleep+0x6f/0x100
[ 7858.216072] [<ffffffff8165bea3>] mutex_lock_nested+0x33/0x4d0
[ 7858.216279] [<ffffffff815a7a5f>] ? netlink_lookup+0x25f/0x460
[ 7858.216487] [<ffffffff8157474b>] rtnetlink_rcv+0x1b/0x40
[ 7858.216687] [<ffffffff815a9a0c>] netlink_unicast+0x19c/0x260
[ 7858.216900] [<ffffffff81573c70>] rtnl_unicast+0x20/0x30
[ 7858.217128] [<ffffffff8161cd39>] ipmr_destroy_unres+0xa9/0xf0
[ 7858.217351] [<ffffffff8161e06f>] ipmr_expire_process+0x8f/0x130
[ 7858.217581] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217785] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.217990] [<ffffffff810fbc95>] call_timer_fn+0xa5/0x350
[ 7858.218192] [<ffffffff810fbbf5>] ? call_timer_fn+0x5/0x350
[ 7858.218415] [<ffffffff8161dfe0>] ? ipmr_net_init+0x180/0x180
[ 7858.218656] [<ffffffff810fde10>] run_timer_softirq+0x260/0x640
[ 7858.218865] [<ffffffff8166379b>] ? __do_softirq+0xbb/0x54f
[ 7858.219068] [<ffffffff816637c8>] __do_softirq+0xe8/0x54f
[ 7858.219269] [<ffffffff8107a948>] irq_exit+0xb8/0xc0
[ 7858.219463] [<ffffffff81663452>] smp_apic_timer_interrupt+0x42/0x50
[ 7858.219678] [<ffffffff816625bc>] apic_timer_interrupt+0x8c/0xa0
[ 7858.219897] <EOI> [<ffffffff81055f16>] ? native_safe_halt+0x6/0x10
[ 7858.220165] [<ffffffff810d64dd>] ? trace_hardirqs_on+0xd/0x10
[ 7858.220373] [<ffffffff810298e3>] default_idle+0x23/0x190
[ 7858.220574] [<ffffffff8102a20f>] arch_cpu_idle+0xf/0x20
[ 7858.220790] [<ffffffff810c9f8c>] default_idle_call+0x4c/0x60
[ 7858.221016] [<ffffffff810ca33b>] cpu_startup_entry+0x39b/0x4d0
[ 7858.221257] [<ffffffff8164f995>] rest_init+0x135/0x140
[ 7858.221469] [<ffffffff81f83014>] start_kernel+0x50e/0x51b
[ 7858.221670] [<ffffffff81f82120>] ? early_idt_handler_array+0x120/0x120
[ 7858.221894] [<ffffffff81f8243f>] x86_64_start_reservations+0x2a/0x2c
[ 7858.222113] [<ffffffff81f8257c>] x86_64_start_kernel+0x13b/0x14a
Fixes: 2942e9005056 ("[RTNETLINK]: Use rtnl_unicast() for rtnetlink unicasts")
When I introduced the lastuse member I made a subtle error because it was
returned as an absolute value but that is meaningless to user-space as it
doesn't allow to see how old exactly an entry is. Let's make it similar to
how the bridge returns such values and make it relative to "now" (jiffies).
This allows us to show the actual age of the entries and is much more
useful (e.g. user-space daemons can age out entries, iproute2 can display
the lastuse properly).
Fixes: 43b9e1274060 ("net: ipmr/ip6mr: add support for keeping an entry age")
Reported-by: Satish Ashok <sashok@cumulusnetworks.com>
Currently lastuse is updated on entry creation and cache hit, but it should
also be updated on entry change. Since both on add and update the ttl array
is updated we can simply update the lastuse in ipmr_update_thresholds.
CC: Roopa Prabhu <roopa@cumulusnetworks.com>
CC: Donald Sharp <sharpd@cumulusnetworks.com>
CC: David S. Miller <davem@davemloft.net>
In preparation for hardware offloading of ipmr/ip6mr we need an
interface that allows to check (and later update) the age of entries.
Relying on stats alone can show activity but not actual age of the entry,
furthermore when there're tens of thousands of entries a lot of the
hardware implementations only support "hit" bits which are cleared on
read to denote that the entry was active and shouldn't be aged out,
these can then be naturally translated into age timestamp and will be
compatible with the software forwarding age. Using a lastuse entry doesn't
affect performance because the members in that cache line are written to
along with the age.
Since all new users are encouraged to use ipmr via netlink, this is
exported via the RTA_EXPIRES attribute.
Also do a minor local variable declaration style adjustment - arrange them
longest to shortest.
CC: Shrijeet Mukherjee <shm@cumulusnetworks.com>
CC: Satish Ashok <sashok@cumulusnetworks.com>
CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
CC: James Morris <jmorris@namei.org>
CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
CC: Patrick McHardy <kaber@trash.net>
All inet6_netconf_notify_devconf() callers are in process context,
so we can use GFP_KERNEL allocations if we take care of not holding
a rwlock while not needed in ip6mr (we hold RTNL there)
Fixes: d67b8c616b48 ("netconf: advertise mc_forwarding status")
Fixes: f3a1bfb11ccb ("rtnl/ipv6: use netconf msg to advertise forwarding status")
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
This fixes wrong-interface signaling on 32-bit platforms for entries
created when jiffies > 2^31 + MFC_ASSERT_THRESH.
Signed-off-by: Tom Goff <thomas.goff@ll.mit.edu>
Rename IP6_INC_STATS_BH() to __IP6_INC_STATS()
and IP6_ADD_STATS_BH() to __IP6_ADD_STATS()
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Since (at least) commit b17a7c179dd3 ("[NET]: Do sysfs registration as
part of register_netdevice."), netdev_run_todo() deals only with
unregistration, so we don't need to do the rtnl_unlock/lock cycle to
finish registration when failing pimreg or dvmrp device creation. In
fact that opens a race condition where someone can delete the device
while rtnl is unlocked because it's fully registered. The problem gets
worse when netlink support is introduced as there are more points of entry
that can cause it and it also makes reusing that code correctly impossible.
Reviewed-by: Cong Wang <cwang@twopensource.com>
Similar to ipv4, when destroying an mrt table the static mfc entries and
the static devices are kept, which leads to devices that can never be
destroyed (because of refcnt taken) and leaked memory. Make sure that
everything is cleaned up on netns destruction.
Fixes: 8229efdaef1e ("netns: ip6mr: enable namespace support in ipv6 multicast forwarding code")
CC: Benjamin Thery <benjamin.thery@bull.net>
Replace dst_output_okfn with dst_output
This is immediately motivated by the bridge code that chains functions that
call into netfilter. Without passing net into the okfns the bridge code would
need to guess about the best expression for the network namespace to process
packets in.
As net is frequently one of the first things computed in continuation functions
after netfilter has done it's job passing in the desired network namespace is in
many cases a code simplification.
To support this change the function dst_output_okfn is introduced to
simplify passing dst_output as an okfn. For the moment dst_output_okfn
just silently drops the struct net.
Pass a network namespace parameter into the netfilter hooks. At the
call site of the netfilter hooks the path a packet is taking through
the network stack is well known which allows the network namespace to
be easily and reliabily.
This allows the replacement of magic code like
"dev_net(state->in?:state->out)" that appears at the start of most
netfilter hooks with "state->net".
In almost all cases the network namespace passed in is derived
from the first network device passed in, guaranteeing those
paths will not see any changes in practice.
The exceptions are:
xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm)
ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp)
ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp)
ipv4/raw.c:raw_send_hdrinc() sock_net(sk)
ipv6/ip6_output.c:ip6_xmit() sock_net(sk)
ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev)
ipv6/raw.c:raw6_send_hdrinc() sock_net(sk)
br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev
In all cases these exceptions seem to be a better expression for the
network namespace the packet is being processed in then the historic
"dev_net(in?in:out)". I am documenting them in case something odd
pops up and someone starts trying to track down what happened.
Add a sock paramter to dst_output making dst_output_sk superfluous.
Add a skb->sk parameter to all of the callers of dst_output
Have the callers of dst_output_sk call dst_output.
This switches IPv6 policy routing to use the shared
fib_default_rule_pref() function of IPv4 and DECnet. It is also used in
multicast routing for IPv4 as well as IPv6.
The motivation for this patch is a complaint about iproute2 behaving
inconsistent between IPv4 and IPv6 when adding policy rules: Formerly,
IPv6 rules were assigned a fixed priority of 0x3FFF whereas for IPv4 the
assigned priority value was decreased with each rule added.
Since then all users of the default_pref field have been converted to
assign the generic function fib_default_rule_pref(), fib_nl_newrule()
may just use it directly instead. Therefore get rid of the function
pointer altogether and make fib_default_rule_pref() static, as it's not
used outside fib_rules.c anymore.
Signed-off-by: Phil Sutter <phil@nwl.cc>
In the IPv6 multicast routing code the mrt_lock was not being released
correctly in the MFC iterator, as a result adding or deleting a MIF would
cause a hang because the mrt_lock could not be acquired.
This fix is a copy of the code for the IPv4 case and ensures that the lock
is released correctly.
Signed-off-by: Richard Laing <richard.laing@alliedtelesis.co.nz>
Acked-by: Cong Wang <cwang@twopensource.com>
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
drivers/net/ethernet/mellanox/mlx4/cmd.c
net/core/fib_rules.c
net/ipv4/fib_frontend.c
The fib_rules.c and fib_frontend.c conflicts were locking adjustments
in 'net' overlapping addition and removal of code in 'net-next'.
The mlx4 conflict was a bug fix in 'net' happening in the same
place a constant was being replaced with a more suitable macro.
We need to wait for the flying timers, since we
are going to free the mrtable right after it.
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
We have to hold rtnl lock for fib_rules_unregister()
otherwise the following race could happen:
fib_rules_unregister(): fib_nl_delrule():
... ops = lookup_rules_ops();
list_del_rcu(&ops->list);
list_for_each_entry(ops->rules) {
fib_rules_cleanup_ops(ops); ...
list_del_rcu(); list_del_rcu();
Note, net->rules_mod_lock is actually not needed at all,
either upper layer netns code or rtnl lock guarantees
we are safe.
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
Cc: Thomas Graf <tgraf@suug.ch>
drivers/net/usb/asix_common.c
drivers/net/usb/sr9800.c
drivers/net/usb/usbnet.c
include/linux/usb/usbnet.h
net/ipv4/tcp_ipv4.c
net/ipv6/tcp_ipv6.c
The TCP conflicts were overlapping changes. In 'net' we added a
READ_ONCE() to the socket cached RX route read, whilst in 'net-next'
Eric Dumazet touched the surrounding code dealing with how mini
sockets are handled.
With USB, it's a case of the same bug fix first going into net-next
and then I cherry picked it back into net.
Don't use dev->iflink anymore.
The goal of this patch is to prepare the removal of the iflink field. It
introduces a new ndo function, which will be implemented by virtual interfaces.
There is no functional change into this patch. All readers of iflink field
now call dev_get_iflink().
IP addresses are often stored in netlink attributes. Add generic functions
to do that.
For nla_put_in_addr, it would be nicer to pass struct in_addr but this is
not used universally throughout the kernel, in way too many places __be32 is
used to store IPv4 address.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
Having to say
> #ifdef CONFIG_NET_NS
> struct net *net;
> #endif
in structures is a little bit wordy and a little bit error prone.
Instead it is possible to say:
> typedef struct {
> struct net *net;
> #endif
> } possible_net_t;
And then in a header say:
> possible_net_t net;
Which is cleaner and easier to use and easier to test, as the
possible_net_t is always there no matter what the compile options.
Further this allows read_pnet and write_pnet to be functions in all
cases which is better at catching typos.
This change adds possible_net_t, updates the definitions of read_pnet
and write_pnet, updates optional struct net * variables that
write_pnet uses on to have the type possible_net_t, and finally fixes
up the b0rked users of read_pnet and write_pnet.
Contrary to common expectations for an "int" return, these functions
return only a positive value -- if used correctly they cannot even
return 0 because the message header will necessarily be in the skb.
This makes the very common pattern of
if (genlmsg_end(...) < 0) { ... }
be a whole bunch of dead code. Many places also simply do
return nlmsg_end(...);
and the caller is expected to deal with it.
This also commonly (at least for me) causes errors, because it is very
common to write
if (my_function(...))
/* error condition */
and if my_function() does "return nlmsg_end()" this is of course wrong.
Additionally, there's not a single place in the kernel that actually
needs the message length returned, and if anyone needs it later then
it'll be very easy to just use skb->len there.
Remove this, and make the functions void. This removes a bunch of dead
code as described above. The patch adds lines because I did
- return nlmsg_end(...);
+ nlmsg_end(...);
+ return 0;
I could have preserved all the function's return values by returning
skb->len, but instead I've audited all the places calling the affected
functions and found that none cared. A few places actually compared
the return value with <= 0 in dump functionality, but that could just
be changed to < 0 with no change in behaviour, so I opted for the more
efficient version.
One instance of the error I've made numerous times now is also present
in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't
check for <0 or <=0 and thus broke out of the loop every single time.
I've preserved this since it will (I think) have caused the messages to
userspace to be formatted differently with just a single message for
every SKB returned to userspace. It's possible that this isn't needed
for the tools that actually use this, but I don't even know what they
are so couldn't test that changing this behaviour would be acceptable.
drivers/net/ieee802154/fakehard.c
A bug fix went into 'net' for ieee802154/fakehard.c, which is removed
in 'net-next'.
Add build fix into the merge from Stephen Rothwell in openvswitch, the
logging macros take a new initial 'log' argument, a new call was added
in 'net' so when we merge that in here we have to explicitly add the
new 'log' arg to it else the build fails.
pim6_protocol was added when initiation, but it not deleted.
Similarly, unregister RTNL_FAMILY_IP6MR rtnetlink.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
