[ Upstream commit 87c11f1ddbbad38ad8bad47af133a8208985fbdf ]
Similar to commit 44f49dd8b5a6 ("ipmr: fix possible race resulting from
improper usage of IP_INC_STATS_BH() in preemptible context."), we cannot
assume preemption is disabled when incrementing the counter and
accessing a per-CPU variable.
Preemption can be enabled when we add a route in process context that
corresponds to packets stored in the unresolved queue, which are then
forwarded using this route [1].
Fix this by using IP6_INC_STATS() which takes care of disabling
preemption on architectures where it is needed.
[1]
[ 157.451447] BUG: using __this_cpu_add() in preemptible [00000000] code: smcrouted/2314
[ 157.460409] caller is ip6mr_forward2+0x73e/0x10e0
[ 157.460434] CPU: 3 PID: 2314 Comm: smcrouted Not tainted 5.0.0-rc7-custom-03635-g22f2712113f1 #1336
[ 157.460449] Hardware name: Mellanox Technologies Ltd. MSN2100-CB2FO/SA001017, BIOS 5.6.5 06/07/2016
[ 157.460461] Call Trace:
[ 157.460486] dump_stack+0xf9/0x1be
[ 157.460553] check_preemption_disabled+0x1d6/0x200
[ 157.460576] ip6mr_forward2+0x73e/0x10e0
[ 157.460705] ip6_mr_forward+0x9a0/0x1510
[ 157.460771] ip6mr_mfc_add+0x16b3/0x1e00
[ 157.461155] ip6_mroute_setsockopt+0x3cb/0x13c0
[ 157.461384] do_ipv6_setsockopt.isra.8+0x348/0x4060
[ 157.462013] ipv6_setsockopt+0x90/0x110
[ 157.462036] rawv6_setsockopt+0x4a/0x120
[ 157.462058] __sys_setsockopt+0x16b/0x340
[ 157.462198] __x64_sys_setsockopt+0xbf/0x160
[ 157.462220] do_syscall_64+0x14d/0x610
[ 157.462349] entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 0912ea38de61 ("[IPV6] MROUTE: Add stats in multicast routing module method ip6_mr_forward().")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Amit Cohen <amitc@mellanox.com>
When the MC route socket is closed, mroute_clean_tables() is called to
cleanup existing routes. Mistakenly notifiers call was put on the cleanup
of the unresolved MC route entries cache.
In a case where the MC socket closes before an unresolved route expires,
the notifier call leads to a crash, caused by the driver trying to
increment a non initialized refcount_t object [1] and then when handling
is done, to decrement it [2]. This was detected by a test recently added in
commit 6d4efada3b82 ("selftests: forwarding: Add multicast routing test").
Fix that by putting notifiers call on the resolved entries traversal,
instead of on the unresolved entries traversal.
[1]
[ 245.748967] refcount_t: increment on 0; use-after-free.
[ 245.754829] WARNING: CPU: 3 PID: 3223 at lib/refcount.c:153 refcount_inc_checked+0x2b/0x30
[ 245.802357] Hardware name: Mellanox Technologies Ltd. MSN2740/SA001237, BIOS 5.6.5 06/07/2016
[ 245.811873] RIP: 0010:refcount_inc_checked+0x2b/0x30
[ 245.907487] Call Trace:
[ 245.910231] mlxsw_sp_router_fib_event.cold.181+0x42/0x47 [mlxsw_spectrum]
[ 245.917913] notifier_call_chain+0x45/0x7
[ 245.922484] atomic_notifier_call_chain+0x15/0x20
[ 245.927729] call_fib_notifiers+0x15/0x30
[ 245.932205] mroute_clean_tables+0x372/0x3f
[ 245.936971] ip6mr_sk_done+0xb1/0xc0
[ 245.940960] ip6_mroute_setsockopt+0x1da/0x5f0
[2]
[ 246.128487] refcount_t: underflow; use-after-free.
[ 246.133859] WARNING: CPU: 0 PID: 7 at lib/refcount.c:187 refcount_sub_and_test_checked+0x4c/0x60
[ 246.183521] Hardware name: Mellanox Technologies Ltd. MSN2740/SA001237, BIOS 5.6.5 06/07/2016
[ 246.193062] Workqueue: mlxsw_core_ordered mlxsw_sp_router_fibmr_event_work [mlxsw_spectrum]
[ 246.202394] RIP: 0010:refcount_sub_and_test_checked+0x4c/0x60
[ 246.298889] Call Trace:
[ 246.301617] refcount_dec_and_test_checked+0x11/0x20
[ 246.307170] mlxsw_sp_router_fibmr_event_work.cold.196+0x47/0x78 [mlxsw_spectrum]
[ 246.315531] process_one_work+0x1fa/0x3f0
[ 246.320005] worker_thread+0x2f/0x3e0
[ 246.324083] kthread+0x118/0x130
[ 246.327683] ? wq_update_unbound_numa+0x1b0/0x1b0
[ 246.332926] ? kthread_park+0x80/0x80
[ 246.337013] ret_from_fork+0x1f/0x30
Fixes: 088aa3eec2ce ("ip6mr: Support fib notifications")
Signed-off-by: Nir Dotan <nird@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
KMSAN detected read beyond end of buffer in vti and sit devices when
passing truncated packets with PF_PACKET. The issue affects additional
ip tunnel devices.
Extend commit 76c0ddd8c3a6 ("ip6_tunnel: be careful when accessing the
inner header") and commit ccfec9e5cb2d ("ip_tunnel: be careful when
accessing the inner header").
Move the check to a separate helper and call at the start of each
ndo_start_xmit function in net/ipv4 and net/ipv6.
Minor changes:
- convert dev_kfree_skb to kfree_skb on error path,
as dev_kfree_skb calls consume_skb which is not for error paths.
- use pskb_network_may_pull even though that is pedantic here,
as the same as pskb_may_pull for devices without llheaders.
- do not cache ipv6 hdrs if used only once
(unsafe across pskb_may_pull, was more relevant to earlier patch)
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Lots of conflicts, by happily all cases of overlapping
changes, parallel adds, things of that nature.
Thanks to Stephen Rothwell, Saeed Mahameed, and others
for their guidance in these resolutions.
mfc6_cache is not needed by ip6mr_forward2 so drop it from the input
argument list.
Signed-off-by: David Ahern <dsahern@gmail.com>
vr.mifi is indirectly controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
net/ipv6/ip6mr.c:1845 ip6mr_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
net/ipv6/ip6mr.c:1919 ip6mr_compat_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
Fix this by sanitizing vr.mifi before using it to index mrt->vif_table'
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
In order to pass extack together with NETDEV_PRE_UP notifications, it's
necessary to route the extack to __dev_open() from diverse (possibly
indirect) callers. One prominent API through which the notification is
invoked is dev_open().
Therefore extend dev_open() with and extra extack argument and update
all users. Most of the calls end up just encoding NULL, but bond and
team drivers have the extack readily available.
Signed-off-by: Petr Machata <petrm@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
When doing a route dump across all address families, do not error out
if the table does not exist. This allows a route dump for AF_UNSPEC
with a table id that may only exist for some of the families.
Do return the table does not exist error if dumping routes for a
specific family and the table does not exist.
Update parsing of route dump request to enable kernel side filtering.
Allow filtering results by protocol (e.g., which routing daemon installed
the route), route type (e.g., unicast), table id and nexthop device. These
amount to the low hanging fruit, yet a huge improvement, for dumping
routes.
ip_valid_fib_dump_req is called with RTNL held, so __dev_get_by_index can
be used to look up the device index without taking a reference. From
there filter->dev is only used during dump loops with the lock still held.
Set NLM_F_DUMP_FILTERED in the answer_flags so the user knows the results
have been filtered should no entries be returned.
Implement kernel side filtering of routes by egress device index and
table id. If the table id is given in the filter, lookup table and
call mr_table_dump directly for it.
Add struct fib_dump_filter for options on limiting which routes are
returned in a dump request. The current list is table id, protocol,
route type, rtm_flags and nexthop device index. struct net is needed
to lookup the net_device from the index.
Declare the filter for each route dump handler and plumb the new
arguments from dump handlers to ip_valid_fib_dump_req.
Add helper to check netlink message for route dumps. If the strict flag
is set the dump request is expected to have an rtmsg struct as the header.
All elements of the struct are expected to be 0 with the exception of
rtm_flags (which is used by both ipv4 and ipv6 dumps) and no attributes
can be appended. rtm_flags can only have RTM_F_CLONED and RTM_F_PREFIX
set.
Update inet_dump_fib, inet6_dump_fib, mpls_dump_routes, ipmr_rtm_dumproute,
and ip6mr_rtm_dumproute to call this helper if strict data checking is
enabled.
The code to obtain the correct table for the incoming interface was
missing for IPv6. This has been added along with the table creation
notification to fib rules for the RTNL_FAMILY_IP6MR address family.
Signed-off-by: Patrick Ruddy <pruddy@vyatta.att-mail.com>
Signed-off-by: Mike Manning <mmanning@vyatta.att-mail.com>
Due to the use of rhashtables in net namespaces,
rhashtable.h is included in lots of the kernel,
so a small changes can required a large recompilation.
This makes development painful.
This patch splits out rhashtable-types.h which just includes
the major type declarations, and does not include (non-trivial)
inline code. rhashtable.h is no longer included by anything
in the include/ directory.
Common include files only include rhashtable-types.h so a large
recompilation is only triggered when that changes.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: NeilBrown <neilb@suse.com>
Pull networking updates from David Miller:
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
commit 0bbbf0e7d0e7 ("ipmr, ip6mr: Unite creation of new mr_table")
refactored ipmr_new_table, so that it now returns NULL when
mr_table_alloc fails. Unfortunately, all callers of ipmr_new_table
expect an ERR_PTR.
This can result in NULL deref, for example when ipmr_rules_exit calls
ipmr_free_table with NULL net->ipv4.mrt in the
!CONFIG_IP_MROUTE_MULTIPLE_TABLES version.
This patch makes mr_table_alloc return errors, and changes
ip6mr_new_table and its callers to return/expect error pointers as
well. It also removes the version of mr_table_alloc defined under
!CONFIG_IP_MROUTE_COMMON, since it is never used.
Fixes: 0bbbf0e7d0e7 ("ipmr, ip6mr: Unite creation of new mr_table")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Currently, raw6_sk(sk)->ip6mr_table is set unconditionally during
ip6_mroute_setsockopt(MRT6_TABLE). A subsequent attempt at the same
setsockopt will fail with -ENOENT, since we haven't actually created
that table.
A similar fix for ipv4 was included in commit 5e1859fbcc3c ("ipv4: ipmr:
various fixes and cleanups").
Fixes: d1db275dd3f6 ("ipv6: ip6mr: support multiple tables")
Variants of proc_create{,_data} that directly take a struct seq_operations
and deal with network namespaces in ->open and ->release. All callers of
proc_create + seq_open_net converted over, and seq_{open,release}_net are
removed entirely.
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Synchronous pernet_operations are not allowed anymore.
All are asynchronous. So, drop the structure member.
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Since ipmr and ip6mr are using the same mr_mfc struct at their core, we
can now refactor the ipmr_cache_{hold,put} logic and apply refcounting
to both ipmr and ip6mr.
Signed-off-by: Yuval Mintz <yuvalm@mellanox.com>
Add the ability to discern whether a given FIB rule notification relates
to the default rule inserted when registering ip6mr or a different one.
Would later be used by drivers wishing to offload ipv6 multicast routes
but unable to offload rules other than the default one.
In similar fashion to ipmr, support fib notifications for ip6mr mfc and
vif related events. This would later allow drivers to react to said
notifications and offload the IPv6 mroutes.
Kirill found that recently added synchronize_rcu() call in
ip6mr_sk_done()
was slowing down netns dismantle and posted a patch to use it only if
the socket
was found.
I instead suggested to get rid of this call, and use instead
SOCK_RCU_FREE
We might later change IPv4 side to use the same technique and unify
both stacks. IPv4 does not use synchronize_rcu() but has a call_rcu()
that could be replaced by SOCK_RCU_FREE.
Tested:
time for i in {1..1000}; do unshare -n /bin/false;done
Before : real 7m18.911s
After : real 10.187s
Fixes: 8571ab479a6e ("ip6mr: Make mroute_sk rcu-based")
Reported-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Yuval Mintz <yuvalm@mellanox.com>
Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com>
The various MFC entries are being held in the same kind of mr_tables
for both ipmr and ip6mr, and their traversal logic is identical.
Also, with the exception of the addresses [and other small tidbits]
the major bulk of the nla setting is identical.
Unite as much of the dumping as possible between the two.
Notice this requires creating an mr_table iterator for each, as the
for-each preprocessor macro can't be used by the common logic.
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
MFC_NOTIFY exists in ip6mr, probably as some legacy code
[was already removed for ipmr in commit
06bd6c0370bb ("net: ipmr: remove unused MFC_NOTIFY flag and make the flags enum").
Remove it from ip6mr as well, and move the enum into a common file;
Notice MFC_OFFLOAD is currently only used by ipmr.
Same as previously done with the mfc seq, the logic for the vif seq is
refactored to be shared between ipmr and ip6mr.
With the exception of the final dump, ipmr and ip6mr have the exact same
seq logic for traversing a given mr_table. Refactor that code and make
it common.
ipmr and ip6mr utilize the exact same methods for searching the
hashed resolved connections, difference being only in the construction
of the hash comparison key.
In order to unite the flow, introduce an mr_table operation set that
would contain the protocol specific information required for common
flows, in this case - the hash parameters and a comparison key
representing a (*,*) route.
mfc_cache and mfc6_cache are almost identical - the main difference is
in the origin/group addresses and comparison-key. Make a common
structure encapsulating most of the multicast routing logic - mr_mfc
and convert both ipmr and ip6mr into using it.
For easy conversion [casting, in this case] mr_mfc has to be the first
field inside every multicast routing abstraction utilizing it.
Now that both ipmr and ip6mr are using the same mr_table structure,
we can have a common function to allocate & initialize a new instance.
Following previous changes to ip6mr, mr_table and mr6_table are
basically the same [up to mr6_table having additional '6' suffixes to
its variable names].
Move the common structure definition into a common header; This
requires renaming all references in ip6mr to variables that had the
distinct suffix.
Since commit 8fb472c09b9d ("ipmr: improve hash scalability") ipmr has
been using rhashtable as a basis for its mfc routes, but ip6mr is
currently still using the old private MFC hash implementation.
Align ip6mr to the current ipmr implementation.
In ipmr the mr_table socket is handled under RCU. Introduce the same
for ip6mr.
The two implementations have almost identical structures - vif_device and
mif_device. As a step toward uniforming the mr_tables, eliminate the
mif_device and relocate the vif_device definition into a new common
header file.
Also, introduce a common initializing function for setting most of the
vif_device fields in a new common source file. This requires modifying
the ipv{4,6] Kconfig and ipv4 makefile as we're introducing a new common
config option - CONFIG_IP_MROUTE_COMMON.
These pernet_operations create and destroy /proc entries,
populate and depopulate net::rules_ops and multiroute table.
All the structures are pernet, and they are not touched
by foreign net pernet_operations. So, it's possible to mark
them async.
When we dump the ip6mr mfc entries via proc, we initialize an iterator
with the table to dump but we don't clear the cache pointer which might
be initialized from a prior read on the same descriptor that ended. This
can result in lock imbalance (an unnecessary unlock) leading to other
crashes and hangs. Clear the cache pointer like ipmr does to fix the issue.
Thanks for the reliable reproducer.
Here's syzbot's trace:
WARNING: bad unlock balance detected!
4.15.0-rc3+ #128 Not tainted
syzkaller971460/3195 is trying to release lock (mrt_lock) at:
[<000000006898068d>] ipmr_mfc_seq_stop+0xe1/0x130 net/ipv6/ip6mr.c:553
but there are no more locks to release!
1 lock held by syzkaller971460/3195:
#0: (&p->lock){+.+.}, at: [<00000000744a6565>] seq_read+0xd5/0x13d0
fs/seq_file.c:165
stack backtrace:
CPU: 1 PID: 3195 Comm: syzkaller971460 Not tainted 4.15.0-rc3+ #128
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_unlock_imbalance_bug+0x12f/0x140 kernel/locking/lockdep.c:3561
__lock_release kernel/locking/lockdep.c:3775 [inline]
lock_release+0x5f9/0xda0 kernel/locking/lockdep.c:4023
__raw_read_unlock include/linux/rwlock_api_smp.h:225 [inline]
_raw_read_unlock+0x1a/0x30 kernel/locking/spinlock.c:255
traverse+0x3bc/0xa00 fs/seq_file.c:135
seq_read+0x96a/0x13d0 fs/seq_file.c:189
proc_reg_read+0xef/0x170 fs/proc/inode.c:217
do_loop_readv_writev fs/read_write.c:673 [inline]
do_iter_read+0x3db/0x5b0 fs/read_write.c:897
compat_readv+0x1bf/0x270 fs/read_write.c:1140
do_compat_preadv64+0xdc/0x100 fs/read_write.c:1189
C_SYSC_preadv fs/read_write.c:1209 [inline]
compat_SyS_preadv+0x3b/0x50 fs/read_write.c:1203
do_syscall_32_irqs_on arch/x86/entry/common.c:327 [inline]
do_fast_syscall_32+0x3ee/0xf9d arch/x86/entry/common.c:389
entry_SYSENTER_compat+0x51/0x60 arch/x86/entry/entry_64_compat.S:125
RIP: 0023:0xf7f73c79
RSP: 002b:00000000e574a15c EFLAGS: 00000292 ORIG_RAX: 000000000000014d
RAX: ffffffffffffffda RBX: 000000000000000f RCX: 0000000020a3afb0
RDX: 0000000000000001 RSI: 0000000000000067 RDI: 0000000000000000
RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
BUG: sleeping function called from invalid context at lib/usercopy.c:25
in_atomic(): 1, irqs_disabled(): 0, pid: 3195, name: syzkaller971460
INFO: lockdep is turned off.
Google 01/01/2011
Call Trace:
___might_sleep+0x2b2/0x470 kernel/sched/core.c:6060
__might_sleep+0x95/0x190 kernel/sched/core.c:6013
__might_fault+0xab/0x1d0 mm/memory.c:4525
_copy_to_user+0x2c/0xc0 lib/usercopy.c:25
copy_to_user include/linux/uaccess.h:155 [inline]
seq_read+0xcb4/0x13d0 fs/seq_file.c:279
WARNING: CPU: 1 PID: 3195 at lib/usercopy.c:26 _copy_to_user+0xb5/0xc0
lib/usercopy.c:26
Reported-by: syzbot <bot+eceb3204562c41a438fa1f2335e0fe4f6886d669@syzkaller.appspotmail.com>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
/proc has been ignoring struct file_operations::owner field for 10 years.
Specifically, it started with commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba
("Fix rmmod/read/write races in /proc entries"). Notice the chunk where
inode->i_fop is initialized with proxy struct file_operations for
regular files:
- if (de->proc_fops)
- inode->i_fop = de->proc_fops;
+ if (de->proc_fops) {
+ if (S_ISREG(inode->i_mode))
+ inode->i_fop = &proc_reg_file_ops;
+ else
+ inode->i_fop = de->proc_fops;
VFS stopped pinning module at this point.
convert remaining users of rtnl_register to rtnl_register_module
and un-export rtnl_register.
Requested-by: David S. Miller <davem@davemloft.net>
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
Avoid traversing the list of mr6_tables (which requires the
rtnl_lock) in ip6mr_sk_done(), when we know in advance that
a match will not be found.
This can happen when rawv6_close()/ip6mr_sk_done() is invoked
on non-mroute6 sockets.
This patch helps reduce rtnl_lock contention when destroying
a large number of net namespaces, each having a non-mroute6
raw socket.
v2: same patch, only fixed subject line and expanded comment.
Signed-off-by: Francesco Ruggeri <fruggeri@arista.com>
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Notice that in some cases I placed the "fall through" comment
on its own line, which is what GCC is expecting to find.
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
This change allows us to later indicate to rtnetlink core that certain
doit functions should be called without acquiring rtnl_mutex.
This change should have no effect, we simply replace the last (now
unused) calcit argument with the new flag.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Add Netlink notifications on cache reports in ip6mr, in addition to the
existing mrt6msg sent to mroute6_sk.
Send RTM_NEWCACHEREPORT notifications to RTNLGRP_IPV6_MROUTE_R.
MSGTYPE, MIF_ID, SRC_ADDR and DST_ADDR Netlink attributes contain the
same data as their equivalent fields in the mrt6msg header.
PKT attribute is the packet sent to mroute6_sk, without the added
mrt6msg header.
Suggested-by: Ryan Halbrook <halbrook@arista.com>
Signed-off-by: Julien Gomes <julien@arista.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
Network devices can allocate reasources and private memory using
netdev_ops->ndo_init(). However, the release of these resources
can occur in one of two different places.
Either netdev_ops->ndo_uninit() or netdev->destructor().
The decision of which operation frees the resources depends upon
whether it is necessary for all netdev refs to be released before it
is safe to perform the freeing.
netdev_ops->ndo_uninit() presumably can occur right after the
NETDEV_UNREGISTER notifier completes and the unicast and multicast
address lists are flushed.
netdev->destructor(), on the other hand, does not run until the
netdev references all go away.
Further complicating the situation is that netdev->destructor()
almost universally does also a free_netdev().
This creates a problem for the logic in register_netdevice().
Because all callers of register_netdevice() manage the freeing
of the netdev, and invoke free_netdev(dev) if register_netdevice()
fails.
If netdev_ops->ndo_init() succeeds, but something else fails inside
of register_netdevice(), it does call ndo_ops->ndo_uninit(). But
it is not able to invoke netdev->destructor().
This is because netdev->destructor() will do a free_netdev() and
then the caller of register_netdevice() will do the same.
However, this means that the resources that would normally be released
by netdev->destructor() will not be.
Over the years drivers have added local hacks to deal with this, by
invoking their destructor parts by hand when register_netdevice()
fails.
Many drivers do not try to deal with this, and instead we have leaks.
Let's close this hole by formalizing the distinction between what
private things need to be freed up by netdev->destructor() and whether
the driver needs unregister_netdevice() to perform the free_netdev().
netdev->priv_destructor() performs all actions to free up the private
resources that used to be freed by netdev->destructor(), except for
free_netdev().
netdev->needs_free_netdev is a boolean that indicates whether
free_netdev() should be done at the end of unregister_netdevice().
Now, register_netdevice() can sanely release all resources after
ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit()
and netdev->priv_destructor().
And at the end of unregister_netdevice(), we invoke
netdev->priv_destructor() and optionally call free_netdev().
Both conflict were simple overlapping changes.
In the kaweth case, Eric Dumazet's skb_cow() bug fix overlapped the
conversion of the driver in net-next to use in-netdev stats.
Andrey Konovalov reported a BUG caused by the ip6mr code which is caused
because we call unregister_netdevice_many for a device that is already
being destroyed. In IPv4's ipmr that has been resolved by two commits
long time ago by introducing the "notify" parameter to the delete
function and avoiding the unregister when called from a notifier, so
let's do the same for ip6mr.
The trace from Andrey:
kernel BUG at net/core/dev.c:6813!
invalid opcode: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 1 PID: 1165 Comm: kworker/u4:3 Not tainted 4.11.0-rc7+ #251
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs
01/01/2011
Workqueue: netns cleanup_net
task: ffff880069208000 task.stack: ffff8800692d8000
RIP: 0010:rollback_registered_many+0x348/0xeb0 net/core/dev.c:6813
RSP: 0018:ffff8800692de7f0 EFLAGS: 00010297
RAX: ffff880069208000 RBX: 0000000000000002 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88006af90569
RBP: ffff8800692de9f0 R08: ffff8800692dec60 R09: 0000000000000000
R10: 0000000000000006 R11: 0000000000000000 R12: ffff88006af90070
R13: ffff8800692debf0 R14: dffffc0000000000 R15: ffff88006af90000
FS: 0000000000000000(0000) GS:ffff88006cb00000(0000)
knlGS:0000000000000000
CR2: 00007fe7e897d870 CR3: 00000000657e7000 CR4: 00000000000006e0
Call Trace:
unregister_netdevice_many.part.105+0x87/0x440 net/core/dev.c:7881
unregister_netdevice_many+0xc8/0x120 net/core/dev.c:7880
ip6mr_device_event+0x362/0x3f0 net/ipv6/ip6mr.c:1346
notifier_call_chain+0x145/0x2f0 kernel/notifier.c:93
__raw_notifier_call_chain kernel/notifier.c:394
raw_notifier_call_chain+0x2d/0x40 kernel/notifier.c:401
call_netdevice_notifiers_info+0x51/0x90 net/core/dev.c:1647
call_netdevice_notifiers net/core/dev.c:1663
rollback_registered_many+0x919/0xeb0 net/core/dev.c:6841
unregister_netdevice_many net/core/dev.c:7880
default_device_exit_batch+0x4fa/0x640 net/core/dev.c:8333
ops_exit_list.isra.4+0x100/0x150 net/core/net_namespace.c:144
cleanup_net+0x5a8/0xb40 net/core/net_namespace.c:463
process_one_work+0xc04/0x1c10 kernel/workqueue.c:2097
worker_thread+0x223/0x19c0 kernel/workqueue.c:2231
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x31/0x40 arch/x86/entry/entry_64.S:430
Code: 3c 32 00 0f 85 70 0b 00 00 48 b8 00 02 00 00 00 00 ad de 49 89
47 78 e9 93 fe ff ff 49 8d 57 70 49 8d 5f 78 eb 9e e8 88 7a 14 fe <0f>
0b 48 8b 9d 28 fe ff ff e8 7a 7a 14 fe 48 b8 00 00 00 00 00
RIP: rollback_registered_many+0x348/0xeb0 RSP: ffff8800692de7f0
---[ end trace e0b29c57e9b3292c ]---
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Refactor inet6_netconf_notify_devconf to take the event as an input arg.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Commit 5e1859fbcc3c ("ipv4: ipmr: various fixes and cleanups") fixed
the issue for ipv4 ipmr:
ip_mroute_setsockopt() & ip_mroute_getsockopt() should not
access/set raw_sk(sk)->ipmr_table before making sure the socket
is a raw socket, and protocol is IGMP
The same fix should be done for ipv6 ipmr as well.
This patch can fix the panic caused by overwriting the same offset
as ipmr_table as in raw_sk(sk) when accessing other type's socket
by ip_mroute_setsockopt().
Signed-off-by: Xin Long <lucien.xin@gmail.com>
