path: root/net/ipv6/ipv6_sockglue.c
2015-12-02ipv6: add complete rcu protection around np->optEric Dumazet
This patch addresses multiple problems : UDP/RAW sendmsg() need to get a stable struct ipv6_txoptions while socket is not locked : Other threads can change np->opt concurrently. Dmitry posted a syzkaller (http://github.com/google/syzkaller) program desmonstrating use-after-free. Starting with TCP/DCCP lockless listeners, tcp_v6_syn_recv_sock() and dccp_v6_request_recv_sock() also need to use RCU protection to dereference np->opt once (before calling ipv6_dup_options()) This patch adds full RCU protection to np->opt Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31ipv6: coding style: comparison for equality with NULLIan Morris
The ipv6 code uses a mixture of coding styles. In some instances check for NULL pointer is done as x == NULL and sometimes as !x. !x is preferred according to checkpatch and this patch makes the code consistent by adopting the latter form. No changes detected by objdiff. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20ipv6: invert join/leave anycast rtnl/socket locking orderMarcelo Ricardo Leitner
Commit baf606d9c9b1 ("ipv4,ipv6: grab rtnl before locking the socket") missed to update two setsockopt options, IPV6_JOIN_ANYCAST and IPV6_LEAVE_ANYCAST, causing a lock inverstion regarding to the updated ones. As ipv6_sock_ac_join and ipv6_sock_ac_leave are only called from do_ipv6_setsockopt, we are good to just move the rtnl lock upper. Fixes: baf606d9c9b1 ("ipv4,ipv6: grab rtnl before locking the socket") Reported-by: Ying Huang <ying.huang@intel.com> Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18ipv4, ipv6: kill ip_mc_{join, leave}_group and ipv6_sock_mc_{join, drop}Marcelo Ricardo Leitner
in favor of their inner __ ones, which doesn't grab rtnl. As these functions need to operate on a locked socket, we can't be grabbing rtnl by then. It's too late and doing so causes reversed locking. So this patch: - move rtnl handling to callers instead while already fixing some reversed locking situations, like on vxlan and ipvs code. - renames __ ones to not have the __ mark: __ip_mc_{join,leave}_group -> ip_mc_{join,leave}_group __ipv6_sock_mc_{join,drop} -> ipv6_sock_mc_{join,drop} Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18ipv4,ipv6: grab rtnl before locking the socketMarcelo Ricardo Leitner
There are some setsockopt operations in ipv4 and ipv6 that are grabbing rtnl after having grabbed the socket lock. Yet this makes it impossible to do operations that have to lock the socket when already within a rtnl protected scope, like ndo dev_open and dev_stop. We normally take coarse grained locks first but setsockopt inverted that. So this patch invert the lock logic for these operations and makes setsockopt grab rtnl if it will be needed prior to grabbing socket lock. Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26ipv6: tcp: fix race in IPV6_2292PKTOPTIONSEric Dumazet
IPv6 TCP sockets store in np->pktoptions skbs, and use skb_set_owner_r() to charge the skb to socket. It means that destructor must be called while socket is locked. Therefore, we cannot use skb_get() or atomic_inc(&skb->users) to protect ourselves : kfree_skb() might race with other users manipulating sk->sk_forward_alloc Fix this race by holding socket lock for the duration of ip6_datagram_recv_ctl() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09ipv6: remove useless spin_lock/spin_unlockDuan Jiong
xchg is atomic, so there is no necessary to use spin_lock/spin_unlock to protect it. At last, remove the redundant opt = xchg(&inet6_sk(sk)->opt, opt); statement. Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-24ipv6: White-space cleansing : gaps between function and symbol exportIan Morris
This patch makes no changes to the logic of the code but simply addresses coding style issues as detected by checkpatch. Both objdump and diff -w show no differences. This patch removes some blank lines between the end of a function definition and the EXPORT_SYMBOL_GPL macro in order to prevent checkpatch warning that EXPORT_SYMBOL must immediately follow a function. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-24ipv6: White-space cleansing : Line LayoutsIan Morris
This patch makes no changes to the logic of the code but simply addresses coding style issues as detected by checkpatch. Both objdump and diff -w show no differences. A number of items are addressed in this patch: * Multiple spaces converted to tabs * Spaces before tabs removed. * Spaces in pointer typing cleansed (char *)foo etc. * Remove space after sizeof * Ensure spacing around comparators such as if statements. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-15ipv6: remove unnecessary break after returnFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-07ipv6: Implement automatic flow label generation on transmitTom Herbert
Automatically generate flow labels for IPv6 packets on transmit. The flow label is computed based on skb_get_hash. The flow label will only automatically be set when it is zero otherwise (i.e. flow label manager hasn't set one). This supports the transmit side functionality of RFC 6438. Added an IPv6 sysctl auto_flowlabels to enable/disable this behavior system wide, and added IPV6_AUTOFLOWLABEL socket option to enable this functionality per socket. By default, auto flowlabels are disabled to avoid possible conflicts with flow label manager, however if this feature proves useful we may want to enable it by default. It should also be noted that FreeBSD has already implemented automatic flow labels (including the sysctl and socket option). In FreeBSD, automatic flow labels default to enabled. Performance impact: Running super_netperf with 200 flows for TCP_RR and UDP_RR for IPv6. Note that in UDP case, __skb_get_hash will be called for every packet with explains slight regression. In the TCP case the hash is saved in the socket so there is no regression. Automatic flow labels disabled: TCP_RR: 86.53% CPU utilization 127/195/322 90/95/99% latencies 1.40498e+06 tps UDP_RR: 90.70% CPU utilization 118/168/243 90/95/99% latencies 1.50309e+06 tps Automatic flow labels enabled: TCP_RR: 85.90% CPU utilization 128/199/337 90/95/99% latencies 1.40051e+06 UDP_RR 92.61% CPU utilization 115/164/236 90/95/99% latencies 1.4687e+06 Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-01inet: move ipv6only in sock_commonEric Dumazet
When an UDP application switches from AF_INET to AF_INET6 sockets, we have a small performance degradation for IPv4 communications because of extra cache line misses to access ipv6only information. This can also be noticed for TCP listeners, as ipv6_only_sock() is also used from __inet_lookup_listener()->compute_score() This is magnified when SO_REUSEPORT is used. Move ipv6only into struct sock_common so that it is available at no extra cost in lookups. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-26ipv6: yet another new IPV6_MTU_DISCOVER option IPV6_PMTUDISC_OMITHannes Frederic Sowa
This option has the same semantic as IP_PMTUDISC_OMIT for IPv4 which got recently introduced. It doesn't honor the path mtu discovered by the host but in contrary to IPV6_PMTUDISC_INTERFACE allows the generation of fragments if the packet size exceeds the MTU of the outgoing interface MTU. Fixes: 93b36cf3425b9b ("ipv6: support IPV6_PMTU_INTERFACE on sockets") Cc: Florian Weimer <fweimer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-19ipv6: make IPV6_RECVPKTINFO work for ipv4 datagramsHannes Frederic Sowa
We currently don't report IPV6_RECVPKTINFO in cmsg access ancillary data for IPv4 datagrams on IPv6 sockets. This patch splits the ip6_datagram_recv_ctl into two functions, one which handles both protocol families, AF_INET and AF_INET6, while the ip6_datagram_recv_specific_ctl only handles IPv6 cmsg data. ip6_datagram_recv_*_ctl never reported back any errors, so we can make them return void. Also provide a helper for protocols which don't offer dual personality to further use ip6_datagram_recv_ctl, which is exported to modules. I needed to shuffle the code for ping around a bit to make it easier to implement dual personality for ping ipv6 sockets in future. Reported-by: Gert Doering <gert@space.net> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-19ipv6: add a flag to get the flow label used remotlyFlorent Fourcot
This information is already available via IPV6_FLOWINFO of IPV6_2292PKTOPTIONS, and them a filtering to get the flow label information. But it is probably logical and easier for users to add this here, and to control both sent/received flow label values with the IPV6_FLOWLABEL_MGR option. Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-15ipv6: move IPV6_TCLASS_SHIFT into ipv6.h and define a helperLi RongQing
Two places defined IPV6_TCLASS_SHIFT, so we should move it into ipv6.h, and use this macro as possible. And define ip6_tclass helper to return tclass Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18ipv6: support IPV6_PMTU_INTERFACE on socketsHannes Frederic Sowa
IPV6_PMTU_INTERFACE is the same as IPV6_PMTU_PROBE for ipv6. Add it nontheless for symmetry with IPv4 sockets. Also drop incoming MTU information if this mode is enabled. The additional bit in ipv6_pinfo just eats in the padding behind the bitfield. There are no changes to the layout of the struct at all. Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-12ipv6: fix incorrect type in declarationFlorent Fourcot
Introduced by 1397ed35f22d7c30d0b89ba74b6b7829220dfcfd "ipv6: add flowinfo for tcp6 pkt_options for all cases" Reported-by: kbuild test robot <fengguang.wu@intel.com> V2: fix the title, add empty line after the declaration (Sergei Shtylyov feedbacks) Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09ipv6: remove rcv_tclass of ipv6_pinfoFlorent Fourcot
tclass information in now already stored in rcv_flowinfo We do not need to store the same information twice. Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr> Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09ipv6: add flowinfo for tcp6 pkt_options for all casesFlorent Fourcot
The current implementation of IPV6_FLOWINFO only gives a result if pktoptions is available (thanks to the ip6_datagram_recv_ctl function). It gives inconsistent results to user space, sometimes there is a result for getsockopt(IPV6_FLOWINFO), sometimes not. This patch add rcv_flowinfo to store it, and return it to the userspace in the same way than other pkt_options. Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr> Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-08ipv6: enable IPV6_FLOWLABEL_MGR for getsockoptFlorent Fourcot
It is already possible to set/put/renew a label with IPV6_FLOWLABEL_MGR and setsockopt. This patch add the possibility to get information about this label (current value, time before expiration, etc). It helps application to take decision for a renew or a release of the label. v2: * Add spin_lock to prevent race condition * return -ENOENT if no result found * check if flr_action is GET v3: * move the spin_lock to protect only the relevant code Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-09ipv6: make lookups simpler and fasterEric Dumazet
TCP listener refactoring, part 4 : To speed up inet lookups, we moved IPv4 addresses from inet to struct sock_common Now is time to do the same for IPv6, because it permits us to have fast lookups for all kind of sockets, including upcoming SYN_RECV. Getting IPv6 addresses in TCP lookups currently requires two extra cache lines, plus a dereference (and memory stall). inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6 This patch is way bigger than its IPv4 counter part, because for IPv4, we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6, it's not doable easily. inet6_sk(sk)->daddr becomes sk->sk_v6_daddr inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr at the same offset. We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic macro. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-31ipv6: rename datagram_send_ctl and datagram_recv_ctlTom Parkin
The datagram_*_ctl functions in net/ipv6/datagram.c are IPv6-specific. Since datagram_send_ctl is publicly exported it should be appropriately named to reflect the fact that it's for IPv6 only. Signed-off-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Allow userns root to control ipv6Eric W. Biederman
Allow an unpriviled user who has created a user namespace, and then created a network namespace to effectively use the new network namespace, by reducing capable(CAP_NET_ADMIN) and capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns, CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls. Settings that merely control a single network device are allowed. Either the network device is a logical network device where restrictions make no difference or the network device is hardware NIC that has been explicity moved from the initial network namespace. In general policy and network stack state changes are allowed while resource control is left unchanged. Allow the SIOCSIFADDR ioctl to add ipv6 addresses. Allow the SIOCDIFADDR ioctl to delete ipv6 addresses. Allow the SIOCADDRT ioctl to add ipv6 routes. Allow the SIOCDELRT ioctl to delete ipv6 routes. Allow creation of ipv6 raw sockets. Allow setting the IPV6_JOIN_ANYCAST socket option. Allow setting the IPV6_FL_A_RENEW parameter of the IPV6_FLOWLABEL_MGR socket option. Allow setting the IPV6_TRANSPARENT socket option. Allow setting the IPV6_HOPOPTS socket option. Allow setting the IPV6_RTHDRDSTOPTS socket option. Allow setting the IPV6_DSTOPTS socket option. Allow setting the IPV6_IPSEC_POLICY socket option. Allow setting the IPV6_XFRM_POLICY socket option. Allow sending packets with the IPV6_2292HOPOPTS control message. Allow sending packets with the IPV6_2292DSTOPTS control message. Allow sending packets with the IPV6_RTHDRDSTOPTS control message. Allow setting the multicast routing socket options on non multicast routing sockets. Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, and SIOCDELTUNNEL ioctls for setting up, changing and deleting tunnels over ipv6. Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, SIOCDELTUNNEL ioctls for setting up, changing and deleting ipv6 over ipv4 tunnels. Allow the SIOCADDPRL, SIOCDELPRL, SIOCCHGPRL ioctls for adding, deleting, and changing the potential router list for ISATAP tunnels. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Minor line offset auto-merges. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-13ipv6: setsockopt(IPIPPROTO_IPV6, IPV6_MINHOPCOUNT) forgot to set return valueHannes Frederic Sowa
Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01ipv6: use IS_ENABLED()Amerigo Wang
#if defined(CONFIG_FOO) || defined(CONFIG_FOO_MODULE) can be replaced by #if IS_ENABLED(CONFIG_FOO) Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-12net/ipv6/ipv6_sockglue.c: Removed redundant externEldad Zack
extern int sysctl_mld_max_msf is already defined in linux/ipv6.h. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-13net: implement IP_RECVTOS for IP_PKTOPTIONSJiri Benc
Currently, it is not easily possible to get TOS/DSCP value of packets from an incoming TCP stream. The mechanism is there, IP_PKTOPTIONS getsockopt with IP_RECVTOS set, the same way as incoming TTL can be queried. This is not actually implemented for TOS, though. This patch adds this functionality, both for IPv4 (IP_PKTOPTIONS) and IPv6 (IPV6_2292PKTOPTIONS). For IPv4, like in the IP_RECVTTL case, the value of the TOS field is stored from the other party's ACK. This is needed for proxies which require DSCP transparency. One such example is at http://zph.bratcheda.org/. Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-08ipv6: Implement IPV6_UNICAST_IF socket option.Erich E. Hoover
The IPV6_UNICAST_IF feature is the IPv6 compliment to IP_UNICAST_IF. Signed-off-by: Erich E. Hoover <ehoover@mines.edu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-11-28ipv6: Set mcast_hops to IPV6_DEFAULT_MCASTHOPS when -1 was given.Li Wei
We need to set np->mcast_hops to it's default value at this moment otherwise when we use it and found it's value is -1, the logic to get default hop limit doesn't take multicast into account and will return wrong hop limit(IPV6_DEFAULT_HOPLIMIT) which is for unicast. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-20net: allow CAP_NET_RAW to set socket options IP{,V6}_TRANSPARENTMaciej Żenczykowski
Up till now the IP{,V6}_TRANSPARENT socket options (which actually set the same bit in the socket struct) have required CAP_NET_ADMIN privileges to set or clear the option. - we make clearing the bit not require any privileges. - we allow CAP_NET_ADMIN to set the bit (as before this change) - we allow CAP_NET_RAW to set this bit, because raw sockets already pretty much effectively allow you to emulate socket transparency. Signed-off-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-30net: relax PKTINFO non local ipv6 udp xmit checkMaciej Żenczykowski
Allow transparent sockets to be less restrictive about the source ip of ipv6 udp packets being sent. Google-Bug-Id: 5018138 Signed-off-by: Maciej Żenczykowski <maze@google.com> CC: "Erik Kline" <ek@google.com> CC: "Lorenzo Colitti" <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-19ipv6: Fix ipv6_getsockopt for IPV6_2292PKTOPTIONSDaniel Baluta
IPV6_2292PKTOPTIONS is broken for 32-bit applications running in COMPAT mode on 64-bit kernels. The same problem was fixed for IPv4 with the patch: ipv4: Fix ip_getsockopt for IP_PKTOPTIONS, commit dd23198e58cd35259dd09e8892bbdb90f1d57748 Signed-off-by: Sorin Dumitru <sdumitru@ixiacom.com> Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv6: Convert to use flowi6 where applicable.David S. Miller
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24tproxy: Add missing CAP_NET_ADMIN check to ipv6 sideBalazs Scheidler
IP_TRANSPARENT requires root (more precisely CAP_NET_ADMIN privielges) for IPV6. However as I see right now this check was missed from the IPv6 implementation. Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21tproxy: added tproxy sockopt interface in the IPV6 layerBalazs Scheidler
Support for IPV6_RECVORIGDSTADDR sockopt for UDP sockets were contributed by Harry Mason. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: KOVACS Krisztian <hidden@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-25ipv6: remove ipv6_statisticsEric Dumazet
commit 9261e5370112 (ipv6: making ip and icmp statistics per/namespace) forgot to remove ipv6_statistics variable. commit bc417d99bf27 (ipv6: remove stale MIB definitions) took care of icmpv6_statistics & icmpv6msg_statistics Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Denis V. Lunev <den@openvz.org> CC: Alexey Dobriyan <adobriyan@gmail.com> CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23IPv6: Add dontfrag argument to relevant functionsBrian Haley
Add dontfrag argument to relevant functions for IPV6_DONTFRAG support, as well as allowing the value to be passed-in via ancillary cmsg data. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23IPv6: data structure changes for new socket optionsBrian Haley
Add underlying data structure changes and basic setsockopt() and getsockopt() support for IPV6_RECVPATHMTU, IPV6_PATHMTU, and IPV6_DONTFRAG. IPV6_PATHMTU is actually fully functional at this point. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22IPv6: Generic TTL Security Mechanism (final version)Stephen Hemminger
This patch adds IPv6 support for RFC5082 Generalized TTL Security Mechanism. Not to users of mapped address; the IPV6 and IPV4 socket options are seperate. The server does have to deal with both IPv4 and IPv6 socket options and the client has to handle the different for each family. On client: int ttl = 255; getaddrinfo(argv[1], argv[2], &hint, &result); for (rp = result; rp != NULL; rp = rp->ai_next) { s = socket(rp->ai_family, rp->ai_socktype, rp->ai_protocol); if (s < 0) continue; if (rp->ai_family == AF_INET) { setsockopt(s, IPPROTO_IP, IP_TTL, &ttl, sizeof(ttl)); } else if (rp->ai_family == AF_INET6) { setsockopt(s, IPPROTO_IPV6, IPV6_UNICAST_HOPS, &ttl, sizeof(ttl))) } if (connect(s, rp->ai_addr, rp->ai_addrlen) == 0) { ... On server: int minttl = 255 - maxhops; getaddrinfo(NULL, port, &hints, &result); for (rp = result; rp != NULL; rp = rp->ai_next) { s = socket(rp->ai_family, rp->ai_socktype, rp->ai_protocol); if (s < 0) continue; if (rp->ai_family == AF_INET6) setsockopt(s, IPPROTO_IPV6, IPV6_MINHOPCOUNT, &minttl, sizeof(minttl)); setsockopt(s, IPPROTO_IP, IP_MINTTL, &minttl, sizeof(minttl)); if (bind(s, rp->ai_addr, rp->ai_addrlen) == 0) break ... Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13net: sk_dst_cache RCUificationEric Dumazet
With latest CONFIG_PROVE_RCU stuff, I felt more comfortable to make this work. sk->sk_dst_cache is currently protected by a rwlock (sk_dst_lock) This rwlock is readlocked for a very small amount of time, and dst entries are already freed after RCU grace period. This calls for RCU again :) This patch converts sk_dst_lock to a spinlock, and use RCU for readers. __sk_dst_get() is supposed to be called with rcu_read_lock() or if socket locked by user, so use appropriate rcu_dereference_check() condition (rcu_read_lock_held() || sock_owned_by_user(sk)) This patch avoids two atomic ops per tx packet on UDP connected sockets, for example, and permits sk_dst_lock to be much less dirtied. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-19IP: CleanupsJohn Dykstra
Use symbols instead of magic constants while checking PMTU discovery setsockopt. Remove redundant test in ip_rt_frag_needed() (done by caller). Signed-off-by: John Dykstra <john.dykstra1@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-19net: Fix IP_MULTICAST_IFEric Dumazet
ipv4/ipv6 setsockopt(IP_MULTICAST_IF) have dubious __dev_get_by_index() calls. This function should be called only with RTNL or dev_base_lock held, or reader could see a corrupt hash chain and eventually enter an endless loop. Fix is to call dev_get_by_index()/dev_put(). If this happens to be performance critical, we could define a new dev_exist_by_index() function to avoid touching dev refcount. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
