path: root/net/ipv6/netfilter/nf_conntrack_l3proto_ipv6.c
2011-06-06netfilter: add more values to enum ip_conntrack_infoEric Dumazet
Following error is raised (and other similar ones) : net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’: net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’ not in enumerated type ‘enum ip_conntrack_info’ gcc barfs on adding two enum values and getting a not enumerated result : case IP_CT_RELATED+IP_CT_IS_REPLY: Add missing enum values Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: David Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2010-10-21tproxy: split off ipv6 defragmentation to a separate moduleBalazs Scheidler
Like with IPv4, TProxy needs IPv6 defragmentation but does not require connection tracking. Since defragmentation was coupled with conntrack, I split off the two, creating an nf_defrag_ipv6 module, similar to the already existing nf_defrag_ipv4. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: KOVACS Krisztian <hidden@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-13netfilter: cleanup printk messagesStephen Hemminger
Make sure all printk messages have a severity level. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-02-15netfilter: nf_conntrack: add support for "conntrack zones"Patrick McHardy
Normally, each connection needs a unique identity. Conntrack zones allow to specify a numerical zone using the CT target, connections in different zones can use the same identity. Example: iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1 iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1 Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-02-03netfilter: nf_conntrack: support conntrack templatesPatrick McHardy
Support initializing selected parameters of new conntrack entries from a "conntrack template", which is a specially marked conntrack entry attached to the skb. Currently the helper and the event delivery masks can be initialized this way. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-12-15netfilter: fix crashes in bridge netfilter caused by fragment jumpsPatrick McHardy
When fragments from bridge netfilter are passed to IPv4 or IPv6 conntrack and a reassembly queue with the same fragment key already exists from reassembling a similar packet received on a different device (f.i. with multicasted fragments), the reassembled packet might continue on a different codepath than where the head fragment originated. This can cause crashes in bridge netfilter when a fragment received on a non-bridge device (and thus with skb->nf_bridge == NULL) continues through the bridge netfilter code. Add a new reassembly identifier for packets originating from bridge netfilter and use it to put those packets in insolated queues. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=14805 Reported-and-Tested-by: Chong Qiao <qiaochong@loongson.cn> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-12-15ipv6: reassembly: use seperate reassembly queues for conntrack and local ↵Patrick McHardy
delivery Currently the same reassembly queue might be used for packets reassembled by conntrack in different positions in the stack (PREROUTING/LOCAL_OUT), as well as local delivery. This can cause "packet jumps" when the fragment completing a reassembled packet is queued from a different position in the stack than the previous ones. Add a "user" identifier to the reassembly queue key to seperate the queues of each caller, similar to what we do for IPv4. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-08-25netfilter: nf_conntrack: log packets dropped by helpersPatrick McHardy
Log packets dropped by helpers using the netfilter logging API. This is useful in combination with nfnetlink_log to analyze those packets in userspace for debugging. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-08-10netfilter: conntrack: switch hook PFs to nfprotoJan Engelhardt
Simple substitution to indicate that the fields indeed use the NFPROTO_ space. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2009-03-25netfilter: nf_conntrack: calculate per-protocol nlattr sizeHolger Eitzenberger
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-16netfilter: remove IPvX specific parts from nf_conntrack_l4proto.hChristoph Paasch
Moving the structure definitions to the corresponding IPvX specific header files. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-08netfilter: netns nf_conntrack: pass netns pointer to nf_conntrack_in()Alexey Dobriyan
It's deducible from skb->dev or skb->dst->dev, but we know netns at the moment of call, so pass it down and use for finding and creating conntracks. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_l3protoJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-01-31[NETFILTER]: nf_conntrack: annotate l3protos with constJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][FRAGS]: Move ctl tables around.Pavel Emelyanov
This is a preparation for sysctl netns-ization. Move the ctl tables to the files, where the tuning variables reside. Plus make the helpers to register the tables. This will simplify the later patches and will keep similar things closer to each other. ipv4, ipv6 and conntrack_reasm are patched differently, but the result is all the tables are in appropriate files. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_conntrack: remove print_conntrack function from l3protosPatrick McHardy
Its unused and unlikely to ever be used. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Mark hooks __read_mostlyPatrick McHardy
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-18sysctl: remove broken netfilter binary sysctlsEric W. Biederman
No one has bothered to set strategy routine for the the netfilter sysctls that return jiffies to be sysctl_jiffies. So it appears the sys_sysctl path is unused and untested, so this patch removes the binary sysctl numbers. Which fixes the netfilter oops in 2.6.23-rc2-mm2 for me. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Patrick McHardy <kaber@trash.net> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15[INET]: Collect common frag sysctl variables togetherPavel Emelyanov
Some sysctl variables are used to tune the frag queues management and it will be useful to work with them in a common way in the future, so move them into one structure, moreover they are the same for all the frag management codes. I don't place them in the existing inet_frags object, introduced in the previous patch for two reasons: 1. to keep them in the __read_mostly section; 2. not to export the whole inet_frags objects outside. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: ctnetlink: use netlink policyPatrick McHardy
2007-10-10[NETFILTER]: nfnetlink: rename functions containing 'nfattr'Patrick McHardy
There is no struct nfattr anymore, rename functions to 'nlattr'. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink: convert to generic netlink attribute functionsPatrick McHardy
Get rid of the duplicated rtnetlink macros and use the generic netlink attribute functions. The old duplicated stuff is moved to a new header file that exists just for userspace. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NETFILTER]: Make nf_ct_ipv6_skip_exthdr() static.Adrian Bunk
nf_ct_ipv6_skip_exthdr() can now become static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[NETFILTER]: nf_conntrack: mark protocols __read_mostlyPatrick McHardy
Also remove two unnecessary EXPORT_SYMBOLs and move the nf_conntrack_l3proto_ipv4 declaration to the correct file. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[NETFILTER]: nf_conntrack: make l3proto->prepare() generic and renames itYasuyuki Kozakai
The icmp[v6] l4proto modules parse headers in ICMP[v6] error to get tuple. But they have to find the offset to transport protocol header before that. Their processings are almost same as prepare() of l3proto modules. This makes prepare() more generic to simplify icmp[v6] l4proto module later. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[NETFILTER]: nf_conntrack: Increment error count on parsing IPv4 headerYasuyuki Kozakai
2007-07-10[NETFILTER]: Convert DEBUGP to pr_debugPatrick McHardy
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: remove old memory allocator of conntrackYasuyuki Kozakai
Now memory space for help and NAT are allocated by extension infrastructure. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[NETFILTER]: nf_conntrack: fix helper module unload racesPatrick McHarrdy
When a helper module is unloaded all conntracks refering to it have their helper pointer NULLed out, leading to lots of races. In most places this can be fixed by proper use of RCU (they do already check for != NULL, but in a racy way), additionally nf_conntrack_expect_related needs to bail out when no helper is present. Also remove two paranoid BUG_ONs in nf_conntrack_proto_gre that are racy and not worth fixing. Signed-off-by: Patrick McHarrdy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[NET]: Fix comparisons of unsigned < 0.Bill Nottingham
Recent gcc versions emit warnings when unsigned variables are compared < 0 or >= 0. Signed-off-by: Bill Nottingham <notting@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: Remove changelogs and CVS IDsPatrick McHardy
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-07[NETFILTER]: nf_conntrack_ipv6: fix incorrect classification of IPv6 ↵Patrick McHardy
fragments as ESTABLISHED The individual fragments of a packet reassembled by conntrack have the conntrack reference from the reassembled packet attached, but nfctinfo is not copied. This leaves it initialized to 0, which unfortunately is the value of IP_CT_ESTABLISHED. The result is that all IPv6 fragments are tracked as ESTABLISHED, allowing them to bypass a usual ruleset which accepts ESTABLISHED packets early. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[NETFILTER]: nf_conntrack/nf_nat: fix incorrect config ifdefsPatrick McHardy
The nf_conntrack_netlink config option is named CONFIG_NF_CT_NETLINK, but multiple files use CONFIG_IP_NF_CONNTRACK_NETLINK or CONFIG_NF_CONNTRACK_NETLINK for ifdefs. Fix this and reformat all CONFIG_NF_CT_NETLINK ifdefs to only use a line. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: nf_conntrack: fix invalid conntrack statistics RCU assumptionPatrick McHardy
NF_CT_STAT_INC assumes rcu_read_lock in nf_hook_slow disables preemption as well, making it legal to use __get_cpu_var without disabling preemption manually. The assumption is not correct anymore with preemptable RCU, additionally we need to protect against softirqs when not holding nf_conntrack_lock. Add NF_CT_STAT_INC_ATOMIC macro, which disables local softirqs, and use where necessary. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack: move conntrack protocol sysctls to individual modulesPatrick McHardy
2006-12-02[NETFILTER]: nf_conntrack: move extern declaration to header filesPatrick McHardy
Using extern in a C file is a bad idea because the compiler can't catch type errors. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: rename struct nf_conntrack_protocolMartin Josefsson
Rename 'struct nf_conntrack_protocol' to 'struct nf_conntrack_l4proto' in order to help distinguish it from 'struct nf_conntrack_l3proto'. It gets rather confusing with 'nf_conntrack_protocol'. Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-09-22[NETFILTER]: Change tunables to __read_mostlyBrian Haley
Change some netfilter tunables to __read_mostly. Also fixed some incorrect file reference comments while I was in there. (this will be my last __read_mostly patch unless someone points out something else that needs it) Signed-off-by: Brian Haley <brian.haley@hp.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[NETFILTER]: conntrack: don't call helpers for related ICMP messagesPatrick McHardy
None of the existing helpers expects to get called for related ICMP packets and some even drop them if they can't parse them. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Fix section mismatch warningsPatrick McHardy
Fix section mismatch warnings caused by netfilter's init_or_cleanup functions used in many places by splitting the init from the cleanup parts. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Clean up hook registrationPatrick McHardy
Clean up hook registration by makeing use of the new mass registration and unregistration helpers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[NETFILTER]: Rename init functions.Andrew Morton
Every netfilter module uses `init' for its module_init() function and `fini' or `cleanup' for its module_exit() function. Problem is, this creates uninformative initcall_debug output and makes ctags rather useless. So go through and rename them all to $(filename)_init and $(filename)_fini. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[NETFILTER]: nf_conntrack: support for layer 3 protocol load on demandPablo Neira Ayuso
x_tables matches and targets that require nf_conntrack_ipv[4|6] to work don't have enough information to load on demand these modules. This patch introduces the following changes to solve this issue: o nf_ct_l3proto_try_module_get: try to load the layer 3 connection tracker module and increases the refcount. o nf_ct_l3proto_module put: drop the refcount of the module. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
